Staro 23.10.2020., 05:50   #1801
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,253
Fino! Premda meni nije jasno zašto se uopće više gledaju i koriste te brojke iz 3dmarka i ostalih bench only alata kada nemaju veze s realnošću.
Ono jedna grafa ima bolji rezultat u tim čudesima, a u stvarnosti je sporija u igrama i slično...
Čemu taj USB-C na grafi?
To je za VR headsete?
Tehnologija koja je IMHO odavno propala (opet).
EDIT:
AMD navodno priprema i grafe za rudare, bez video izlaza.
Slobodno me dodajte na PSN
Zadnje izmijenjeno od: Disco. 23.10.2020. u 05:57.
Disco je online   Reply With Quote
Staro 23.10.2020., 08:12   #1802
kiki86
Tehničar
Datum registracije: Dec 2011
Postovi: 1,076
usb-c se adapterima može u bilo koji izlaz pretvorit ako se ne varam
a sam po sebi je manji, pa mozda radi ustede mjesta, neznam...
Staro 23.10.2020., 08:22   #1803
MadBoY
MadModerator
MadBoY's Avatar
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
2017 su kupili Nitero, koji su radili na wireless VR headsetu. Možda izbace usput i neki VR headset.
Staro 23.10.2020., 09:01   #1804
Gigi1
Postovi: 2,138
Autor BusMaster Pregled postova
Alleged AMD Radeon RX 6000 “Big Navi GPU” Graphics Card PCB Leaks Out
Link: https://wccftech.com/alleged-amd-rad...pcb-leaks-out/
Citat:
AMD Radeon RX 6000 "Big Navi" GPU Scores Over 11,000 Points in 3DMark Firestrike?
In addition to the PCB leak, CapFrameX has reported that AMD's Big Navi GPU "Navi 21" delivers a score of 11,500 points in the 3DMark Firestrike Ultra benchmark. There are no details on which Big Navi SKU is the user referring to as there are three variants, the XL, XT, and XTX. Regardless, a GPU score that high puts the Big Navi GPU at around 8.5% faster than the GeForce RTX 3080 which is super impressive. If these numbers are for the reference card and the "XT" variant than there's no doubt that AMD has all eyes to steal the performance crown from even NVIDIA's flagship graphics offering, the GeForce RTX 3090.
yup, pisao sam tu u nekoliko navrata da ce se mnogi iznenaditi sa rasterizacijskim perf rdna2
Staro 23.10.2020., 10:50   #1805
HCS
Premijum
HCS's Avatar
Postovi: 1,360
AMD Radeon "Big Navi" PCB Allegedly Pictured
Sve vise informacija curi, i sve bolje to izgleda. Samo da cijena i dostupnost budu ok, Navi ce biti no-brainer.
Takoder, vjerojatno nebi smjelo vise biti onih bolnih problema s driverima na pocetku, jer realno nije nova arhitektura vise, a trenutni rade fantasticno.
Staro 23.10.2020., 12:45   #1806
BusMaster
BusMaster's Avatar
Datum registracije: Apr 2017
Postovi: 343
AMD Radeon RX 6800 XT “Big Navi” GPU Alleged 3DMark Benchmarks Leaked – Faster Than GeForce RTX 3080 at 4K, Slower In Port Royal Ray Tracing
Link: https://wccftech.com/amd-radeon-rx-6...tx-3080-at-4k/
Staro 23.10.2020., 12:54   #1807
RimtuTiTuki
RimtuTiTuki's Avatar
Postovi: 1,629
wow... Stvarno bi mogli ujebati nvidiju kao što su i intel...
Staro 23.10.2020., 17:00   #1808
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,578
Mogu povjerovat da su konkurentne ako isto idu po 350w, no opet smrdi ta 256 bit sabirnica i taj mem. bandwidth. Jedino što može biti da su te info netočne (performanse ili podaci o sabirnici) ili je ta cache shema neviđena
Staro 23.10.2020., 17:11   #1809
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,253
Autor kiki86 Pregled postova
E ako je tako, onda je to super.
@Manuel: Pa što nije ta shema već probana na X1 neki sićušni ESRAM koji je kao trebao biti super a na kraju ispao ćorak. Mislim da je ćorak bio zato jer ga devovi nisu znali iskoristiti, ali to isto bi se moglo desiti i sa RDNA2...ili bi to bilo kontrolirano kroz drivere ili sam HW, pa devovi ne moraju ništa implementirat u igre....?
Staro 23.10.2020., 17:28   #1810
Manuel Calavera
Postovi: 14,578
Ma to mora funkcionirati odmah bez ikakvih optimzacija, u protivnom 0 bodova
Staro 23.10.2020., 18:19   #1811
Gigi1
Postovi: 2,138
Autor Gigi1 Pregled postova
stvarno je tesko pogledati video i pokoji patent od pred par stranica sto sam stavljao
Staro 23.10.2020., 18:50   #1812
Sam Fischer
Džabe si krečio!
Sam Fischer's Avatar
Postovi: 5,190
Autor HCS Pregled postova
Iz tvoje tipkovnice u Božje uši, jer ja sam danas skoro kliknuo na 5700XT na Amazonu što bi bio jako glup potez, makar je cijena bila super (oko 2650kn).
Već mi je stvarno dosta čekanja xD
Staro 23.10.2020., 19:09   #1813
Manuel Calavera
Postovi: 14,578
A gle, dostupnost sigurno neće biti dobra, jer nikad nije pri launchu. To su neka ajmo reći pravila struke da se ne napravi mnogo zaliha pri launchu (radi potencijalnog povlačenja s tržišta ako se pojavi serijska greška).
Ne pomaže ni informacija da neće biti AiB modela ove godine (ili na kapaljku), stari leak, ali čini se istinit, jer "nit pisma nit razglednice" o AiB modelima, a kao što znamo curenje slika krene dva-tri mjeseca ranije, mjesec minimum. Stare informacije kažu da je AMD kasno poslao primjerke AiB partnerima (PCB, specifikacije)
Ne pomaže ni činjenica da nema nvidije, pa će sigurno i navala biti veća, što opet može utjecati na cijene...
Naravno ne mora biti paper launch kao nvidia, ali da će zalihe i cijene biti bajne na početku - malo vjerojatno
Staro 23.10.2020., 21:16   #1814
Sam Fischer
Džabe si krečio!
Postovi: 5,190
Hoćeš reć da sada ta 5700Xt i ne zvuči kao loša kupnja za te novce? Jer si me sad opet potpalio xD
Staro 23.10.2020., 21:23   #1815
Postovi: 8,163
Sljedeći tjedan budu poznati svi RDNA 2 detalji i onda, ako bude sranje, fino kreni u kupnju za RX 5700 XT. Čisto da se ne zajebeš, ako bude neki RX 6000 model zapravo RX 5700 XT rebrand, ali s nižom cijenom.
Staro 23.10.2020., 21:23   #1816
HCS
Premijum
HCS's Avatar
Postovi: 1,360
Ma nece ti bit toliki skok sa 1070etke. Bolje pricekati ovaj Navi.
Staro 23.10.2020., 22:05   #1817
Manuel Calavera
Postovi: 14,578
Ako pričaš o onoj asusici cooler je smeće. Jako treba paziti kod Navija, sapphire pulse ili red dragon minimum
Hoću reći da ćete teško kupiti nešto pametno u višim kategorijama ove godine...
Neke normalne cijene kao i zalihe se ne mogu očekivati niti od AMD-a
Staro 23.10.2020., 23:05   #1818
Sam Fischer
Džabe si krečio!
Postovi: 5,190
Pa to gruntam cijelo vrijeme. Kad upgradeaš, upgradeaj kako treba
Da, gledao sam tu Asusicu Dual običnu. Pa ima ok recenzije
Staro 23.10.2020., 23:13   #1819
Manuel Calavera
Postovi: 14,578
Dali u tim recenzijama ima obrađene sve 4 temperature - gpu, gpu hotspot, vrm i rak ranu - ddr6 temperature? Pretpostavljam da ne...
Nitko ozbiljan nije to recenzirao, rastavio itd. Cooler rang iznad - TUF je katastrofa, praktično tvornički neispravan (ddr6 - 110C), pa su radili reviziju koja ima EVO u imenu, no problem kod asus dual evo je što ima evo u imenu od starta tj. nije revizija coolera, a veoma upitno je dali je ispravan, kad im prve TUF i strix nisu valjale...
Staro 24.10.2020., 08:04   #1820
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,253
Donekle mu i drži vodu ova priča o razlozima nedostupnosti Amperea:
Staro 24.10.2020., 08:09   #1821
kopija
DIY DILETANT
kopija's Avatar
Lokacija: Čistilište
Postovi: 3,519
A i budu rasprodaje prethodne generacije. Strpljen-spašen. Uglavnom.
Staro 24.10.2020., 12:13   #1822
Zvonimir_s
Zvonimir_s's Avatar
Postovi: 406
..bas sam u razmisljanu kupnje neke grsficke..i od ove koju.imam (7950)..pojma.nemam.stomuzeti..aa...totalni kaos... Da cekam.ove Navi...il da trazim.nesto do cca 1500kn?
Zvonimir_s je offline   Reply With Quote
Staro 24.10.2020., 13:10   #1823
Manuel Calavera
Postovi: 14,578
Nešto novo do 1500kn nećeš imati sigurno nekoliko mjeseci
Staro 24.10.2020., 19:55   #1824
Zvonimir_s
Zvonimir_s's Avatar
Postovi: 406
ma gledam 580tke i 1060 suoer nesto..ili koje su vec i ne cini mi se bas kao neki drasticni napredak, koji bi imao za 5-6 godina koristenja.. Ovu imam sad..hmm..7-8...godina..
Staro 24.10.2020., 21:36   #1825
exzzy
exzzy's Avatar
Datum registracije: Aug 2014
Postovi: 843
Mozda zato kaj su tu 4 godine stare kartice...
Staro 24.10.2020., 22:44   #1826
suedamA obmaR
Game, PC ,motobikes, bike
suedamA obmaR's Avatar
Datum registracije: Jan 2010
Lokacija: Sibenik
Postovi: 776
Autor Zvonimir_s Pregled postova
Nemas sta cekat, nece ove nove kartice isgurno biti jeftine.Za oko 500kn rx570, 580, 480 ili R9 290, Furry za malo vise. Od nvidie GTX 970 ili 1060.
Ili do 1200kn Gtx 1070, 980ti ili Vega 56.
suedamA obmaR je offline   Reply With Quote
Staro 25.10.2020., 12:09   #1827
JC Denton
dr. sc. tech. dipl. ing.
JC Denton's Avatar
Lokacija: Rijeka-Opatija
Postovi: 3,164
RX580 8GB za cca 700kn, mozda uz jos nesto garancije. Puno isplativije od GTX1060 6GB, a u današnjim igrama obično i malo brže. To ti je cca 90% brze od toga sto imas, za 1080p vise nego dobro jos par godina (za casual gamera).
Ako trazis nesto brže (dugotrajnije ili za 1440p u par godina starim igrama), potrazi polovne GTX1070 ili GTX1660Ti/Super (ova potonja obicno ide sa nesto garancije) za 1100-1200kn, odnosno cca 1500kn.
Od novih grafa još ne očekujem nešto novo u klasi sub 2000kn. No, možda me iznenade...
Zadnje izmijenjeno od: JC Denton. 25.10.2020. u 12:25.
Staro 25.10.2020., 12:50   #1828
PR3DA70R
PR3DA70R's Avatar
Lokacija: Yautja Prime
Postovi: 1,221
RX580 8GB za 700 kn. Gdje? Daj 'vamo.
Staro 25.10.2020., 13:08   #1829
guerra
Datum registracije: May 2019
Postovi: 522
Autor PR3DA70R Pregled postova
Sta ce ti 8gb na rx 580? Pa to je bila jedna od zescih prevara sto su prodavali te kartice sa nepotrebnih 8gb vram-a kad ce na toj kartici puno prije gpu nego vram postati bottleneck...
guerra je offline   Reply With Quote
Staro 25.10.2020., 13:19   #1830
PR3DA70R
PR3DA70R's Avatar
Postovi: 1,221
Ma ciljam GTX 1060 3GB ili RX 570 4GB radije al možda bi uzeo i RX580 ako se nađe.
Na integriranoj sam pa bi htio bar nešto za 1080p gaming dok ne vidim koju novu grafu ću.
Prodao i PS4 a krenuli kišni dani a ja ne mogu niš zaigrat. Serije mi dojadile...
Malo me kriza lovi. xD
