|  05.08.2020., 23:01 | #1 |
| MiningMod Datum registracije: Jun 2005 Lokacija: Zagreb
					Postovi: 8,715
				Ethereum (ETH) mining RX5500XT/ 5600XT / 5700 / 5700XT
			 Bilo mi malo dosadno, pa eto da i to probamo   Prva na test je pala Asrock Challenger RX 5500 XT 8GB * Trenutna cijena navedene je oko 1800 kn * Najjeftinija trenutno RX 5500 XT 8GB je Powercolor 1580 kn .png) SimpleMining OS + phoenixminer-v5.1b Code: Core MHz: _______ Memory MHz: _______ Core undervolt: _______ Memory UV (MVDD): _______ Aggressive undervolt: OFF Powerstage: 5 Target Temperature ℃: 80 Minimum Fan speed %: 65 Eth: New job #1e42ef0f from ssl://eu1.ethermine.org:5555; diff: 4000MH Eth speed: 25.407 MH/s, shares: 1/0/0, time: 0:01 Code: Core MHz: 1000 Memory MHz: 950 (nema učinka preko toga) Core undervolt: 850 Memory UV (MVDD): _______ Aggressive undervolt: OFF Powerstage: 5 Target Temperature ℃: 80 Minimum Fan speed %: 65 Potrošnja iz utičnice (+AthlonX2+4GB Ram): cca 120W Eth: New job #4376fdc5 from ssl://eu1.ethermine.org:5555; diff: 4000MH Eth speed: 27.550 MH/s, shares: 1/0/0, time: 0:02 Code: ... |
|  06.08.2020., 06:32 | #2 |
| DIY DILETANT Datum registracije: Jan 2009 Lokacija: Čistilište
					Postovi: 3,638
				 | Mutno se sjećam se da je bila neka radeonka u ovo doba 2017-e u Linksa na akciji za nekih 1400kn. Bio ultimativni best-buy. Sapphire 480 4GB? Ili 470? Kolko je gutala struje i koji je hashrate bio? |
|  06.08.2020., 11:16 | #4 |
| Premium Datum registracije: Sep 2005 Lokacija: zagreb
					Postovi: 1,363
				__________________ AMD Ryzen 5900X; Gigabyte Aorus X570 Elite; Corsair Vengeance RGB Pro SL DDR4 2X16 Gb 3600 Mhz; AMD Radeon Gigabyte 7900 XTX; SSD Patriot Viper VP4300 PCIe m.2 GEN4 2 Tb;Lian Li 011 Dynamic EVO; LG C2 |
|  09.08.2020., 11:58 | #5 |
| Premium Datum registracije: Feb 2017 Lokacija: Osijek
					Postovi: 119
				 | Isprobao sam i ja svoju XFX RX 5600 XT 12Gbps 6GB GDDR6 THICC II Pro Phoenix miner 5.1c + Windows 10. Postavke su: cclock 1230 MHz, cvddc 800 mV, mclock 1800 MHz, mvddc 850 mV S tim postavkama hashrate je 39,19 MH/s i potrošnja same grafičke 100W iz utičnice. https://imgur.com/a/bVSnVP8 Na ovoj grafičkoj najviše što sam uspio klokati memoriju a da je stabilna je 1800 MHz. Najveći hashrate koji sam uspio izvući je 41 MH/s i potrošnja 110W, ali ruši se nakon nekog vremena. Možda bi na nekom mining OS-u radilo bolje nego na windowsima. Vidio sam da neke grafičke idu i 42MH/s, ali i ovo je sasvim ok. Po ovome bi rig sa 6xRX 5600XT davao oko 235-245 MH/s i trošio oko 700W. Ako netko planira kupiti XFX RX 5600 XT 6GB GDDR6 THICC II Pro, pripazite na memoriju koju dobivate zato što XFX ne nudi BIOS za nadogradnju sa 12Gbps na 14Gbps, nego postoji ista verzija grafičke samo s bržom memorijom. Zadnje izmijenjeno od: damba_. 09.08.2020. u 12:03. |
|  09.08.2020., 13:29 | #6 |
| Premium Datum registracije: Aug 2016 Lokacija: Bestovje,Sv.Nedelja
					Postovi: 2,834
				 | Koju ti memoriju imaš ??? micron,hynix,samsung ??? Jesi modao bios na toj kartici ??? Radeon RX 5600 XT 6GB ETHASH 1250 - 925 - Micron - 0.800 - 42.86 - 116 - PhoenixMiner 4.9c - CL 19.50 - 2.7W/MH - WhiteSpot Core clock - Mem clock - Memory type - Stable V - Hash rate - Watts - Miner -Driver - W/H - Source Zadnje izmijenjeno od: Nbdy32. 09.08.2020. u 13:36. |
|  09.08.2020., 13:51 | #7 |
					Postovi: 119
				 | Ne znam koja je memorija jer u GPU-Z ne piše ništa. Gdje to mogu provjeriti? Nisam modao bios. Probao sam s RedBios editorom kopirati tajminge sa 1550 MHz na 1750, 1800, 1875 i 2000, ali nisam mogao flashati taj bios, izbacio mi je error. To je bilo s prvim biosom, ovaj drugi nisam probao modati. Je li kod tebe modani bios ili original? |
|  09.08.2020., 15:41 | #8 |
					Postovi: 2,834
				 | Ovaj benchmark je sa mmpos stranice,dečki tamo testiraju raznorazne kartice ... Zato sam ti i stavio da probaš ... GPU-z bi trebao pokazati koja je memorija na kartici ... Ja imam samo 570 Nitro+ .... :-) |
|  19.08.2020., 21:59 | #9 |
| Premium Datum registracije: Aug 2006 Lokacija: Zagreb
					Postovi: 209
				 | Pozdrav, Da li netko ima deju zakaj na Red devil RX5700 nemrem updejtat bios više? Prvi put sam uspio, ali više ne da. Prvi put sam uspio ali sam zaboravio editirati sa power toolsom da se može malo više overclockati. Vratio sam na tvornički bios preko FreeDosa prema uputama koje sam našao, ali modificirani bios ne da više nikako. Kaže da ne može obrisati rom? Jel ima neku zaštitu ili ima neka caka koju ne znam? Hvala |
|  20.08.2020., 22:45 | #10 |
					Postovi: 2,834
				 | Jel da čitati bios ??? Probaj isčitati bios i vratiti nazad,bez modifikacije, ako ide,onda taj bios editiraj i probaj vratiti ... Jel ako si stavio noviji bios, stariju verziju neće prihvatiti ... |
|  24.08.2020., 21:51 | #11 |
| Premium Datum registracije: Dec 2017 Lokacija: Istra
					Postovi: 219
				 | Rig 5xRx5700 3xAsus DUAL-RX5700-O8G-EVO, 8GB 1xASRock Radeon RX 5700 Challenger D 8G OC 1xMSI Radeon RX 5700 XT MECH OC sve originalni bios 5.6.0-200807--hiveos-beta, AMD driver OpenCL 19.50 phoenixminer-ver. 5.0b i druge 840W iz zida, clock 1300/900, core volt 775, 252-257 Mh/s, temp core 60-66 temp mem 92-102, stale shares 18% stabilno nekoliko sati NHOS 1.2.0 low power mode, miner ? 1080W iz zida, clock ?/?, core volt ?, 251 Mh/s, core temp 64-76, mem temp ? stabilno nekoliko sati mmpOS phoenixminer-ver. 5.1c 852W iz zida, clock 1330/915, core volt 800, 264 Mh/s, core temp 56-64, mem temp 88-94 nema stale shares Nije stabilno ni 30 min. prvo dobijem poruku kartica xy has low hashrate, onda ide restart minera, drugi put bude neka druga, ne znam uzrok Nema skoro nikakve razlike u hashrateu medju karticama, ili su sve 50 Mh/s ili sve 53 Mh/s. NHOS previše troši uz najslabiji hashrate. HiveOS previše grije i proizvodi stale shares kako god mijenjao clockove, voltažu i verzije minera. mmpOS moram još probati iako nemam ideju kako to ustabiliti. |
|  25.08.2020., 07:34 | #13 |
					Postovi: 2,834
				 | Gle za nešto stabilno moraš se igrati sa karticama ... Benchmark koji sam stavio je za modificirani bios ... Stavi kartice da rade bez ikakvog clocka,pa kako fripper veli,ckockaj jednu po jednu ... ako ti se sviđa kako hashaju na normali,ostavi ih tak ... ako ne u modifikaciju ... Niko od nas nije od prve uspio staviti 6-8-12 kartica u rig i da je sve oda savršeno radilo,inače čekiranje i pregled sharova se radi nakon 2 sata,onda se računa da se rig "ustabilio" ... Evo i ja tek od jučer svoje 570 nitro sa 29 uspio nagurati na 31 ... mala razlika,ali na 30 kartica,dobio sam 2 kartice (po hash-u)... nemam 5700 niti jednu,da bi ti dao neki konkretan savjet ... svi preporučaju red dragone i to čak bez XT-a (jeftinije za isti hash) ... |
|  30.08.2020., 20:59 | #14 |
					Postovi: 219
				 | Znam da bi trebao jednu po jednu, ali..  nemam pc samo za testiranje, i da maknem ostalih 5 šteta je da ne rade bilo koliko sad kad je isplativo, dok ja iz jedne pokušavam izvući par Mh/s više.  Stvar je u tome da i bez ikakvog clocka rig nije najstabilniji. Evo npr. skinuo sam jučer najnoviji mmpOS, stavio na Overclocking and config disabled i radilo je cijeli dan stabilno, sad je već 6 grafa, 303 Mh/s 1000W iz zida, memclock default 875, core clock i core voltage su sami došli na približno željene vrijednosti oko 1350 i 800. Onda probam dići samo memclock na 900, ne tijekom mininga, to je ranije uvijek išlo. Krene dobro 312 Mh/s ali ubrzo se sruši mmpOS. Sad sam vratio na Overclocking disabled opet radi oko 300 Mh/s ali troši 1150W iz zida, 2 grafe se spustile core clock i voltage a 4 drže jako visoko, mem temp su kod nekih na samoj granici 104-106 ali radi. Znači ništa nisam dirao u odnosu na jučer a velika razlika. Koliko sam čitao hrpa ljudi ima problema s ovim grafama, i ako kome radi taj ne napiše koji je točno OS i koja verzija AMD drivera i minera. Zanimljiv mi je oglas na njuškalu, MINING RIG 6 X RX5700, Hashing power 350 MH / s Potrošnja energije max. 850 W u opisu Nicehash OS s kojim sam isto već svašta pokušavao ali troši više i daje manje |
|  31.08.2020., 08:58 | #15 |
					Postovi: 8,715
				 | Zasto ne probas simple mining? On je meni uvijek bio najbolji i najlaksi za postaviti. I 1000w za 6x 5700 je ok pa ipak su te grafe 180w. Vecina mojih rigova sa 6x rx570 su na 800w sto ispada za 200w više imas 70% veci hash. I probaj smanjiti core clock a ne dizati. Testiram ovih dana rx5700 pa vidimo... |
|  31.08.2020., 10:10 | #16 |
					Postovi: 219
				 | Nisam dizao core clock nego je visok bio kad bi isključio bilo kakav overclock. Probao sam noćas simple mining, na prvu mi bolje izgleda od HiveOSa, mmpOSa i NHOSa. Ostavio sam preko noći OC na 1300/910 0,8V 0,8V i još uvijek tako radi. 990W iz zida 316 Mh/s 6xrx5700, i temperature su niže, pretpostavljam da se memclock može još malo dići ali već s ovim sam zadovoljan. |
|  01.09.2020., 17:59 | #18 | |
| Premium Datum registracije: Feb 2004 Lokacija: Zagreb
					Postovi: 305
				 | Citiraj:
|  01.09.2020., 23:21 | #19 |
					Postovi: 219
				 | Nisam modao bios, napisao sam to već. Hoću vidjeti što se može izvući sa originalnim. Mogući dobitak je u % puno manji nego što je to bio sa modanjem biosa rx570/580, tako da se meni s tim ne žuri. Mislim da rudarski programi mogu i bez promjene biosa koristiti druge memory timingse ali i da sve to nije još dorađeno, mijenjaju se driveri, pa se onda rudarski programi moraju usklađivati s driverima ili bolje rade sa starim. Ja sam u svemu tome amater, ali recimo mogu u phoenixminer dodati samo jedan extra parametar -openclLocalWork 128 i hashrate svake rx5700 ide puno preko 60 Mh/s i mogu to staviti na youtube, ako me ne zanima koliko ću imati invalid ili stale shares. |
|  02.09.2020., 01:22 | #20 | |
					Postovi: 305
				 | Citiraj:
 Kupio danas dvije Sapphire RX5700XT Nitro+ 8GB. Sutra pokušam. Skinuo Red Bios Editor i atiflash293plus, ali idem prvo bez modanja | |
|  02.09.2020., 16:51 | #21 |
					Postovi: 305
|  05.09.2020., 00:02 | #22 |
					Postovi: 219
				 | Modao sam bios jedne PowerColor Red Devil Rx 5700, promijenio sam samo memory timingse, kopirao one sa 1500 na sve više. Nemam još konačan rezultat ali trenutno mi radi u SMOSu sama kao jedan rig:  56,8 Mh/s pri 1400/925 Mhz, 825/825/1350 mV uz malo manju potrošnju i temperature nego prije. Rig sa 5 RX5700 bez modanja biosa radi mi 266,1 Mh/s (5x53,2) isto SMOS, Phoenixminer 5.1c pri 1400/920 Mhz, 800/800/1350 mV Zanimljivo da mi ovaj rig nije bio potpuno stabilan dok iz njega nisam izbacio gore navedenu Red Devil koja bi morala biti najbolja grafa. Najskuplja, jedina ima 3 venta, dual bios i najniže mjerene temperature. |
|  14.09.2020., 19:10 | #24 |
					Postovi: 2,834
				 | Pa ...... stigle dragonice ... Hash je 55.6 MH/s uz prikazano trošenje od 117-119W ... Realno je to oko 135,kad se uračuna i ploča i proc,ram i hard ... iliti da velim da 3 kartice troše 530W sa HDD (neki 2.5"),ram (4gb),proc (G4560) i H110-DP3 ploča ... klokovi su : 1390 CORE 912 MEM 0.787 V 1325 MVDD 800 MVDDCI Sustav koji se koristi je MMPOS Temperatura je lijepih 60 stupnjeva za core (uz 70% ventilatora) to ću sutra još probat smanjiti Temperatura memorije je 82-86 stupnjeva,što vele da je isto OK ... Moram i priznati da 3 dragonice imaju pola sharova od 12 komada 570 NITRO+,a razlika u hashu je 200 ... Kučište koje sam iskoristio ima opciju za ventilatore,pa će i oni sutra doć najvjerojatnije unutra,tako da se ventovi na karticama mogu smanjiti ... Zadnje izmijenjeno od: Nbdy32. 14.09.2020. u 21:21. |
|  15.09.2020., 20:21 | #25 |
					Postovi: 219
				 | Bios modan? Isto kao što sam ja? MVDD može na 1300 jer tako sad rade sve moje, a i preporučuju na smos supportu - smanjit će temperaturu memorije. Nije mi jasno, misliš da rade više shareova nego što bi trebale po hashu? |
|  07.10.2020., 23:11 | #27 |
					Postovi: 219
				 | Nakon dosta igranja, evo malo šire analize.. Rig se satoji od 6 kartica: 1x POWERCOLOR Radeon RX 5700 Red Devil 1x MSI Radeon RX 5700 XT MECH OC 1x Asrock Radeon RX 5700 Challenger D 8G OC 3x ASUS Radeon RX 5700 DUAL 08G-EVO Powercolor ima modan bios, ostale ne. Simplemining, Phoenixminer-v5.1c Rig se ne može pustiti da radi bez ikakvog overclocka jer troši +300W uz manji hash a kartice se kuhaju. Evo slike kako to izgleda uz napomenu da su prikazane temperature EDGE a postoje još i ASIC i MEM. Najbitnije MEM nekima su ovdje i preko 100. Neki preporučeni safe overclock za sve rx5700 trebalo bi početi od: 1300/900 MH/s, core 812 mV mem 1300/750 mV Dizanje core clocka 1300-1400 bitno diže hash ali samo kod nekih kartica (kod mene samo Powercolor). Mem clock može se probati dizati 900-930 ali dobitak je dosta mali u odnosu na rizik nestabilnosti. Neke kartice kao moje 3 Asusice imaju katastrofalno loše hlađenje memorije. Tada treba probati undervoltati memoriju ispod 1300 ali ako ne ide jedino je rješenje spustiti mem clock ako treba i na default 875. Na drugoj slici je jedno dosta stabilno stanje riga 318 MH/s 855W (iz zida oko 940W što izgleda dosta realno 85W za mbo+cpu i3-7100) |
|  08.11.2020., 19:13 | #28 |
					Postovi: 219
				 | Mali update. Modao sam bios 3x ASUS Radeon RX 5700 DUAL 08G-EVO  i sad one imaju najveći hash. I dalje se previše griju (mem preko 90) ali to je isto i sa manjim clockom i sa bilo kakvim postavkama. Kupio sam i jednu Asus TUF Gaming X3 EVO OC Radeon RX 5600 XT koja je vrlo hladna i daje 42 Mh/s. |
|  12.11.2020., 10:26 | #30 |
| Premium Datum registracije: Aug 2007 Lokacija: ...01...
					Postovi: 73
				 | Planiram složiti jedan rig sa 6 x 5700XT. Zanima me da li bi bilo dovoljno jedno napajanje od 1200W? Hvala unaprijed! |
