#91 |
Datum registracije: Dec 2009
Lokacija: *
Postovi: 120
Može netko s T-com adsla pingat 1.1.1.1? To mi je bio najbrži dns, a sad kad ga pingam izbacuje 125ms dok su T-com i Google uredno oko 20ms. E sad znam da pinganje dns-a nije cjeloukupni pokazatelj brzine, ali nešto ipak znači ne? Zadnje izmijenjeno od: stifmeister. 07.06.2020. u 11:49. |
#92 |
Postovi: 16,939
PING 1.1.1.1 (1.1.1.1): 56 data bytes 64 bytes from 1.1.1.1: icmp_seq=0 ttl=57 time=14.179 ms 64 bytes from 1.1.1.1: icmp_seq=1 ttl=57 time=16.858 ms 64 bytes from 1.1.1.1: icmp_seq=2 ttl=57 time=23.183 ms 64 bytes from 1.1.1.1: icmp_seq=3 ttl=57 time=14.262 ms 64 bytes from 1.1.1.1: icmp_seq=4 ttl=57 time=17.903 ms 64 bytes from 1.1.1.1: icmp_seq=5 ttl=57 time=14.120 ms |
#93 | |
PRO
Postovi: 4,809
Naravno da znači, svaki korak do stranice će ti trajati više od 125 ms. meni je ping do 1.1.1.1 stabilnih 8 ms.
#94 |
Lokacija: VKCI
Postovi: 1,225
Ping s iskona: Pinging 1.1.1.1 with 32 bytes of data: Reply from 1.1.1.1: bytes=32 time=7ms TTL=58 Reply from 1.1.1.1: bytes=32 time=7ms TTL=58 Reply from 1.1.1.1: bytes=32 time=7ms TTL=58 Reply from 1.1.1.1: bytes=32 time=7ms TTL=58 |
#95 |
Datum registracije: Jun 2012
Postovi: 510
Stvarno nekaj ne valja... HT, Zagreb: Code:
PING 1.1.1.1 (1.1.1.1) 56(84) bytes of data. 64 bytes from 1.1.1.1: icmp_seq=1 ttl=50 time=115 ms 64 bytes from 1.1.1.1: icmp_seq=2 ttl=50 time=115 ms 64 bytes from 1.1.1.1: icmp_seq=3 ttl=50 time=115 ms 64 bytes from 1.1.1.1: icmp_seq=4 ttl=50 time=115 ms 64 bytes from 1.1.1.1: icmp_seq=5 ttl=50 time=115 ms 64 bytes from 1.1.1.1: icmp_seq=6 ttl=50 time=116 ms 64 bytes from 1.1.1.1: icmp_seq=7 ttl=50 time=115 ms Edit: traceroute. Ping skoči između HT-a i Cloudflarea u CIX-u. Code:
1 Fritz7362.lan (192.168.1.1) 0.630 ms 5.506 ms 5.485 ms 2 172.29.252.116 (172.29.252.116) 12.160 ms 12.268 ms 12.499 ms 3 172.29.82.21 (172.29.82.21) 13.217 ms 172.29.16.129 (172.29.16.129) 13.895 ms 172.29.82.17 (172.29.82.17) 13.995 ms 4 gtr11-htr11.ip.t-com.hr (195.29.110.146) 17.721 ms 17.832 ms 17.905 ms 5 cloudflare.cix.hr (185.1.87.115) 110.628 ms 111.021 ms 111.137 ms 6 one.one.one.one (1.1.1.1) 118.966 ms 116.066 ms 116.172 ms Zadnje izmijenjeno od: Blagus. 08.06.2020. u 21:37. |
#96 | |
Datum registracije: Oct 2010
Lokacija: Kaštel Lukšić
Postovi: 1,572
Nešto se događa pri dobivanju IP adrese od DSLama? Ako dobijem IP parove od 9x.xx.xx.xx. ili 8x.xx.xx.xx. sve radi ko po špagi a ako dobijem 78.xx.xx.xx. par nastaju isti problemi s 1.1.1.1 kao da su parovi posve odvojeni. |
#97 |
Postovi: 1,572
Ajd da oživim malo temu. A1 DNSovi Primary DNS address 83.139.103.3 Secondary DNS address 83.139.121.8 EDIT #1 DNSove gore nemože se pingat/testirati ili koristiti ako nije router spojen na mrežu od ISPa. DNSovi su izvučeni preko DSL-AC51 ako trebam dajem SS za proof. Nikad dovoljno pizdekanja/muljaže sa našim ISPovima. Zadnje izmijenjeno od: Karlo666. 27.02.2021. u 15:35. |
#98 |
Datum registracije: Aug 2013
Postovi: 4,336
Jel mogu ovdje navedeni DNS serveri (popularne alternative za filtriranje reklama) naci svoje mjesto na ovom popisu? |
#99 | |
Postovi: 18,875
Sad imam Wireguard VPN koji također ima više block lista, ali u slučaju problema si mogu sam pomoći. Pod svojim accountom na webu imam debugger i odmah vidim što je blokirano pa stavim na white listu. Zasad odlično radi, samo to je VPN... Od nedavno imaju ControlD uslugu pa možeš testirati. Nisam se igrao jer kažem imam njihov VPN. https://controld.com/
#100 | |
Postovi: 23,543
AdGuard DNS > https://adguard.com/en/adguard-dns/overview.html Malo je čudno da navode više servera / čvorišta a u opisu niže samo po par ip adresa, druga je sad stvar jeli Default ili Family protection ili Non-filtering. |
#101 |
Postovi: 4,336
Neznam tocno kako je s PC-ima, (tek sam ih nekidan upisao) ali koristim ih oko godinu dana na svim Android uredjajima gdje su mi se pokazali potpuno uredni i bez nekih nus-pojava i naravno bez bar 95% reklamnog $ranja. |
#102 | |
Postovi: 18,875
#103 | |
Datum registracije: Feb 2016
Lokacija: Unknown
Postovi: 721
Ako se dogodi neki problem u jednom data centru, kompanija čiji DNS koristiš te automatski preusmjeri na drugi najbliži koji radi i ti tu promjenu ni ne osjetiš. S druge strane, kada padnu DNS poslužitelji od A1, Iskona, HT-a itd., oni nemaju zamjenski data centar na koji te mogu spojiti, pa ostaješ bez usluge dok to ne poprave. Opekao sam se već dva puta (Vip) i od tada koristim isključivo javne DNS poslužitelje (prije Google Public DNS, a sada Cloudflare). I dok su se ljudi žalili i mediji pisali kako Vip ima problema i nitko nema interneta, ja sam surfao kao da se ništa nije dogodilo. Cloudflare koristim jer je privatan i najbrži; 1 ms prema istima budući da su im poslužitelji u Zagrebu. |
#104 |
Postovi: 23,543
OcKe ekipa |
#105 |
Lokacija: R Hrvatska
Postovi: 154
Čudna situacija. Izbacio sam Innbox ruter od A1 i vratio Fritza u pogon . Nisam ništa dirao po njemu već je ostala stara konfiguracija koja je do sad radila. Problem se desio da su dns serveri u fritzu bili oni od : CloudFlare Public DNS IPv4: Primary = 1.1.1.1 Secondary = 1.0.0.1 i niti jedan Iphone u kući se nežali spojiti preko wifija ustvari kaže da je: Nedostupna internet veza . U lokalu iako pokazuje da nema interneta i da je spojen na wifi... mogu pristupiti svim uređajima u lokalu , serveru .... Nakon stavljanja googlovih DNS-ova sve radi . Što bi moglo biti uzrok ?? |
#106 |
Postovi: 23,543
Bit će da se iDrekec preko CloudFlare nemože "javit" doma a preko Googla može, malo karikiram ali kužiš šta hoću reći. |
#107 |
Postovi: 154
#108 | |
1
Postovi: 3,588
P: Razne PC i serverske komponente, Laptope, Dijelove za laptope... Zadnje izmijenjeno od: Thermaltake. 14.04.2025. u 07:16. |
