Povratak   PC Ekspert Forum > Računala > Gaming > Konzole
Staro 14.04.2021., 13:24   #301
Postovi: 16,904
Jasno, ovo je "idemo pokupiti lovu i ovisiti o tržištu vani".
Delivery date: we don't care.
Staro 28.04.2021., 20:28   #302
imaticx
Default
imaticx's Avatar
Lokacija: Požega
Postovi: 1,516
Staro 06.05.2021., 20:45   #303
Postovi: 8,336
Sony is working on a PS5 redesign set to start production in 2022
New report claims that Sony suppliers will start producing the components for a redesigned PlayStation 5 between the second and third quarter of 2022. One of those suppliers is TSMC, which will be responsible for producing the 6nm semi-custom AMD chip that the new PS5 model will feature. The redesigned console could feature an AMD-designed, semi-custom chip based on TSMC's 6nm process node. A 5nm chip was also considered, but it was said to be "too costly." Production of the new PS5 chips will reportedly start in Q2-Q3 2022. There's no word yet about external changes to the console.
Izvor: TechSpot
Staro 10.05.2021., 17:30   #304
Postovi: 33,995
Staro 13.05.2021., 09:34   #305
Newmie
Postovi: 1,392
Uzeo sam jučer PSVR, rabljeni. Znao sam da kameru ne mogu spojiti na PS5 bez dodatnog adaptera, ali nisam znao da PSVR uopće ne mogu niti upogoniti bez kamere
Zna li netko koliko se čeka na taj adapter nakon što se naruči od Sony-a? Šalje li se to iz HR ili?
Staro 13.05.2021., 09:50   #306
Mirkopoter
Mirko, a ne Harry
Mirkopoter's Avatar
Postovi: 5,447
Ja čekao preko mjesec dana.
Hala Madrid!
Staro 13.05.2021., 10:01   #307
Newmie
Postovi: 1,392
Fak, toga sam se i bojao.
Ima netko za prodati/posuditi dok meni ne dođe moj?
Staro 16.05.2021., 10:27   #308
LeskiRM
LeskiRM's Avatar
Datum registracije: Feb 2015
Lokacija: Sveta Nedelja
Postovi: 705
Krenuli problemi s mojim Dualsense 5,
Audio jack je labav, kada uštekam slušalice imam oko 2-3 mm praznog hoda i slušalice gube kontakt što dovodi do toga da me kolege u voice chatu ne čuju.
Probao sam sa više slušalica i ista stvar, jednostavno slobodno šeću 2-3 mm nutra van jer ih mehanizam ne drži čvrsto uštekanim..
Pitanje, s obzirom da je kontroler dio paketa s konzolom, moram li slati sve na jamstvo ili samo kontroler?
LeskiRM je offline   Reply With Quote
Staro 16.05.2021., 10:54   #309
Postovi: 16,904
Bilo je slično pitanje u PS4 temi, potvrdile kolege, samo kotroler.
Staro 16.05.2021., 12:10   #310
cic
cic's Avatar
Lokacija: Podravina
Postovi: 1,087
Čini mi se da konzola nakon par ažuriranja koja su bila više ne zuji kao prije. Mislim na ono dok je disk unutra pa s vremena na vrijeme počne vrtit bezveze.
Sent from my LYA-L29 using Tapatalk
cic je offline   Reply With Quote
Staro 16.05.2021., 13:25   #311
Mladenxy
Mladenxy's Avatar
Postovi: 4,372
Bio danas u Santca Domenica da pred naručim konzolu ali odustao. Tko pred naruči može ju očekivati navodno tijekom ljeta i to mi nije problem.
Odustao san jer u stvari pred naručuješ nešto u bundlu sa dvije igre za 5000 kn a ne solo konzolu za 3850 kn. Tak da to ne želim jer jedna od igara uopće nije moj štih.
Staro 16.05.2021., 13:48   #312
LeskiRM
LeskiRM's Avatar
Postovi: 705
Zato što je navala velika, a cijene konzola ne smiju dirati jer je ona preporučena od Sonya, ono kaj smiju jest izmisliti budle. Malo "podlo" ali barem nešto "dobijaš" zauzvrat, za razliku od scalpera.
Staro 16.05.2021., 13:55   #313
Postovi: 16,904
A koje igre se dobiju?
Staro 16.05.2021., 14:13   #314
Mladenxy
Mladenxy's Avatar
Postovi: 4,372
Spiderman zadnji i Demon's Souls
Staro 16.05.2021., 14:18   #315
Newmie
Postovi: 1,392
To se ne isplati uzimati u bundle. Spidermana sam uzeo nekidan za 150kn, a DS je oko 300kn na njuski.
Staro 16.05.2021., 14:21   #316
Mladenxy
Mladenxy's Avatar
Postovi: 4,372
Naravno, zato bi i uzeo verziju sa diskom i lešinario po njuškalu Ovak za te igre 500 kn koje odigraš za par vikenda, nema šanse. Mogu dati 500 kn za GT 7 koji bi igrao par godina i sl.
Staro 18.05.2021., 13:03   #317
panda505
panda505's Avatar
Lokacija: Beertopia
Postovi: 2,013
pa mogao si uzeti bundle sa konzolom i dodatnim joystickom.
To je nekih ~4.800
i dobiješ 10% na gotovinu, 5% na kartice
čisto oke cifra na kraju...
54' / 74' / 90' / 2014
Staro 18.05.2021., 13:15   #318
Mladenxy
Mladenxy's Avatar
Postovi: 4,372
Nije mi to nudio, nego sa dvije igre koje sam naveo za 5000 kn - popust za keš.
Staro 18.05.2021., 13:24   #319
panda505
panda505's Avatar
Lokacija: Beertopia
Postovi: 2,013
A onda ti je kenjao...
Šogor bio prije koji dan:
Staro 18.05.2021., 13:31   #320
Mladenxy
Mladenxy's Avatar
Postovi: 4,372
Autor LeskiRM Pregled postova
Pa i nek mu je kenjao kad se hoće lešinarit po njuškalu
Nebitno, kupit ću PS5 slim i lešinarit se po njuškalu kao i sa PS4 slim. Nije da nemam na čemu i što igrati, strpljen spašen. Odigranim tih 5-6 ekskluziva i prodam dalje dok je pod garancijom.
edit; možda si mislio da se mislim scalpat po njuškalu? To ne radim, da to mislim prodavao bi trenutnu 3060 ti za neke novce.
Isključivo sam mislio na kupovinu polovnih disk igara, i to samo eksluziva jer mrzim tu formu, i ne mislim im nikada platiti punu cijenu jer su nešto zaključali za svoju platformu.
Zadnje izmijenjeno od: Mladenxy. 18.05.2021. u 13:52.
Staro 18.05.2021., 13:51   #321
LeskiRM
LeskiRM's Avatar
Postovi: 705
Ja da sam SD nabio bi u paket COD Cold War, Spiderman, Demon souls, 2 kontrolera, kameru i daljinski zbog takvih lešinara. Doduše već su to i počeli raditi. Ako ništa barem izdaju račun na plaćen iznos. Nek se niko ne uvrijedi, to je samo moje mišljenje kao osoba koja sam igrom slučaja došao do 2 konzole day 1 i jednu prodao dalje bez zarade, na 0. Nemam obraza prodavati maglu.
Staro 18.05.2021., 13:55   #322
Mladenxy
Mladenxy's Avatar
Postovi: 4,372
Eto editirao sam post pa ne znam na kave lešinare ti misliš. Po meni je sony lešinar kao i svatko drugi tko zaključava naslove za neku platformu. To ću sa guštom odigrati za max 50 kn po naslovu.
Staro 18.05.2021., 13:57   #323
LeskiRM
LeskiRM's Avatar
Postovi: 705
Sve pet nisam tebe direktno ciljao niti sam mislio nekog prozivati. Nego tu cijelu situaciju, radije bih da mi SD naplati konzolu 6000kn i izda račun na taj iznos nego Pero koji je kupil konzolu za 4000kn pa preprodaje dalje.
Staro 18.05.2021., 14:00   #324
Mladenxy
Mladenxy's Avatar
Postovi: 4,372
To je isključivo problem Jure koji ju je spreman platiti 6000 kn. Da se mene pita treba mu naplatiti 12000 kn bez porodna pa nek se igra čovjek.
Staro 18.05.2021., 14:11   #325
Postovi: 16,904
Kako misliš slim? Šta nije slim bez BR-a?
Staro 18.05.2021., 14:15   #326
Mladenxy
Mladenxy's Avatar
Postovi: 4,372
Imaš klasičnu verziju sa BR i bez.
Slim dolazi kroz neko vrijeme ili nova revizija na 6nm...još se ne zna.
https://www.techpowerup.com/281868/s...-6-nm-for-2022
Staro 18.05.2021., 14:31   #327
Postovi: 16,904
Aha, ok, tu info znam, predugo mi je to za čekati.
Mislio sam da je već neka interna šema da se zove obaj bez BR "slim".
Thx za info.
Staro 19.05.2021., 18:53   #328
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,310
Autor panda505 Pregled postova
Mladen je tražio konzolu sa BR čitačem, a na ovoj ponudi sa DS5 kontrolerom ja vidim samo verziju bez BR čitača.
Ali da dodam, ovo je bezobrazluk da ti tako kao nude tih par igara za tu cifru, a još i moraš čekat konzolu.
Ne fala, strpljen-spašen.
Do tada možda bude i revizija tog nesretnog DS5, pa riješe sve te probeleme sa njima.
Slobodno me dodajte na PSN
Staro 19.05.2021., 20:21   #329
LeskiRM
LeskiRM's Avatar
Postovi: 705
Igram se ko lud, na bolovanju sam već 2 i pol mjeseca, konzola se ne gasi od jutra pa sve dok ne idem spavat i konzola radi kao urica, ds5 sam mijenjao već..
Staro 19.05.2021., 20:57   #330
Postovi: 16,904
Pa što igraš već 2 i pol mjeseca? Igre s PS5?
Zašto si mijenjao gamepad?
