Staro 15.02.2021., 20:16   #31
Nbdy32
Datum registracije: Aug 2016
Lokacija: Bestovje,Sv.Nedelja
Postovi: 2,821
Vrlo je zanimljivo da te stvari mi se nisu događale sa tim 3xx verzijom drivera ...
Znam da su stari ... preporuka ???... inače drivere sam na sedmici maknuo sa ddu-om i instalirao par verzija 4xx drivera i stalno mi je znao negdje zapeti ...
Staro 15.02.2021., 20:51   #32
domy_os
domy_os's Avatar
Postovi: 18,851
Autor Nbdy32 Pregled postova
Da upravo sam je ažurirao ...
Sa 1060 mi je došao CD sa 3xx driverima,kad sam updejto i na sedmici na 45x drivere,isto mi je znao krešat ...
Di točno nađem logove ...
Minidumpom ???
EDIT :
U minidump folderu nema ništa ...
Event Viewer pogledaj, u minidumpu će ti biti zapisi BSoD-ova, a njih (zasad) nemaš.
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 15.02.2021., 21:42   #33
Nbdy32
Postovi: 2,821
Fault bucket LKD_0x141_Tdr:6_IMAGE_nvlddmkm.sys_Pascal, type 0
Event Name: LiveKernelEvent
Response: Not available
Cab Id: 7c361263-7574-4c6c-8499-d387d3836b49
Problem signature:
P1: 141
P2: ffffc184a77cf010
P3: fffff8052defc188
P4: 0
P5: 4
P6: 10_0_18363
P7: 0_0
P8: 256_1
P9:
P10:
\\?\C:\Windows\LiveKernelReports\WATCHDOG\WATCHDOG-20210215-1718.dmp
\\?\C:\Windows\TEMP\WER-747859-0.sysdata.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER75B7.tmp.WERInternalMetadata.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER75B8.tmp.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER75C8.tmp.csv
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER75D9.tmp.txt
\\?\C:\Windows\Temp\WERB476.tmp.WERDataCollectionStatus.txt
These files may be available here:
\\?\C:\ProgramData\Microsoft\Windows\WER\ReportArchive\Kernel_141_ac5aaf0795ebe9b8ae1dbd6c13f7ccc326e8e4_00000000_cab_dd9c1143-9031-4a69-a0e1-7805371bc121
Analysis symbol:
Rechecking for solution: 0
Report Id: dd9c1143-9031-4a69-a0e1-7805371bc121
Report Status: 268435456
Hashed bucket:
Cab Guid: 0
Staro 15.02.2021., 23:05   #34
medo
#erase startup-config
medo's Avatar
Postovi: 3,699
Pa ti instaliraj desetku, a na sedmici sve radi. Gdje je sad onaj tko ti je rekao da se skoncentriraš da ti riješi problem
nVIDIA fuša s driverima već dulje vrijeme. Čini mi se da su im performanse u igrama u fokusu, a stabilnost je manje bitna. Imam skoro 2god star driver na svojoj sedmici jer radi i ne updateam ga do daljnjega. Sa verzijama prije sam imao problema s DisplayPortom, a novije ne želim isprobavati.
Staro 15.02.2021., 23:40   #35
domy_os
domy_os's Avatar
Postovi: 18,851
Našao sam neke teme, ništa pametno, i da je i da nije do grafe i drivera. Ako je s Windows 7 normalno radilo, onda moraju biti ili driveri ili Windowsi.
https://www.nvidia.com/en-us/geforce...kmsyspascal3d/
https://www.bleepingcomputer.com/for...e-nvlddmkmsys/
https://www.techsupportforum.com/thr...m-sys.1162089/
https://www.windows10forums.com/thre...mkm-sys.10872/
1060 podržava Feature Set H, znači podržava sve osim AV1 decodinga. Možeš probati forsirati određeni format videa preko add-ona tipa enhanced-h264ify za Firefox i Chrome pa u njemu odabrati da blokira sve codece osim h264 i 60 fps videa.
https://github.com/alextrv/enhanced-h264ify
Staro 16.02.2021., 06:54   #36
Nbdy32
Postovi: 2,821
Ma nisam prezahtjevan što se tiče te grafe,ili čitajte ne igram se uopće,samo sam htio da kad je već 8600K unutra bude i neka solidna grafa ... :-)
Vraćam stare drivere sad koji dan,pa ću vidjeti jel će biti OK ...
