Staro 01.03.2021., 16:39   #271
mann
mann's Avatar
Postovi: 2,219
Autor Nikky Pregled postova
Ima tu interesantnih stvari,
između ostalog izgleda da bi se mogao složiti multi_wan (hybridcfg - failback), može biti interesantno poslovnim korisnicima,
TR069 / remote ni ne treba rješavati osim ako se tako ne dogovorite sa ISP - om,
možda bi se moglo malo poraditi template da user vulgaris može lakše iz web konfiga podesiti ...
Nisam jos gledao ali fritz ima fallback na 3G / 4G u gui-u.
EDIT: U grubo ja vidim ovo kao bitne dijelove
vccs {
VPI = 1;
VCI = 32;
traffic_class = atm_traffic_class_UBR;
pcr = 0;
scr = 0;
priority = 0;
dsl_encap = dslencap_mixed;
ipbridgeing = no;
ipbridgeing_igmp = no;
pppoeforwarding = no;
connections = "internet", "voip", "tr069", "iptv";
Odmah ispod vccs
mcupstream = "iptv";
dok je internet interface
is_mcupstream = no;
nakon toga voip int
enabled = yes;
name = "iptv";
weight = 50;
dsl_encap = dslencap_ether;
dslinterfacename = "dsl";
no_masquerading = no;
use_fixed_masqaddr_if_no_masquerading = no;
no_firewall = no;
stackmode = stackmode_ipv4only;
pppoevlanauto = no;
pppoevlanauto_startwithvlan = no;
vlancfg {
vlanencap = vlanencap_tcom;
tagtype = vlantagtype_customer;
vlanid = 1500;
vlanprio = 2;
tos = 0;
ppptarget = "iptv";
rfc4638_enabled = no;
fixed_masqaddr = 0.0.0.0;
mtu = 0;
gre_server_cfg {
server_dnsprefer = protoprefer_ipv4;
dpd {
inactivity = 20s;
replywait = 1s;
npings = 4;
period = 30s;
allow_netbios = no;
etherencapcfg {
use_dhcp = yes;
use_dhcp_if_not_encap_ether = no;
ipaddr = 0.0.0.0;
netmask = 0.0.0.0;
gateway = 0.0.0.0;
dns1 = 0.0.0.0;
dns2 = 0.0.0.0;
class_identifier = "fritz7590";
is_mcupstream = yes;
stay_always_online = yes;
disable_ondemand = no;
reconnect_delay_after_conn_abort = 30s;
only_route_when_connected = no;
redial_delay_after_auth_failure = 1m;
redial_limit = 3;
redial_after_limit_reached = 10m;
redial_after_limit_reached_variance = 5m;
redial_after_limit_randomize = no;
redial_delay_after_low_error = 10s;
redial_delay_after_ppp_timeout = 10s;
redial_delay_after_ppp_error = 1m;
routes_only_for_local = no;
dproutes_only_for_local = no;
hide_interface_address = no;
disable_staticroutes_on_dhcproutes = no;
ripv2receiver_enabled = no;
ripv2_update_timer = 30s;
ripv2authmode = ripv2_auth_none;
ripv2md5_keyid = 0;
ripv2passwd = "";
set_replicate_dhcpoptions_in_parameter_request_list = no;
unset_ignored_dhcpoptions_in_parameter_request_list = yes;
dsldpconfig {
security = dpsec_firewall;
filter_teredo = yes;
filter_netbios = yes;
filter_sip = no;
filter_smtp = no;
sip_alg = no;
lowinput {
policy = "permit";
lowoutput {
policy = "permit";
highinput {
policy = "permit";
highoutput {
policy = "permit";
dhcp_auth_mode = auth_none;
dhcp_requests_with_client_id = yes;
dhcp_ignore_options_in_renewing = no;
is_erouter = no;
fakepacm = no;
dhcp_tr069_add_device_vendor_options = no;
use_random_macaddr = no;
arp_reply_for_any_net_enabled = yes;
Zadnje izmijenjeno od: mann. 01.03.2021. u 16:56.
mann je online   Reply With Quote
Staro 01.03.2021., 18:04   #272
Olymp
Datum registracije: Mar 2009
Lokacija: U svemiru
Postovi: 17
Thumbs up ...slažem se
Ali i dio ovog ("nqos", "bridges", "classifiers"):
Code:
nqos {
        version = 15;
        macaddr_whitelist_enabled = no;
        bridge_with_switch_separation = yes;
        bridge_lp_mode = -1;
        patch1TR114 = no;
        defaultresult {
                tos = 0;
                vlan_prio = -1;
                queueref = "default";
        appls {
                enabled = yes;
                name = "sip-appl-toi";
                protocol = qos_classifier_appl_sip;
                result {
                        tos = 184;
                        vlan_prio = 6;
                        queueref = "hrealtime";
                enabled = yes;
                name = "sip-appl";
                result {
                        tos = 0;
                        vlan_prio = -1;
        bridges {
                enabled = yes;
                name = "iptvbridge";
                ident = "vcc:0";
                vlancfg {
                        vlanencap = vlanencap_fixed_prio;
                        vlanid = 1500;
                        vlanprio = 2;
                        tos = 0;
                disable_igmp_fwd = no;
                with_pppoe_bridging = no;
                enabled = no;
                name = "voicebridge";
                ident = "vcc:0";
                vlancfg {
                        vlanid = 1405;
                        vlanprio = 5;
                        tos = 0;
        classifiers {
                enabled = yes;
                name = "STB1";
                type = qos_cfg_hidden;
                iface = qos_lan;
                rule = "dhcpoption 60 HT_STB_* STB";
                result {
                        tos = -1;
                        vlan_prio = -1;
                        bridgeref = "iptvbridge";
obzirom na nemogućnost podešavanja istog preko GUI-a, uspoređujući s dostupnim ar7.cfg na netu!
Olymp je offline   Reply With Quote
Staro 01.03.2021., 21:25   #273
Olymp
Lokacija: U svemiru
Postovi: 17
Lightbulb Nadogradnja firmwarea
Zna li tko što se desi prilikom službene nadogradnje firmwarea?
Ostaje li postavljena modificirana konfiguracija?
Čisto da i to spomenemo.
Staro 01.03.2021., 22:33   #274
Postovi: 23,523
Upgrade na novi fw bi trebao proći ok,
neki zez se može desiti jedino ako neki dio ključno izmjene.
Staro 01.03.2021., 23:11   #275
Karlo666
Karlo666's Avatar
Datum registracije: Oct 2010
Lokacija: Kaštel Lukšić
Postovi: 1,569
Autor Olymp Pregled postova
Sve bude kako si složio samo sačuvaj config file prije FW upgradea.Zna se nekad dogoditi da proizvođač sakrije neke stvari u GUI na novijem FWu a stari config ga ponovo prikaže(tipa kako ti radi IPTV na TCom configu iako ti i dalje nevidiš GUI element).
Nezaboravimo da treba uraditi FactoryReset nakon FW Upgradea.
Recimo ja nisam htio uraditi DSL-AC68VG FactoryReset nakon FW upgradea nakon par sati bi refuseao konekciju na GUI.
Pošten trgovac:
1,2,3,
Staro 02.03.2021., 08:40   #276
Olymp
Lokacija: U svemiru
Postovi: 17
Moram priznati da nisam još čuo (a ni pročitao) da se nakon FW upgrade-a mora odraditi Factory Reset!
... možda si mislio na soft (warm) reboot? To je sasvim dovoljno osim ako autor FW ne naglasi drugačije.
Obično nakon FW upgrade-a i ide reboot po zadanom.
Prije nadogradnje, backup se svakako treba odraditi!
Zadnje izmijenjeno od: Nikky. 02.03.2021. u 11:24.
Staro 02.03.2021., 11:37   #277
Postovi: 23,523
To šta nisi čuo ne znači da ne treba
Poanta i razlika između factory reset i reset vulgaris je da (neka skripta koja se inače ne pokreće) postavi default parametre,
obično se nalaze u "nvram" sekciji (ona koja se ne briše sa gašenjem). Ako neki parametar nije postavljen ili je krivo postavljen onda može biti problema.
Nije za istu svrhu (a može pomoći), u konfigu se spremi fw verzija (u gornjem primjeru od Fritz - a ima) može se pri importu konfiga pokrenuti neka druga skripta da odradi "šta treba" ako je potrebno.
Staro 02.03.2021., 12:23   #278
Olymp
Lokacija: U svemiru
Postovi: 17
Post
... kao što sam spomenuo ranije (čuo, pročitao), govorim iz osobnog iskustva nadograđujući firmware na raznim uređajima (nije ih bilo previše doduše ali bilo ih je), no ne bi li autor FW to naglasio ranije ili obavijestio nakon nadogradnje ili čak prilikom samog preuzimanja?
Smatram da bi ali i bez obavijesti ili spomena u dokumentaciji, odradio potrebne korake kako bi se nadogradnja uspješno završila i uređaj nakon toga radio ispravno i bolje (tome bi trebao služiti svojevrstan "upgrade")!
Slažem se da uslijed nepravilnog rada ili raznih drugih problema u radu ili slicno ("bug"), nakon nadogradnje FW, nakon što se ostali pokušaji rješavanja eventualnih problema iscrpe, može odraditi postavljanje tvorničkih vrijednosti (Factory Settings, "Factory Reset").
"Factory Reset" (Factory Settings) = postavljanje tvorničkih vrijednosti i ponovno pokretanje uređaj (da ne ulazimo u detalje).
Za vrijeme FW nadogradnje, po proceduri, obično, uređaj se ranije postavlja na tvorničke vrijednosti pa nakon završetka nadogradnje nije potrebno ponovno "ručno", od strane korisnika, dodatno pokretati (Factory Settings iliti Factory Reset)!
"Reset" = postavljanje zadanih vrijednosti i ponovno pokretanje uređaj (da ne ulazimo u detalje). (recimo, preuzimanje vrijednosti iz konfiguracijskih datoteka i ponovno postavljanje pa zatim ponovno pokretanje -da ne ulazimo u detalje).
"Reboot" iliti "Restart" = ponovno pokretanje uređaja bez gašenja ("opcionalno" poduzimanje dodatnih radnji, clear_logs, itd.).
...moguće
..."one more thing"
Na kraju krajeva, ne želiš nakon nadogradnje ponovno postavljati uređaj već se što prije koristiti njime, ili ...
Također, koliko je postavljanje, nakon nadogradnje, uputno "vraćati" iz backup-a, nećemo raspravljati. Iskustva su razna.
Osobno, više volim sve "from scratch", iz nule, ali ponekad to iziskuje jaaako puno vremena i volje, a kažu da je vrijeme novac, volje ponekad manjka, a ja toliko novca nemam, a ni volje
Zadnje izmijenjeno od: Olymp. 02.03.2021. u 14:23. Razlog: ... adding space
Staro 02.03.2021., 23:48   #279
Karlo666
Karlo666's Avatar
Postovi: 1,569
Factory Settings i Factory Reset nisu ista stvar.
Pošten trgovac:
1,2,3,
Staro 03.03.2021., 00:34   #280
skalar
skalar's Avatar
Datum registracije: Apr 2015
Postovi: 1,699
iskonov 7590 i nakon nadogradnje ostaje brendiran na iskon -znaći nadogradnje može ,vračanje na staru verziju nemože trebalo bi imat baš recovery file za iskon,navodno uljudnim mailom avm-u (proizvođaću) bi se mogao dobiti,jer ako nešto krivo krene, bez tog fila -"banana" odnosno servis kojeg i nema u hr ,uploadom t-com config ,router postaje brendiran na tcom -nestaje upgrade ,nadogradnja se vrši na sljedeći način-
1. skidanje novog firmwarea sa ftp-a avm
2. vračanje na tvorničke postavke( vraća se na iskonov brend i moguća je nadogradnja)
3. učitavanje novog firmwarea_( nije potrebno ponovno učitavanje tvorničkih potavki dosad je radilo ok bez toga)
4. učitavanj config fila
napomena iz mog iskustva nadogradnju je najbolje vršiti kad je komp direktno spojen
sa routerom ,preko swicha zna trajati beskonačno.
u tcom config filu ispod postavki ima cijeli roman codiran i izgleda ima veze s tim da sve tri usluge rade bez problema - bez toga 7590 prepoznaje tri usluge ali nemože ih aktivirati,po avm bi trebalo biti moguće ručno složiti iptv(maxtv) preko porta 3-4 ali za to
je potrebno imati reciver kojem se u postavkama može odrediti na koji način može povući ip adresu -što sa samsungom nije moguće iz istog razloga neradi maxtv preko mesha 100%.
poslat ću danas mail avm-u(izgubiti se nema što) pa vidjeti dali imaju oni kakvo rešenje.
p.s( ono što mi je stvarno nije jasno je zašto t-com po pitanju nadogradnje nije išao putem iskona ionako nakon nadogradnje routeri ostaju brendirani i gotovo sam siguran da ono što radim sam doma isto to radi tehničar u centrali samo sa puno većom mogučnosti pogreške.
Staro 08.03.2021., 19:01   #281
Revlyne
Postovi: 45
User: adam2
Pass: adam2
unSetENV provider
(dakle, brišemo providera)
Quit / Exit
7. sada bi router trebao biti otključan za upgrade. Treba ponovno pokrenuti Recovery Tool sa koraka 1 i odraditi upgrade do kraja
8. Brand bi trebao nestati, ali jasno sa njim nestane i firmware, ali je router sada slobodan. Backup file-a settingsa bi trebao raditi.
Sretno
Autor skalar Pregled postova
Ne znam ako će pomoći za debrandiranje, ali možeš probati.
Obavezno napravi backup settingsa prije svega.
1. skinuti recovery file sa Friza (ovisno o modelu - preporuka je internatinal verzija): ftp://ftp.avm.de/fritzbox
2. skinuti Putty
3. spojiti Fritz sa LAN kabelom u LAN1 i pokrenuti recovery proces sa Recovery Toolom (iz koraka 1) i slijediti instrukcije dok nas ne obavijesti da update nije moguće napraviti jer je to provider onemogućio.
4. ne gasiti Recovery Tool i pokrenuti Putty
5. U Puttyju upisati IP adresu (istu onu koju je dao Recovery Tool), Port 21, Protokol Telnet i kliknuti Open
6. otvara se command prompt i upisati:
User: adam2
Pass: adam2
unSetENV provider
Quit / Exit
Sretno
Revlyne je offline   Reply With Quote
Staro 09.03.2021., 04:42   #282
skalar
skalar's Avatar
Postovi: 1,699
ne znam koliko čitam na novijim firmwerima je moguće debrandirati frizove routere, ali prilikom svakog restarta brand se vraća,
a kako prilikom svake promjene postavki se mora restartartat sam došao do zaključka da je jednostavnije vratiti na tvorničke postavke updatat i učitat config file, sa debrandiranjem nedobijamo slobodno rečeno -ništa.
bila bi druga situacija da su ht-ov i iskonov fw uključeni u internacionalnu verziju ali nisu kao što su većina ne njemačkih provajdera gdje se može nabaviti legalno fritz,
logika priće govori da je u firmwareu uključena adresa acs i onako sve postavke bi trebao od tamo pokupiti,
znači realno sigurnosni rizik nebi postajao u tom slučaju jer ih ionako imaju u svojoj ponudi,
jedini razlog je spriječavanje "slobodnog izbora routera", da se eto na mala vrata nebi fritz našao u slobodnoj maloprodaji u hr,
mada nisam baš siguran da bi se i jednom uvozniku isplatilo ih uvoziti s obzirom na broj zainteresiranih, ima nas možda par desetaka ovdje na forumu koji smo spremni investirati u routere ostatak korisnika u hr vjerojatno ni nezna što su routeri.
ovaj prijedlog od "Revlyne" bi itekako pomogao kad nešto krene loše u nadogradnji što se relativno često dešava jer 7590 nema reset gumb (resetira se preko telefona ili iz routera), a kad krivo krene ne možeš se spojit na router niti tel ne radi, treba recovery tool,
e a njega bi ili iskon ili avm trebali dat jer iskon ga prodaje pod totalno otključan router da ne zaboravimo.
Zadnje izmijenjeno od: Nikky. 09.03.2021. u 08:00.
Staro 09.03.2021., 22:26   #283
Karlo666
Karlo666's Avatar
Postovi: 1,569
Nećeš vjerovat čak i žestoki noobovi znaju šta su ruteri i znaju osnovne funkcije (tipa promjeni WiFi i slično).
Znam brat bratu bar 100injak kafića koji se koriste alternativom(sad da ih nenabrajam išli bi od DU do ZG) većina baci šrot u PPPoE passtrought Bridge i nakače neki bolji ruter. I sam znaš koliko puta djeca dođu ovdje na forum pa pitaju zašto nemogu otvorit portove za igre za PC/Konzole.
Većina ima samo Net+TV čak ako i imaju Telefon uopće ga niti nekoriste. Tipa neštko kao DSL-AC55U, DSL-AC750, Archer VR300 sjelo bi im ko budali pleska a nije niti skupo. A dali bi ga znali postaviti sami ja mislim da bi skužili jer ako znaju složit sami PPPoE Passtrough ne vidim razlog zašto nebi uz malo Googlanja?
Eno i moja tema o postavkama pomalo skače na Googlu za traženje a niti me ne čudi.
Imaš tipa kafanu u Kaštel Novome gdje je FritzBox nakačen direkt na liniju a ni traga ni glasa od SpeedŠrota.
Šta nakraju znači da ljudi žele i znaju samo što ovi na SZK poučeni svojim neznanjem i/ili naredbom od vrha vrbuju da se ne može.
Pošten trgovac:
1,2,3,
Zadnje izmijenjeno od: Nikky. 10.03.2021. u 11:13.
Staro 10.03.2021., 09:14   #284
mann
mann's Avatar
Postovi: 2,219
Ma ja ne kuzim jednu stvar, neka se ISP ograde od third party opreme. Neka kazu ne, mi ne vidimo nas ruter na vasoj liniji i ne mozemo vam pomoci. To je ok. Ali neka daju podatke koji trebaju a ne da ih skrivaju kao zmija noge. Cemu? Korisnik ako ne moze spojiti svoj ruter neka vrati ISP-ov i bok.
Reci lijepo, za voip vlan taj, za tv vlan taj, za internet taj. Type of service 0 / 2 / 5. To se jednom napise i bok bok. Ti to ne suportiras, samo si dao mogucnost. Iskon je otisao u dobrom smijeru jedino sto jos bas ne daje vlanove ali ok tome sluzi ovaj forum...
Staro 10.03.2021., 11:19   #285
Postovi: 23,523
Ma tu temu "zašto ne daju / sakrivaju podatke" smo vodili x puta, kao i nabrajali razloge ...
Staro 10.03.2021., 11:45   #286
mann
mann's Avatar
Postovi: 2,219
Ma da, na kraju nije ni bitno sto mi tu filozofiramo, bitno je sto tamo netko na poziciji odlucivanja u tht, a1,optima i slicno misli. No stajaliste iskona pozdravljam i podrzavam. Mali korak za iskon veliki za nas.
Staro 10.03.2021., 23:27   #287
Karlo666
Karlo666's Avatar
Postovi: 1,569
Krivo editano molim delete post
Pošten trgovac:
1,2,3,
Zadnje izmijenjeno od: Karlo666. 10.03.2021. u 23:41.
Staro 10.03.2021., 23:40   #288
Karlo666
Karlo666's Avatar
Postovi: 1,569
Autor mann Pregled postova
Šta ti vrijedi izjava "Eto spoji ti svoje" kad ti oped nežele dat potrebne podatke kao što su VLAN IDovi,MTU/MRU,priorityiji itd...
Da se odluče dogovorit s nekim kao tipa TPLink,Asus ili šta ja znan i da imaju sebe pod QuickSetup ili TR-069 za odabrani uređaj(nevjerovatno al i skupi TPLinkovi imaju TR-069) nikoga ovdje nebi bilo briga o bilo kakvim postavkama i ostalim pizdarijama al eto živimo na balkanu pa šta je tu je.
Ali nisu niti ISPovi toliko krivi koliko je kriv sam HAKOM koji ako išta radi jedva da napravi nešto oko sporova računa.
Ja sam im prije par mjeseci poslao prijedlog i zvao par puta i pojašnjavao a ti likovi meni kažu "A momak moj vidin da se dobro kužiš al ja ti to ništa neznam" šta znači stare ojebine rade u njih a ništa nerazumiju osim onoga ko je koga zajeba sa računima.
Al pazi ja njima pošaljem email čak im i dam linkove ovdje na forum gdje ekipa opisuje klasične i učestale probleme s ISP router opremom i onda ja dobijem ovakvi idiotski generički odgovor:
https://i.imgur.com/26gkafA.png
Pošten trgovac:
1,2,3,
Staro 11.03.2021., 07:38   #289
mann
mann's Avatar
Postovi: 2,219
Upravo zato pohvaljujem iskon, em su u pravilima rekli da mozes koristiti svoju opremu em su omogucili fritz. Oni su jedini koji su tako nesto u hr, da je meni poznato, napravili.
Staro 12.03.2021., 23:12   #290
skalar
skalar's Avatar
Postovi: 1,699
omogučili su fritz koji je brendiran na iskon,zvao danas službu za korisnike i velim dami treba recowery tool iskonov ,jer eto web shop koji mi ga prodao je rekao da je potpuno otključan roter prije prodaje,a nije i dolazi do problema kad nešto zapne jer traži eto baš iskonov recowery tool ,odgovor je bio da se obratim servisu-koji nepostoji u hrvatskoj jer eto router nije u slobodnoj prodaji,pa s toga nepostoji ni servis i nakon jednosatnog natezanja rečeno mi je da pišem pritužbu mailom webschopu.
Staro 13.03.2021., 21:43   #291
mann
mann's Avatar
Postovi: 2,219
Da firm je iskonov je ima prekonfigurirane dropdown postavke od Iskona. Ali je router full otvoren. Doduše čim firm nije int ti ne možeš samo tako pregaziti postojeći firm.
Što se desilo da ti treba iskon firm recovery tool?
Sent using Tapatalk
Staro 02.04.2021., 09:33   #292
skalar
skalar's Avatar
Postovi: 1,699
Desi se ponekad da se router s blesira prilikom nadogradnje i da ništa ne radi niti se možeš spojiti na njega,
s recovery toolom se to da riješiti u par sekundi, bez za sad traje čak i preko sat vremena da rooter dođe k sebi,
čisto iz predostrožnosti, zašto je taj recovery tool državna tajna kako kod iskona tako i kod t-coma,
to samo oni znaju.
Zadnje izmijenjeno od: Nikky. 02.04.2021. u 12:49.
Staro 06.04.2021., 07:07   #293
Karlo666
Karlo666's Avatar
Postovi: 1,569
Zar neradi onaj emergency IP http://169.254.1.1 kojeg AVM navodi na stranici?
Sent from my Nexus 6P using Tapatalk
Pošten trgovac:
1,2,3,
Staro 06.04.2021., 09:53   #294
skalar
skalar's Avatar
Postovi: 1,699
Neradi, orginal recovery tool ti kaže da ti je router brendiran i da nema dalje,
iz podrške iskona mi kažu da ga trebam odnijet na servis kojeg nema u hrvatskoj,
na svu sreću router je nakon sat vremena došao k sebi,
sve me strah ako rikne u garantnom roku što ću onda morat radit da mi ga zamjene.
Zadnje izmijenjeno od: Nikky. 06.04.2021. u 13:32.
Staro 06.04.2021., 12:46   #295
mann
mann's Avatar
Postovi: 2,219
Ima ona fora da ga prebacis na international sa:
quote SETENV firmware_version avme
quote REBOOT
Pa ga onda flashas sa international verziom. Postoji na internetu procedura ali srecom nisma imao potrebu pa je nadam se ni necu isprobavati.
P.s. Dali radi rukernel sa 7590?
Staro 12.04.2021., 12:34   #296
skalar
skalar's Avatar
Postovi: 1,699
n svim roterima avm fw 7+ možeš debrandirat ali nakon restarta ti se vraća brand,a kako moraš restartat da bi ti primio debrand -uzalud ti trud,kao što rekoh nije problem nadogradnja nego vračanje,recimo staviš labor(beta) fw i nešto s njim neštima nemožeš vratit na redovnu verziju jer eto vraća se recovery toolom koji mora biti iskonov u ovom slučaju ,spremanje fw isto ne funkcionira ko fail je prevelik.
Staro 12.04.2021., 14:41   #297
frezer
frezer's Avatar
Datum registracije: Jan 2018
Postovi: 504
Neće. Ni sa 74xx isto ne radi.
Što se tiče ovoga, provjereno radi na 7490. Prebacivao jedan njemački.
"Switch your PC to a fixed IP in the 192.168.178.0 network. Disconnect the FritzBox from the mains. Make sure nothing else but your PC is connected to the Fritz!Box (however is some cases it can help to have a switch between the Fritz!Box and your PC). Open a MS-DOS Window and type ftp 192.168.178.1 (wait for the Enter). Connect your FritzBox to the mains, and try to connect to the FTP server. It may take you several trials and errors to catch the correct time-frame. Once connected to the FTP server, login with adam2/adam2. Now type exactly the following lines:
quote REBOOT
The Fritz!Box will reboot now, and goes into an endless reboot loop. It looks like the FritzBox is broken. No panic, this is normal behaviour: the German Firmware will not load because we changed the "firmware_version" to avme Now you can start the international recovery program and follow the instructions on your screen. Do not forget to reset your PC to a dynamic IP (if needed)"
Zadnje izmijenjeno od: frezer. 12.04.2021. u 14:53.
frezer je offline   Reply With Quote
Staro 20.04.2021., 12:47   #298
skalar
skalar's Avatar
Postovi: 1,699
jedina pozitiva kod iskonovih fritzboxrova je da nisu sakrili update gumb i da možeš sam nadograditi fw kad ga amv izda, što naravno nije beznačajno,
ali nije tako da recimo kupiš negdje vani i da će ti odmah sve raditi na iskonu, fali spajanje na acs i to iz razloga što ni iskonov ni t-com-ov fw nisu dio internacionalnog i to po meni iz nekih čudnih razloga,
jer vjerojatno bi ih manje koštalo da ga jednom uključe u internacionalni, nego da za svaku verziju plačaju da ju prepravljaju samo za njih,
vjerojatno bi im amv to i besplatno napravio jer bi to za njih značilo širenje tržišta, vjerojatni razlog je zadržavanje monopola u izboru opreme prema korisniku,
svi tehnički argumenti po meni padaju u vodu jer eto i najeftiniji kupljeni router radi bolje od t-comovih a i tehička podrška je u dosta slučajeva bolja od sevisa nego od t-coma.
Zadnje izmijenjeno od: Nikky. 20.04.2021. u 13:02.
Staro 20.04.2021., 16:50   #299
Karlo666
Karlo666's Avatar
Postovi: 1,569
U zadnje vrijeme vidim da TCom gura FRITZ!Box 6890 LTE (koji da ga idete sami nabaviti dođe preko 3000 HRK) sa Repeaterom FRITZ!Repeater 1750E a dosad viđeno na 5 mjesta
Žalosno je što ekipa niti nepodesi passworde niti išta a imaju širom otvoren GUI.
Prije cca 2 mjeseca ta ista mjesta su imala stari SpeedŠrot/ZTE ZXDSL 931VII a SpeedPort Pluseve i dalje postavljaju valjda se ljudi nebune toliko na onaj 5Ghz WiFi bug.
Pošten trgovac:
1,2,3,
Staro 21.04.2021., 21:29   #300
Deno
Deno's Avatar
Datum registracije: May 2009
Postovi: 79
6890 LTE je samo za poslovne korisnike i placa se mjesecno oko 50kn ovisno o tarifi koju korisnik ima.
Deno je offline   Reply With Quote
