#151 |
Datum registracije: Apr 2004
Lokacija: ZG - Dubrava
Postovi: 2,184
Generate your own Win 11 ISO preview Thanks to the work of the Windows community, it’s possible to generate an ISO file using the update files served through Windows Update. This is an unofficial method, so naturally we only recommend it for users who are comfortable with taking risks. Upute: https://www.xda-developers.com/download-windows-11/ DL link: https://uupdump.net/selectlang.php?i...1-caa99ff6f213 Rufus: za pripremu USB-a https://rufus.ie/en_US/ Napravi to pa instaliraj na cisto Win 11 Nije službeno preko MS ali također nije piraterija tako da ostavljam javno link.
![]() /connect 185.107.96.125:28990 server rcon: oldschool COD2 PCekspert ekipa https://discord.com/invite/zZ4PeqVpBv Zadnje izmijenjeno od: Blue Spirit. 08.07.2021. u 10:09. |
#152 |
Lokacija: München/Varaždin
Postovi: 4,833
Lenovo LOQ 15AHP9 83DX || AMD Ryzen 5 8645HS / 16GB DDR5 / Micron M.2 2242 1TB / nVidia Geforce RTX 4050 / Windows 11 Pro Lenovo Thinkpad L15 Gen 1 || Intel Core i5 10210U / 16GB DDR4 / WD SN730 256GB / Intel UHD / FreeBSD 14.3 |
#155 |
ODUZIMAM VAM RIJEČ
Postovi: 13,299
novi insider bild https://blogs.windows.com/windows-in...uild-22000-65/
#156 |
Postovi: 4,833
Odaberes da nemas Key, odaberes verziju koju imas i deri. Ako su Windoze legit sustav ce se aktivirat pogotovo ak koristis MS Account. Znam da je MS izjavio da Upgrade sa Win 7 direktno na Win 11 nije podrzan a mogu pretpostavit i da ce upgrade Windows 8 > Windows 11 biti takoder problematican.
#159 |
ODUZIMAM VAM RIJEČ
Postovi: 13,299
#161 |
Datum registracije: Feb 2021
Postovi: 42
Također, možete si generirati Insider Preview za Windows 11 sa ovog linka, ja odaberem prvu opciju većinom kad mi treba, adguard: https://uup.rg-adguard.net/ |
#162 |
DIY DILETANT
Lokacija: Čistilište
Postovi: 3,554
#163 |
ODUZIMAM VAM RIJEČ
Postovi: 13,299
#165 |
ODUZIMAM VAM RIJEČ
Postovi: 13,299
a jesi ciganu ''Microsoft is making it harder to switch default browsers in Windows 11'' https://www.theverge.com/22630319/mi...rowser-changes https://twitter.com/i/status/1427971299813597193 ![]()
#166 |
ODUZIMAM VAM RIJEČ
Postovi: 13,299
dostupan prvi ofišl ISO https://blogs.windows.com/windows-in...ild-22000-160/
#167 |
DIY DILETANT
Postovi: 3,554
https://www.pcworld.com/article/3623...cs-behind.html Sve ima svoj razlog. Mislio sam kupiti TMP modul, ali odustao. A vrijedi i za W10: https://www.ctrl.blog/entry/slow-windows-hvci.html |
#168 | |
Postovi: 8,228
You’ll be able to run Windows 11 on older PCs—if you install the update manually ![]() Citiraj:
#169 |
ODUZIMAM VAM RIJEČ
Postovi: 13,299
Update on Windows 11 minimum system requirements and the PC Health Check app https://blogs.windows.com/windows-in...lth-check-app/
#170 | ||
DIY DILETANT
Postovi: 3,554
Isto vrijedi i za W10. http://forum.pcekspert.com/showpost....&postcount=167 E sad pitanje za ekipu koja ima W11, dal imate u GP ove postavke za isključit VBS/HVCI: https://docs.microsoft.com/en-us/win...ult-enablement Jerbo ako bi se ta prokletinja dala isključit, puna šaka brade za nas sa "prastarim" procesorima. Zadnje izmijenjeno od: kopija. 28.08.2021. u 03:16. |
#171 |
Postovi: 8,228
Huh, ovo je bome poprilična zajebancija za isključiti, a i općenito se cijela stvar s dopuštanjem Windows 11 instalacije na neslužbeno podržani hardver, čini više kao reda-radi. Već su se u međuvremenu stigli ograditi da takve instalacije ne očekuju nikakav oblik podrške, ni buduće nadogradnje i zakrpe kroz Windows Update.
#173 | ||
Postovi: 8,228
Ma svašta su isforsirali, a pravi i možda jedini razlog postojanja Windows 11 OS-a, je Intel Alder Lake, tj. Intel Thread Director. Citiraj:
#174 |
Postovi: 33,952
#175 |
Postovi: 4,833
Mozda je do "Beta" verzije...ali Win 11 je na mom kompu (i5 7300HQ/32GB/Sandisk Extreme nvme/1050Ti) definitivno sporiji od Win 10. Na primjer: 1. Sam UI nije toliko responzivan i cesto se dogada da kad zelim neke stvari iz control panela (novog) direktno otvorit - il se ne otvaraju ili treba duze vrijeme (15-30 sekundi) 2. Obicno volim na jednom ekranu ostavit Youtube na drugom - Forza Horizon 4. Na win 10 - nije bed. Na Win 11 - nasumicna nagla usporavanja i trzanja - i Youtube i Forza. A onda citam i ovo: https://www.osnews.com/story/133872/...t-get-updates/ Iskreno - trenutno imam Dual Boot samo radi Forze tak da...ne dira me osobno previse ali svejedno...sucks. ![]()
#176 | ||
DIY DILETANT
Postovi: 3,554
Ak je tko probao KDE desktop koji je kralj customizacije mogao je vrlo lako završiti sa ovim simptomom i na kraju kliknuti na "reset to defaults" buton previše puta. W11 bude se dal fino tjunat s third-party alatkama, bitno je ono što je ispod haube, a kolko vidim po testovima, novi kernel je bolji od ovog (odličnog) na desetki. Citiraj:
Ponovno i ponovno zaboravljamo da je oduvjek bio "out-of-the-box" Win konfiguriran za Average Joe-a a ne za Power Usera. A od W10 launcha za Average Joa su se promjenile dvije stvari drastično: primarno koristi Iphone s touchscreen UI-jem a kod prijatelja i na Netlfix serijama je vidio kak izgleda OS X desktop i pomislio "hoću i ja!". Plus je znanost dokazala da se prosječni IQ nastavio smanjivati u razvijenim zemljama. I onda fino Microsoft napravi anketicu. Citiraj:
Odnos PU:AJ je (konzervativno) 1:1000, jasno je tko je glavni faktor pri izradi UI. Ak je tko probao KDE desktop koji je kralj customizacije mogao je vrlo lako završiti sa ovim simptomom i na kraju kliknuti na "reset to defaults" buton previše puta. W11 bude se dal fino tjunat s third-party alatkama, bitno je ono što je ispod haube, a kolko vidim po testovima, novi kernel je bolji od ovog (odličnog) na desetki. Zadnje izmijenjeno od: kopija. 29.08.2021. u 03:12. |
#177 | |
DIY DILETANT
Postovi: 3,554
http://forum.pcekspert.com/showpost....&postcount=167 |
#178 | |
Postovi: 4,833
Mozda. Podsjeca me na stara vremena kad je kombo AV + Firewall rijesenja vecine proizvodaca doslovce potrgao kompletan sustav ![]() ![]()
#179 | ||
Postovi: 8,228
Kaj se Windows 11 OS-a tiče, ionak budu napravili po svojem, jedino je blesavo da miču funkcionalnost na koju je većina već navikla i(li) koristila. Citiraj:
#180 |
Lokacija: Zagreb, Črnomerec
Postovi: 2,514
Ovo sa podrškom procesora je smijurija. Moj surface pro sa i7-7660U čiji je proizvođač sam Microsoft ![]() A i7-7820HQ su stavili, kao jednog od svega nekoliko 7th gen cpu modela samo zato što se nalazi u Surface Studio 2 kojeg još uvijek prodaju ![]() |
