Staro 08.07.2021., 10:02   #151
Blue Spirit
Blue Spirit's Avatar
Datum registracije: Apr 2004
Lokacija: ZG - Dubrava
Postovi: 2,181
Generate your own Win 11 ISO preview
Thanks to the work of the Windows community, it’s possible to generate an ISO file using the update files served through Windows Update.
This is an unofficial method, so naturally we only recommend it for users who are comfortable with taking risks.
Upute: https://www.xda-developers.com/download-windows-11/
DL link: https://uupdump.net/selectlang.php?i...1-caa99ff6f213
Rufus: za pripremu USB-a https://rufus.ie/en_US/
Napravi to pa instaliraj na cisto Win 11
Nije službeno preko MS ali također nije piraterija tako da ostavljam javno link.
/connect 185.107.96.125:28990
server rcon: oldschool
Zadnje izmijenjeno od: Blue Spirit. 08.07.2021. u 10:09.
Staro 08.07.2021., 12:55   #152
tomek@vz
tomek@vz's Avatar
Lokacija: München/Varaždin
Postovi: 4,697
Autor No123 Pregled postova
Mogu jedino napraviti clean install windowsa 8.
Ne kuzim. Ak imas Windows 11 ISO kreiras bootabilni USB i OS automatski povuce licencu.
Lenovo LOQ 15AHP9 83DX || AMD Ryzen 5 8645HS / 16GB DDR5 / 1TB Micron M.2 2242 / nVidia Geforce RTX 4050 / Windows 11 Pro
Lenovo Thinkpad T540p || Intel Core i7-4700MQ / 16GB DDR3 / 240GB Sandisk SSD Plus / nVidia Geforce GT 730 / FreeBSD 14.3
Staro 08.07.2021., 15:28   #153
No123
Lokacija: Grad na Dravi
Postovi: 580
Kod Instalacije me pita SN i ako ne upišem ne mogu dalje.
No123 je offline   Reply With Quote
Staro 08.07.2021., 15:33   #154
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,219
meni je bila opcija da kao poslije upišem, da nemam sad
Staro 08.07.2021., 21:47   #155
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,219
Staro 08.07.2021., 22:46   #156
tomek@vz
tomek@vz's Avatar
Postovi: 4,697
Odaberes da nemas Key, odaberes verziju koju imas i deri. Ako su Windoze legit sustav ce se aktivirat pogotovo ak koristis MS Account. Znam da je MS izjavio da Upgrade sa Win 7 direktno na Win 11 nije podrzan a mogu pretpostavit i da ce upgrade Windows 8 > Windows 11 biti takoder problematican.
Staro 08.07.2021., 23:51   #157
No123
Postovi: 580
A što ako nema opcije da nemaš key?
Staro 09.07.2021., 06:56   #158
Sinac
...samo te gledam...
Sinac's Avatar
Postovi: 2,817
Mora biti jer s ključem bez internetske veze ionako ne možeš ništa napraviti.
Staro 15.07.2021., 21:03   #159
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,219
Staro 16.07.2021., 22:49   #160
zlatko
zlatko's Avatar
Lokacija: slavonac
Postovi: 495
laptop star 3 godine.. na win 10 baterija trajala oko 4 sata , na win 11 ( insider ) 6 sati i 17 minuta . od 100% , pa dok se nije sam ugasio. Sviđa mi se.
he,he
zlatko je offline   Reply With Quote
Staro 18.07.2021., 09:26   #161
mate_j
mate_j's Avatar
Datum registracije: Feb 2021
Postovi: 42
Također, možete si generirati Insider Preview za Windows 11 sa ovog linka, ja odaberem prvu opciju većinom kad mi treba, adguard:
https://uup.rg-adguard.net/
mate_j je offline   Reply With Quote
Staro 20.07.2021., 17:28   #162
kopija
DIY DILETANT
kopija's Avatar
Lokacija: Čistilište
Postovi: 3,487
Staro 23.07.2021., 18:24   #163
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,219
Staro 13.08.2021., 10:11   #164
No123
Postovi: 580
Malo sam se igrao, na desktop Windowsa 11 sam stavio wallpaper od Fedore pa to izgleda ovako:
Windows 11:
Fedora 34:
Svaka sličnost je slučajna
Staro 19.08.2021., 13:55   #165
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,219
a jesi ciganu ''Microsoft is making it harder to switch default browsers in Windows 11''
https://www.theverge.com/22630319/mi...rowser-changes
https://twitter.com/i/status/1427971299813597193
Staro 19.08.2021., 19:15   #166
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,219
Staro 21.08.2021., 05:47   #167
kopija
DIY DILETANT
kopija's Avatar
Postovi: 3,487
https://www.pcworld.com/article/3623...cs-behind.html
Sve ima svoj razlog.
Mislio sam kupiti TMP modul, ali odustao.
A vrijedi i za W10:
https://www.ctrl.blog/entry/slow-windows-hvci.html
Staro 27.08.2021., 21:33   #168
Postovi: 8,136
You’ll be able to run Windows 11 on older PCs—if you install the update manually
Microsoft won't stop you from performing manual installs of Windows 11 on systems that don't meet the official requirements. That means that people running Windows 10 on unsupported systems won't be offered Windows 11 through Windows Update, but you'll still be able to update if you download an ISO file and perform an upgrade or a clean install manually. This will be a particular boon to PCs right on the border of Windows 11's system requirements, like those running 6th- or 7th-generation Intel Core CPUs or first-generation AMD Ryzen processors. While DIY PC gamers, IT admins, and other power users will be able to perform a clean install of Windows 11 on existing hardware dating back years, it still sounds like Microsoft will be encouraging millions of people to replace their perfectly good Windows PCs.
Izvor: ArsTechnica
Staro 28.08.2021., 01:21   #169
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,219
Update on Windows 11 minimum system requirements and the PC Health Check app
https://blogs.windows.com/windows-in...lth-check-app/
Staro 28.08.2021., 02:59   #170
kopija
DIY DILETANT
kopija's Avatar
Postovi: 3,487
Da ali će se vući ko krepana mačka jer
virtualization-based security (VBS) which enables several security capabilities, including memory integrity, also known as hypervisor-protected code integrity (HVCI)
radi u software emulation modu.
Isto vrijedi i za W10.
http://forum.pcekspert.com/showpost....&postcount=167
E sad pitanje za ekipu koja ima W11, dal imate u GP ove postavke za isključit VBS/HVCI:
https://docs.microsoft.com/en-us/win...ult-enablement
Jerbo ako bi se ta prokletinja dala isključit, puna šaka brade za nas sa "prastarim" procesorima.
Zadnje izmijenjeno od: kopija. 28.08.2021. u 03:16.
Staro 28.08.2021., 13:12   #171
Postovi: 8,136
Huh, ovo je bome poprilična zajebancija za isključiti, a i općenito se cijela stvar s dopuštanjem Windows 11 instalacije na neslužbeno podržani hardver, čini više kao reda-radi.
Već su se u međuvremenu stigli ograditi da takve instalacije ne očekuju nikakav oblik podrške, ni buduće nadogradnje i zakrpe kroz Windows Update.
Staro 28.08.2021., 14:53   #172
Mario92
Omicron Alpha resident
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,031
Win10 je podržan do 2025. mislim tak da me ne hebe previše support, a onda Win11 ili Linux, kak kome paše
Ryzen 7 5700G
AsRock B550 Pro4
Kingston A2000 1TB NVMe
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
SK Hynix P31 Gold 1TB
13.3" FHD IPS
Staro 28.08.2021., 16:48   #173
Postovi: 8,136
Ma svašta su isforsirali, a pravi i možda jedini razlog postojanja Windows 11 OS-a, je Intel Alder Lake, tj. Intel Thread Director.
Intel Thread Director is a combined hardware/software solution that Intel has engineered with Microsoft focused on Windows 11. This fundamental change is one reason why Windows 11 exists.
I onda su još za dobru mjeru odigrali već dobro poznati potez koji im se i prije fino odbil u glavu.
According to Microsoft, "research showed people wanted a cleaner and simpler Start," and it was redesigned (as was Windows 8) by taking inspiration from smartphones ...
Staro 28.08.2021., 18:46   #174
Postovi: 33,921
Staro 28.08.2021., 22:32   #175
tomek@vz
tomek@vz's Avatar
Postovi: 4,697
Mozda je do "Beta" verzije...ali Win 11 je na mom kompu (i5 7300HQ/32GB/Sandisk Extreme nvme/1050Ti) definitivno sporiji od Win 10. Na primjer:
1. Sam UI nije toliko responzivan i cesto se dogada da kad zelim neke stvari iz control panela (novog) direktno otvorit - il se ne otvaraju ili treba duze vrijeme (15-30 sekundi)
2. Obicno volim na jednom ekranu ostavit Youtube na drugom - Forza Horizon 4. Na win 10 - nije bed. Na Win 11 - nasumicna nagla usporavanja i trzanja - i Youtube i Forza.
A onda citam i ovo:
https://www.osnews.com/story/133872/...t-get-updates/
Iskreno - trenutno imam Dual Boot samo radi Forze tak da...ne dira me osobno previse ali svejedno...sucks.
Staro 29.08.2021., 02:45   #176
kopija
DIY DILETANT
kopija's Avatar
Postovi: 3,487
They're not selling to us
The vast majority of casual Windows users just want to get to their entertainment. The vast majority of student users just want to get to Office 365 and their entertainment. Even the vast majority of office workers just want to get to the software applications they use.
Power users are not the target audience. If something is convenient for the majority but not for those who fiddle with God Mode or run multiple virtual machines or whatever defines your idea of a power user, your views are less of a concern to Windows designers.
And it's been that way for years.
Ak je tko probao KDE desktop koji je kralj customizacije mogao je vrlo lako završiti sa ovim simptomom i na kraju kliknuti na "reset to defaults" buton previše puta.
W11 bude se dal fino tjunat s third-party alatkama, bitno je ono što je ispod haube, a kolko vidim po testovima, novi kernel je bolji od ovog (odličnog) na desetki.
Sad kad sam prespavao ovaj članak iz The Registera (inicijalno sam se doslovce primio za glavu čitajući ga), čini mi se potpuno razumljiva odluka re: Start.
Ponovno i ponovno zaboravljamo da je oduvjek bio "out-of-the-box" Win konfiguriran za Average Joe-a a ne za Power Usera.
A od W10 launcha za Average Joa su se promjenile dvije stvari drastično: primarno koristi Iphone s touchscreen UI-jem a kod prijatelja i na Netlfix serijama je vidio kak izgleda OS X desktop i pomislio "hoću i ja!".
Plus je znanost dokazala da se prosječni IQ nastavio smanjivati u razvijenim zemljama.
I onda fino Microsoft napravi anketicu.
"research showed people wanted a cleaner and simpler Start," and it was redesigned (as was Windows 8) by taking inspiration from smartphones,
"Cleaner and simpler Start," jer je stvarni život ružan, prljav i prekompliciran za shvatit pa Start može fino kompenzirat taj problem. Apple je to shvatio još prije dva desetljeća.
Odnos PU:AJ je (konzervativno) 1:1000, jasno je tko je glavni faktor pri izradi UI.
Zadnje izmijenjeno od: kopija. 29.08.2021. u 03:12.
Staro 29.08.2021., 03:16   #177
kopija
DIY DILETANT
kopija's Avatar
Postovi: 3,487
Možda je do ovog:
Staro 29.08.2021., 06:31   #178
tomek@vz
tomek@vz's Avatar
Postovi: 4,697
Autor kopija Pregled postova
Mozda. Podsjeca me na stara vremena kad je kombo AV + Firewall rijesenja vecine proizvodaca doslovce potrgao kompletan sustav No mislim da ce se to ipak malo optimizirat do finalne verzije. Ak ne - Win 10 / Linux su way to go za starija racunala i to je to
Staro 29.08.2021., 14:25   #179
Postovi: 8,136
Da, ovo za KDE sam se i sam našel u takvoj situaciji, tak da ne treba biti i previše izbora, jer opet nije dobro.
Kaj se Windows 11 OS-a tiče, ionak budu napravili po svojem, jedino je blesavo da miču funkcionalnost na koju je većina već navikla i(li) koristila.
  • Loss of the option for a full screen Start menu – good for accessibility in some cases, and on tablets
  • No way to resize the Windows 11 Start menu
  • Loss of ability to have small icons in the Taskbar
  • No way to move the taskbar to the top of the screen
  • General lack of customisation options
IMHO, ovo čak i nisu neke posebno napredne opcije, posebice kad ih Windows 10 OS nativno nudi, ali eto - koristili budu se dodatni alati za one kojima budu falile takve mogućnosti.
Staro 30.08.2021., 22:47   #180
Exy
Exy's Avatar
Lokacija: Zagreb, Črnomerec
Postovi: 2,498
Ovo sa podrškom procesora je smijurija. Moj surface pro sa i7-7660U čiji je proizvođač sam Microsoft samo zbog procesora nije kompatibilan sa Win11.
A i7-7820HQ su stavili, kao jednog od svega nekoliko 7th gen cpu modela samo zato što se nalazi u Surface Studio 2 kojeg još uvijek prodaju
