Staro 18.04.2020., 14:25   #7501
Gigi1
Postovi: 2,138
Meni je dost specijalno kad ista platforma(s.939) omogući skoro pa 100% povecanje perf. pogotovo kad se gleda u kontekstu okolnosti
Staro 18.04.2020., 15:16   #7502
Pa isto je napravio i Intel sa svojom platformom
Zato velim da nije meni niš specijalno bilo po tom pitanju performanse su drugo, tu je ubijao... do C2D.
Meni je ostala u jako dobrom sjećanju ta ploča i taj Opteron 165 koji se OCa 1200MHz iznad svog nominalnog takta.
Što se tiče Zen4 tj serije 5000, da naprave da 6c/12t idu na AM4 ploče, to bi bio pun pogodak.
Ali pošto postoje naznake da Zen4 bude refreš Zena3 na manjem nodu sa DDR5 IMCom, u tom slučaju i nije neka priča kad će Zen3 biti zverka sam po sebi i biti full podržan na AM4.
Staro 18.04.2020., 15:33   #7503
Postovi: 8,207
Mogel bi i 5nm, odnosno samim time i AMD-ov Zen 4 ispasti ipak malo konkretniji odmak od nadolazećeg Zen 3 čuda tehnike. Pogotovo sad kad AMD ima jako lijepe pogodnosti kod TSMC-a.
Velim, ne trebaju ništa ekstra izmišljati, svega par (tranzicijskih) modela s DDR4/DDR5 IMC-om za sve kojima se odmah ne skače na skupu DDR5 platformu.
I, ako ništ drugo, zbog toga, jer Intel sigurno ne bude tak nekaj (po)nudil.
TSMC’s 5-nanometer node entered risk production early last year. C.C. Wei confirmed that N5 is now in volume production with good yield. We have recently covered TSMC 5-nanometer node disclose from a number of conferences. The node will deliver around 1.8x improvement in density along with 15% higher speed at iso-power or, alternatively, 30% lower power at the same speed. N5, like N7, is expected to remain a long-lasting node. “We expect a very fast and smooth ramp of N5 in the second half of this year driven by both mobile and HPC applications,” C.C. Wei added. TSMC estimates that N5 will contribute about 10% of wafer revenue in 2020. TSMC is observing a higher number of tape-outs compared to N7 at the same period of time during their ramp.
Izvor: WikiChip Fuse
Staro 18.04.2020., 22:18   #7504
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,584
Autor Gigi1 Pregled postova
Amd generalno još od socketa 462 podržava multi gen kompatibilnost cpu-a, uz ponešto iznimaka poput s754/s940/fm1 itd.
Vjerojatno ce tako biti i u buducnosti
Ja sam recimo uzeo AM2 čim je bio izašao 2006 god. Krepala mi ploča nakon garancije - kupio AM2+/AM3 ploču (AM2 cpu je išao na AM2+/AM3). Nakon athlona prešao na phenoma dvojku (AM3) na istoj toj ploči što sam imao pred ryzena.
E sad da mi je prije toga kojim slučajem prije ryzena krepala AM2+/AM3 ploča - mogao sam kupiti novu AM3+ ploču u koju bi mogao tutniti tog phenoma i kasnije nadograditi na FX 83xx koji bi vjerojatno imao do sada (ili pred ovo razdoblje). Znači to bi bio flow od 14 faking godina međusobno kompatibilnih socketa, gdje bi jedno bilo poveznica (cpu ili mbo) a drugo promjenjivo za nedaj bože ili nadogradivo. Nevjerojatno kad razmisliš
Staro 19.04.2020., 09:59   #7505
pci_e3x
Premium spammer
pci_e3x's Avatar
Datum registracije: Aug 2010
Lokacija: D.Zagora
Postovi: 776
AMD Reportedly Launching B550 Motherboards Come June 16th
It's expected that B550 motherboards will be had for higher pricing than AMD's previous mainstream B450 motherboards, though, due to increased costs with improved I/O and the additional requirements for PCIe 4.0 wiring. Considering AMD's X570-based motherboards can be had from the $150 barrier upwards, it's likely (via an educated guess only) that B550 will occupy the $90-$150 range.
Staro 19.04.2020., 16:51   #7506
Autor Amd_Shill Pregled postova
Ne bi se cudio
Duh Jerry Sandersa i eho njegove maksime jos odzvanja hodnicima u Sunnyvaleu
Ne feri Gle što si pisao pred izlazak Zena, nebili se unapred pripremio na možebitne visoke cijene prvih Ryzen procesora:
TVOJ POST od 31.12.2016.
Malo je Karitas, malo nije Karitas, po potrebi, a? Zato sam i rekao da nema smisla voditi bilo kakve rasprave o nekim poštenjima u odnosima "fizička osoba tj.kupac - korporacija koja barata milijardama".
Ne znam kako vama ostalima, ali meni se čini ovdje kako je B550 toliko odgađan (11 mjeseci ako je u Lipnju launch) samo zato jer X570 ploče bilježe slabu prodaju tj. puno manju od očekivane. Nekako ne vjerujem u priču o kompleksnosti čipseta nego više od loših (za MBO vendore) rezultata prodaje preskupih X570 ploča.
11 mjeseci nakon X570 i 3 mjeseca prije X670. No dobro, neka im je sa srećom.
Zadnje izmijenjeno od: Brko. 19.04.2020. u 17:14.
Staro 19.04.2020., 17:30   #7507
Dottore
Dottore's Avatar
Postovi: 7,635
Već u 11mj mislio ubositi x570 itx ploču i sve do danas dalje stoji ista cijena. Kao da nema promjene između Gigabyte i Asusa.
Отправлено через SM-N960F
HP 845 G8
CPU: AMD Ryzen 7 PRO 5850U
Graphic: AMD Radeon 680M
OS: Windows 11 Pro 24H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
LCD: 14" IPS @ 1920 x 1200
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
OS: Windows 11 Pro 23H2
Dottore je online   Reply With Quote
Staro 19.04.2020., 17:36   #7508
Manuel Calavera
Postovi: 14,584
Nek pričekaju zen3 s B pločama, da imaju out of the box support kad su već ovoliko čekali...
Staro 20.04.2020., 08:03   #7509
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,259
A ne, tada će ići sa novim x670 koji možda neće imat aktivno hlađenje.
Ugl i ja mislim da je razlog ovo što Brko kaže, a ne vidim nikakvu potrebu da ih sada izbacuju..B550 mislim.
A x570 su jako skupe ploče, i još ti ventovi na čipsetima.
Slobodno me dodajte na PSN
Staro 20.04.2020., 10:21   #7510
Gigi1
Postovi: 2,138
Autor Disco Pregled postova
ja ne kužim te fobije od ventova, mali ventic vrti se na 700-800 rpm kad opteretim grafu i proc ili ssd, ne cujem ga da radi niti da postoji, samo ima dodatni benefit jer uz chipset piri po m.2 hladnjaku i pomaže pri disipaciji topline s njega
win/win
spike da su to zujalice su vrijedile nekad davno u prošlosti na na jeftinjola plocama sa nforce4 chipsetima kada bi lageri otišli
Staro 20.04.2020., 10:51   #7511
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,259
win/win
Ti mali ventovi su bili poznati i po crkavanju, tj nekom polucrkavanju kad bi se čuli svakakvi zvukovi iz njih. A samo vrijeme će reći koliko su izdržljivi ti novi. Staru ploču sam koristio 7 godina.
Ugl. ja bi ih pod svaku cijenu izbjegao.
Staro 20.04.2020., 11:57   #7512
Manuel Calavera
Postovi: 14,584
X670 definitivno hoće izbaciti, ali ja pričam o B čipsetu. Nema mi smisla sad do ljeta izbaciti, a za pola godine izlazi zen3 i onda bi kao opet trebali čekati B čipset za njih...
Ionako su mbo vendori naštancali nove ture B450 uoči ryzen 3000 serije...
Staro 20.04.2020., 13:06   #7513
Gigi1
Postovi: 2,138
ti ventovi na nforce 4 chipsetima su se vrtili na 3500+rpm, zato i jesu crkavali
Staro 20.04.2020., 14:21   #7514
sti
Lokacija: Lawl
Postovi: 1,374
Prije par dana sam nešto gledao na nekom od popularnijih tech kanala, ubij me sad kojem, ali u nekom trenutku je u kadru bio screenshot iz HWinfo i mislim da se vent od X570 chipseta maksimalno zavrtio do 5000 rpm.
Staro 20.04.2020., 18:46   #7515
MadBoY
MadModerator
MadBoY's Avatar
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
AMD priprema izbaciti dva nova Ryzen 3 procesora, Ryzen 3 3100 (4C/8T 3.9GHz 18MB 65W) i Ryzen 3 3300X (4C/8T 4.3GHz 18MB 65W).
Navodno su ovo i cijene:
Uz B550 još će izbaciti i A520 chipset.
Staro 20.04.2020., 20:07   #7516
Manuel Calavera
Postovi: 14,584
Znači jeftiniji R3 više nije čisti quad, možda athlona bumpaju na quada umjesto 2c4t
Samo općenito ti R3 bi se morali prodavati za kiki-riki da bi bili relevantni pored starijih 6c12t i 8c16t na akcijama (tipa 500kn), al mislim da ništa od toga
Staro 20.04.2020., 21:31   #7517
MadBoY
MadModerator
MadBoY's Avatar
Lokacija: N/A
Postovi: 5,195
U vecini igara ce ovi novi R3 vjerojatno imati vise fps od starih R5 i R7. Plus bolja podrska za RAM jer su ipak to Zen2 jezgre. Sve ovisi za sta ce se komp koristiti.
Staro 20.04.2020., 22:36   #7518
Manuel Calavera
Postovi: 14,584
Dobro 4c8t još prolazi, ali ne dugo... Bit će svršavanja kad u gamingu u dosta igara (singlecore) bude prebacio ryzene 1000 i 2000 sa 6 i 8 jezgri, no kad naleti prava igra bit će ćorak... No ajd bar se ima na što i jeftino nadograditi na sockeu u budućnosti...
Staro 20.04.2020., 23:03   #7519
nathan.fake
Lokacija: n/a
Postovi: 1,258
stigo je "novi" Ryzen 3 1200 AF, clockovi su kao i na starom 1200 AE, samo sto je Zen+, cijena cca €55
https://www.techpowerup.com/266029/a...n-architecture
https://www.computerbase.de/preisver...-a2275002.html
konkurencija Athlon 200GE/3000G.. ovisi trebas int. VGA ili 2 prave jezgre
nathan.fake je offline   Reply With Quote
Staro 21.04.2020., 17:36   #7520
MadBoY
MadModerator
MadBoY's Avatar
Lokacija: N/A
Postovi: 5,195
Evo i sluzbeno su predstavili nove Ryzene.
AMD Ryzen 3 3100, 4c8t, 3.6 GHz base - 3.9 GHz boost - 99 USD
AMD Ryzen 3 3300X, 4c8t, 3.8 GHz base - 4.3 GHz boost - 120 USD
AMD B550 Chipset
The new B550 chipset for socket AM4 is the latest addition to the AMD 500 Series chipset family with support for the industry-leading AMD Ryzen 3000 Series desktop processors. The upcoming B550 motherboards are the only mainstream modern chipset with compatibility for PCIe® 4.0, unlocking twice the bandwidth of B450 motherboards for high-speed, high-power performance in gaming and multitasking.
Availability
The AMD Ryzen 3 3100 and AMD Ryzen 3 3300X are expected to be available from leading retailers and etailers worldwide beginning May 21, 2020. AMD B550 motherboards are expected to be available beginning June 16, 2020 from ODM partners including ASRock, ASUS, Biostar, Colorful, GIGABYTE, and MSI at leading retailers and etailers.
https://www.amd.com/en/press-release...ily-unleashing
Staro 21.04.2020., 18:47   #7521
Manuel Calavera
Postovi: 14,584
Ma kao što sam i pisao, tough sell, budući da je 1600AF $85. Oko 100$ će krenuti (odnosno pro već jesu) i zen+ 8 core... Eventualno kome MT nije bitan, a singlecore jest. Od gamera recimo PUBG, starcraft...
Naravno ovaj X model odmah otpada jer pričamo o 100$ vs 120$ za isti vrag
Staro 23.04.2020., 08:45   #7522
nathan.fake
Lokacija: n/a
Postovi: 1,258
YD1600BBAFBOX je gotovo svuda nedostupan. to nije bio aktualni model, nego ciscenje lagera ko je jamio jamio
ali da, pored jeftinih zen+ ryzena 5 i 7, ovi trenutno nemaju smisla. ko kupuje sada bolje ubost r5 2600(x) ili r7 2700(x).
s druge strane pohvalno je sto dolaze sa SMT-om.
Staro 23.04.2020., 08:50   #7523
Alister
Alister's Avatar
Datum registracije: Aug 2009
Postovi: 1,490
Pa kako? Protis ih ima, Futura ih ima?
Staro 23.04.2020., 08:53   #7524
nathan.fake
Lokacija: n/a
Postovi: 1,258
Autor Alister Pregled postova
https://www.futura-it.hr/amd-ryzen-5...-1600/product/
Skladište dobavljača: 1 kom
da, ima ih kolko os, navali narode
Staro 23.04.2020., 09:00   #7525
Mladenxy
Mladenxy's Avatar
Postovi: 4,333
Autor nathan.fake Pregled postova
Da, a ryzen 3600 ima samo tri komada, znači nestalo i njih?
https://www.futura-it.hr/procesor-am...00496/product/
Staro 23.04.2020., 09:08   #7526
Alister
Alister's Avatar
Postovi: 1,490
Pa ako piše raspoloživo odmah, to znači da ih Futura ima na svojoj lokaciji. A kada ne budu uopće dostupnih u RH onda možemo pričati o nestašici, a ne sada kada je uvoz robe malo u banani
Staro 23.04.2020., 11:33   #7527
pci_e3x
Premium spammer
pci_e3x's Avatar
Lokacija: D.Zagora
Postovi: 776
Staro 23.04.2020., 14:36   #7528
Manuel Calavera
Postovi: 14,584
Leakovi za taj cpu nisu potrebni. Samo aktualne ryzene iz 3000 serije staviti na taj clock i eto ti singlecore rezultata
Staro 24.04.2020., 15:33   #7529
Postovi: 8,207
Staro 25.04.2020., 20:51   #7530
BusMaster
BusMaster's Avatar
Datum registracije: Apr 2017
Postovi: 343
AMD’s Next-Gen Cezanne Ryzen 5000 APUs Detailed
