Staro 14.12.2020., 13:19   #781
Immortalis
Slobodan leni seronja
Immortalis's Avatar
Postovi: 852
Ne mogu nigdje na internetima naci kako se nosi 6700k i 3070 sa ovom igrom
Staro 14.12.2020., 13:38   #782
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,274
Eh da, evo tih DF preporučenih postavki:
Standard Optimised Settings
Contact Shadows: On
Improved Facial Lighting Geometry: On
Local Shadow Mesh Quality: High
Local Shadow Quality High
Cascaded Shadows Range: High
Cascaded Shadows Resolution: Medium
Distant Shadows Resolution: High
Volumetric Fog Resolution: 1080p Ultra, 1440p High, 4K Medium
Volumetric Cloud Quality: Medium
Max Dynamic Decals: Ultra
Screen Space Reflections Quality: Low but High if you find the amount of grain distracting.
Subsurface Scattering Quality: High
Ambient Occlusion: Low (there is barely a difference)
Colour Precision: Medium
Mirror Quality: 1080p High. 1440p High, 4K Medium
Level of Detail: High
Recommended Ray Tracing Settings
Ray Traced Reflections: On
Ray Traced Shadows: Off
Ray Traced Lighting: Medium
If that is not enough for you, Turn off reflections - the RT lighting is more important, on balance.
Image Quality Recommendations: 1080p DLSS Quality, 1440p, DLSS Balanced, 4K, DLSS Performance
Slobodno me dodajte na PSN
Staro 14.12.2020., 13:44   #783
thunder11
thunder11's Avatar
Datum registracije: Dec 2013
Postovi: 1,698
Pošto sam na poslu trenutno, šta bi bilo ako:
- Upalim DSR factor u NVCP-u (označim sve rezolucije). Upalim igru nativno na 1440p, ali izaberem 4K (DSR) i onda postavim DLSS na performance ili ultra performance ?
U smislu, da li je ikada itko čisto iz znatiželje isprobavao funkcijonalnost DLSS-a u kombinaciji sa DSR-om? Ili sam pre malo čitan i DLSS ne radi osim na nativnim rezolucijama pa to sve pada u vodu ?
Staro 14.12.2020., 13:45   #784
Doktor O
I encompass, and I eclips
Doktor O's Avatar
Datum registracije: Jul 2010
Lokacija: Plazikur
Postovi: 1,043
ryzen fix mi vratio 20+ frejmova, žalosno da moram sam sebi fixat gejm ali ok.
Jedav ssam od dosade prešao dio di krademo relic..toliko nepotrebne priče me živcira.
Sjednu u auto i 5 min pričaju o tome da trebaju krenuti.
užas.
Ima jpš kakvih fixeva da nabijem frejmova još?
hvala za linkove i specs.
Doktor O je offline   Reply With Quote
Staro 14.12.2020., 14:15   #785
R3nchi
R3nchi's Avatar
Postovi: 438
Pitanje..Zapeo na misiji od dexa.LOL znam prva misija, NEkako izaso iz onog goodfood koji q, i sad me trazi da se vratim nazad unutra i pricam s jackiem, aL na ulazu stoji lik, neda mi unutra, a ja ne mogu nista..
NE vidim nikakav alternativni ulaz
R3nchi je offline   Reply With Quote
Staro 14.12.2020., 14:20   #786
zgmmax
zgmmax's Avatar
Postovi: 1,668
Kod takvih stvari je meni pomogao restart igre.
Izađeš i uđeš i sve je ok
Staro 14.12.2020., 15:01   #787
IGoR_2803
IGoR_2803's Avatar
Lokacija: N/A
Postovi: 759
Još ništa iz Sancta Domenice, ovi iz pošte zajebavaju. Ugl., tražit ću povrat. Pa samo da pitam za ovu foru s ruskim VPN-om - mogu li igru dodati u svoj usual GOG account ako kupim koristeću HOLA VPN na ruskom webu? Jer ako moram imati drugi account - zajebi, nemam volje za to.
Staro 14.12.2020., 15:09   #788
guerra
Datum registracije: May 2019
Postovi: 522
Autor Immortalis Pregled postova
Pogledaj si test od Gamers Nexus i kako se nosi ryzen 3300x, tvoj 6700k bi trebao biti par fps-a gore/dolje.
guerra je offline   Reply With Quote
Staro 14.12.2020., 15:31   #789
Flatline
Flatline's Avatar
Postovi: 196
Autor IGoR_2803 Pregled postova
Ja sam upalio vpn otisao na https://www.gog.com/game/cyberpunk_2077
kliknuo buy ulogovao se svojim accountom i platio paypal-om kunama.
Izaslo me 23.73 eura
Flatline je online   Reply With Quote
Staro 14.12.2020., 15:49   #790
IGoR_2803
IGoR_2803's Avatar
Lokacija: N/A
Postovi: 759
Odlično. Kupljeno uspješno preko ruskog GOG-a. 178 kuna s paypalom. A u SD otkazao narudžbu.
Staro 14.12.2020., 16:45   #791
dbL
dbL's Avatar
Datum registracije: Mar 2020
Postovi: 322
Updateao sam na 1.04 medjutim i dalje kad izadjem kao street kid iz kafica od kirka, igra se skrsi, sve sam probao
rjesio : AVX fix https://www.nexusmods.com/cyberpunk2077/mods/34
Zadnje izmijenjeno od: dbL. 14.12.2020. u 17:26. Razlog: UPDATE
Staro 14.12.2020., 16:55   #792
LostX
LostX's Avatar
Lokacija: SK
Postovi: 155
Autor R3nchi Pregled postova
Isti probem, odigrao ponovno misiju i ista stvar, jesi našao rješenje... 1.04 verzija
LostX je offline   Reply With Quote
Staro 14.12.2020., 17:22   #793
axo
Datum registracije: Sep 2017
Postovi: 1,428
Pa kaze ajmo opet malo ćaćkat po postavkama.
https://www.reddit.com/r/Amd/comment...m_source=share
Staro 14.12.2020., 17:55   #794
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,274
Autor axo Pregled postova
Bilo je to već pred koju stranicu.
Staro 14.12.2020., 18:02   #795
axo
Postovi: 1,428
Autor Disco Pregled postova
E hebiga, nisam stigao procitat od tamo gdje sam stao.
Nema veze dva put je dva put
Staro 14.12.2020., 19:28   #796
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,584
Ma dečki okanite se ćorava posla i pričekajte bar još koji patch
Staro 14.12.2020., 20:08   #797
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,274
Šteta šta nemaš jaču grafu da probaš igru.
Vjeruj mi dobra je i u ovom polomljenjom stanju.
Većinom su to grafički bugovi.
I ovo je vj igra u najgorem stanju koju sam do sada igrao, a ne volim ni RPG-e, i svejedno uživam.
Ako voliš SF, igra će ti biti bogovska.
Staro 14.12.2020., 20:17   #798
Doktor O
Doktor O's Avatar
Lokacija: Plazikur
Postovi: 1,043
ajme kakav smor je ova tranzicija silverhanda i završetak prvog acta...20min ničega realno, ali ajde, bitno je za priču
Staro 14.12.2020., 20:25   #799
Postovi: 8,267
Ja sam mu u već nekoliko navrat diljem raznih tema napomenul nek provjeri rabljene RX i GTX modele, jer dosad je već mogel svašta kupiti.
Staro 14.12.2020., 20:31   #800
Vendetta
Vendetta's Avatar
Postovi: 919
Vendetta je offline   Reply With Quote
Staro 14.12.2020., 20:37   #801
Exy
Exy's Avatar
Lokacija: Zagreb, Črnomerec
Postovi: 2,537
Sad ste se vas dvojica našli čovjeku govorit što mu treba u životu
Prilično sam siguran da zna kakve su cijene rabljenih grafi i što mu treba.
Ionako ima još 5-6 mjeseci fore dok ovi uspiju uredit taj Cyberpunk da liči na ono što obećavaju od 2012...
Staro 14.12.2020., 20:40   #802
Postovi: 8,267
Ma ne, nije to, imali smo već prije slične rasprave u kojima Manuel čeka nove kartice, pa sam spomenul nek provjeri rabljene - fino se naigra i onda kad stignu nove, ako valjaju - kupuje.
Kaj se igre tiče, da - bude malo potrajalo dok ju dovedu u kak spada stanje, jer ovo nažalost nije posloženo ni za jednu platformu.
Staro 14.12.2020., 20:41   #803
scarwin
scarwin's Avatar
Datum registracije: Sep 2014
Lokacija: Zagora
Postovi: 179
Nakon patcha 1.04 nemam nikakvih problema. S obzirom na procesor nisam očekiva dobre performanse, al skroz dobro sve ide i nakon 5h igre nisan naiša na game-breaking bug. Eventualno koji grafički glitch i to je to.
Sve na high osim shadows i mirror reflection ili tako nešto, to sam na low stavio. fps od 45-80 na 1080p
scarwin je offline   Reply With Quote
Staro 14.12.2020., 20:46   #804
Mladenxy
Mladenxy's Avatar
Postovi: 4,347
Ja isto ne kužim gdje oni pronalaze te "lomove". Pokušavam nači bug i ništa Također performanse sasvim OK. Samo da je snage za igranje nakon posla
Staro 14.12.2020., 20:49   #805
Ag008
RESPECT MY AUTHORITAH
Ag008's Avatar
Postovi: 7,485
Ništa se nije promijenilo kada sam uređivao csv i stavio 16Gb rama, isto oko 3gb koristi, cpu 50% max.
Što je najgore, zabunom otvorio 2 instance igre exe.
Uopće mi nije pao fps. Igra kao da koristi 2Gb rama, 40% cpua i pola grafičke
Staro 14.12.2020., 20:57   #806
Doktor O
Doktor O's Avatar
Lokacija: Plazikur
Postovi: 1,043
Autor Ag008 Pregled postova
slčoži si ryzen fix, on je meni dao 20% više fps
Staro 14.12.2020., 21:37   #807
thekingnoa
Lokacija: slavonski brod
Postovi: 110
Napravio sam ryzen fix i radi iako mi treba bolja grafa, pucketa mi ton ponekad i pitanje :
pokrenem patch na v1.4 i u igri i dalje pise 1.3, zna netko zasto ?
thekingnoa je offline   Reply With Quote
Staro 14.12.2020., 22:38   #808
sti
Lokacija: Lawl
Postovi: 1,376
Meni je kod pucketanja zvuka pomoglo smanjivanje sampling ratea u Windowsima na 24bit/96kHz.
Staro 14.12.2020., 22:51   #809
Manuel Calavera
Postovi: 14,584
Ma kasno je sad za to, glupo mi uzimat sad polaris i sl. za međurješenje.
Sad sam zadnje instalirao thalos principle, a sjetio sam se da sam potpuno zaboravio na LA: Noir, na to sam skroz bio nahajpan i MGSV. Sve to može gurati ova do proljeća. I planescape torment nisam završio, Dungeons 3...
Ne znam, uvijek sam u nekom zaostatku, ne kužim kako ljudi imaju vremena za nešto novo što je tek izašlo tj. kako nemaju što igrati pa piče igre u ovakvom žalosnom stanju, a znamo da će igra za par mjeseci biti med i mlijeko. Jednostavno općenito nisam nestrpljiv, na CP 2077 nisam nešto posebno nahajpan, nemam je uopće u planovima
Staro 15.12.2020., 07:41   #810
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,274
Ne znam da li si ti čitao preporuke od frajera koji je napisao to za CSV.
Ne stavlja se sav dostupan RAM, stavi max 10gb, a VRAM stavi cijeli.
I ovo što ti kažu, ako si na Ryzenu obavezno napravi AMD fix jer se tek onda koristi SMT.
Autor thekingnoa Pregled postova
Ovo pucketanje mi se jednom desilo. A ako ti ne piše 1.4, onda nisi dobro instalirao patch, provjeri si path kada instaliravaš patch, skužit ćeš i po tome da instalacija traje i traje... (yogurt )
Ma tako se može čekat do beskonačnosti (sjetim se jednog frenda koji je tako čekao davnih dana stalno novu grafu, kao taman će kupit, ali najavili su novo, pa opet i opet...ostao na nekoj starudiji...). Ja sam puko i reko nema više čekanja, uzimam sada pa sam opet miran koju godinu (isto sam napravio i sa procesorom, pa realno još sam mogao ostat na i5, nije da nije radio).
A to koliko se stigne igrat, to je drugi par rukava. Inače se slažem sa filzofijom da je pametnije odigrat neku igru kakvih min 6 mj nakon izlaska...ali eto, išao sam probati CP2077 i nema nazad.
