#452 |
Datum registracije: Apr 2017
Postovi: 343
AMD 32-Core EPYC "Milan" Zen 3 CPU Fights Dual Xeon 28-Core Processors Link: https://www.techpowerup.com/276932/a...ore-processors https://www.tomshardware.com/news/am...specifications |
#453 |
Postovi: 343
AMD’s Ryzen Threadripper Pro CPUs & WRX80 Motherboards Coming To Consumer Segment in March 2021 – 64 Cores, 128 PCIe Lanes & 8-Channel Memory Link: https://wccftech.com/amds-ryzen-thre...ch-march-2021/ Dobra vijest za "power usere" i konačna brukva u kaspsu za Intel Hedt (ako takvo nešto još postoji).. ![]() |
#454 |
Freelancer
Lokacija: Bilje (Osijek)
Postovi: 5,292
E, TO te ja pitam, napokon workstaion ploce sa 7 slotova ![]() Njamiiii
#456 |
Freelancer
Postovi: 5,292
Ma 4 grafe su dosta, dvije u plocu (3 i 7 slot) i dvije na extenderu. 1600AX ce nahranit 3 kom 390 a ako budu bas sve 4 kom 3090 još jedno 650w je dosta ![]() Mjesta u kucistu imam za 7 komada to nije problem ![]()
#457 |
Postovi: 343
AMD EPYC 7543 ‘Milan’ Server CPU With 32 Zen 3 Cores & 3.7 GHz Clocks Benchmarked, Huge Single-Threaded Performance Increase Link: https://wccftech.com/amd-epyc-7543-m...ance-increase/ |
#459 | |
Lokacija: karlovac
Postovi: 2,073
Phil of the future! |
#460 |
Master Of Disaster
Datum registracije: Nov 2002
Postovi: 1,265
zabavno za pogledati ![]() DIY Threadripper 1950X u "laptopu" https://www.youtube.com/watch?v=NsdX...ture=emb_title
#461 |
Postovi: 14,584
AMD 3rd Gen EPYC Milan 7003 CPU Specifications & Prices Leaked By Dell, Flagship EPYC 7763 64 Core Chip For Under $7,000 US Djeluje povoljno naspram prethodnih epyca i intela |
#462 |
Postovi: 343
AMD EPYC Genoa CPU Platform Detailed – Up To 96 Zen 4 Cores, 192 Threads, 12-Channel DDR5-5200, 128 PCIe Gen 5 Lanes, SP5 ‘LGA 6096’ Socket Linkovi: https://wccftech.com/amd-epyc-genoa-...a-6096-socket/ https://videocardz.com/newz/amd-epyc...lga6096-socket ... još jedan monster CPU od AMD-a.. ![]() |
#464 |
Freelancer
Postovi: 5,292
Jos malo i chip ce biti ko tava za palacinke velik ![]()
#465 |
Postovi: 8,283
Je, ali takav jedan bude vrlo lako nudil performanse u rangu ili bolje od dual-socket Sapphire Rapids platforme, pa se onda i veličina i potrošnja brzo prihvate, jer kak god se okrene - bolje je od onoga kaj konkurencija nudi. Intel Sapphire Rapids bude baziran na LGA-4677 platformi, a osnova budu dva slijepljena 28-core CPU-a, tako da svekupno mogu ponuditi 56-core rješenje s 400 TDP-om. U svakom slučaju, AMD bude ponudil skoro duplo više jezgri u istom paketu s tim da je EPYC Milan zapravo ono čemu Sapphire Rapids konkurira. ![]() |
#467 |
Freelancer
Postovi: 5,292
#468 |
Postovi: 8,283
Sadašnji Intel i AMD u toj kategoriji idu bez problema za kakvih 8.000 do 10.000$ po komadu za high-end modele, samo kaj AMD nudi više za te nofce. ![]() Zadnje izmijenjeno od: The Exiled. 28.02.2021. u 18:10. |
#469 |
MadModerator
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
Iduće godine će se s dva ta Epyca i 8 GPU-a moći napraviti server koji će biti brži u rendanju nego cijeli rack servera prije 5-6 godina ![]()
#470 |
Freelancer
Postovi: 5,292
I sad se moze ubaciti 8 komada RTX 8000 i imati monster render "farmu" unutar jednog kompa AKO imas cca 65-70k USD viska ![]()
#471 | |
Postovi: 8,283
AMD to Launch 3rd Generation EPYC on March 15th: Milan with Zen 3 ![]() Citiraj:
EDIT: Zadnje izmijenjeno od: The Exiled. 15.03.2021. u 14:45. |
#472 |
Lokacija: hr
Postovi: 976
Jel netko zna one serverske matične sa puno slotova za ram jel se moraju popuniti svi slotovi da bi radilo ili može manje, a koliko manje? Odgovor: Ne treba. Može po 4 modula po cpu. Zadnje izmijenjeno od: lit. 26.04.2021. u 10:10. |
#474 |
Postovi: 8,283
U prijevodu, "jebe se AMD-u za Intel i njihov HEDT". ![]() ![]()
#475 |
Prvoklasni Krkan
Postovi: 5,291
#476 | ||||
Postovi: 8,283
#477 |
Datum registracije: Aug 2020
Postovi: 895
Rasturat će gu*ove Intelu, još uz 3d v-cache threadripper će biti zvijer. |
#478 |
Datum registracije: Oct 2010
Lokacija: Sfera
Postovi: 408
Zasto je Threadripper toliko skuplji od AM4 procesora? Jel netko ima ovdje Threadrippera? |
#479 | |
Prvoklasni Krkan
Postovi: 5,291
HEDT i Workstation...izguglaj si te pojmove. U prijevodu to su ti traktori i kamioni u odnosu na aute (AM4) da ti objasnim najjednostavnije. CPU-i koji služe za rad i neisplativi su za nas kućne korisnike. |
#480 |
Lokacija: Zg/Zd
Postovi: 716
I to neki Lamborghinijev traktor ![]() U duhu Discovog primjera ... ako trebaš prevesti 7 ili više osoba onda je zgodnije uzeti neki veliki SUV/mini-bus nego napraviti dvije ili više tura nekim malim gradskim autom. Da, Threadripperi su skupi, ali ako staviš cijelu konfiguraciju u kalkulaciju zajedno sa softverskim licencama, često ispadnu relativno jeftinije rješenje. Neki poslovi kao npr. 3D rendering se mogu efikasno distribuirati ("distributed rendering") na više slabijih/jeftinijih konfi gdje onda jedna od njih ima ulogu "mastera" i mrežom šalje podatke (3D model) ostalima na računanje (od toga i naziv "render-slave") na kojima se vrti "bezglava" (bez GUI-ja) verzija softvera i vraća rezultat (cijelu ili dio slike) "masteru". Teško je povući granicu ili dati neku univerzalnu formulu, ovisi o poslu, koliko se efikasno može skalirati, rokovima ... za freelancere i male firme, više manjih konfi je fleksibilnije rješenje a i na kraju radnog vijeka lakše je prodati neki "mali" Ryzen ili i7/i9 nego dual-CPU Xeon ili Threadripper. Primjer iz prakse ... jedan R9 3900X je 20% brži od dual-CPU Xeona (2x E5-2350, 20c/40t) a Threadripper 3970X 3 puta (300%) pa se starog Xeona više ne isplati ni paliti. Da ne spammam dalje temu, ukratko, TRiperi su odlični i koliko god na prvu čudno zvučalo nisu ni toliko skupi. Nažalost, zbog nedostatka konkurencije, novi (Chagall) će vjerojatno biti skuplji. |
