Staro 20.06.2020., 00:40   #2791
Tajl3r
Dobro je sve.
Tajl3r's Avatar
Datum registracije: Sep 2012
Lokacija: 00001
Postovi: 2,490
Autor zwer54 Pregled postova
Evo pustio sam ga na 1.33V na 4.55ghz, ram na 3800 cl16 i odigrao 1.5h pubga na 2560x1440 rezoluciji i semi max detaljima. fps ne pada ispod 130.
Nitko ne drzi max oc za 24/7 pa tako ni ja, no ja sam cinebench odvrtio na 4.6 sve jezgre, a ti kak hoces.
Ako je u pubg stabilan onda je stabilan,cestitam definitivno je silikonska lutrija.
Staro 28.06.2020., 14:26   #2792
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,584
AMD Ryzen CPUs Retain Leading DIY Market Share In Japan Despite Launch of Intel’s 10th Gen Lineup
A chart formulated by the tech outlet shows the DIY CPU market share for AMD and Intel CPU. The interesting part is that this share is not specific to a single retailer but is based upon retail channel sales across Japan. The current statistics show that AMD Ryzen CPUs, especially the 3rd Gen Ryzen 3000 series have helped AMD retain a share of 67.4% during the previous month while Intel CPUs amount to a share of 32.6%.
Staro 29.06.2020., 15:28   #2793
Postovi: 8,354
  • European Hardware Awards announced; AMD CPU and GPU division wins big
    AMD's CPU division has completely razed Intel's offerings when it comes to awards, with no Intel CPU even being credited with a single prize.
  • AMD "Cezanne" APU to stick with "Vega" iGPU, "Van Gogh" tets RDNA2
    AMD plans to launch "Cezanne" in 2021, which makes it the immediate successor to "Renoir." On the other hand, the "Van Gogh" silicon slated for 2021 is expected to receive RDNA2 graphics
  • AMD Ryzen 4000 "Vermeer" CPUs almost ready to hit the market
    The CPUs are now at B0 stepping and are going through the usual validation process. The B0 stepping is where the CPU is fully working and now it just needs to go on mass production.
  • AMD B550 motherboard shown running Zen+ "Pinnacle Ridge" and "Picasso" CPUs
    The AMD B550 chipset isn't supposed to run 1st- and 2nd-generation AMD Ryzen processors, or even Ryzen 5 3400G and 3200G APUs based on the older "Zen+" microarchitecture. Given this, imagine our surprise when someone with access to a B550 motherboard was able to run older processors on it. ASUS TUF Gaming B550M-Plus motherboard running "Zen+" based Ryzen 5 3400G APU based on the "Picasso" silicon, and Ryzen 5 2600X processor based on the "Pinnacle Ridge" silicon
  • The Rise, Fall and Revival of AMD
    AMD is currently in the strongest position that they've ever been in its 51-year history. With the ambitious Zen project showing no signs of hitting any limits soon, the company's phoenix-like rebirth has been a tremendous success.
    They're not at the top of the mountain though, and perhaps for the better. It's said that history always repeats itself, but let's hope that this doesn't come to pass.
Staro 30.06.2020., 09:48   #2794
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,749
Zadnje izmijenjeno od: Sn4k3. 30.06.2020. u 14:42.
Staro 17.07.2020., 11:44   #2795
Psycho
Master Of Disaster
Psycho's Avatar
Datum registracije: Nov 2002
Postovi: 1,268
https://www.instagram.com/tv/CCs-N1E...ource=ig_embed
just a small 3rd Gen AMD build haha
Staro 19.07.2020., 02:00   #2796
Tean
Postovi: 182
Ryzen 3 3200G Wraith Stealth cooler je poprilično glasan, i jos mjenja brzinu stalno što još više iritira. Ima li neki fix za to ili treba uzeti neki drugi hladnjak?
Tean je offline   Reply With Quote
Staro 19.07.2020., 09:48   #2797
iggi
Lokacija: qǝɹƃɐz
Postovi: 436
Jedina pomoć ti je uzeti jači hladnjak, ovo ti je neki best buy
LC Power LC-CC-120 ili gledati polovno.
iggi je offline   Reply With Quote
Staro 20.07.2020., 19:36   #2798
Tean
Postovi: 182
A koliko ce taj biti tiši?
Staro 20.07.2020., 19:48   #2799
iggi
Lokacija: qǝɹƃɐz
Postovi: 436
Za tvoj procesor nečujan.
To je već pristojan komad metala i toplovodnih cijevi + 120mm ventilator.
Staro 26.07.2020., 03:44   #2800
zwer54
zwer54's Avatar
Lokacija: Dublin
Postovi: 1,977
Evo konacno sam finalizirao clock 3900X-a. Nasao sam neku optimalnu sredinu sa clockom per ccx te stavio prve 3 jezgre na 4.3, druge 3 na 4.2 i ponovo isto za drugi ccx, voltaza 1.2V i LLC na 3.
Prolazi sve benchmarke, stress testove i visesatno igranje. Temperatura u surfanju i desktop koristenju vrti se 36-40, u igrama 40-45, ovisi od igre, a max u stress testu bilo je 68 stupnjeva.
Max stabilan clock ide 44.75 GHz na svih 12 jezgri uz 1.3V i benchmark rezultati su bolji no u gamingu i nije bilo neke razlike jer me koci graficka, a ne cpu pa sam ga spustio na gore navedene taktove da ga ne "koljem" sa voltazom, a i hladnije i tise radi. Sve u svemu, radi na daleko nizim voltazama od stocka.
https://valid.x86.fr/eewtua
Staro 26.07.2020., 21:36   #2801
rokonja
rokonja's Avatar
Lokacija: tamo tamo daleko
Postovi: 163
Ima smisla mjenjat 2600x sa 3600xt (mislio kupit)?
rokonja je offline   Reply With Quote
Staro 26.07.2020., 21:39   #2802
Manuel Calavera
Postovi: 14,584
Ne. Pogotovo ne XT, te pred skori izlazak zen3 (ryzen 4000)
Staro 26.07.2020., 22:15   #2803
rokonja
rokonja's Avatar
Postovi: 163
Ma imam B450 tako da sam malo skeptičan prema upgredu na taj zen3, pa mislio ostat na starijoj ili ti sadašnjoj verziji. A neki ryzen sa 8 jezgri ima smisla updejtat? Nije mi neka sila (mogu čekat zen3) sad mjenjat samo eto palo na pamet.
Staro 27.07.2020., 08:36   #2804
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,312
Autor rokonja Pregled postova
Ako niš drugo,čekaj da 3600 ode na 900-1000kn.
Slobodno me dodajte na PSN
Staro 27.07.2020., 12:13   #2805
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,749
AFAIK, AMD je sluzbeno izjavio da ce B450 biti kompatibilan sa nadolazecim Ryzen 4000 desktop modelima. Nemas sto biti skeptican. Eventualno te tu Gigabyte moze za*ebati, ali cisto sumnjam u to...
Ako ti nije prisa, pricekaj jos par mjeseci, mislim da se isplati - barem po performansama ako ne i cijeni
Staro 27.07.2020., 13:06   #2806
rokonja
rokonja's Avatar
Postovi: 163
Ma nema priše, čekat ću i krenud u borbu zvanu "upadate i upgrade" . Ujedno hvala i na savjetima.
Edit: tu na forumu pročitao: kad bi nešto radio na pc-u, a neznaš što. jednostano ga rastavi, očisti i ponovo satavi.
Zadnje izmijenjeno od: rokonja. 27.07.2020. u 14:15.
Staro 27.07.2020., 21:51   #2807
mkey
Datum registracije: Sep 2018
Lokacija: tu
Postovi: 3,544
Jako dobar savjet. Mene opet strefilo da idam sastavljat PC ali nekako sam se ohladio. Sastavio bih novi samo da se više riješim tog povremenog ludila
mkey je online   Reply With Quote
Staro 27.07.2020., 22:03   #2808
Manuel Calavera
Postovi: 14,584
Pojavili se laptopi sa budžet ryzen 4000 i kod nas
https://www.nabava.net/search.php?q=15.6%22+4300U
Veliki napredak s obzirom koji se cpu može imati u lapu od 3000kn, za 3200kn i sa 512gb ssd-om.
Staro 28.07.2020., 01:00   #2809
SlavoS
Datum registracije: May 2003
Postovi: 1,116
Još da se pojavi ovako nešto
https://www.idealo.de/preisvergleich...2a-lenovo.html
Navodno imaju najbolje hlađenje u klasi.
SS
SlavoS je offline   Reply With Quote
Staro 28.07.2020., 10:14   #2810
lobo64
lobo64's Avatar
Postovi: 1,346
Autor Sn4k3 Pregled postova
Upravo gledam CPU support liste.
Trenutno Asrock, MSI i Gigabyte na b450 ne nudi podršku za 4xxx niti za 4xxxG procove, barem ne prema support listama.
Možda se to promjeni, no nekako sumnjam...
Ostale vendore nisam gledao.
Staro 28.07.2020., 11:40   #2811
Libertus
Libertus's Avatar
Datum registracije: Jul 2017
Lokacija: Ramura
Postovi: 2,803
Kako će nuditi kada nisu niti izašli?
MSI je na svojim MAX pločama najavio podršku svim budućim AM4 procesorima. Za ostale nisam siguran kako će, ali vjerojatno će ih većina održavati. Jedino je Asus bio javno protiv podrške, ali to ne znači da se neće predomisliti kada drugi uvedu.
Staro 28.07.2020., 12:42   #2812
lobo64
lobo64's Avatar
Postovi: 1,346
Autor Libertus Pregled postova
Sve b550 ploče nude podršku, barem za 4xxxG modele, makar još procovi nisu izašli, odnosno ih nema kao retail...
Staro 28.07.2020., 13:27   #2813
Libertus
Libertus's Avatar
Lokacija: Ramura
Postovi: 2,803
Moraš se odlučiti da li pričaš za B550 i B450. B550 je odmah najavljena sa podrškom za seriju 4xxx, dok se još AMD držao da B450 neće podržavati iste. Tako da B550 bi trebale odmah imati podršku, dok B450 će dobiti kroz neko vrijeme, a nerealno je očekivati da će je imati prije izlaska samih procesora iako i to može biti.
Kao što rekao, podrška za nove CPU na B450 nije zagarantirana i ovisi o MBO vendoru. MSI se tu očitovao unaprijed, za ostale ćemo vidjeti.
Staro 28.07.2020., 15:49   #2814
lobo64
lobo64's Avatar
Postovi: 1,346
Znači usprkos AMDovoj najavi da će b450 podržavati 4xxx seriju, kao vlasnik b450 ploče osuđen sam na milost ili nemilost proizvođača ploča?
IIdeeš...
Staro 28.07.2020., 19:25   #2815
mkey
Lokacija: tu
Postovi: 3,544
Nisi dobro pročitao. Nitko za B450 nije garantirao podršku za zen3.
Staro 28.07.2020., 19:28   #2816
Postovi: 8,354
Spomenuli su da će podrška biti u obliku beta BIOS-a, na odgovornost kupaca i to je zapravo ono kaj su ljudi i tražili.
Jedini je zajeb da nisu rekli kad budu ti BIOS-i dostupni, jer prednost imaju nove ploče.
Staro 29.07.2020., 01:00   #2817
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,749
Kao sto kolega Libertus kaze, a da prvo pricekamo neka procesori izadju pa cemo pricati o mozebitnim biosima. Mislim da OEM-ima nisu bas prioritet B450 ploce pored X570 i B550 koje moraju biti spremne do izlaska Ryzen 4000 serije.
Ne sumnjam da ce naknadno i B450 pa mozda cak i odredjene X370/B350 ploce dobit bios update, al otom potom
Staro 30.07.2020., 11:22   #2818
John Creasy
Vocna iglica u mudante
John Creasy's Avatar
Lokacija: Beograd
Postovi: 2,837
kolega uzeo komp, GB b450 gaming X i ryzen3600.. na ploči ima naljepnica da je 3000 ready, ali kad je spojio kaže da se čuje samo beep i tako u krug.. jel to znak za proc (treba bios update) ili da tražim krivca negdje drugdje? imam r1200 u ormaru, nije problem bios updateati
Staro 30.07.2020., 11:28   #2819
Postovi: 8,354
Da, vrlo vjerojatno treba friški BIOS, pa mu možeš prvo to eliminirati. I za svaki slučaj provjeri da monitor nije spojen direktno na ploču, jer se još uvijek dosta ljudi zezne, mada nije svaki Ryzen APU model.
Staro 30.07.2020., 21:10   #2820
mkey
Lokacija: tu
Postovi: 3,544
Ne bi po meni tuilio zbog toga gdje je monitor spojen. Ali, bogati, ako treba bios update šta mu znači ta naljepnica Ima li kakva zvjezdica font 1 na njoj?
* 3000 ready nakon upedjta biosa koji vam možemo i mi odradit za 200kn
