Staro 16.04.2021., 23:35   #1141
Ivo_Strojnica
PRO
Ivo_Strojnica's Avatar
Postovi: 4,809
Ponukan komentarima za desktop enviroment, složija sam sljedeće:
Gnome
gnome-tweaks: sudo apt install gnome-tweaks
bottom panel: sudo apt install gnome-shell-extension-dash-to-panel
i restart,
Lipo izgleda, vidit ćemo kako će se ponašati, malo da se maknem od cinammona.
Staro 17.04.2021., 10:29   #1142
Ivo_Strojnica
PRO
Postovi: 4,809
Evo mene opet:
Za vikend sam odlučija malo se poigrati sa linuxom, prebacija se potpuno na NVME (A2000) + btrfs.
Uglavnom, koristim uredno komp i odjednom - freeze. katkad po nekoliko sekundi, katkad nekoliko minuta.
Mislim se sigurno je disk neispravan, kontroler ne radi, no idem vidjeti statse - sve ok, nema bad read/write poruka...
Na kraju iša čitati btrfs dokumentaciju i slagati mount opcije...
Uglavnom, glavni krivac mi je parametar "discard".
Stavio sam "discard=async" i sada mi uredno radi sustav.
Valjda će još nekome pomoći da ne gubi živce ko ja.
Cijeli fstab:
UUID=<blabla> / btrfs defaults,subvol=@,ssd,noatime,discard=async,space_cache,commit=120,compress=zstd:1 0 0
Staro 17.04.2021., 10:55   #1143
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 4,999
Evo mene opet:
Cijeli fstab:
Na BTRFS-u nemoj discard koristiti:
Copy-on-write means that allocated blocks are not overwritten – instead, when a data block in a file changes, a new block is allocated with the new data and the file is updated to refer to the new block instead of the original one. When the old block is no longer referenced by any part of the file system, it is freed. Copy-on-write does not mean that no blocks are ever freed.
The discard option just tells Btrfs to report free blocks to the underlying device. Btrfs already keeps track of which blocks are free, and reporting this information to the underlying device won't affect copy-on-write behaviour.
Staro 17.04.2021., 11:56   #1144
Nick7
Lokacija: Velika Gorica
Postovi: 1,525
To nije razlog za ne koristiti discard.
Discard ima itekako smisla jer on kaze SSD-u koji blokovi su oslobodjeni zbog njegovog internog garbage collectiona.
U suprotnom, SSD misli da se s vremenom skroz zapunio, te ces zbog toga izgubiti dio performansi SSD-a (discard=TRIM).
Sent from my Mi 9T using Tapatalk
Staro 17.04.2021., 12:26   #1145
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 4,999
Autor Nick7 Pregled postova
Tocno. A sad procitaj moj post jos jednom.
Zadnje izmijenjeno od: tomek@vz. 17.04.2021. u 12:34.
Staro 17.04.2021., 13:34   #1146
Dottore
Dottore's Avatar
Postovi: 7,664
Ovako nešto + još interna baterija.
Fedora + Cinammon meni radi odlično.
LVM + Ext4 + rolling update svakih 7 dana.
Od novijih izleta sam isproba Pop_OS!, super radi također, no Fedora mi je bliža srcu.
Koji je to model laptopa?
Отправлено через SM-G975F
HP 845 G8
CPU: AMD Ryzen 7 PRO 5850U
Graphic: AMD Radeon 680M
OS: Windows 11 Pro 24H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
LCD: 14" IPS @ 1920 x 1200
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
OS: Windows 11 Pro 23H2
Staro 17.04.2021., 14:05   #1147
Nick7
Postovi: 1,525
OK, ne kuzim.. kazes da se ne koristi discard, das opis sto radi i kako radi sa btrfs-om.
Discard *je* dobra stvar, i kako je Ivo_Strojnica napisao, treba ga koristiti u async modu, inace dolazi do usporenja.
Staro 17.04.2021., 15:59   #1148
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 4,999
O ovome pricam.
+ sa Arch WIKI-a:
A Btrfs filesystem is able to free unused blocks from an SSD drive supporting the TRIM command. Starting with kernel version 5.6 there is asynchronous discard support, enabled with mount option discard=async. Freed extents are not discarded immediately, but grouped together and trimmed later by a separate worker thread, improving commit latency. More information about enabling and using TRIM can be found in Solid State Drives#TRIM.
Da, discard=async opcija sljaka ali kad je BTRFS u pitanju fstrim je bolja opcija.
Staro 17.04.2021., 18:43   #1149
Nick7
Postovi: 1,525
O ovome pricam.
Da, brtfs interno prati koji blokovi su free, sto nema veze direktno sa SSD-om. On to ne zna, tj. ne zna sve dok ne dobije TRIM komandu.
Zasto?
discard=async radi sam po sebi. Ne treba nikakav cronjob i sl.
Nekad davno, kad je discard bio sync komanda, onda da. To je bio problem - jer si mogao imati freezove, kako je bilo i napisano nesto prije u threadu.
No sa async modom nema razloga za ne koristiti. Fire and forget.
Staro 17.04.2021., 21:03   #1150
Ivo_Strojnica
PRO
Postovi: 4,809
Autor Dottore Pregled postova
Lenovo Thinkpad T560.
Staro 25.04.2021., 10:31   #1151
Hamm
Pod naletima kopita zla
Hamm's Avatar
Lokacija: SMB / ZGB
Postovi: 7,735
Ima još netko problema s H.265? Pokrenem ga uredno preko preko VLC playera (3.0.9.2)
OS Linux 5.8.0-50-generic #56~20.04.1-Ubuntu
Video se prikazuje uredno ali zvuk zastajkuje ko da svaku sekundu pauzira. Tako je sa apsolutno svim x265 sadržajem.
Mplayer playa uredno video i audio. Da ok mogu koristii mplayer za x265 ali...znate kako to ide.
Zadnje izmijenjeno od: Hamm. 25.04.2021. u 10:37.
Staro 25.04.2021., 14:39   #1152
domy_os
domy_os's Avatar
Postovi: 18,875
Na kojoj GPU? NVIDIA nije baš na ti s Linuxom, vidi ovdje instrukcije, možda si nešto propustio.
https://wiki.archlinux.org/index.php...o_acceleration
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 25.04.2021., 14:52   #1153
dbL
dbL's Avatar
Datum registracije: Mar 2020
Postovi: 324
Jel probao netko ubuntu 21.04, wayland je po defaultu umjesto xorga.. !? kako radi ?
Staro 25.04.2021., 15:04   #1154
Postovi: 8,354
Autor Hamm Pregled postova
Probaj prešaltati na neki drugi audio output, dok pod Input/Codecs (umjesto Automatic) možeš složiti jedan od ovih koje domy_os spominje, ovisi koji ti bolje odgovara.
Staro 25.04.2021., 15:55   #1155
Mihael
Mihael's Avatar
Lokacija: Home
Postovi: 2,186
S vlcom nikad nisam bio zadovoljan
1.Bomi - ali taj projekt stoji od 2015. bojim se da se više ne da pokrenuti
2. SMPlayer (forntend za mpv/mplayer) - lijepu temu, postelati i nema brige
Staro 25.04.2021., 21:47   #1156
domy_os
domy_os's Avatar
Postovi: 18,875
Autor Mihael Pregled postova
Također, VLC mi uvijek bio li-la, SMPlayer sve vrti bez problema i dosta je sličan MPC-u na Windowsima, čak ima i takva neka tema.
Staro 26.04.2021., 08:58   #1157
Hamm
Hamm's Avatar
Lokacija: SMB / ZGB
Postovi: 7,735
@domy..da nvidia i koliko vidim sve je ok. Budem probao SMPlayer.
@Exiled. Probao sam prošetati ali na žalost nema efekta.
SMplayer radi bez greške.
Staro 26.04.2021., 09:30   #1158
Ivo_Strojnica
PRO
Postovi: 4,809
također glas za SMPlayer, odličan player. Meni je bio jedini issue gdje nije bilo VSynca u malo jačim bitrateima.
Staro 26.04.2021., 16:17   #1159
NoMaam
NoMaam's Avatar
Datum registracije: Apr 2018
Lokacija: ovdje
Postovi: 38
Da se malo ubacim među vas . Vlc radi dobro ali iz nekog razloga mi ne leži.
SMplayer mi je odličan i samo njega koristim. Prva liga je .
Prije sam mislio da je šteta što nema mogučnost snimanja kao VLC ali nakon godina i godina korištenja sam shvatio da mi snimanje nije nikada ni trebalo .
Pozz
NoMaam je offline   Reply With Quote
Staro 26.04.2021., 20:00   #1160
mkey
Datum registracije: Sep 2018
Lokacija: tu
Postovi: 3,544
Evo kad već pljujemo po VLC da i ja hračnem. Meni je VLC banana, nekako bi to trebao biti puno uglađeniji proizvod (makar mi se to tako čini, s obzirom koliko je dugo u điru) ali SMPlayer mi je bolji 4x. Ima i podršku za custom shortcute koje su mi omogućile neke stvari na koje sam navikao sa potplayerom i vozi. Ima nekih bugova, znam da sam ga uspio polomiti promjenom neke postavke vezano za skaliranje GUIa (ili tako nešto) ali to ne diram pa nema problema
Poslao sam i developerima neku kintu, zaslužili su.
Staro 27.04.2021., 18:21   #1161
domy_os
domy_os's Avatar
Postovi: 18,875
Fedora 34 final je vani pa navalite...
https://getfedora.org/en/workstation/download/
Staro 24.05.2021., 11:57   #1162
c-shadow
c-shadow's Avatar
Postovi: 3,491
Jel netko možda uspio na gnjiluxu iskoristiti bluetooth slušalice da radi HSP/HFP profil s pristojnom kvalitetom zvuka, dakle SBC codec?
Naravno da pod winblowsima (s oba USB adaptera) i na androidu sve radi out of the box tako da nije stvar u slušalicama.
Isprobao sam dosad:
- ubuntu kernel 5.8.0-53-generic
- 2 BT USB adaptera s chipsetima: CSR8510 A10 (BT 4.x) i Realtek rtl8761b (BT 5)
Rezultati:
Pulseaudio - nula bodova, nema podrške za to, developeri se posvađali u staroj dobroj linux maniri Odnosno, može se natjerati da radi, ali preko dodatnih programa tipa ofono i zvuk je teška katastrofa jer ne radi SBC
PipeWire 0.3.28 - navodno podržava, može se odabrati profil, ali nema zvuka :-)
A2DP i slični jednosmjerni profili rade uredno, ali ja bi baš i mikrofon koristio
Pipewire je navodno trebao zamijeniti Pulse u Gedori...
Staro 24.05.2021., 14:59   #1163
Ivo_Strojnica
PRO
Postovi: 4,809
ne, imali smo već raspravu, ništa nisam uspija.
U fedori uopće nije radija HSP profil, a u ubuntu je kao "radio", ali nažalost, kvaliteta i "mic dropping" me navelo da spojim žicu i pomirim se sa sudbinom.
Staro 24.05.2021., 16:58   #1164
c-shadow
c-shadow's Avatar
Postovi: 3,491
U lošoj kvaliteti se može složiti i na ubuntu 20.04. Ali stvarno je zvuk grozan (CVSD encoding i sampling rate 8 kHz) i rješenje je komplicirano i skroz zaobilazno.
Ako se proba nešto u boljoj kvaliteti, onda ne rade niti sluške niti mikrofon.
Zeza me što znam imati seanse od po sat-dva na zoomu i sl. konferencijskim alatima, a ne moram biti stalno za kompom pa bi protegnuo noge malo dok pričam s ljudima
Windozeri naravno rade uredno s istim hardverom, kao i android.
Staro 24.05.2021., 17:46   #1165
Postovi: 23,543
A stara dobra žnjora / žica ?
Uštekaš, i 5 M ako treba, radi.
Malo zafrkavam, morao sam
Staro 25.05.2021., 14:10   #1166
stef
stef's Avatar
Lokacija: Zabok
Postovi: 3,393
Mislim da sam postao u krivoj temi, linkam ovdje: http://forum.pcekspert.com/showpost....&postcount=542
Dakle, HP ProBook 455 G7 (R7 4700U).
Specke:
* Ryzen 7 4700U (8 core / 448 shaders)
* 16GB (uskoro upgrade na 32GB)
* neki WD nvme od 500GB
Fedora 34, Cinnamon.
Jednostavno particioniranje bez LVM-a (/boot, /boot/efi, / i swap od 4G). Dakle, sve u root. Luks2 na / particiju. XFS kao file sistem. (Btrfs sam izbjegao za sada.)
Ako bi nekog zanimala recenzijica ... napišem par riječi. Inicijalni dojam je jako dobar.
Zadnje izmijenjeno od: stef. 25.05.2021. u 14:18.
Staro 25.05.2021., 14:20   #1167
Ivo_Strojnica
PRO
Postovi: 4,809
nema to šta loše raditi.
Ali ti si onda bome pro, kad nemaš snapshotting za sve "izlete u nepoznato"
Staro 25.05.2021., 14:22   #1168
stef
stef's Avatar
Lokacija: Zabok
Postovi: 3,393
Sve eksperiemente dižem u vagrantu i dockeru, nema divljanja po OS-u .
Iskreno, pretočio sam setup koji vučem sa starog lapa još od Fedore 30. Ali, mogao bih probati .
EDIT: Samo da potvrdim, apsolutno sve radi po PS-u. lm-sensors očitava sve temperature out-of-the box. Sve kontrole rade. Za test sam instalirao Quake2 i Quake3 (vulkan) te Dotu 2 preko Steam-a (isto vulcan). Sve klapa. Temperature pod opterećenjem odu do 76°C, ali se vent manje čuje nego npr. kod EliteBook-a i7-8550U. U "normalnom" radu su ispod 40.
Najviše me iznenađuje što su grafiku uspjeli skrpati tak dobro u kernelu, na relativno novom proizvodu.
Zadnje izmijenjeno od: stef. 30.05.2021. u 11:24.
Staro 02.06.2021., 09:00   #1169
c-shadow
c-shadow's Avatar
Postovi: 3,491
Bilo već više puta rasprava oko SSDa na linuxu i mount opcija discard, povremenog fstrima itd...
Imam u jednom relativno slabo opterećenom stroju Crucial MX500. Kako mene ponekad pere OCD oko nekih sitnica, imam neki servis dignut koji sa svih diskova po svim strojevima doma trpa u bazu SMART statuse
Pa sam malo izvukao statistiku za taj MX500.
Stare i prethodne serije imale su čak i bugova oko pretjeranog write amplificationa za što je micron izdavao novi firmware, a dosta se usera žalilo da se prebrzo troše, npr:
https://forums.tomshardware.com/thre...itten.3571220/
https://forums.anandtech.com/threads...-ssds.2576727/
Dakle, na tom disku, ext4, noatime i default commit interval koji je 5s.
Standardni ubuntu tjedni timer za fstrim, stroj je upaljen 24/7.
SSD za 6 mjeseci rada ima u smartu oko 1.8TB writes, ext4 kaže Lifetime writes=1.5GB, SSD Life Left SMART atribut je 97%, znači nekakvo prosječno trošenje, ništa zabrinjavajuće, sasvim u okviru predviđenog trajanja. Vrti se neka virtualka gore, neki logovi s routera, UPSa itd. idu na to računalo, nema puno velikih writeova.
Ono što je zanimljivo je da sam nakon nekog vremena ubacio commit=60 i premontirao tu particiju.
Rezultat na Write amplification factor je zanimljiv, na grafu to je bilo nešto prije 1.3. Faktor je računat po Crucialovoj formuli dostupnoj ovdje. Dakle, produljenjem commit intervala trenutno je zaustavljen rast WAF koji je dotada dosta strmo rastao
Tijekom druge polovice intervala testirao sam i discard opciju na jedno mejsec dana i u mojem slučaju nema apsolutno nikakvog utjecaja.
Zato se ovaj commit=10 izgleda jako dobro odrazio na WAF tako da ostavljam to do daljnjeg kao opciju.
Iako se disk po svim parametrima ne troši previše, bolje je koliko se može produljiti vijek trajanja, zar ne
Staro 07.06.2021., 21:06   #1170
mkey
Lokacija: tu
Postovi: 3,544
Jedno pitanjce vezano za podršku za viši refresh rate, u mom slučaju 144Hz. Koji desktop odabrati (a da nije gnome )?
Moj trenutni desktop cinnamon uopće niti ne daje opciju, a kamoli da podržava taj refresh rate.
Probao sam live Feroda 34 workstation - Gnome 40 ima postavku za 144Hz pod display i očito to radi kako treba. Jedino što nisam fan gnoma a za sada koliko vidim nema niti dark temu.
Probao sam i Garudu dragonized/gaming. Desktop ima postavku ali ja razliku između 60/144Hz ne uspijevam vidjet s tom ekstremnom animacijom kakovu su ugurali tamo. Neon style mi je skoro OK, ali moram malo vremena provesti s time da vidim može li se to malo normalizirati.
Probao sam još nekoliko kombinacija, Mint 20.1 Mate, Mint debian Cinnamon, MX 19.3 te možda još pokoji, i dok (svi?) nude postavku, refresh rate očito nije podržan kako spada.
Moguće da je problem i u tome što sam pokušao u live, bez instalacije. Svi savjeti dobrodošli.
