Staro 16.03.2020., 17:03   #4081
Mikygs
Lokacija: Gospic
Postovi: 305
Nije ukljucen smart resolution,probao sam ga ukljuciti / iskljuciti.
Vivid mode je ukljucen na oba mobitela ,brightness isti te sve ostale postavke.
Jednostavno se vidi razlika ,boje su puno bolje na P20P i izrazenije,tekst bolji i ostriji.
Na P30P mi jednostavno "tamnije" izgleda i nije bas tako "ostro".
Pricao sam s kolegom koji isto ima P30P ,kaze da je istu stvar primjetio.
Evo i citat sa xda foruma :
" They should have definitely gone with a 2k panel, as the display on this phone reminds me a lot of the S5 and S4 displays. Texts looks fuzzy, and the brighter the screen goes, the more you'll be able to notice the pixels, and you don't even need to look for them. Maybe my eyes got used to the sharper displays I had in the past few years, but even when compared to my last year's P20 P30, this doesn't look that good in terms of sharpness."
Mikygs je offline   Reply With Quote
Staro 16.03.2020., 17:50   #4082
Exy
Exy's Avatar
Lokacija: Zagreb, Črnomerec
Postovi: 2,564
P20P ima 1080 x 2240 6,1" ekran, P30P ima 1080 x 2340 6,47" ekran, razlika u oštrini ne bi trebala biti vidljiva golim okom
Ne znam u čemu bi mogla biti stvar, možda font? Ili imaš super vid
Staro 16.03.2020., 18:07   #4083
Dottore
Dottore's Avatar
Postovi: 7,666
@exy
Slike su ispale dobre. Boja i prirodno svjetlo čini svoje.
Uživaj!
Отправлено через SM-N975F
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 16.03.2020., 21:40   #4084
Exy
Exy's Avatar
Postovi: 2,564
Autor zvonac Pregled postova
A low light slike
Evo ga -> https://drive.google.com/open?id=12z...SlkWjQZ1SqpPxb
Uživajte u praznom Zg
Ima i par night slika sa wide kamerom. Ponegdje je night mode, ponegdje automatik. U night modu je dosta bitno gdje je fokus, osim ako se koristi pro mode što mi se nije dalo. Ali siguran sam da bi ručne postavke dale najbolje rezultate, no tko ima vremena za to dok slika mobitelom....
Imam osjećaj da mob može više, samo je potrebno nešto i znati o fotografiranju i postavkama, ne samo point and shoot.
Autor Dottore Pregled postova
@exy
Uživaj!
Hvala
Ma jasna stvar je da bilo koji današnji mob daje takve slike kad je vedro i sunčano. Više me zanimao zoom i tako, ipak je to na kraju krajeva samo igračka.
Staro 16.03.2020., 23:47   #4085
Mikygs
Lokacija: Gospic
Postovi: 305
Autor Exy Pregled postova
Malo sam se poigrao.. u mom slucaju bilo je potrebno malo povecati brightness te u developer mode-u povecati display density na vrijednost izmedju 400-400 dpi ,kako kome vec odgovara. Takodjer ,malo i ebay kinezarija kaljeno igra ulogu,ali sad je to to
Budem jos uzeo nekakvo kvalitetnije kaljeno / foliju i ko sisa
Staro 17.03.2020., 06:12   #4086
Postovi: 34,001
Već su našli jednostavnu metodu za instalaciju Google Play na Huawei mobitele
https://www.technobaboy.com/2020/03/...store-install/
Staro 17.03.2020., 11:27   #4087
Xenon
Postovi: 1,542
zeleni P40 lite je fenomenalan
Xenon je offline   Reply With Quote
Staro 18.03.2020., 17:47   #4088
Old friend
Postovi: 432
Nije toliko stvar u samom instaliranju applikacija koliko u samom certificiranju uređaja od strane Google Play Protecta.
A to svako malo ne radi. Ako sada i radi pitanje je do kada će. Dakle što i vrijedi instalirati kada ne možeš ući u app jer ti Google izbaci da ti uređaj nije certificiran.
Old friend je offline   Reply With Quote
Staro 18.03.2020., 20:27   #4089
Exy
Exy's Avatar
Postovi: 2,564
Jednostavno treba zaboraviti na google play na novim Huaweima i gotovo. Te fore sa sideloadanjem, microg-em i sl. će raditi možda 0,5% ljudi, ako i toliko.
Bio je linkan na ovom topicu članak gsmarene, guide kroz Huawei AppGallery. Meni konkretno bi falio netflix, i to je to. Sve ostalo bi mogao kroz AppGallery srediti bez većih problema.
Inače, kažu ljudi da P40 lite leti, sad dal je to zato što nema google bloat gore ili zato što ima odličan hardware za midrangera, ostaje za vidjeti
Staro 18.03.2020., 21:03   #4090
SympForTheDevil
SympForTheDevil's Avatar
Datum registracije: Sep 2019
Postovi: 636
Lete svi Huawei od Kirina 970 još. Nema to toliko veze sa hw/google koliko sa optimizacijom EMUI-a za Kirin procesore.
Staro 19.03.2020., 06:19   #4091
Postovi: 34,001
Isto i kao iOS-om - OS optimiziran za određeni hardver. I normalno da leti.
Staro 19.03.2020., 09:37   #4092
Ivo_Strojnica
PRO
Ivo_Strojnica's Avatar
Postovi: 4,810
To mogu potvrditi, meni Huawei Mate 20 Pro stvarno neumoran i nakon dvije godine.
Staro 19.03.2020., 11:48   #4093
SympForTheDevil
Postovi: 636
I meni M10P...i baterija mu je još nenadjebiva....princip deri dok ne stane
Staro 20.03.2020., 07:54   #4094
sasha2511
Mindfreak
sasha2511's Avatar
Datum registracije: Apr 2015
Postovi: 1,232
Autor SympForTheDevil Pregled postova
tako i kod mene.. cekamo android 10 za njega.. moj je jos u garanciji pa namjeravam i bateriju promjenit za mufte kad se moze.. jos ce on posluzit.. 😉
Poslano sa mog BLA-L09 koristeći Tapatalk
sasha2511 je offline   Reply With Quote
Staro 25.03.2020., 18:46   #4095
Exy
Exy's Avatar
Postovi: 2,564
P30P, napunjen prekjučer u ponoć. Dark mode, always on display uključen 7-24, auto brightness. 7H SOT-a upravo, gledao malo youtube na putu sa posla, došao doma, vidio da je pao ispod 30% pa reko da ga stavim na punjač, onda sam se malo šokirao koliko je sati radio.
Baterija je stvarno najpodcijenjenija prednost ovog mobitela
Staro 25.03.2020., 19:12   #4096
Neo-ST
Neo-ST's Avatar
Postovi: 8,445
Sutra live otkrivanje pobjednika u teškoj kategoriji...
https://www.phonearena.com/news/Watc...-here_id123291
Staro 25.03.2020., 20:09   #4097
Odlično.
Samo molim da sutra tijekom izljeva sreće bude doza objektivnosti i samokontrole tj da ne bude pizdarija kao lani kad je izlazio P30Pro + situacija sa sankcijama.
Samo to.
Staro 25.03.2020., 20:41   #4098
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,422
naletio na ovo, možda nekog zanima tematika
Staro 25.03.2020., 20:47   #4099
zvonac
zvonac's Avatar
Lokacija: Sv.Nedelja
Postovi: 5,824
P40 me zanima, 6.1", oled ekran, 3850 baterija, glavna kamera kao i na P40P..
Staro 25.03.2020., 21:16   #4100
SympForTheDevil
Postovi: 636
Baš. 6.1 je sada kompakt klasa u Android svijetu. Nadajmo se da će stići na EU tržište.
Staro 25.03.2020., 21:20   #4101
zvonac
zvonac's Avatar
Postovi: 5,824
Da, doci ce i kod nas. Dimenzijama taman po mojoj mjeri...
Jedino jos treba vidit to nepostojanje gappsa kak bu to sve radilo u praksi.
Staro 26.03.2020., 14:40   #4102
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,422
Staro 26.03.2020., 14:40   #4103
Neo-ST
Neo-ST's Avatar
Postovi: 8,445
Staro 26.03.2020., 14:46   #4104
Dottore
Dottore's Avatar
Postovi: 7,666
Bude to odvijalo preko weba.
Za nekoga tko ne voli installirane google servise.
Отправлено через SM-T820
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 26.03.2020., 14:49   #4105
Huawei nastavlja sa agresivnim marketingom.
Opet Day 1 review, kao i za P30 Pro:
https://m.gsmarena.com/huawei_p40_pro-review-2089.php
Staro 26.03.2020., 14:59   #4106
SympForTheDevil
Postovi: 636
Ima li negdje potvrda da će doći u EU tržište i kod teleoperatera?
Jer nigdje ne nalazim.
Bummer i to veliki je 60hz ekran,non stereo zvuk,komplilacije sa googlom....te kad uzmemo cijenu ne možemo ni izbjeći pitanje zastarjelog soc-a.
500€ bi morala gornja cijena biti imho.
Staro 26.03.2020., 17:48   #4107
Postovi: 34,001
Teško će ga teleoperateri uzeti kada nema podršku za GMS. Zbog toga i nisu namijenjeni za EU već za Kinu gdje je GMS ne toliko bitna stavka obzirom da Kinezi imaju svoje pandane.
Staro 26.03.2020., 18:22   #4108
Piše da je očekivana cenka cca 800 ojra.
Staro 26.03.2020., 18:51   #4109
Ivo_Strojnica
PRO
Postovi: 4,810
to je ok za početnu cijenu....ovo bih vrlo lako mogao nabaviti kad cijena malo padne.
Srebrna boja mi je apsolutno predivna!
Staro 26.03.2020., 19:03   #4110
SympForTheDevil
Postovi: 636
OK? Dobiješ telefon sa 90hz screenom,jačim soc-om,stereo zvucnicima, wireless chargingom,boljom baterijom, googleomza 550€(khm khm Mi 10)
I biti će kod operatera za razliku od P40(vulgaris)...što će otvoriti prostor za jači price dump.
A uskoro dolazi i OnePlus 8 vulgaris po sličnoj cijeni (550-600).
Jedino što će možda P40 imati na svojoj strani je kamera....a i to ostaje za vidjeti.
