#782 |
Prvoklasni Krkan
Postovi: 5,333
Eh da, evo tih DF preporučenih postavki: Standard Optimised Settings Contact Shadows: On Improved Facial Lighting Geometry: On Local Shadow Mesh Quality: High Local Shadow Quality High Cascaded Shadows Range: High Cascaded Shadows Resolution: Medium Distant Shadows Resolution: High Volumetric Fog Resolution: 1080p Ultra, 1440p High, 4K Medium Volumetric Cloud Quality: Medium Max Dynamic Decals: Ultra Screen Space Reflections Quality: Low but High if you find the amount of grain distracting. Subsurface Scattering Quality: High Ambient Occlusion: Low (there is barely a difference) Colour Precision: Medium Mirror Quality: 1080p High. 1440p High, 4K Medium Level of Detail: High Recommended Ray Tracing Settings Ray Traced Reflections: On Ray Traced Shadows: Off Ray Traced Lighting: Medium If that is not enough for you, Turn off reflections - the RT lighting is more important, on balance. Image Quality Recommendations: 1080p DLSS Quality, 1440p, DLSS Balanced, 4K, DLSS Performance |
#783 |
Datum registracije: Dec 2013
Postovi: 1,699
Pošto sam na poslu trenutno, šta bi bilo ako: - Upalim DSR factor u NVCP-u (označim sve rezolucije). Upalim igru nativno na 1440p, ali izaberem 4K (DSR) i onda postavim DLSS na performance ili ultra performance ? ![]() U smislu, da li je ikada itko čisto iz znatiželje isprobavao funkcijonalnost DLSS-a u kombinaciji sa DSR-om? Ili sam pre malo čitan i DLSS ne radi osim na nativnim rezolucijama pa to sve pada u vodu ? |
#784 |
I encompass, and I eclips
Datum registracije: Jul 2010
Lokacija: Plazikur
Postovi: 1,106
ryzen fix mi vratio 20+ frejmova, žalosno da moram sam sebi fixat gejm ali ok. Jedav ssam od dosade prešao dio di krademo relic..toliko nepotrebne priče me živcira. Sjednu u auto i 5 min pričaju o tome da trebaju krenuti. užas. Ima jpš kakvih fixeva da nabijem frejmova još? hvala za linkove i specs.
#785 |
Datum registracije: Dec 2009
Postovi: 438
Pitanje..Zapeo na misiji od dexa.LOL znam prva misija, NEkako izaso iz onog goodfood koji q, i sad me trazi da se vratim nazad unutra i pricam s jackiem, aL na ulazu stoji lik, neda mi unutra, a ja ne mogu nista.. NE vidim nikakav alternativni ulaz |
#787 |
Lokacija: N/A
Postovi: 770
Još ništa iz Sancta Domenice, ovi iz pošte zajebavaju. Ugl., tražit ću povrat. Pa samo da pitam za ovu foru s ruskim VPN-om - mogu li igru dodati u svoj usual GOG account ako kupim koristeću HOLA VPN na ruskom webu? Jer ako moram imati drugi account - zajebi, nemam volje za to. ![]() |
#788 |
Datum registracije: May 2019
Postovi: 522
#789 | |
Postovi: 196
kliknuo buy ulogovao se svojim accountom i platio paypal-om kunama. Izaslo me 23.73 eura |
#791 |
Datum registracije: Mar 2020
Postovi: 326
Updateao sam na 1.04 medjutim i dalje kad izadjem kao street kid iz kafica od kirka, igra se skrsi, sve sam probao ![]() rjesio : AVX fix https://www.nexusmods.com/cyberpunk2077/mods/34 Zadnje izmijenjeno od: dbL. 14.12.2020. u 18:26. Razlog: UPDATE |
#792 |
Lokacija: SK
Postovi: 157
Isti probem, odigrao ponovno misiju i ista stvar, jesi našao rješenje... 1.04 verzija
#793 |
Datum registracije: Sep 2017
Postovi: 1,433
#794 | |
Prvoklasni Krkan
Postovi: 5,333
#797 |
Prvoklasni Krkan
Postovi: 5,333
Šteta šta nemaš jaču grafu da probaš igru. Vjeruj mi dobra je i u ovom polomljenjom stanju. Većinom su to grafički bugovi. I ovo je vj igra u najgorem stanju koju sam do sada igrao, a ne volim ni RPG-e, i svejedno uživam. Ako voliš SF, igra će ti biti bogovska. ![]() |
#799 |
Postovi: 8,448
#801 | |
Lokacija: Zagreb, Črnomerec
Postovi: 2,611
Sad ste se vas dvojica našli čovjeku govorit što mu treba u životu ![]() Prilično sam siguran da zna kakve su cijene rabljenih grafi i što mu treba. ![]() Ionako ima još 5-6 mjeseci fore dok ovi uspiju uredit taj Cyberpunk da liči na ono što obećavaju od 2012... |
#802 |
Postovi: 8,448
Ma ne, nije to, imali smo već prije slične rasprave u kojima Manuel čeka nove kartice, pa sam spomenul nek provjeri rabljene - fino se naigra i onda kad stignu nove, ako valjaju - kupuje. ![]() Kaj se igre tiče, da - bude malo potrajalo dok ju dovedu u kak spada stanje, jer ovo nažalost nije posloženo ni za jednu platformu. |
#803 |
Datum registracije: Sep 2014
Lokacija: Zagora
Postovi: 179
Nakon patcha 1.04 nemam nikakvih problema. S obzirom na procesor nisam očekiva dobre performanse, al skroz dobro sve ide i nakon 5h igre nisan naiša na game-breaking bug. Eventualno koji grafički glitch i to je to. Sve na high osim shadows i mirror reflection ili tako nešto, to sam na low stavio. fps od 45-80 na 1080p |
#805 |
RESPECT MY AUTHORITAH
Postovi: 7,488
Ništa se nije promijenilo kada sam uređivao csv i stavio 16Gb rama, isto oko 3gb koristi, cpu 50% max. Što je najgore, zabunom otvorio 2 instance igre exe. Uopće mi nije pao fps. Igra kao da koristi 2Gb rama, 40% cpua i pola grafičke
#806 |
Lokacija: Plazikur
Postovi: 1,106
slčoži si ryzen fix, on je meni dao 20% više fps
#809 | |
Postovi: 14,584
Sad sam zadnje instalirao thalos principle, a sjetio sam se da sam potpuno zaboravio na LA: Noir, na to sam skroz bio nahajpan i MGSV. Sve to može gurati ova do proljeća. I planescape torment nisam završio, Dungeons 3... Ne znam, uvijek sam u nekom zaostatku, ne kužim kako ljudi imaju vremena za nešto novo što je tek izašlo tj. kako nemaju što igrati pa piče igre u ovakvom žalosnom stanju, a znamo da će igra za par mjeseci biti med i mlijeko. Jednostavno općenito nisam nestrpljiv, na CP 2077 nisam nešto posebno nahajpan, nemam je uopće u planovima |
#810 | |||
Prvoklasni Krkan
Postovi: 5,333
Ne stavlja se sav dostupan RAM, stavi max 10gb, a VRAM stavi cijeli. I ovo što ti kažu, ako si na Ryzenu obavezno napravi AMD fix jer se tek onda koristi SMT. Citiraj:
)Citiraj:
A to koliko se stigne igrat, to je drugi par rukava. Inače se slažem sa filzofijom da je pametnije odigrat neku igru kakvih min 6 mj nakon izlaska...ali eto, išao sam probati CP2077 i nema nazad. ![]() |
