Staro 18.01.2006., 22:04   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
ATI MMC 9.13
Veseljaci iz ATI-jevog MMC odjela su se KONAČNO sjetili izbaciti novi verziju MMC-a.
Release Notes:
Resolved Issues
The following section provides information on issues that have been resolved with the latest release of the ATI Multimedia Center™. These include the following:
* Launching a DTV application on a system with less than 100mb of free space no longer results in a blank screen being displayed when streaming video. Further information on this resolved issue can be found in topic number 737-19381
* Each click of the Channel Lockout button no longer results in password dialog boxes being displayed for each click of the button. Further information on this resolved issue can be found in topic number 737-19385
* Using the keyboard or mouse to select the channel surf button no longer results in the channel surf grid appearing for a few seconds and then disappearing as normal TV resumes. Further information on this resolved issue can be found in topic number 737-19387
* Clicking the ATI icon while playing a slide-show and selecting About, no longer results in slide-show files failing to respond. Further information on this resolved issue can be found in topic number 737-19388
* Video stutter is no longer noticed when playing DVD and having ATI RAGE Pass Thru audio enabled. Further information on this resolved issue can be found in topic number 737-19389
* Connecting a flat panel display device to the top DVI connector, and a CRT to the lower DVI connector no longer results in a no signal dialog box being displayed when streaming DVD video through either the composite or S-Video connector. Further details on this resolved issue can be found in topic number 737-21529
* Attempting to schedule a once a week recording no longer results in the TV becoming active, but the recording failing to start. This issue is known to occur under the Windows XP, and Windows XP MCE operating systems when using an ATI All-in-Wonder® X1800 product. Further details on this resolved issue can be found in topic number 737-21528
* Attempting to play a DVD using the ATI DVD player under Windows XP MCE with an Apple Cinema display device connected no longer results in a blank playback window. Further details on this resolved issue can be found in topic number 737-21527
* Auto-scanning an analog source no longer results in the channels detected populating the digital list. Further details on this resolved issue can be found in topic number 737-21520
* A wrong message box is currently displayed when using the record option on DTV. Further details on this resolved issue can be found in topic number 737-21521
* Channel surfing the TV under Windows XP Media Center Edition no longer results in the audio for the TV being muted when restarting the TV. Further details on this resolved issue can be found in topic number. 737-21522
* The TV info bar is no longer displayed for a brief momment when watch DTV. Further details on this resolved issue can be found in topic number 737-21523
* Creating time-shifted captured files when watching TV in full screen mode no longer results in the capture files not being available when attempting to playback the captured files. Further details on this resolved issue can be found in topic number 737-21524
* The time shift slider is now working properly once the buffer file wraps around. Further details on this resolved issue can be found in topic number 737-21525
* The initial page for creating a scheduled FM event is no longer displayed in english only and is displayed in the correct localized language as selected by the user. Further details on this resolved issue can be found in topic number 737-21534
* Completing the steps to create a new user defined preset, no longer results in the user defined pre-set being unavailable to the user. Further details on this resolved issue can be found in topic number 737-21533
* Scheduling a recording under Windows XP or Windows XP MCE, no longer results in the recorded file name failing to correspond to the one touch record setting. This issue is known to occur with a PAL version of the All-in-Wonder. Further details on this resolved issue can be found in topic number 737-21532
* Using the remote to cycle through the TV scheduled watching options by repeatatively clicking the OK button, no longer results in only a one time watching option being available. Further details on this resolved issue can be found in topic number 737-21531
* The teletext button is no longer missing in the TV control panel for PAL systems. Further details on this resolved issue can be found in topic number 737-21530
Known Issues with the ATI Multimedia Center™
The following section provides information on known issues and product limitation for the ATI Multimedia Center™ 9.13. These include the following:
* The time remaining is not provided on the record panel when performing any type of recording function. Further details can be found in topic number 737-21518
* Entering the Broadcast time option and selecting to start watching a TV program from the beginning after watching TV for an extended period of time may result in the Time Shift slider bar moving to the beginning, but the playback of the video remains in the same place. Further details can be found in topic number 737-21519
* Scheduling a TV recording using the VCD format, may result in the schduled recording failing to start until using the mouse to click on any portion of the ATI MMC. Further details can be found in topic number 737-20031
* Starting a UTV session, followed by switching from UTV to Component/S-Video, and then back to UTV may result in a mommentary flash of static video and audio before the UTV session resumes normally. Further details can be found in topic number 737-21498
* Starting a UTV session and activating Picture-in-Picture may result in the inability to change channels on the main channel. Further details can be found in topic number 737-21526
* Setting the region to PAL may result in the UTV window appearing slightly off center. Further details can be found in topic number 737-21513
https://support.ati.com/ics/support/...e&folderID=293
Staro 19.01.2006., 12:56   #2
feelgood
I'm DEAD sexy!!!
feelgood's Avatar
Datum registracije: Sep 2002
Postovi: 349
Kaj mi to vrijedi kad mi debili nisu dali MMC CD uz grafulju a ovo su samo update-i. Ko da mi drugi useri ne zaslužujemo ATI player
ASUS Crosshair V Formula
Processor AMD FX-8320E
Corsair Vengance Pro DDR3 2133 2x4 GB
NVIDIA GeForce GTX 1060 6GB
feelgood je offline   Reply With Quote
Staro 19.01.2006., 13:46   #3
Jelc
Super Moderators
Postovi: 17,485
Originally posted by feelgood
ATI player
E, s tim bi se baš usrećio
To na kraju krajeva ni nije njihov soft, mislim da to za njih dela CyberLink...
Bolji ti je CyberLink-ov PowerDVD.
Staro 19.01.2006., 13:59   #4
Vedran
Vedran's Avatar
Lokacija: Kutina
Postovi: 1,208
Jelc, jel znaš možda kako MMC stoji s podrškom za Theatre 550Pro?
Vedran je offline   Reply With Quote
Staro 19.01.2006., 14:11   #5
domy_os
domy_os's Avatar
Postovi: 18,928
Šta je uopće MMC?
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 19.01.2006., 14:35   #6
Jelc
Super Moderators
Postovi: 17,485
Ovaj zadnji ok.
domy-Multi-Media-Centar
Nakon svakog izlaska najčešće se tom odjelu ATI-ja j**e mamica uzduž i poprijeko neta uz topice tipa " MMC 9.13 sucks"
Izgleda da je najnoviji feature 9.13 nemogućnost pauziranja pri captureu
Staro 19.01.2006., 16:15   #7
feelgood
I'm DEAD sexy!!!
feelgood's Avatar
Postovi: 349
Jel može PowerDVD vrtit video koji dolazi iz externog Sourcea? Spojil sam plejku na komp i gledam sliku sa Invideo DV3R il kak se već zove no slika je dosta mutna...
Staro 19.01.2006., 17:44   #8
Jelc
Super Moderators
Postovi: 17,485
Ima CyberLink kompletan soft sa kojim možeš delati capture, gledati DVD, editirati i sl...pogledaj malo na njihivom siteu.
Pogledaj u opciji source kaj ti PowerDVD nudi, ja ga sad nemam instaliranog pa bi pričao napamet...
