Staro 21.11.2020., 11:14   #91
axo
Datum registracije: Sep 2017
Postovi: 1,428
Autor max111 Pregled postova
Najveća mana su cijene i još ih nema nigdje raspoložive za kupiti. Ne vidim tu prednosti kad cijene divljaju i bez obzira na takvo stanje još se sve proda u roku odmah.
Poslano sa mog Nokia 7 plus koristeći Tapatalk
Nisam mislio na cijenu i dostupnost.
Nego na performanse.
Staro 21.11.2020., 13:04   #92
max111
max111's Avatar
Postovi: 543
Autor axo Pregled postova
Znam, nisam ni ja mislio na performanse. To sa svakom novom generacijom napredak postoji to nije sporno. Zanimljivo koliko cijene sve više idu gore ali nije problem sve se proda pa zašto onda ne bi bilo sve skuplje, ista stvar amd ili nvidia.
CPU Intel i7 6700K
MBO ASRock Z270 Extreme4
RAM Kingston HyperX (2x8GB)
VGA MSI GTX970 4G TF5
HDD (1TB Samsung F3, Samsung 960 EVO, WD Caviar Green 3TB)
PSU Corsair AX750W
Windows 10 x64
max111 je offline   Reply With Quote
Staro 21.11.2020., 16:33   #93
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,584
Pazi dečki mi tu pričamo i po 100w razlike u potrošnji kod gpu iste klase
Ne može svatko imati 3080 u svom kućištu. Plus da još bude naklokan i9 i TDP-a u kućištu ko u priči
Staro 21.11.2020., 17:08   #94
Postovi: 8,255
AMD Radeon RX 6700 XT with 2,560 ALUs and 12GB GDDR6
Shortly after the release of the AMD Radeon RX 6800 XT and RX 6800 (test) based on the new RDNA-2 architecture and the Navi-21 GPUs, there are initial rumors about the Radeon RX-6700 series. Like the Radeon-RTX-6800 series, the smaller series will consist of two graphics cards based on the Navi-22 GPU. Unsurprisingly, both Radeon-RX-6700 series graphics cards are based on the smaller Navi 22 aka NavyFlounderwith up to 40 CUs, 2,560 shaders and 12 GB of GDDR6 video memory. The video memory, on an equal footing with the Radeon RX-6800 series, is designed to support the new AMD Infinity Cache technology for higher overall storage interface performance. In the case of Navi 22 XT (Radeon RX 6700 XT) and Navi 22 XTL (Radeon RX 6700), however, the memory bus should only be 192-bit wide. The Total Graphics Power ("TGP") is provided by Patrick Schurr with 186 to 211 watts for the Radeon RX 6700 XT and 146 to 156 watts for the Radeon RX 6700. The TGP of the direct predecessors Radeon RX 5700 XT and RX 5700 (test) was 225 and 180 watts respectively.
Izvor: ComputerBase
Staro 21.11.2020., 17:56   #95
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,268
E tu ćemo vidjet pravi napredak. 5700/XT vs 6700/XT.
Slobodno me dodajte na PSN
Disco je online   Reply With Quote
Staro 21.11.2020., 18:06   #96
Postovi: 8,255
IMHO, moglo bi bez problema ispasti kakvih 50% poboljšanja u odnosu na RX 5700 seriju, a RX 6700 (XT) izdanja budu s time u rangu s nadolazećim RTX 3060 (Ti) modelima.
Staro 21.11.2020., 18:35   #97
Joza_Seraf
Joza_Seraf's Avatar
Datum registracije: Jun 2015
Lokacija: Klc
Postovi: 568
Da li će biti 550 napajanje oke za 6800 ili ću ga morati mjenjati? Mišljenja? I kad dolaze custom modeli? 25-og? Ciljam na sapphire
Samo čekam dan kada će mi netko pokucati na vrata i zatražiti me bubreg jer sam negdje odscrollao dolje i stavio kvačicu na "Slažem sa svime"!!
Joza_Seraf je offline   Reply With Quote
Staro 21.11.2020., 18:42   #98
Postovi: 8,255
Da, 25.11. su AiB modeli u opticaju, a napajanje bi trebalo biti i više nego OK za običnu RX 6800.
Staro 21.11.2020., 18:45   #99
Joza_Seraf
Joza_Seraf's Avatar
Lokacija: Klc
Postovi: 568
Ne ciljam XT jer razlika u cijeni će biti solidna.. a kupujem na amazonu, tako da se nadam da do 05.01. Biti na zalihi
Staro 21.11.2020., 23:06   #100
Manuel Calavera
Postovi: 14,584
Napajanje se neće ni oznojit
Teško kad je prema TPU 6800 na 1080p brža 35% od 5700XT, 51% na 1440p i 64% na 4K. Dakle mora to biti slabije
Inače ovom analogijom naspram Navi 21 i Navi 22, ako je Navi 23 nova arhitektura - ona bi imala 128-bit sabirnicu i 8gb vram, te 64mb infinity cachea. Znači pola 6800XT, osim u CU
Zadnje izmijenjeno od: Manuel Calavera. 21.11.2020. u 23:14.
Staro 21.11.2020., 23:25   #101
fooK
Powaaa user
fooK's Avatar
Lokacija: Hrvatska, Zagreb
Postovi: 160
Kad se mogu te grafičke očekivati u našim dućanima? Kakve se cijene uopće očekuju 5000-6000-7000?
Poslano sa mog SM-G986B koristeći Tapatalk
Fun starts @ 2000 rpm with 465nM
Pošteni trgovac: 1
fooK je offline   Reply With Quote
Staro 21.11.2020., 23:31   #102
Manuel Calavera
Postovi: 14,584
Piše da će konkurirati 3060Ti i 3060, a glasine za prvu kažu da imaju MSRP 399$ - što bi kod nas bilo 3600-4000kn, KAD bi situacija bila normalna (a nije). Znači vjerojatno će biti 4500kn, te imati 2080 super pefromanse. Dali će se moći kupiti i kada, to ne znaju ni nvidija/AMD
Staro 22.11.2020., 00:09   #103
fooK
Powaaa user
fooK's Avatar
Postovi: 160
Hvala ti na brzom odgovoru!
Kupio bih nešto kroz koji tjedan, a čekam kao bedak da se pojavi nešto od toga svega 😁
Pošteni trgovac: 1
Staro 22.11.2020., 07:46   #104
Joza_Seraf
Joza_Seraf's Avatar
Lokacija: Klc
Postovi: 568
Autor fooK Pregled postova
Ufff 25-og probat klikati, u koliko sati ne znam.
Staro 22.11.2020., 08:15   #105
axo
Postovi: 1,428
Autor Joza_Seraf Pregled postova
Vjv u 15h, 25 tog.
https://www.amd.com/en/where-to-buy/...eries-graphics
E sad koji ducan ce imat pitaj babu
Staro 22.11.2020., 10:16   #106
fooK
Powaaa user
fooK's Avatar
Postovi: 160
A, nakon toga, ako propustim, čekamo dok se netko ne smiluje i pošalje novu pošiljku?
Kako glupa situacija zapravo, a još više što me iritira su ove fore sa cijenama. Nešto umjesto 500 eura kod nas košta 750. Osjećam se kao jelen ako nešto preplatim 50% više od inicijalno komuniciranje cijene 🤯
Pošteni trgovac: 1
Staro 22.11.2020., 10:36   #107
Joza_Seraf
Joza_Seraf's Avatar
Lokacija: Klc
Postovi: 568
nažalost to je tako. Ne znam kako će stanje biti na amazon.de.. Ja planiram ovako ionako uzet iz Švabije s obzirom da mi je rodbina tamo, pa malo i te dućane pratim
Staro 22.11.2020., 10:47   #108
PR3DA70R
PR3DA70R's Avatar
Lokacija: Yautja Prime
Postovi: 1,226
Cyberpunk 2077 won't have ray tracing for AMD Radeon GPUs at launch
Read more: https://www.tweaktown.com/news/76359...nch/index.html
Ovo će nagovoriti neke da uzmu RTX radije. Što će povećati potražnju RTX, ali možda smanjiti za RX?
Staro 22.11.2020., 10:59   #109
Manuel Calavera
Postovi: 14,584
Računaj da američke cijene, odnosno MSRP nema uključen porez, tako da računaj dolare pretvorit u eure x 1.25, pa na to još marže od 2% do 10% i to ti je ta cijena koja bi trebala biti. Ugrubo MSRPx9 za kune. Sve iznad toga je preplaćeno od zamišljenog
Uglavnom davno se trebalo pomiriti da ništa od gpu ove godine. Nvidija je priznala da zalihe neće biti dovoljne "nekoliko mjeseci"
Staro 22.11.2020., 11:38   #110
the_ghost
lar~
the_ghost's Avatar
Postovi: 1,557
Vec sam nekoliko puta vidio ovu teoriju dodavanja marze na MSRP, to ne funkcionira tako. MSRP dobavljaci u HR ne placaju (ili ako da, onda su glupi), oni dobivaju popust na MSRP, tako da ako je MSRP u europi (bez pdva) tipa 270E, oni ce dobiti 10% popusta na tu cijenu (osim sto su marze mozda manje). Tako funkcionira barem onaj ostatak IT industrije u kojem sam ja bio (a marze su znale biti i puno vece za vece projekte). Javna tajna je da ti npr Cisco daje cca 50% popusta na list price.
Staro 22.11.2020., 13:01   #111
sliver
Datum registracije: Jan 2010
Postovi: 149
Autor PR3DA70R Pregled postova
I mene ovo vuče na 3070 jer primarno radim upgrade radi maxanja te igre. Nekako se i dalje nadam da će se na 6800 XT moći vrtiti RT na 1440p.
sliver je offline   Reply With Quote
Staro 22.11.2020., 13:38   #112
Exomaniac
Datum registracije: Mar 2016
Postovi: 763
Ionako ništa nije, a niti će biti dostupno jedno 5 minuta nakon što izađu kartice tako da ne vidim šta brigate oko toga
Ali ako se dobro sjećam, mogao se i Witcher 3 HairWorks enejblati na HD 7970 u ono vrijeme dok je i jedno i drugo bilo popularno, tako da mislim da će se moći forceati i na AMD karticama RT. Kao i na Tomb Raideru ako se ne varam. A i vjerojatno će kroz mjesec-dva dodati i podršku za AMD kartice, ovo se odnosi na at launch
Staro 22.11.2020., 13:43   #113
Manuel Calavera
Postovi: 14,584
Moglo bi se čak dogoditi da AMD dobije ove RT bitke oko optimizacija u igrama, jer nvidija plaća tj. sponzorira svaki naslov da se ubaci njihov RT u igre, kao što znamo na primjerima u prošlosti to neće trajati vječno (physix, gameworks), dok će RDNA2 imati sve više "RT" naslova zbog konzola. Nešto tipa nabace ga samo na haubu od auta ili na lokvu asfalta , to vam je RT i vozi miško
Staro 22.11.2020., 13:52   #114
RimtuTiTuki
RimtuTiTuki's Avatar
Postovi: 1,635
Autor the_ghost Pregled postova
U pravu si, naravno da dobavljači imaju bolje cijene, ali..
MSRP nije isti za EU i USA, a Hr dobavljači računaju jako nepovoljan tečaj na EU MSRP - skoro 8kn/€.
I zato su cijene u HR dosta veće
Staro 22.11.2020., 14:05   #115
the_ghost
lar~
the_ghost's Avatar
Postovi: 1,557
Autor RimtuTiTuki Pregled postova
Ja bi to samo nazvao onime sto zapravo je, pumpanjem zarade (jer mogu).
Staro 22.11.2020., 14:23   #116
Manuel Calavera
Postovi: 14,584
Jbga da, rabat sigurno imaju, ali vidiš i po cijenama da to nije to.
Inače formula je od tipa koji je radio u "industriji" kod nas, a istu formulu (bez zaokruživanja konverzija, jer ih nema) sam našao od nekog tipa iz njemačke. Uvijek je ispadalo točno kod novih launcheva. Doslovce bude u 50-100kn na 3 soma
Staro 22.11.2020., 16:59   #117
Exomaniac
Postovi: 763
Niti jedna igra osim Quake 2 nema nikakvu eksluzivnu Nvidia tehnologiju, svi koriste standardan DirectX DXR. A Quake 2 ima takvu tehnogliju jer dotad DXR još nije bio finaliziran pa koriste Nvidia ekstenziju za Vulkan.
Staro 22.11.2020., 17:02   #118
Manuel Calavera
Postovi: 14,584
Da, ali pogledaj kakav utjecaj na perfomanse imaju nvidia sponzorirani naslovi sa RT na radeonke, a kakav AMD sponzorirani naslovi (npr. Dirt 5, gdje su brže i sa "RT")
Sve će to biti old school drkanje kao prije 5-10 god. kad je nvidia platila cryteku da simuliraju vodu ispod betona u Crysis 2, jer je veći perfomance hit imao na radeonke nego na njih
Misliš da je ovo slučajno što nvidijin RT u cyberpunku neće raditi na AMD? Pa ljudi su to platili. Kao i hairworks za witchera, a na kraju ispalo da radi normalno i na radeonkama kad se podesi kako treba (isto sabotaža jedne postavke)
Staro 23.11.2020., 08:59   #119
Gigi1
Postovi: 2,138
del
Staro 23.11.2020., 10:10   #120
imik
imik's Avatar
Postovi: 626
Dirt koristi samo sjene automobila i to u manjoj količini nego SOTR. Malo RT AMD je ok, više RT i performanse padaju.
imik je offline   Reply With Quote
