Staro 18.12.2020., 07:35   #451
Immortalis
Slobodan leni seronja
Immortalis's Avatar
Postovi: 852
A konacno, ovo cekam 3 godine...
Staro 08.01.2021., 15:22   #452
BusMaster
BusMaster's Avatar
Datum registracije: Apr 2017
Postovi: 343
AMD 32-Core EPYC "Milan" Zen 3 CPU Fights Dual Xeon 28-Core Processors
Link: https://www.techpowerup.com/276932/a...ore-processors
https://www.tomshardware.com/news/am...specifications
Staro 13.01.2021., 14:05   #453
BusMaster
BusMaster's Avatar
Postovi: 343
AMD’s Ryzen Threadripper Pro CPUs & WRX80 Motherboards Coming To Consumer Segment in March 2021 – 64 Cores, 128 PCIe Lanes & 8-Channel Memory
Link: https://wccftech.com/amds-ryzen-thre...ch-march-2021/
Dobra vijest za "power usere" i konačna brukva u kaspsu za Intel Hedt (ako takvo nešto još postoji)..))
Staro 13.01.2021., 14:09   #454
Lewis
Freelancer
Lewis's Avatar
Lokacija: Bilje (Osijek)
Postovi: 5,297
E, TO te ja pitam, napokon workstaion ploce sa 7 slotova .
Njamiiii
Staro 13.01.2021., 19:13   #455
Psycho
Master Of Disaster
Psycho's Avatar
Datum registracije: Nov 2002
Postovi: 1,268
Autor Lewis Pregled postova
Njamiiii
Kako ces spojiti sve 3090ke na to? Riseri i tri 1.2kW napajanja?
Staro 13.01.2021., 19:36   #456
Lewis
Freelancer
Lewis's Avatar
Postovi: 5,297
Ma 4 grafe su dosta, dvije u plocu (3 i 7 slot) i dvije na extenderu. 1600AX ce nahranit 3 kom 390 a ako budu bas sve 4 kom 3090 još jedno 650w je dosta .
Mjesta u kucistu imam za 7 komada to nije problem
Staro 16.01.2021., 19:33   #457
BusMaster
BusMaster's Avatar
Postovi: 343
AMD EPYC 7543 ‘Milan’ Server CPU With 32 Zen 3 Cores & 3.7 GHz Clocks Benchmarked, Huge Single-Threaded Performance Increase
Link: https://wccftech.com/amd-epyc-7543-m...ance-increase/
Staro 17.01.2021., 14:20   #458
Psycho
Master Of Disaster
Psycho's Avatar
Postovi: 1,268
to je to sta mi treba za vCPU performance.
Staro 17.01.2021., 17:28   #459
emilblomsky
emilblomsky's Avatar
Lokacija: karlovac
Postovi: 2,074
Gledao sam Linusa kad je spojio 2x3090 i 10900k na hx 1000,i ugasilo se računalo kad je pokrenuo Tomb Raidera!
Phil of the future!
Staro 22.01.2021., 23:12   #460
Psycho
Master Of Disaster
Psycho's Avatar
Postovi: 1,268
zabavno za pogledati
DIY Threadripper 1950X u "laptopu"
https://www.youtube.com/watch?v=NsdX...ture=emb_title
Staro 03.02.2021., 20:09   #461
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,584
Staro 28.02.2021., 17:05   #462
BusMaster
BusMaster's Avatar
Postovi: 343
AMD EPYC Genoa CPU Platform Detailed – Up To 96 Zen 4 Cores, 192 Threads, 12-Channel DDR5-5200, 128 PCIe Gen 5 Lanes, SP5 ‘LGA 6096’ Socket
Linkovi: https://wccftech.com/amd-epyc-genoa-...a-6096-socket/
https://videocardz.com/newz/amd-epyc...lga6096-socket
... još jedan monster CPU od AMD-a..)
Staro 28.02.2021., 17:10   #463
Postovi: 8,324
AMD ne (pre)staje, dok se Intel istovremeno pretvara da je (kod njih i dalje) sve u najboljem redu ko u starim danima slave.
Staro 28.02.2021., 17:11   #464
Lewis
Freelancer
Lewis's Avatar
Postovi: 5,297
Jos malo i chip ce biti ko tava za palacinke velik .
Staro 28.02.2021., 17:38   #465
Postovi: 8,324
Je, ali takav jedan bude vrlo lako nudil performanse u rangu ili bolje od dual-socket Sapphire Rapids platforme, pa se onda i veličina i potrošnja brzo prihvate, jer kak god se okrene - bolje je od onoga kaj konkurencija nudi.
Intel Sapphire Rapids bude baziran na LGA-4677 platformi, a osnova budu dva slijepljena 28-core CPU-a, tako da svekupno mogu ponuditi 56-core rješenje s 400 TDP-om.
U svakom slučaju, AMD bude ponudil skoro duplo više jezgri u istom paketu s tim da je EPYC Milan zapravo ono čemu Sapphire Rapids konkurira.
Staro 28.02.2021., 17:52   #466
kasko
kasko's Avatar
Lokacija: Ivanić_Grad
Postovi: 2,009
Kolko bude cijena tog 200 konja procesora cca?
kasko je online   Reply With Quote
Staro 28.02.2021., 17:56   #467
Lewis
Freelancer
Lewis's Avatar
Postovi: 5,297
Autor kasko Pregled postova
Manje nego Intelovih 100 konja .
Staro 28.02.2021., 17:56   #468
Postovi: 8,324
Sadašnji Intel i AMD u toj kategoriji idu bez problema za kakvih 8.000 do 10.000$ po komadu za high-end modele, samo kaj AMD nudi više za te nofce.
Zadnje izmijenjeno od: The Exiled. 28.02.2021. u 18:10.
Staro 28.02.2021., 19:35   #469
MadBoY
MadModerator
MadBoY's Avatar
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
Iduće godine će se s dva ta Epyca i 8 GPU-a moći napraviti server koji će biti brži u rendanju nego cijeli rack servera prije 5-6 godina .
Staro 28.02.2021., 19:40   #470
Lewis
Freelancer
Lewis's Avatar
Postovi: 5,297
I sad se moze ubaciti 8 komada RTX 8000 i imati monster render "farmu" unutar jednog kompa AKO imas cca 65-70k USD viska .
Staro 08.03.2021., 22:24   #471
Postovi: 8,324
AMD to Launch 3rd Generation EPYC on March 15th: Milan with Zen 3
The launch event will feature presentations from CEO Dr. Lisa Su, CTO Mark Papermaster, GM Enterprise and Embedded Solutions (EESC) Forrest Norrod, and GM Server Business Unit Dan McNamara. Leading data center partners and customers will also make an appearance. To date we know that AMD’s Milan processor line will feature up to 64 Zen 3 cores, using a seemless transition from the Zen 2 EPYC Rome ecosystem with pin-compatible processors. Milan will also offer up to 128 PCIe lanes, eight channel memory, and dual socket configurations. If the desktop Zen 3-based processors are any measure, +19% IPC generational gains are expected with the new processor, despite main memory access likely remaining the same.
Izvor: AnandTech
EDIT:
Zadnje izmijenjeno od: The Exiled. 15.03.2021. u 14:45.
Staro 26.04.2021., 10:00   #472
lit
Lokacija: hr
Postovi: 976
Jel netko zna one serverske matične sa puno slotova za ram jel se moraju popuniti svi slotovi da bi radilo ili može manje, a koliko manje?
Odgovor: Ne treba. Može po 4 modula po cpu.
Zadnje izmijenjeno od: lit. 26.04.2021. u 10:10.
lit je offline   Reply With Quote
Staro 16.07.2021., 06:09   #473
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,308
Slobodno me dodajte na PSN
Staro 16.07.2021., 13:38   #474
Postovi: 8,324
U prijevodu, "jebe se AMD-u za Intel i njihov HEDT". Obzirom na situaciju, dobro je da uopće izdaju nešto jače, jer nemaju apsolutno nikakvu potrebu, tj. konkurenciju.
Staro 26.07.2021., 08:40   #475
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,308
Staro 17.08.2021., 18:56   #476
Postovi: 8,324
Gigabyte leak reveals Zen 3 Threadripper CPUs codenamed 'Chagall'
These CPUs will max out at the same 64 Cores and 280W as Ryzen 3000 Threadripper, but feature the significantly quicker Zen 3 architecture, a recipe that is known to make the best CPUs on the market. According to the Gigabyte leak, it appears AMD is preparing two lineups for Zen 3 Threadripper. One will be dedicated towards the HEDT market, while the second is targeted towards workstation users (called Threadripper Pro), with significantly more memory channels. The HEDT chips will work on the TRX40 platform, while the workstation models will be on the WRX80 socket.
Izvor: Tom's Hardware
AMD EPYC leak showcases the power of AMD's Zen 4 Genoa processors
For starters, these new leaks confirm that AMD's SP5/Zen 4 EPYC processors will support DDR5 memory. Beyond that, we now know that AMD's Zen 4 EPYC processors will utilise 12 Core Chiplet Dies (CCDs) and support 12-channel memory configurations. These changes alone will give AMD's next-generation EPYC processors a major increase in CPU core count and a monumental increase in total memory bandwidth. AMD's Zen 4 architecture is also due to support AVX-512, a feature that has been missing from AMD's EPYC product line from its inception. AVX-512 support is a major advantage of Intel's Xeon lineup, so much so that it was a critical aspect of Intel's Ice Lake marketing. Bringing AVX-512 support to EPYC will hit Intel hard, as it removes one of their most marketed advantages over AMD's EPYC lineup.
Izvor: OC3D i HardwareLuxx
Staro 17.08.2021., 20:13   #477
Dr. Strange
Datum registracije: Aug 2020
Postovi: 897
Rasturat će gu*ove Intelu, još uz 3d v-cache threadripper će biti zvijer.
Staro 18.08.2021., 04:02   #478
Starsylph
Datum registracije: Oct 2010
Lokacija: Sfera
Postovi: 408
Zasto je Threadripper toliko skuplji od AM4 procesora? Jel netko ima ovdje Threadrippera?
Starsylph je offline   Reply With Quote
Staro 18.08.2021., 05:00   #479
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,308
Autor Starsylph Pregled postova
Pa jesi npr pročitao tekst koji je stavio Exiled?
HEDT i Workstation...izguglaj si te pojmove.
U prijevodu to su ti traktori i kamioni u odnosu na aute (AM4) da ti objasnim najjednostavnije. CPU-i koji služe za rad i neisplativi su za nas kućne korisnike.
Staro 18.08.2021., 15:51   #480
Max Rockatansky
Lokacija: Zg/Zd
Postovi: 718
I to neki Lamborghinijev traktor
U duhu Discovog primjera ... ako trebaš prevesti 7 ili više osoba onda je zgodnije uzeti neki veliki SUV/mini-bus nego napraviti dvije ili više tura nekim malim gradskim autom.
Da, Threadripperi su skupi, ali ako staviš cijelu konfiguraciju u kalkulaciju zajedno sa softverskim licencama, često ispadnu relativno jeftinije rješenje.
Neki poslovi kao npr. 3D rendering se mogu efikasno distribuirati ("distributed rendering") na više slabijih/jeftinijih konfi gdje onda jedna od njih ima ulogu "mastera" i mrežom šalje podatke (3D model) ostalima na računanje (od toga i naziv "render-slave") na kojima se vrti "bezglava" (bez GUI-ja) verzija softvera i vraća rezultat (cijelu ili dio slike) "masteru".
Teško je povući granicu ili dati neku univerzalnu formulu, ovisi o poslu, koliko se efikasno može skalirati, rokovima ... za freelancere i male firme, više manjih konfi je fleksibilnije rješenje a i na kraju radnog vijeka lakše je prodati neki "mali" Ryzen ili i7/i9 nego dual-CPU Xeon ili Threadripper.
Primjer iz prakse ... jedan R9 3900X je 20% brži od dual-CPU Xeona (2x E5-2350, 20c/40t) a Threadripper 3970X 3 puta (300%) pa se starog Xeona više ne isplati ni paliti.
Da ne spammam dalje temu, ukratko, TRiperi su odlični i koliko god na prvu čudno zvučalo nisu ni toliko skupi. Nažalost, zbog nedostatka konkurencije, novi (Chagall) će vjerojatno biti skuplji.
