Staro 07.02.2006., 22:14   #1
DejoGH
DejoGH's Avatar
Postovi: 349
Nec Nd3520
Imam NEC ND3520 przilicu:
Sve je bilo ok , ali mi neki dan kad sam htjeo neki dvd kopirat na komp kopiralo oko 30 min , a inace kopira po 5-10 minuta. i kad sam htjeo sprzit nesto s kompa na dvd przilo mi 30 min (inace po 8 minuta)
kako da to popravim , evo sve o przilici
Anti - dust seal
MultiRead compliant
PC 2001 Certification
Vertical operation possible
Access Time (CD): 120 ms
Access Time (DVD): 120 ms
Audio Connections: analog-and digital output
Dimensions (HxWxD): 148mm x 42mm x 190mm
Interface: IDE/ATAPI Ultra DMA 33 mode 2
Media Supported: DVD-ROM, DVD-R, DVD+R, DVD+R9, DVD-RW, DVD+RW, CD-ROM, CD-R AND CD-RW WITH 80mm AND 120mm diameter
Memory: 2 Mbytes
Modes Supported: DVD Video, CD-DA, CD Extra, CD Text, CD-ROM, CD-ROM XA, CD-I, CD-I Ready, CD-Bridge, Photo-CD, CD-Audio
PIO Mode: Mode 4
Transfer Rate Read CD: 48x max
Transfer Rate Read DVD: 16x max
Transfer Rate Write (CD): CD-R: 48x, CD-RW: 24x
Transfer Rate Write (DVD): DVD-R: 16x, DVD-RDL: 4x, DVD-RW: 6x, DVD+R: 16x, DVD+R9: 4x, DVD+RW: 8x
Weight: 0.9kg
Writing Methods - CD: DAO (disc at once), SAO (session at once), TAO (track at once with zero gap, variable or fixed packet, multisession
Writing Methods - DVD: Random Access Writing (DVD+- RW) Sequential Writing (DVD+-R/DVD+-RW)
DejoGH je offline   Reply With Quote
Staro 07.02.2006., 23:30   #2
tutix
tutix's Avatar
Postovi: 4,069
da ti nije prebacio kanale primary ili secondary na pio mode umjesto dma.
Staro 08.02.2006., 12:22   #3
shadow
Lokacija: Zagreb, Hrvatska
Postovi: 77
Desni miš na MyComputer - Manage pa Device Manager ljevo na ATA controller stisni na + pa na primary i secondary channel desni miš properties pa Advanced Settings ako su ti uređaji u ultra DMA modu onda je sve u redu ako piše PIO probaj prebacit i restart pa provjeri ponovo ako je PIO opet ostao ond uninstal primary i secondary pa restart sam će ih naći i u 90% slučajeva ih stavi u udma mode
Pozdrav
Learn this, business has no business with patriotism. For business, patriotism is just product
shadow je offline   Reply With Quote
Staro 08.02.2006., 20:15   #4
DejoGH
DejoGH's Avatar
Postovi: 349
stavio sam kanale na dma , ali mi i dalje sporo radi....
molim vas pomagajte , razbit cu sve...
Staro 08.02.2006., 20:18   #5
DejoGH
DejoGH's Avatar
Postovi: 349
primary kanal mi je na Ultra DMA mode5
a secondary na ultra dma mode 2...
da nije do toga sto su različiti , da probam staviti noviji firmare???
Staro 08.02.2006., 21:23   #6
BrunoZG
Junior Member
BrunoZG's Avatar
Datum registracije: May 2003
Postovi: 3,205
da , ali tek kad otkriješ gdje je problem.
AMD 3800+x2@2500, 1,375V
MB-ASROCK DUAL SATA(bios 2.2) 2+ENERMAX485W
2x512 Supertalent CL2
HDD-Hitachi 160GB, WD 800JB
ELSA 7600GT
Leadtek-2000XP expert
DVDROM-LITEON-167T ,DVDRW BENQ 1650,DVDRW NEC ND2500A@2510_fw205C
Monitor: Samsung 997MB (19')
Terratec Sky 5.1,EPSON-C42
BrunoZG je offline   Reply With Quote
