Datum registracije: Sep 2011
Postovi: 1,105
Problem sa primanjem maila
Prije 7-8 dana tajnica me zove da pokušava poslati na moj mail jedan email ali da nikako ne prolazi. Mislio sam da je tajnica nešto zeznula, pogotovo jer sam taj dan dobio 15-20 mailova bez problema. Danas me zove drugi klijent, i kaže da ima problema sa slanjem e maila na moj mail i prosljedi log: Diagnostic information for administrators: Delivery has failed to these recipients or groups: 'xxxxxxxxxxx' (xxxxxxxxxxxxxxxxr) The email address you entered couldn't be found. Please check the recipient's email address and try to resend the message. If the problem continues, please contact your email admin. Diagnostic information for administrators: Generating server: HEXMBX05.tcloud.local xxxxxxxxxxxxxxxxxxxxxxxxxx Remote Server returned '550 5.1.10 RESOLVER.ADR.RecipientNotFound; Recipient not found by SMTP address lookup' Original message headers: Received: from HEXMBX08.tcloud.local (10.240.138.169) by HEXMBX05.tcloud.local (10.240.138.166) with Microsoft SMTP Server (version=TLS1_2, cipher=TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256_P256) id 15.1.1713.5; Mon, 8 Jun 2020 11:31:50 +0200 Received: from HEXMBX08.tcloud.local ([fe80::5144:2483:5432:7c0b]) by HEXMBX08.tcloud.local ([fe80::5144:2483:5432:7c0b%16]) with mapi id 15.01.1713.004; Mon, 8 Jun 2020 11:31:50 +0200 Content-Type: application/ms-tnef; name="winmail.dat" Content-Transfer-Encoding: binary From: =?iso-8859-2?Q?xxxxxxxxxxxx <xxxxxxxxxxxxxxxxxxxxx> To: =?iso-8859-2?Q?=27xxxxxxxxxxxxxxx= <xxxxxxxxxxx> Subject: xxxxxxxxxxxxxxxx Thread-Topic: xxxxxxxxxxxxxxxxxx! Thread-Index: AdY9dzYLmuGxz1B3SN6m0IOkWuwsoQ== Date: Mon, 8 Jun 2020 11:31:50 +0200 Message-ID: <xxxxxxxxxxxxxxxxxxxxxxxxx> Accept-Language: en-US, hr-HR Content-Language: en-US X-MS-Has-Attach: yes X-MS-TNEF-Correlator: <xxxxxxx> MIME-Version: 1.0 X-Originating-IP: [93.136.xxxxxxxxxxxxx] Return-Path: xxxxxxxxxxxxxxx Uredno i danas zaprimao mailove, poslao par praznih mailova sa različitih adresa, svi su uredno došli. Wtf? Poslano sa mog RNE-L21 koristeći Tapatalk |
E Pluribus UNIX
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,750
Nemas tu bas puno neke mudrosti, sve dok ne pogodis mail koji nije prosao i sa strane posiljatelja ne napravis neki trace odnosno debug, kako god zelis. Uvijek se mozes obratiti vlastitoj mail administraciji oko toga ima li nekakvih ispada, pa onda naknadno DNS sluzbi Do tada, razloga moze biti 100, a da je tek 101 tocan; a variraju od samih postavki tvojeg mail servera, mreznih gresaka i slicno.
#3 | |
Postovi: 1,105
Jedina poveznica između prvog i drugog neuspjelog pošiljatelja je da koriste telekomcloud.hr mail server Poslano sa mog RNE-L21 koristeći Tapatalk |
