Staro 27.07.2020., 13:04   #8191
Postovi: 8,213
AMD and Intel do battle over TSMC capacity
The potentially bigger news, for TSMC at least, comes today via Taiwan's China News which asserts that Intel is indeed in talks with TSMC and is anxious to grab production capacity.
Insiders talking to the Taiwanese newspaper have indicated the following:
  • Intel has reached an agreement with TSMC
  • TSMC will begin mass production of Intel CPUs and / or GPUs next year
  • Intel chips will be fabricated on TSMC's 7nm optimised version of its 6nm process. (I'm not sure if that means TSMC N7P, N7+, or N6.)
Intel can be thankful for the TSMC capacity made available by the Huawei / HiSilicon orders being cancelled or it would be in an even worse position. Meanwhile, AMD will press ahead to try and take advantage of its chief opponent's misfortunes / missteps. AMD hopes to capture market share in desktops, laptops, and servers and its Zen 3 CPUs and RDNA 2 GPUs will be instrumental in this aim going into the new year. AMD's next gen parts will be made on TSMC's N7/N7+ processes, and it is expected to be TSMC's biggest 7nm customer in 2021. This is all the more impressive because TSMC's 7nm capacity for 2021 will be double what it was this year.
Izvor: Hexus.net
Zadnje izmijenjeno od: The Exiled. 27.07.2020. u 13:18.
Staro 27.07.2020., 16:17   #8192
ShebY
ShebY's Avatar
Lokacija: Velika / Osijek
Postovi: 1,442
Ovo smrdi od glave do repa.
Pa nije silikon voda, ak ne puni jedna tvornica može druga.
Arhitektura se treba razvijati za proces, i svaki proces zahtjeva prilagodbe.
Ovo baš smrdi ko izmišljotina neka.
Staro 27.07.2020., 17:10   #8193
Mladenxy
Mladenxy's Avatar
Postovi: 4,333
To onda znači da nisu morali stati u red iza AMD-a i Nvidije?
Staro 27.07.2020., 17:36   #8194
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,584
Ne znam što je naškrabano na tom jeziku, ali ako insuinira da je rocket lake na 7nm tsmc vijest je fake da nemože biti više. Bit će na 14nm 100%, velike su zajebancije napravljene da bi se to backportalo sa 10nm na 14nm, da bi samo preko noći to prebacili na tsmc 7nm u par mjeseci
Ne kažem da im nešto u daljnoj budućnosti neće praviti, za grafičke se priča već dulje vrijeme
Staro 27.07.2020., 17:43   #8195
Postovi: 8,213
Jesu, AMD ima prednost pred njima, a za Intel su prema ovome u TSMC-u morali prilagoditi svoj 6nm koji je najbliže onome kaj su u Intelu uspjeli postići s dosadašnjim 10nm peripetijama.
Da li je baš istina ili nije - ne znamo, ali se bome itekak poklapa, jer realno Intel je ovo sigurno jedno dulje vrijeme dogovaral i prvi procesori budu im dostupni tek krajem 2021., dok glavnina stiže tijekom 2022. i 2023.
IMHO više je do prijevoda, nego da je čista laž, jer Rocket Lake bude ionak koristil 10nm jezgre koje budu pripasane na 14nm, a TSMC bi prema ovome i Intelovih 10nm trebal moći posložiti sa svojih 6nm.
Budemo vidjeli kud ovo vodi, ali Intel je fino govno moral progutati za ovaj dogovor.
Zadnje izmijenjeno od: The Exiled. 27.07.2020. u 18:19.
Staro 06.08.2020., 09:07   #8196
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,747
Staro 06.08.2020., 10:39   #8197
Manuel Calavera
Postovi: 14,584
Staro 06.08.2020., 11:28   #8198
Postovi: 8,213
Živo me zanima kak se bude Alder Lake nosil s tim, jer Intel bude ih 100% preCtavil kao punokrvnu i ravnopravnu konkurenciju.
Code:
{ PCI_DEVICE_ID_INTEL_ADL_S_ID_1, "Alderlake-S (8+8+1)" }
{ PCI_DEVICE_ID_INTEL_ADL_S_ID_2, "Alderlake-S (8+6+1)" }
{ PCI_DEVICE_ID_INTEL_ADL_S_ID_3, "Alderlake-S (8+4+1)" }
{ PCI_DEVICE_ID_INTEL_ADL_S_ID_4, "Alderlake-S (8+2+1)" }
{ PCI_DEVICE_ID_INTEL_ADL_S_ID_5, "Alderlake-S (8+0+1)" }
{ PCI_DEVICE_ID_INTEL_ADL_S_ID_6, "Alderlake-S (6+8+1)" }
{ PCI_DEVICE_ID_INTEL_ADL_S_ID_7, "Alderlake-S (6+6+1)" }
{ PCI_DEVICE_ID_INTEL_ADL_S_ID_8, "Alderlake-S (6+4+1)" }
{ PCI_DEVICE_ID_INTEL_ADL_S_ID_9, "Alderlake-S (6+2+1)" }
{ PCI_DEVICE_ID_INTEL_ADL_S_ID_10, "Alderlake-S (6+0+1)" }
{ PCI_DEVICE_ID_INTEL_ADL_S_ID_11, "Alderlake-S (4+0+1)" }
{ PCI_DEVICE_ID_INTEL_ADL_S_ID_12, "Alderlake-S (2+0+1)" }
{ PCI_DEVICE_ID_INTEL_ADL_S_ID_13, "Alderlake-S (8+6+1)" }
{ PCI_DEVICE_ID_INTEL_ADL_S_ID_14, "Alderlake-S (8+6+1)" }
{ PCI_DEVICE_ID_INTEL_ADL_S_ID_15, "Alderlake-S (8+8+1)" }
{ PCI_DEVICE_ID_INTEL_ADL_P_ID_1, "Alderlake-P (2+8+2)" }
{ PCI_DEVICE_ID_INTEL_ADL_P_ID_2, "Alderlake-P (2+4+2)" }
{ PCI_DEVICE_ID_INTEL_ADL_P_ID_3, "Alderlake-P (6+8+2)" }
{ PCI_DEVICE_ID_INTEL_ADL_P_ID_4, "Alderlake-P (6+4+2)" }
{ PCI_DEVICE_ID_INTEL_ADL_P_ID_5, "Alderlake-P (4+8+2)" }
{ PCI_DEVICE_ID_INTEL_ADL_P_ID_6, "Alderlake-P (2+4+2)" }
{ PCI_DEVICE_ID_INTEL_ADL_P_ID_7, "Alderlake-P (2+8+2)" }
{ PCI_DEVICE_ID_INTEL_ADL_P_ID_8, "Alderlake-P (2+0+2)" }
{ PCI_DEVICE_ID_INTEL_ADL_P_ID_9, "Alderlake-P (2+0+2)" }
Staro 06.08.2020., 11:45   #8199
Manuel Calavera
Postovi: 14,584
Alder lake bi trebao ići na zen4, a zen3 bi se trebao kefati sa rocket lakeom. Osim ako nije došlo do nekih promjena
Staro 06.08.2020., 11:52   #8200
Postovi: 8,213
Je, ali u to vrijeme bude još uvijek i Zen 3 aktualan (slično ko danas Zen 2, pred dolazak Zen 3), a sudeći po Lakefieldu ove manje jezgre nemaju šanse, kamoli kad se i Zen 4 ubaci u priču.
Za Rocket Lake znamo da nažalost ne bude ništa pametno i novo u usporedbi s trenutnim Comet Lake modelima, tak da bi tu Zen 3 trebal proći bez ikakvih problema.
EDIT: AMD Ryzen 5 Pro 4650G 6c/12T za ~1.500 kn i Ryzen 7 Pro 4750G 8C/16T za ~2.400 kn
Zadnje izmijenjeno od: The Exiled. 06.08.2020. u 12:30.
Staro 06.08.2020., 14:22   #8201
Manuel Calavera
Postovi: 14,584
Bome odlične cijene APU-a! I to tako brzo na DIY tržištu!
Košta praktično isto kao R5 3600 i R7 3700X
Staro 06.08.2020., 14:30   #8202
Postovi: 8,213
Da, cijene su super, a iGPU je zapravo gratis u ovom slučaju. Još kad se pojavi ostatak ponude i bog-bogova.
Staro 06.08.2020., 16:12   #8203
Manuel Calavera
Postovi: 14,584
Fora je što su odmah cijene ovakve, ne treba čekat kalibriranje tjednima, mjesecima. Cijene R3 3100 i 3300X se po meni još nisu kalibrirale, a ti apu mogu ići samo dolje...
Staro 06.08.2020., 17:10   #8204
toshiro
Lokacija: rijeka
Postovi: 155
Ima li usporednih testova? Kolikp su uopće brzi ti apui?
Poslano sa mog SM-G950F koristeći Tapatalk
toshiro je offline   Reply With Quote
Staro 06.08.2020., 19:19   #8205
MAHER
Postovi: 1,583
Nvidija je na kraju reda, zamjerili se. A amd je prvi i najveci kupac za 2021 ali ima se kapaciteta.
MAHER je offline   Reply With Quote
Staro 06.08.2020., 19:38   #8206
Mladenxy
Mladenxy's Avatar
Postovi: 4,333
Autor toshiro Pregled postova
Gledajući TFLOPS ima ih jednako kao RX 460 što zbilja nije loše ako zanemariš da će izlaziti sve zahtjevnije igre.
Staro 06.08.2020., 20:18   #8207
Postovi: 8,213
Službeno još ništa, ali zato ima neslužbenih (1 - 2) materijala. Sve u svemu CPU dio u rangu ili malo bolji od postojećih Zen 2 modela, dok iGPU uopće nije za zanemariti.
Staro 06.08.2020., 20:20   #8208
JC Denton
dr. sc. tech. dipl. ing.
JC Denton's Avatar
Lokacija: Rijeka-Opatija
Postovi: 3,164
Glavni problem AMD APUa je memory bandwith. Sve ostalo je cak solidno za to što je.
Staro 06.08.2020., 20:24   #8209
Postovi: 8,213
Izgleda da ni propusnost više ne bude problem s ovim novim čipovima.
Staro 06.08.2020., 20:28   #8210
toshiro
Lokacija: rijeka
Postovi: 155
Ok, onda što se tiče samo proca trebao bi biti tu negdje sa 3600?
Staro 06.08.2020., 20:30   #8211
Postovi: 8,213
Da, ista je Zen 2 arhitektura, tak da tu nema brige po tom pitanju. R5 4000G APU u rangu s R5 3000 CPU i R7 4000G APU u rangu s R7 3000 CPU.
Staro 06.08.2020., 23:09   #8212
scarzz
scarzz's Avatar
Lokacija: Stuttgart/Rijeka
Postovi: 414
https://www.youtube.com/watch?v=0oyACWS7vwA&t=0s
Ima vec raznih testova od PRO verzije koji su zapravo isti chipovi, performanse ipak nisu na razini 3000 zen2 serije vjerojatno zbog dosta manjeg cache-a -> https://www.youtube.com/watch?v=IRNbxg3K6jw
scarzz je offline   Reply With Quote
Staro 07.08.2020., 00:06   #8213
Manuel Calavera
Postovi: 14,584
Autor scarzz Pregled postova
Mogu vjerovati da je malo sporiji zbog manje chacea, ali ovo iz drugog linka mi je malo prevelika razlika. Najbolje pričekati vrhunske recenzente tipa hardwareunboxed/techspot, techpowerup ili švapske portale i sl. pa ćemo vidjeti
No to da je nešto sporiji bi dalo odgovor na pitanje zašto koštaju podjednako sa igpu u vrijednosti ekvivalnente zasebne gpu od 500-600kn
Staro 07.08.2020., 15:48   #8214
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,747
Staro 08.08.2020., 14:43   #8215
BusMaster
BusMaster's Avatar
Datum registracije: Apr 2017
Postovi: 343
Ryzen 7 Pro 4750G Review
_______________________________________________________________
Evo jednog testa, ne izgleda loše taj APU, uglavnom u rangu sa 3700X, u nekim benchevima i bolji...
Staro 10.08.2020., 12:56   #8216
Postovi: 8,213
Švabi su također testirali nove R5 Pro 4650G i R7 Pro 4750G APU modele.
Staro 14.08.2020., 13:43   #8217
BusMaster
BusMaster's Avatar
Postovi: 343
AMD Ryzen 5 PRO 4650G Renoir APU review
Link: https://www.guru3d.com/articles-page...-review,1.html
Izgleda da AMD za sada štanca samo te PRO modele za OEM-ove.
Šteta što dolaze sa zaključanim množiteljem, jer koliko se da vidjeti iz recenzije, ovi procovi rade na istoj ili bliskoj frekv. kao 3400G serija ali sa dosta manjim naponom... Ima li tko infomaciju kada bi se trebali pojaviti "obični" primjerci 4000APU serije?
Staro 15.08.2020., 17:45   #8218
Manuel Calavera
Postovi: 14,584
Staro 24.08.2020., 14:21   #8219
Postovi: 8,213
AMD Ryzen 2021-2022 roadmap with codenames leak - Van Gogh and Warhol
The interesting part is that the leak mentions Cezanne, Van Gogh and 'Warhol' for next year (2021) already. Warhol would be released after Vermeer, according to the stuff leaked by MebiuW. AMD Warhol could/would be a Vermeer Refresh or an the product that transitions the platform from AM4 to AM5 socket. Van Gogh is labelled as ‘CVML’ which presumably means ‘Computer Vision and Machine Learning’. and thus is aimed at a market segment than Cezanne. However Navi2-based APUs would thus be expected in 2021. Cezanne would be based on Vega7 graphics, Van Gogh will be the first APU series would see Navi architecture. The roadmap also shows part of 2022, and if you look a bit deeper you'll see cut off 'Raphael'. based on a different socket than AM4. So this means Warhol would become an intermediate generation before AM5 will be introduced. Zen 3, a 7nm node and PCIe 4.0 would still be used - it is not yet clear what differentiates this alleged Ryzen 5000 series.
Izvor: Guru3D
Bilo bi super da stvarno u pripremi imaju kakav model s hibridnim DDR4/DDR5 memorijskim kontrolerom, o čemu smo zapravo već prije pričali da AMD može složiti, ako hoće.
Staro 24.08.2020., 20:46   #8220
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,848
