Staro 16.04.2021., 10:05   #241
E-mil
Oppa Gangbang Style
E-mil's Avatar
Postovi: 1,763
Znači zaključak bi bio, uzeti i5-10400 + neku B560 ploču (ili ipak nešto iz generacije prije)?
Koja je uopće razlika izmedju B560 i H570? Gledam u HGSpotu slične cijene, oko 950 kn.
E-mil je offline   Reply With Quote
Staro 16.04.2021., 10:16   #242
Postovi: 8,228
Nove 500 serije ploče podržavaju RAM OC opcije, dok prijašnje to nisu nudile, a sve ostalo je stvar opreme i kak kome odgovara.
Staro 16.04.2021., 10:18   #243
Mladenxy
Mladenxy's Avatar
Postovi: 4,336
Nemaš nikakve koristi od B560 i desete generacije procesora, pogledaj video koji sam stavio, čak ni memoriju ne možeš dizati preko 2666 mhza, imaš jedan M.2 slot, nemaš pcie 4.0.
Staro 16.04.2021., 11:39   #244
Postovi: 8,228
Iskreno, koji god procesor da stavi, to je mrtva platforma, jer čak i Rocket Lake nativno nudi samo jedan NVMe PCI-E 4.0, dok je uopće upitno tko će ionako skupe Gen4 diskove stavljati na budžet platformu.
EDIT:
In this review we check out the cheaper (Core i5-11400F) 6-core part; it has a 4.2 GHz All core turbo tied to a 65W TDP, however, it is possible to alter these power limits as PL1 and PL2 states are not considered "overclocking" by Intel, and that means you'll see a lot of varying performance on the several motherboard brands. Core i5-11400F has 6-cores/12-threads clocked at 2.60 GHz, with an up to 4.40 GHz Turbo Boost and 4.2 GHz all-core boost. This mainstream processor lacks Boost 3.0, Thermal Velocity Boost, and Adaptive Boost. Each core has a 512 KB dedicated L2 cache, and the cores share 12 MB of L3 cache. Intel gives the Core i5-11400F a little additional leeway. PL2 is 154 watts for 28 seconds. Then, according to the specifications, a brake is applied going back to PL1 with 65 watts. The reason why we tested with motherboard optimizations enabled is that the Achilles heel of the 1400F is the all-core base and turbo clock,. That base clock will lower itself to 2600 MHz on all cores to stay in line with the 65W TDP. We've seen immensely different results in our Z590 motherboard reviews. Settings like power duration and all-core frequency vary per board and brand.
Izvor: Guru3D
Zadnje izmijenjeno od: The Exiled. 16.04.2021. u 15:34.
Staro 16.04.2021., 16:28   #245
Starsylph
Datum registracije: Oct 2010
Lokacija: Sfera
Postovi: 408
Autor MadBoY Pregled postova
Ne računaj previše na bolju dostupnost. Alder Lake dolazi krajem godine, nema smisla proizvesti hrpu Rocket Lake procesora kad će uskoro trebati uvaliti novi procesor, matičnu i RAM . Ovo je izašlo samo da Intel može na prezentaciji rekordnih zarada reći da imaju novi procesor i da su opet "gaming king", barem prema njihovim mjerilima .
Nisam posve siguran da će alder lake doći ove godine. Možda zen3+ ove, alder lake sljedeće.
Starsylph je offline   Reply With Quote
Staro 16.04.2021., 16:32   #246
Postovi: 8,228
Stiže sigurno ove godine (1 - 2), jer Intel već užurbano radi na pripremi i promociji. Još Rocket Lake nije stigel kak spada, ovi su već počeli gurati Alder Lake.
Staro 19.04.2021., 13:51   #247
Mladenxy
Mladenxy's Avatar
Postovi: 4,336
i5 11400f nema ni za lijek...vele majstori da nebu ničega cijele godine.
https://www.pcgamer.com/intel-and-ts...022-or-beyond/
Staro 19.04.2021., 14:14   #248
Postovi: 8,228
Š.O.K._i_V.J.E.V.E.R.I.C.A.
I još ih k tome muče isti problemi s ABF materijalima ko i sve ostale ...
Intel has been reporting substrate shortages to key partners all last week. Intel’s Q1 allocations for Rocket Lake are still pretty good, so the SKUs have been available for at least a couple of weeks, if not longer, near MSRP and still will be. So if you are planning to buy a RKL CPU, you certainly shouldn’t wait too long, because it won’t get any cheaper for a while. More expensive at most. The reason: unfortunately, Q2 allocations for Rocket Lake will be hit hard due to the substrate shortage. Since Core i9 is prioritized, Core i7 and Core i5 should be the most affected.
Izvor: Igor's Lab
Staro 19.04.2021., 16:42   #249
Mladenxy
Mladenxy's Avatar
Postovi: 4,336
Ak bu tak onda je početna cijena za i5 11400F čisti marketing, da se ima o čemu pisati. Ali pričekajmo i vidimo...
Staro 19.04.2021., 16:45   #250
Postovi: 8,228
Ma cijeli Rocket Lake je da se ima o čemu pisati, klasičan Intel marketing, mada su mogli to komotno preskočiti, kak smo i već komentirali na ovakvim temama. Core i5-10400(F) i Comet Lake društvo su sad ulov samo takav.
Staro 19.04.2021., 18:04   #251
MadBoY
MadModerator
MadBoY's Avatar
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
Vjerujem da će i 10400(F) uskoro biti nemoguće kupiti, tog sad ima samo zato jer su ih naštancali hrpu pa imaju velike zalihe. Ako im fali ABF-a, onda će to usmjeriti sve na Alder Lake, da imaju dovoljno komada za prodati kad izađe.
Staro 19.04.2021., 19:13   #252
Odinarius
All-rounder
Datum registracije: Sep 2013
Postovi: 1,320
Diy desktop je uvijek zadnji u svakom redu prioriteta. Prvo serveri pa laptopi, pa OEM, za desktop što ostane.
Odinarius je online   Reply With Quote
Staro 19.04.2021., 19:36   #253
Upravo to. Rocket Lake je ništa drugo nego promo materijal te da se dioničarima malo prezentira "nova" arhitektura koja je vrlo odlična i "bolja" od konkurencije.
i7 i i9 odroni samo takvi, a cijeli lineup od 8-10 (il koliko već) SKUova ovisi o jednom 11400F modelu. Ajd i i5 11600K nije loš iako za njega treba i ploča od 2000+ kn da bi radio kak se spada što nikako više nije buđet opcija.
I opet se vraćamo na ono kaj smo pričali pred 10tak dana - kome TREBA 11400F za igre i drkarenje po doma, neka ili uzme 10400F ili čeka Alder Lake. A ako baš ne može bez PCI Gen4 i bržeg RAMa, onda pregrist i uzet omraženi AMD gdje za 5600X može bez problema proći ploča do 1000 kuna i jedan i drugi su mrtvi socketi i zadnje što DDR4 bude vidio.
Tako da Mladenova teorija o prodaji na vagone baš i nije zaživjela :/
Staro 19.04.2021., 19:44   #254
Mladenxy
Mladenxy's Avatar
Postovi: 4,336
Barem dva vagona će prodati, tako da je.
Staro 19.04.2021., 19:45   #255
Javi tu kad popišeš sve prodane primjerke.
Staro 19.04.2021., 19:46   #256
Mladenxy
Mladenxy's Avatar
Postovi: 4,336
Može, čekamo rekordne zarade za početak.
Staro 19.04.2021., 19:48   #257
Kaj god te Mladene veseli, bitno da te ne boli.
Staro 19.04.2021., 19:53   #258
Mladenxy
Mladenxy's Avatar
Postovi: 4,336
Sobzirom da sam BSOD vidio zadnji puta 2003. ništa me ne boli
Staro 19.04.2021., 19:54   #259
Također, tamo negdje socket 370, možda 478
Staro 19.04.2021., 19:56   #260
Mladenxy
Mladenxy's Avatar
Postovi: 4,336
Ne stigneš ni vidjeti kad ih mijenjaš ko čarape
Staro 19.04.2021., 20:35   #261
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,747
Autor Brko Pregled postova
Sve stoji druze, samo ne znam jel to 100% sigurno... Sudeci po zadnjim leakovima i dostupnim informacijama na netu, mislim da cemo vidjeti jos jedan uarch na AM4, refresh zena3, tzv. zen3+ tj. Warhol. AFAIK, poslije toga se sa zen4 ide na novi AM5 socket, Ddr5, pci-e5 itd... Za Intel me ne cudi previse iako ne znam dal je to sluzbeno potvrdjeno...
Staro 19.04.2021., 20:42   #262
Postovi: 8,228
Za Intel je službeno, nemaju ništa do Alder Lakea koji je LGA-1700 + DDR5 platforma i valjda da mogu, danas bi ga izbacili, a za AMD se nadamo (potencijalom) Zen 3+ osvježenju.
Staro 19.04.2021., 22:06   #263
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,584
Ništa, kupujte. Svejedno i5 10400f ili i5 11400f dok ima po ovim cijenama, jel bi kasnije moglo biti kmečanja
Staro 19.04.2021., 23:23   #264
gin.tonic
gin.tonic's Avatar
Postovi: 2,434
Dobro govori kolega, brzo odlaze i cijena im se digla
gin.tonic je offline   Reply With Quote
Staro 20.04.2021., 14:31   #265
Odinarius
All-rounder
Postovi: 1,320
Autor Sn4k3 Pregled postova
Da, Tom sa MLID je to spominjao, da Zen3+ ostane na AM4 koji onda nije mrtva platforma. Iznenadilo me, ali sve je moguće.
Staro 20.04.2021., 15:06   #266
Postovi: 8,228
IMHO, pošto raspravljamo o tome zajedno s Rocket Lakeom, već minimalno godinu dana, pa u slučaju da AMD stvarno izbaci Zen 3+ koji još k tome ima hibridni DDR4/DDR5 IMC, pa kasnije može na novi socket - bog-bogova kaj se poteza tiče.
AMD carefully engineered its AM3 memory controller allowing it to operate in both DDR2 and DDR3 modes. Any AM3 CPU can thus work in either a Socket-AM3 motherboard with DDR3 memory, or in a Socket-AM2+ motherboard with DDR2 memory. Next month, AMD will launch the first Socket-AM3 Phenom II processors. The main difference here is that these parts will support DDR3 memory. Oh no, another socket, right? Wrong. Socket-AM3 Phenom II parts will also work in Socket-AM2+ motherboards, the two are pin-compatible. When in an AM2+ board, these upcoming Phenom II processors will work in DDR2 mode, but when in an AM3 board they will work in DDR3 mode. How cool is that? AMD just needed a physical memory interface on Phenom II that could operate at both 1.8V (DDR2) and 1.5V (DDR3) as well as work with timings for either memory technology.
Izvor: AnandTech
Bilo bi super da opet istu stvar slože, ali ovaj put za aktualni AM4 i nadolazeći AM5 socket.
EDIT:
Zadnje izmijenjeno od: The Exiled. 20.04.2021. u 17:50.
Staro 21.04.2021., 05:17   #267
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,262
Pa imao sam ja Gigu p35c-ds3 koja je podržavala i DDR2(4 utora) i DDR3(2 utora) i radilo je sve uredno. Kasnije sam uzeo DDR3 prije prelaska na Sandy.
Slobodno me dodajte na PSN
Staro 21.04.2021., 08:28   #268
Postovi: 8,228
Da, bilo je raznih kombinacija, mada u ovom slučaju je dosta da izbace CPU seriju koja ima DDR4/DDR5 IMC, pa ovisno o ploči (AM4 ili AM5) se koristi određena memorija.
Staro 21.04.2021., 09:23   #269
Odinarius
All-rounder
Postovi: 1,320
Spomenuo Ian Cutress jučer da i Skylake ima DDR3 kontroler u sebi jer je prva generacija bila hibridna, danas se naravno ne koristi.
Staro 21.04.2021., 09:40   #270
Imao sam ga. i3 6100T + DDR3 SODIMM. I isti proc radi sa DDR4 SODIMM na drugoj ploči.
Za destop su bile H110 ploče ako se ne varam.
