Povratak   PC Ekspert Forum > Računala > Kriptovalute
Staro 03.08.2020., 19:35   #1441
domy_os
domy_os's Avatar
Postovi: 18,852
Crypto.com je danas svima opalio veliku šamarčinu... Da sad ne pasteam cijeli mail:
In order to maximise the benefits arising from increasing use of blockchain technology, streamline our operations and leverage the advanced capabilities of the Crypto.com Chain, we are implementing the MCO Swap Program.
The process for swapping your MCO, and the terms and conditions that apply to this process, are set out below.
What is the MCO Swap Program?
At its core, MCO is a blockchain-based transferable representation of attributed functions of the Smart Contract System.
There will be no change to this core functionality, but we are expanding MCO functionality and representing it in a new way. Specifically, the MCO Swap Program will involve combining the current functionalities of MCO, with CRO’s utility and technology, in a “one stop shop” token to enable a streamlined Crypto.com ecosystem. The swap program will also serve to leverage the advanced capabilities of the Crypto.com Chain, in preparation of its upcoming mainnet launch.
Once the swap process is complete:
- The Crypto.com ecosystem will use one streamlined token (CRO) with the combined functionality, rather than two separate tokens (CRO and MCO).
- All functions currently attributed to MCO will still exist and will be preserved, but will be enhanced and represented by CRO.
- MCO that is not swapped will still exist and circulate on the Ethereum blockchain as ERC-20 tokens, but Crypto.com will no longer support these tokens and no Crypto.com service or product will require or permit usage of these tokens.
Znači, od danas za novu karticu moraš stakeati više nego ČETIRI puta veći iznos u protuvrijednosti USD.
https://crypto.com/en/cards.html
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 03.08.2020., 19:55   #1442
d0X
Kostolomac
d0X's Avatar
Postovi: 1,493
Šupčarski potez prema novim korisnicima. Ali barem postojeći zadržavaju beneficije.
Will my MCO stake also be swapped under the MCO Swap program? What happens to my MCO staking benefits?
Yes, your MCO stake will be converted at the MCO Swap Rate. However, the existing staking benefits that you enjoyed before performing the swap will remain unchanged.
To illustrate, if you have staked 500 MCO before performing the swap, your 500 MCO stake will be converted into a 13,820 CRO stake. You will continue to enjoy the same benefits (e.g. 3% cashback, Spotify and Netflix rebates, among others). If you decide to un-stake your CRO, 13,820 CRO will be returned to your CRO Wallet.
As highlighted the example above, you do not have to stake more CRO to retain your staking benefits (to reach the 50,000 CRO tier). However, If you decide un-stake your 13,820 CRO stake, you will have to re-stake the full 50,000 CRO to regain the same benefits.
PSN Steam
Staro 04.08.2020., 13:32   #1443
GrimReaperKC
wannabe expert
GrimReaperKC's Avatar
Lokacija: Koprivnica
Postovi: 155
Autor domy_os Pregled postova
objavili danas da ce smanjiti cak u odnosu na prvotno stanje, tak da eto sad vam je prilika napraviti upgrade tko može.. ja pičim na icy white karticu
GrimReaperKC je offline   Reply With Quote
Staro 04.08.2020., 13:51   #1444
d0X
Kostolomac
d0X's Avatar
Postovi: 1,493
Autor GrimReaperKC Pregled postova
Bome si dobar kad imaš 100k kn za zafrkanciju Ostajem na Jade Green, previše mi je to para.
PSN Steam
Staro 04.08.2020., 18:02   #1445
domy_os
domy_os's Avatar
Postovi: 18,852
Čestitam! I naravno nakon svake fork/swap igranke, valute propadaju, ali počelo se lagano oporavljati čim su smanjili stake iznose za pet puta...
Prvi april je davno prošao...
Meni je jučer Crypto.com aplikacija prestala raditi. Kliknem i traži da ponovno instaliram, a već je instalirana. Onda sam morao skroz uninstall pa install i prijavu.
Staro 04.08.2020., 18:04   #1446
PR3DA70R
PR3DA70R's Avatar
Lokacija: Yautja Prime
Postovi: 1,226
Wut, zar toliko povjerenja imaš u to?
Ne usudim se držat gore ni za crvenu kamo li za bijelu. A nisam se još ni registrirao. XD
Staro 04.08.2020., 18:19   #1447
domy_os
domy_os's Avatar
Postovi: 18,852
Pitanje koliko je pravog fiata stavio gore. Ja od fiata nisam ništa stavio, a trenutno sam i bez kartice na 15000 kn. Kad krene sjedati cashback i referrali, krenut će se još brže penjati.
Staro 04.08.2020., 19:33   #1448
GrimReaperKC
wannabe expert
Postovi: 155
ne vjerujem u fiat, pogotovo "pravi" fiat .
razlog zbog kojeg sam u kriptu. ljepse mi je drzati "keš" u kriptu, pogotovo npr "u kartici" od koje imam višestruke benefite nego da mi keš doma stoji,ili da ga bankari vrte i sebi trpaju u dzep.
stvar je mindseta i perspektive.
kartice su sada full povoljne za uzet prvi put (ili za upgrade) pa sam samo predlozio da si razmotrite to. *not a financial advice*
btw jos jedna dobra vijest je da su našli alternativu za wirecard
Staro 04.08.2020., 19:44   #1449
PR3DA70R
PR3DA70R's Avatar
Postovi: 1,226
Da ali nemaš nikakve sigurnosti. Opletu neki fake hack scam i obustave sve transakcije, blokiraju ti račun i ciao. Kao u svim dosadašnjim slučajevima sa mjenjačnicama. Šta možeš u tom slučaju?
Ne znam, možda zabrijavam bezveze, ali skeptičan sam.
I ja ću radije držat u kriptu sve. Ali na ledgeru, ne na nekom tuđem "računu".
Staro 04.08.2020., 20:25   #1450
neverin
Datum registracije: Dec 2017
Postovi: 219
Nemam nikakvu kripto karticu pa sam se danas prijavio na Wirex. Vidim da imam btc, eth.. accounte tj. adrese. To znači da samo trebam poslati kripto na navedenu adresu odakle hoću, sa svog walleta, ili bilo kog exchangea? Nisam našao nikakva pravila o tome.
Koliko približno mogu staviti kripta na karticu dnevno, mjesečno i godišnje a da to ne bude odmah sumnjivo i da me ne traže dokaze odakle mi?
Nude mi da linkam svoje postojeće hr bankovne kartice s njihovom, koliko je to mudro i da li sam odmah time linkan i sa našom PU?
neverin je offline   Reply With Quote
Staro 04.08.2020., 20:35   #1451
GrimReaperKC
wannabe expert
Postovi: 155
Autor PR3DA70R Pregled postova
realno danas ti ništa nije sigurno, i sve ti je manipulirano. zlato,dionice,nafta,banke.. optuze me za terorizam zatvore mi u banci račun, zaplijene sve. kome cu se zalit?
naravno, da meni nije sve na Crypto . com, trenutno je nešto više od 50% jer sam investirao u upgrade kartice,al obicno 60-70% drzim na ledgeru..
risk management je bitan, nismo hazarderi ne?
Staro 04.08.2020., 20:44   #1452
PR3DA70R
PR3DA70R's Avatar
Postovi: 1,226
Ne pričam o tome što ćeš hodlati i što će te potencijalno odvesti u "underwater realms" zauvijek. Nego kako ćeš izgubiti velik dio investicije jer si je povjerio nekome na čuvanje. Kao npr. crypto.com.
Gle takav scenario je nerealan jednak kao scenerio da će se hrvatska za dvije godine izvući iz dugova. Priča o hakiranju takvih sajtova je daleko realnija.
Just sayin'.
Treba biti na oprezu sa tim. Da ne bi bilo plakanja na kraju.
Staro 04.08.2020., 20:51   #1453
GrimReaperKC
wannabe expert
Postovi: 155
Just sayin'.
sve 5.. nisam friski u spaceu, nisam ni dugo baš. rana 2017.
svjestan sam rizika
Staro 05.08.2020., 05:50   #1454
kopija
DIY DILETANT
kopija's Avatar
Lokacija: Čistilište
Postovi: 3,571
Autor neverin Pregled postova
1. Samo pošalješ sa bilo kojeg walleta/exchangea.
2. Možeš staviti kolko hoćeš, ali imaš limite koliko možeš potrošiti. Limiti postoje da ne bi zašao u "sumnjivu" zonu.
3. Napravio si KYC proceduru kad si se registrirao, to znači da PU može dobiti uvid u transakcije s karticom. Ako te muči PU, jedina sigurna metoda je prodat nekom putem foruma, "pare na sunce" metodom.
Moguće je BESPLATNO produžiti W10 sigurnosne nadogradnje do 2028!
Staro 05.08.2020., 08:08   #1455
neverin
Postovi: 219
Ne mislim povlačiti ne znam koliko, za to imam uplate kripta iz hr sa računima. Samo ne bi htio da zbog nekog sitniša moram predavati joppd i slično jer se to sa takvom karticom beskrajno komplicira, zbog broja transakcija, tečaja. Radje bi si isplatio direkt na tekući isto kripta koliko sam i uplatio sa čistim računima u kunama.
Dakle zanima me koliko se može na Wirex staviti kripta a da Wirex oko toga ne pravi probleme, ili prijavljuje kome. Vidio sam ograničenja samo za isplate, da imam takav prihod u kriptu ne bi ovdje postavljao pitanje.
Staro 05.08.2020., 09:01   #1456
Nbdy32
Datum registracije: Aug 2016
Lokacija: Bestovje,Sv.Nedelja
Postovi: 2,821
Ja majnam direktno na wirex, imam tamo nešto love,do sada nisam imao nikakvih pitanja od njih ...
Niti od naših za prebacivanje na tekući ...
Nbdy32 je online   Reply With Quote
Staro 11.08.2020., 13:27   #1457
kopija
DIY DILETANT
kopija's Avatar
Postovi: 3,571
Da li je netko nedavno naručivao Wirex karticu?
Ja čekam već mjesec dana da mi stigne, gubim nadu pomalo.
Staro 11.08.2020., 14:45   #1458
Nbdy32
Postovi: 2,821
Maher - čak i mislim da ju je relativno brzo dobio ...
Ja sam svoju čekao čak i 2 mjeseca,ali onda je bilo shipping po zeljama,pa smo mi malo kasnije došli na red :-)
Staro 11.08.2020., 15:05   #1459
MAHER
Postovi: 1,583
Cca 4 tjedna sam ju cekao, tokom lockdowna dosla
MAHER je offline   Reply With Quote
Staro 11.08.2020., 18:45   #1460
kopija
DIY DILETANT
kopija's Avatar
Postovi: 3,571
Hvala, bio sam u iskušenju da ih idem prcat putem chata.
Strpljen, spašen. Valjda.
Staro 11.08.2020., 19:07   #1461
Nbdy32
Postovi: 2,821
A gle,daj ih malo ... :-)
Staro 13.08.2020., 06:12   #1462
kopija
DIY DILETANT
kopija's Avatar
Postovi: 3,571
Autor Nbdy32 Pregled postova
Nisam mogao odoliti pa poslao email. Odgovorili promptno.
Kartica stigla jučer.
Jel moram na nešto paziti glede Wirexa?
Obratiti pažnju na sitna slova?
Jel prolazi plaćanje svugdje?
Staro 13.08.2020., 11:42   #1463
Nbdy32
Postovi: 2,821
Da,ja kupovao od tommy-a do hgšrota, lokomotive mi netrebaju još :-)
Imaš o njihov povrat za kupovinu ...
Paziti,ne koliko si prebaciš na karticu,toliko ćeš i moć potrošiti :-)
Staro 26.08.2020., 11:08   #1464
GrimReaperKC
wannabe expert
Postovi: 155
jel dobio tko Crypto.com karticu u skorije vrijeme?
Evo ja vec 13 radnih dana cekam, status je jos issued.
Kad je bila ona navala u EU i sa zelenom(tier 3) sam cekao 10 radnih dana na shipped.
Osjećam se pomalo hendikepirano bez kartice
Staro 26.08.2020., 11:09   #1465
Nbdy32
Postovi: 2,821
Šparaj :-)
Staro 26.08.2020., 11:43   #1466
domy_os
domy_os's Avatar
Postovi: 18,852
Meni je crvena metalna poslana prije tjedan dana i danas mi stigne plastična koja naravno ne radi. A status issued mi je stajao skoro mjesec dana.
Staro 26.08.2020., 12:25   #1467
GrimReaperKC
wannabe expert
Postovi: 155
to su ti vj poslali prvo pa naknadno crvenu,zato plava ne radi jer je crvena aktivna.
dobro znači bitno da šalju i da stiže.moja je vj na putu al status nije promijenjen.
Staro 31.08.2020., 21:38   #1468
domy_os
domy_os's Avatar
Postovi: 18,852
Danas stigla crvena metalna, aktivirana, dodana u Curve, loadao odmah nešto love s deviznog računa da ne diram crypto i sve fercera.
Staro 01.09.2020., 07:44   #1469
GrimReaperKC
wannabe expert
Postovi: 155
odlično, čestitam
kod mene još uvijek ništa, čuo sam se sa supportom kažu da je kartica spremna da bude poslana
Staro 02.09.2020., 01:32   #1470
domy_os
domy_os's Avatar
Postovi: 18,852
odlično, čestitam
Hvala.
A stara kartica ti i dalje radi za vrijeme dok čekaš novu?
