|  18.10.2020., 13:22 | #1 |
| Registered User Datum registracije: Jul 2015 Lokacija: Vukovar
					Postovi: 288
				(riješeno) Crni ekran, ne mogu reinstall windowsa
			 Dobio sam jedan stariji laptop s neispravnim windowsima XP, koji bi mi dobro došao za neke manje zahtjevne radnje ali je problem šta nikako da reinstaliram windowse  Kao prvo kad upalim comp pojavi se onaj crni ekran sa slijedećim sadržajem: We apologize for the inconvenience, but Windows did not start successfuly recent hardware or software change might have caused this. If your computer stopped responding, restarted unexpectedly or was automatically shut down to protect your files and folders, choose Last Know good Configuration to revert to the most recent settings that worked. If a previous startup attempt was interrupted due to a power failure or bt the Power or Reset button was pressed, or if you aren't sure what caused the problem. choose Start windows Normally. Safe Mode Safe mode with Networking Safe Hode with Comnand Prompt. Last Knoun Good Configuration Start Windows Nornally Use the up and down arrow keys to move the highlight to your choice. Šta god odabrao od navedenih 5 stavki stalno dolazi taj isti crni ekran Napravio sam programom “Rufus” Bootable Usb s “win 7”, odabrao taj Usb kao first boot device i opet taj isti crni ekran Nikako da započnem instalaciju Zna li ko kako da rješim taj problem |
|  18.10.2020., 13:45 | #2 |
| PizzoZder Datum registracije: Jan 2003 Lokacija: Umag
					Postovi: 12,613
				 | Ako imas cd, pokusaj sa cd-a bootat. Stariji lapovi su imali problem bootanja sa usb-a.
				__________________ Prodajem kucu na klizistu.. Nije puno presla..... Member Of PC Ekspert 100+kg Demolition Squad NAJNOVIJE = Povoljno RAM..http://www.downloadmoreram.com/... tor i AMD kupili.... NOVO! Prodajem visokokvalitetni tropleteni hardverski konac za fixiranje coolera |
|  18.10.2020., 13:50 | #3 |
					Postovi: 288
				 | Kažu mi neki da pokušam iz Dos-a pokrenuti "CHKDSK" ali neznam kako da uđem u Dos |
|  18.10.2020., 14:02 | #4 |
| Vocna iglica u mudante Datum registracije: Oct 2005 Lokacija: Beograd
					Postovi: 2,837
				 | da ti udje u safe mode, mogao si onda pokrenit cmd- i odatle napravit repair.. inače, ako ti ne prolazi ništa od ovih 5 stavki, nešt se sjebalo, što i sam možeš zaključit.. osobno nikakvi checkdsk i ostale pizdarije ne bi pokretao jer mislim da ne bi pomoglo.. probaj nabavit CD kopiju windowsa i vidjet dal će pokrenit.. kad startaš komp s usbom na kojem je win7, ne izbaci ti ni onu poruku "press any key to continue"?, odmah ti ponudi safe mode i ovo ostalo? u kojem formatu si napravio win7 usb? MBR ili GPT? ako to uopće ima veze s win7 Zadnje izmijenjeno od: John Creasy. 18.10.2020. u 14:13. |
|  18.10.2020., 14:26 | #5 |
					Postovi: 288
|  18.10.2020., 14:52 | #6 |
| ...samo te gledam... Datum registracije: Mar 2007 Lokacija: Zagreb
					Postovi: 2,832
				 | Vidi da li laptop uopće može vriti Windows 7: https://support.microsoft.com/en-us/...m-requirements I probaj kako je Nino naveo, bootaj s optičkim medijem, USB je postao funkcionalan kao bootabilan tek s novijim verzijama BIOS-a, ako je bio XP u pogonu na toj mašini onda je velika vjerojatnost da BIOS laptopa ne podržava USB boot. Čak bootanje i nije toliko veliki problem koliko je problem da se OS-u koji se instalira prijavi uređaj za koji on tek mora postaviti drajver, USB drajver je dosta problematičan ako nisu svi tehnički zahtjevi za on-the-fly pri instalaciji nisu podržani, pogotovo Windows 7 koji nemaju toliko podržanu dinamičku mogućnost mijenjanja drajvera bootabilnog uređaja kod samog bootanja kao što imaju Windows 10. |
|  18.10.2020., 15:09 | #7 |
| Moderator Datum registracije: Sep 2006 Lokacija: St
					Postovi: 23,548
				 | I opet pričamo o kruškama i jabukama umjesto da se precizno naveo model lapa   99% da W7 radi na tom (starom) lapu, naravno da treba prvo detektirati jeli sa hdd - om sve ok (koliko može biti obzirom na starost). Odnesi nekom tko zna šta radi i bude W7 brzo u funkciji. |
|  18.10.2020., 16:13 | #8 |
					Postovi: 288
				 | Shit A evo sad sam umetnuo CD windows XP i pokrenuo instalaciju i dolazi poruka: "Setup did not find any hard disk drives i nstalled in your computer" Problem je šta neznam koji je model laptopa, jer su sve naljepnice pohabane |
|  18.10.2020., 16:23 | #9 |
					Postovi: 23,548
				 | Zato jer treba pripremiti install cd da ima integriran drajver za sata kontroler i eventualno usb ... Rekoh da ti treba netko sa iskustvom i znanjem. Probaj sa W7 cd - om. Ako nemaš nikoga, možeš probati sa W10 smetjem samo za test i da pokupiš info jer će vjerojatno raditi sporo i nikako a kasnije će te koštati živaca. |
|  18.10.2020., 16:29 | #10 |
					Postovi: 2,837
				 | Hmm pa zar nije da su sve "novije" verzije XP-a imale već sata i ostalo u sebi? Ajd one prve verzije XP-a da tako kažem.. Nije valjda da je CD s XP-om iz davne 2001. godine? za win7 u redu, ali isto tako, pretpostavljam da nije original (garant nije ni XP no ne bitno ovdje), lako se može skinit verzija koja već ima sve integrirano u sebi |
|  18.10.2020., 16:30 | #11 |
| Premium Datum registracije: Sep 2018 Lokacija: tu
					Postovi: 3,566
				 | Imaš Plob boot manager koji se rokne na CD pa on osposobi kvazi boot s USBa https://www.plop.at/en/bootmanager/download.html To ti je praktično jedini bootabilni CD koji ti treba. Što se tiče diska, moguće da je disk u banani ili kako niki kaže imaš upaljen SATA pa XP ne zna što da radi s njime. U tome slučaju, da potvrdiš, imaš vjerojatno u BIOSU opciju IDE koja se može postaviti na SATA ili AHCI te nešto kao Legacy ili sl. Ovo potonje bi trebalo omogućiti XP da detektira HDD. Ako je toliko star laptop i original HDD je u njemu, vjerojatno je u dosta lošem stanju, ako je uopće funkcionalan. Ja svakako ne bih gubio vrijeme na instaliranje XPa, puno bolje se prešaltati na neki light linux, tipa xubuntu ili bodhi. |
|  18.10.2020., 18:41 | #12 | |
					Postovi: 23,548
				 | Citiraj:
 Ako je lap "dovoljno" star onda bi W7 možda mogao proći (bez da se i njemu dodaje sata drajver). Da nisi tako daleko već bi riješili / detektirali blem. Za koji os dignit, definitivno W7 ili neki light linux kao Zorin OS Lite ili Linux Mint Xfce. Kad se već spominje linux distribucije, možeš ih upotrebiti u Live varijanti (samo boot sa cd - a): - za detekciju šta je sa hdd - om - za hw detekciju o kojem se lapu radi - za vidjeti jeli ti paše verzija linux - a Računaj da je sve usporeno u Live varijanti jer se os vrti sa sporog cd - a umjesto sa hdd - a. | |
|  18.10.2020., 20:20 | #13 |
					Postovi: 288
				 | Evo sad sam opet pokušao instalaciju WinXP sa DVD-a i započela je instalacija i nakon provjere dolazi poruka "Setup did not find any hard disk drives installed in your computer" E sad neznam jeli to neispravan HD ili možda spoj neki Ima li neki način da ustanovim ispravnost HD-a |
|  19.10.2020., 07:55 | #15 |
| White Rabbit Datum registracije: May 2006 Lokacija: -
					Postovi: 5,050
				 | Bote led...dode po savjet i onda i dalje radi po svome. 1. Bootaj Live Linux da vidis dal uopce unutra je disk i jel ispravan 2. XP u sebi nema SATA AHCI drivere > zato najvjerojatnije ne nalazi HDD 3. Mozes probat sa E2B napravit bootabilni USB, slozi u BIOS-u da boota najprije sa USB-a, ja sam tako imao srecu na par starih krtnija pa gore kopiras Win7 32bit ISO https://www.fosshub.com/Easy2Boot.html 4. Ako ovo gore neznas sam napravit ili ti jednostavno nejde napravi kao sto je Nino - reko - daj lap u ruke nekom tko se kuzi u posao. P.S. - koji je uopce lap u pitanju? |
|  19.10.2020., 12:44 | #16 |
					Postovi: 288
				 | Za nevjerovat proradili windowsi U Biosu pod ATA/IDE configuration je bilo namješteno AHCI i kad sam promjenio na IDE proradili windowsi I sad sam vidio neke podatke o laptopu „ASUS Eee PC 1005HA“ Procesor Intel Atom, 1666 MHz Sistemska memorija 1 GB Tvrdi disk 160 GB I sad htio bi povećati memoriju na 2 GB ali neznam koju vrstu memorije da tražim Zadnje izmijenjeno od: Žak Onanis. 19.10.2020. u 12:50. |
|  19.10.2020., 12:57 | #17 |
					Postovi: 2,837
				 | https://www.asus.com/Laptops/Eee_PC_...pecifications/ 1GB DDR2 SO-DIMM ( MAX to 2GB RAM available) znači ddr2 so-dimm za laptope... trošak 50-100kn polovno i koji su windowsi na laptopu? Xp ili win7? to se netko igrao u biosu, možda isto probao stavit win7 pa zaboravio vratit na IDE u biosu |
|  19.10.2020., 14:10 | #18 |
					Postovi: 288
				 | Windows XP, neznam da li da probam instalirat Windows 7 (32 bit) jer neznam da li ču nač najvažnije drivere za win7 (grafika, zvuk, wireless itd) |
|  19.10.2020., 14:13 | #19 |
					Postovi: 2,837
				 | trebao bi moći jer na onom linku i piše da podržava win 7 Genuine Windows® 7 Starter Genuine Windows® 7 Home Basic Genuine Windows® 7 Home Premium Genuine Windows® XP Home (*Pre-installed with Microsoft Office Home & Student 2007 60-day Trial and vary by country) |
|  19.10.2020., 15:41 | #20 |
					Postovi: 23,548
				 | Ne nego netko tko je prije prčkao (nazovi instalirao) nije znao odraditi posao kako treba. Po defaultu je u Bios - u AHCI mod rada ali tada treba odg. sata drajver, prebacivanjem u IDE mode drajver ne treba ali obično radi malo sporije. Na supportu ima sve što treba > https://www.asus.com/Laptops/Eee_PC_...Desk_Download/ Za ram, nezgodan detalj je da ima samo jedan slot pa moraš zamijeniti postojeći, info: http://eeepc1005.blogspot.com/2009/09/ram.html https://www.mrmemory.co.uk/memory-ra...netbook/1005ha naravno da probaš naći lokalno, polovno. Netko će reći da je suludo ulagati u taj lap ali ako čovjeka veseli i ako jeftino nađe neki sata ssd onda će tek "poletiti", info: http://eeepc1005.blogspot.com/2009/09/upgrade-time.html Taj malac je zgodan za nositi okolo ali računaj da je unutra Atom N270 kojeg je vrijeme pregazilo ali može poslužiti za lagane zadatke. Zbog toga možda je još bolje dignuti prilagođeni lagani Linux. Za žuntu: https://en.wikipedia.org/wiki/Asus_Eee_PC https://en.wikipedia.org/wiki/Xandros https://ninelizardsblog.blogspot.com...ok-1005ha.html https://wiki.debian.org/DebianEeePC preciznije treba staviti Debian Xfce ... |
|  19.10.2020., 16:05 | #21 |
| Premium Datum registracije: Mar 2006 Lokacija: Opatija
					Postovi: 34,005
				 | Na njega je bolje staviti Linux jer zbog slabog CPU i malo RAMa šteka s bilo kojim winsima, čak i s XPom.
				__________________ "Dvije stvari su beskonačne - svemir i ljudska glupost. Za svemir nisam siguran." A. Einstein |
|  19.10.2020., 16:37 | #22 |
					Postovi: 288
				 | Ma on bi mi bi bio samo kao neka rezerva i na njega bi radio (pisao) u Wordu, i pomalo surfao. I to bi bilo sve Zašto bi ga bacio u smeće ako služi, kužite |
|  19.10.2020., 16:57 | #24 |
					Postovi: 23,548
				 | Evo prijedlog: - u Bios - u vrati na AHCI - skini Linux Mint 19.3 Xfce 32 bit > http://www.mirrorservice.org/sites/w...xfce-32bit.iso - sa Rufus - om taj iso prebaci na neki usb stick - boot i instaliraj Ako zapneš pitaj, Xfce je lagani gui i raditi će koliko - toliko upotrebljivo. |
|  19.10.2020., 20:52 | #26 |
					Postovi: 5,050
				 | Problem je da je to tak spor i slab komp da cak ni sa WinXP nije nikad radilo prihvatljivo. Slusaj Ninu - Linux + XFCE ili mozda cak Linux + LXDE kombinacija koja ce jedino kolko - tolko prihvatljivo radit na tome...s nekim se starim kantama ne isplati zahebavat jednostavno. |
|  20.10.2020., 10:46 | #28 |
					Postovi: 288
				 | Ok probaču popodne instalirat taj Linux pa ču javit kak je prošlo |
|  20.10.2020., 15:27 | #29 |
					Postovi: 288
				 | Prvi put čujem za taj LXDE, jeli to neki dodatak Linuxu Kako se to instalira, da li nakon instalacije Linuxa ili ...... Gdje da nađem link za download, guglao sam ali ga ne nalazi Ako nije problem pojasnite mi malo |
|  20.10.2020., 19:02 | #30 |
					Postovi: 23,548
				 | LXDE ili Xfxe su GUI tj. front end slikovnice a ima ih još. U #24 postu imaš uputu i link na Linux Mint 19.3 Xfce 32 bit iso file koji trebaš prebaciti na usb stick kako bi odradio instalaciju. Za to možeš upotrebiti Rufus portable > https://github.com/pbatard/rufus/rel...ufus-3.12p.exe ili Etcher-Portable > https://github.com/balena-io/etcher/...le-1.5.109.exe Kada "napraviš" usb stick ide boot sa njega i instalacija ... |
