Zaključane teme
Staro 14.01.2006., 22:31   #1
Facelessone
Facelessone's Avatar
Postovi: 4,205
HELP!! hitno plz.
Ovak. Frendu je komp pocel nekej srat pa ga j emeni dal da ga sredim i skužil sam svaki put kad reinstalita windoze nakon nekok vremena mu prestane komp radit tj. nemože uc u windowse. Dođe do dijela gdje bi trebala ic onda crtica (taj dio se ne pojavi) i napiše: Windows could not start because the fallowing file is missing or corrupt:
<Windows root>\system32\ntoskrnl.exe
Please re-install a copy of file above.
Sad ajd pliz neki savijet kaj da napravim s tim i kak da se rijesim toga
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Facelessone je offline
Staro 14.01.2006., 23:08   #2
domy_os
domy_os's Avatar
Postovi: 18,940
Čini se da je disk počeo otezat papke. Skeniraj HD Tuneom.
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
domy_os je offline
Staro 14.01.2006., 23:13   #3
Facelessone
Postovi: 4,205
hmmm to mi je malo čudno zato kaj je disko novi maxtor od 80 gb s-ata. idem onda ja sad skinut program pa to pogledat pa javim
AMD Ryzen 7 5700X
BQ Pure Rock
500GB Crucial MX500
Fractal Define R4
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate SkyHawk 6TB
Staro 14.01.2006., 23:37   #4
Facelessone
Postovi: 4,205
sad sam se uvjeril 10000% da je hard krepal. kad sam mu vec par puta pokusal instaliart windowse prvo ga nije htio formatirat u NTFS. samo je stajal i lampica na kučištu je gorila a onda sam ga probal formatirat u NTFS (quick) i onda dođe do kraja jako brzo i kaže da je disk nemoguce formatirat i jos nekej uglavnom da je krepal. E sad mu lijepo mogu rec da ga fura u ve-mulj da mu daju novi disk (to ce mu bit 3) jer mu je jedan vec krepal a meni je bilo čudno kad su mu mjenjali prvi put hard-disk kak to da su mu dali hard koji ima normalan 12V konektor zato kaj sam mjesec i pol prije toga dvojici frendova slagal komp i hardovi su isto bili iz ve-mulja al nisu imala normalan 12V konektor nego samo s-ata.
AMD Ryzen 7 5700X
BQ Pure Rock
500GB Crucial MX500
Fractal Define R4
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate SkyHawk 6TB
Staro 15.01.2006., 14:46   #5
nicko
Postovi: 4,190
da li se disk možda zove maxtor??
nicko je offline
Staro 15.01.2006., 16:45   #6
domy_os
domy_os's Avatar
Postovi: 18,940
LOL
domy_os je offline
Staro 15.01.2006., 16:51   #7
BrunoZG
Junior Member
BrunoZG's Avatar
Datum registracije: May 2003
Postovi: 3,205
da li taj disk normalno radi kad je spojena ana njega nisu instalirani win nego na neki drugi?
AMD 3800+x2@2500, 1,375V
MB-ASROCK DUAL SATA(bios 2.2) 2+ENERMAX485W
2x512 Supertalent CL2
HDD-Hitachi 160GB, WD 800JB
ELSA 7600GT
Leadtek-2000XP expert
DVDROM-LITEON-167T ,DVDRW BENQ 1650,DVDRW NEC ND2500A@2510_fw205C
Monitor: Samsung 997MB (19')
Terratec Sky 5.1,EPSON-C42
BrunoZG je offline
Staro 15.01.2006., 17:21   #8
Facelessone
Postovi: 4,205
ma kaj vam je to probal sam ga forumatirat i više ni to neče gotov je ide na reklamaciju i daj čitajte malo MAXTOR 80GB S-ATA
AMD Ryzen 7 5700X
BQ Pure Rock
500GB Crucial MX500
Fractal Define R4
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate SkyHawk 6TB
Staro 15.01.2006., 17:52   #9
nicko
Postovi: 4,190
ah, nisam vidio taj post....ali sam pogodio
i onda ekipa kupuje i hvali maxtore....za mene ni pod razno...
nicko je offline
Staro 15.01.2006., 22:09   #10
Facelessone
Postovi: 4,205
može lock
AMD Ryzen 7 5700X
BQ Pure Rock
500GB Crucial MX500
Fractal Define R4
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate SkyHawk 6TB
Staro 15.01.2006., 22:22   #11
Thoroughbred B
Thoroughbred B's Avatar
Datum registracije: Apr 2003
Lokacija: RI
Postovi: 4,918
Bome i ja sam se namucio s maxtorima
Thoroughbred B je offline
Staro 16.01.2006., 17:15   #12
Infekted
Just Member...
Infekted's Avatar
Lokacija: The End.
Postovi: 17
Stoji mi na stolu jedana takav....Pukla igla ccc Jel se zna dogoditi da koji MAXTOR zbilja i radi??
Infekted je offline
Zaključane teme
