Staro 15.06.2021., 10:29   #1
Žak Onanis
Datum registracije: Jul 2015
Lokacija: Vukovar
Postovi: 288
(riješeno) Kako da nađem jedan word dokument u compu?
Evo ovako, u compu imam mali milijun dokumenata i trebao bi pronaći jedan dokument ali neznam pod kojim imenom je spremljen negdje u compu, ali znam sigurno jednu rečenicu koja se nalazi u tom dokumentu
I sad sjećam se da sam prije otprilike 10 g u jednoga kolege vidio kako pomoću te rečenice pronalazi dokument u kojemu se ona nalazi
Zna li ko šta o tome
Žak Onanis je offline   Reply With Quote
Staro 15.06.2021., 10:34   #2
Blue Spirit
Blue Spirit's Avatar
Datum registracije: Apr 2004
Lokacija: ZG - Dubrava
Postovi: 2,195
Skini i instaliraj Search Everything
https://www.voidtools.com/Everything....x64-Setup.exe
How to integrate Everything search in the Windows 10 taskbar
Windows 10 users can now integrate the Everything search engine directly into the Windows taskbar using the new 'EverythingToolbar' application. If you are a user of voidtool's Everything search engine for Windows, you know what a terrific search tool it is for Windows. However, to search for files and data, you need to perform your searches using the Everything app. This week, developer Stephan Rumswinkel released a new open-source application called EverythingToolbar that lets you integrate an Everything search field directly into the Windows 10 toolbar. This field displays instant search results from the Everything index, includes keyboard shortcut navigation, customizable 'Open with..' commands, and supports light/dark/medium themes, as shown below.
Izvor: BleepingComputer
Autor kasko Pregled postova
Naklon do poda za ovaj info !!!
Search Everthing koristim vec godinama umjesto defoltnog Windows search-a, a ovo je samo šlag na tortu.
Info za one koji ne znaju ... Everything indeksira sve - prikaže / potraži sve datoteke u djelic sekunde, cak i na obicnom HDD-u.
/connect 185.107.96.125:28990
server rcon: oldschool
Staro 15.06.2021., 10:37   #3
brodjo
Playmaker
brodjo's Avatar
Lokacija: Osijek/Wien
Postovi: 1,661
Uđi u neki folder, odeš desno gore na View karticu, imaš skroz desno Options. Kad ti se otvori window Folder Options, imas treci tab Search. Tamo oznacis zadnju opciju "Always search file names and contents. Probaj onda ponovno pretraziti
brodjo je offline   Reply With Quote
Staro 15.06.2021., 11:34   #4
kopija
DIY DILETANT
kopija's Avatar
Lokacija: Čistilište
Postovi: 3,685
Does Everything search file contents?
Yes, "Everything" can search file content with the content: search function.
kopija je online   Reply With Quote
Staro 15.06.2021., 12:28   #5
Paxton
Expert from the shadow
Paxton's Avatar
Lokacija: Sibinj
Postovi: 696
Notepad++ > Find in files, filter na .doc (.docx) extenziju.
Paxton je offline   Reply With Quote
Staro 15.06.2021., 12:35   #6
OuttaControl
OuttaControl's Avatar
Lokacija: Dalmacija
Postovi: 5,893
Ili sa Total Commander pretragom isto mozes pretrazivati sadrzaj unutar fileova,
@Exiled i Blue, thanks za ovo za everything brutalan alat, sa ovim taskbarom još bolji
Staro 15.06.2021., 14:00   #7
Blue Spirit
Postovi: 2,195
search everything brutalan alat, sa ovim taskbarom još bolji
OFC miljama svjetlosnih godina bolji od standardnog windows search-a.
Staro 15.06.2021., 14:11   #8
Žak Onanis
Lokacija: Vukovar
Postovi: 288
Evo sad sam instalirao taj "Search everything" i za probu upisao jednu riječ iz jednog dokumenta, ali oon ne pronalazi dokument u kome se nalazi ta riječ
On mi samo izlista naslove datoteka ali ne i dokument u kome se nalazi odabrana riječ
Zadnje izmijenjeno od: Žak Onanis. 15.06.2021. u 14:22.
Staro 15.06.2021., 14:35   #9
kopija
DIY DILETANT
kopija's Avatar
Postovi: 3,685
Autor Žak Onanis Pregled postova
http://forum.pcekspert.com/showpost....39&postcount=4
Staro 15.06.2021., 15:01   #10
Blue Spirit
Postovi: 2,195
Staro 15.06.2021., 15:21   #11
Žak Onanis
Lokacija: Vukovar
Postovi: 288
Evo sad sam uradio po tim uputama ali opet nije to to
Na taj način on mi pronađe dokument u kojemu se nalazi ta riječ ali samo kad mu zadam folder u kome se nalazi taj dokument. (iako sam označio include subfolders)
Ali meni treba da mi pretraži i sve subfoldere označenog foldera, jer moji dokumenti se nalaze u više foldera na raznim mjestima
Staro 15.06.2021., 15:22   #12
Paxton
Paxton's Avatar
Lokacija: Sibinj
Postovi: 696
Autor Paxton Pregled postova
Staro 15.06.2021., 15:41   #13
nino
nino's Avatar
Postovi: 12,613
Skrati muke i sebi i nama.
http://dngrep.github.io/
Staro 15.06.2021., 18:13   #14
Žak Onanis
Lokacija: Vukovar
Postovi: 288
Autor nino Pregled postova
Bravo Nino taj DnGrep mi napokon pronalazi ono šta tražim (pretražuje subfoldere)
A programi "Everything" i "Notepad++" ne pronalaze ništa (osim ako odaberem folder u kojemu se nalazi tražena riječ)
Staro 15.06.2021., 18:35   #15
Princ288
Princ288's Avatar
Datum registracije: May 2012
Postovi: 848
Copernic
https://copernic.com/en/
Placa se, ali i vrijedi po meni.
Sent from my GM1913 using Tapatalk
Princ288 je offline   Reply With Quote
