Staro 18.02.2020., 00:43   #31
Lewis
Freelancer
Lewis's Avatar
Lokacija: Bilje (Osijek)
Postovi: 5,256
Dionica Nvidie je neki dan skocila gore +7% tako da ocito neko nesto vec zna sta je u pripremi .
Staro 18.02.2020., 11:43   #32
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,578
Mislim da i vrapci na grani znaju da će nvidia na 7nm razvaliti. Logično jer ide novi full node + nova arch
Staro 23.02.2020., 00:06   #33
Manuel Calavera
Postovi: 14,578
Naglašavam da je ovo glasina sa velikim G (sa nekog novog twittera od nekog tko nema povijest)
RUMORS: NVIDIA Ampere GPU Massive Die Size, Specifications, Architecture and More!
Ovih 826mm za flagship zvuči abnormalno za 7nm+. Ako se obistini bit će čudovište. Pretpostavljam da bi to bila titanka i da bi koštala kao ozbiljniji auto
Staro 24.02.2020., 19:59   #34
Manuel Calavera
Postovi: 14,578
What Igor is essentially saying is that important people who are usually invited to such a huge launch haven't been invited and travel calendars haven't been filled in. This likely means that the event at GTC 2020 is not going to be as big as we hoped - which lessens the likelihood of an Ampere launch almost significantly. Igor posits that Ampere will actually launch around Siggraph and Gamescom - the usual dates for a next-generation GPU launch from NVIDIA.
https://wccftech.com/igors-lab-no-nv...hing-in-march/
Staro 24.02.2020., 20:04   #35
stef
stef's Avatar
Lokacija: Zabok
Postovi: 3,346
Reticle limit na 7nm TSMC je navodno manji od 500mm^2.
Drugo, to je objavio lik koji je potpuni anonimus.
stef je online   Reply With Quote
Staro 27.02.2020., 19:36   #36
tole_
Casual Racist
tole_'s Avatar
Lokacija: Sneed's feed and seed (formerly Chuck's)
Postovi: 422
ASML skeneri imaju reticle limit od 858mm2 (26x33mm), što bi se pak trebalo prepoloviti uvođenjem novih High-NA EUV uređaja 2023. god. (ako ne bude odgoda). Tako da tih 826mm2 za GA100 nije nemoguće, kao što ni 815mm2 nije bio problem za GV100. No to su čipovi za HPC tržište, pitanje je šta bude s onima gaming kartice.
Ne znam od kuda ovom Walošeku ideja da bi Geforce kartice trebale biti predstavljene na GTCu, jer to bi bio presedan. Jedino ako je on mislio da nebu ništa ni od HPC Ampera na GTCu?
Nego da, što se tiče gaming kartica, postoje glasine da su odgođene za Q1/Q2 2021. god. Razlog je taj što se nvidia odlučila za Samsungov 7nm proces koji je izgleda u banani s yieldovima, pa su ovi bili primorani sve prebaciti nazad na TSMC. Kako javlja jedan od ovih twitter kineza, tapeout bi trebao biti gotov u 3.-4.mj., a od tad do gotovog proizvoda treba oko godinu dana, tako da eto. Pitanje je samo radi li se tu o samo određenim čipovima ili pak o svima osim GA100. Mislim da će se kroz mjesec dana puno toga znati. U svakom slučaju, AMD bi mogao nakon dugo vremena preuzeti vrh ako su glasine o 80CU čipu istinite, a puno njih se gotovo kune da jesu.
Why did the console peasant cross the road?
To render the buildings on the other side!
tole_ je offline   Reply With Quote
Staro 27.02.2020., 22:06   #37
stef
stef's Avatar
Lokacija: Zabok
Postovi: 3,346
Navodno Nvidia ide s TSMC, Samsung kasnije.
Staro 27.02.2020., 22:31   #38
Manuel Calavera
Postovi: 14,578
Pa zar nije bilo službeno od nvidie da idu na TSMC, a Samsung samo za manju paletu proizvoda (kao svojevremeno gtx 1050 i 1050Ti na 14nm samsung)? Mislim da sam linkao u ovoj ili Turing temi
Edit
The information comes straight from NVIDIA's CEO who stated during the media Q/A session that they will primarily be selecting TSMC for the majority of their next-generation 7nm GPU orders with Samsung only receiving a smaller number of orders.
https://www.google.com/amp/s/wccftec...pu-ampere/amp/
Informacija još od prije božića. Katoličkog
Ampere osobno očekujem između 5 i 7 mjeseca. To je uglavnom nvidijin termin. Mada ako se ova korona razbukta može se odgodit
Zadnje izmijenjeno od: Manuel Calavera. 27.02.2020. u 22:42.
Staro 01.03.2020., 15:05   #39
Postovi: 8,130
The graphics card with 108 CUs was listed with 48GB of VRAM and a 1.01GHz while the 118 CU card was listed with 24GB of VRAM and a 1.11GHz clock speed.
Staro 01.03.2020., 15:47   #40
Lewis
Freelancer
Lewis's Avatar
Postovi: 5,256
Oooooh, kakva ce to mrcina biti ako poduplaju broj jezgri i VRAM i jos kako je ranije receno da ce RT jezgre biti bolje/vise komada.
Uf jedva cekam
Staro 03.03.2020., 21:02   #41
MAHER
Postovi: 1,583
Vec vidim koznjak sa msrp od 2k usd.
MAHER je offline   Reply With Quote
Staro 03.03.2020., 21:03   #42
Lewis
Freelancer
Lewis's Avatar
Postovi: 5,256
Treba ubost koju dionicu dok su jos ispod 270$ .
Staro 07.03.2020., 16:53   #43
Manuel Calavera
Postovi: 14,578
Staro 10.03.2020., 21:49   #44
Psycho
Master Of Disaster
Psycho's Avatar
Datum registracije: Nov 2002
Postovi: 1,265
ovo sta dolazi ove godine za GPUe svih vrsta, boze mili..cudovista
Staro 10.03.2020., 21:52   #45
Pa bilo bi i vrijeme. Nije baš da su sa Turingom napravili skok sa Pascala kakav su napravili na Pascalu sa Maxwella. A to je bilo sad već davne 2016.
Staro 10.03.2020., 22:07   #46
Psycho
Master Of Disaster
Psycho's Avatar
Postovi: 1,265
istina, ali kad pogledas realno nije bilo ni potrebno em zbog manjka konkurencije em sto su high end graficke jos uvijek zvijeri koje nisu potrebne vecini.
dok za HPC trziste ne bi znao reci da li je potreban novi skok.
Staro 10.03.2020., 22:17   #47
Ma samo neka RTX 3080 bude 40-50% jača od 2080Ti i da košta kao sadašnja 2080 super - GG
Staro 10.03.2020., 22:30   #48
Postovi: 8,130
U međuvremenu su kompletno otkazali GTC online izdanje.
nVidia today announced that, in light of the spread of the coronavirus, it is deferring plans to deliver a webcast keynote as part of the digital version of its GPU Technology Conference later this month. The company will, instead, issue on Tuesday, March 24, news announcements that had been scheduled to be shared in the keynote. This will be followed by an investor call with nVidia founder and Chief Executive Officer Jensen Huang, which will be accessible to other listeners.
Izvor: Guru3D
Staro 10.03.2020., 23:53   #49
messiah
aka Mithrandir
messiah's Avatar
Postovi: 449
Izvor: Guru3D
Otkazali su samo keynote, kojeg mijenjaju "vijestima". GTC Online zasad je i dalje planiran od 25.3 nadalje.
Vjerojatno će i u skraćenom formatu predstaviti nešto, jer investor call nakon toga inače nema smisla.
messiah je offline   Reply With Quote
Staro 11.03.2020., 10:04   #50
JC Denton
dr. sc. tech. dipl. ing.
JC Denton's Avatar
Lokacija: Rijeka-Opatija
Postovi: 3,164
Vjerojatno im je bitnije kakve će biti RTX3060/3070 u odnosu na njihove prethodnike... mislim da im je to najprodavaniji segment
Staro 11.03.2020., 20:05   #51
sti
Lokacija: Lawl
Postovi: 1,370
Iiiii gotovo, počinje spuštanje na zemlju... Jao kako se hajpao Ampere, ni ozbiljni forumi poput ovog nisu ostali imuni
https://wccftech.com/nvidia-geforce-...-launch-rumor/
GeForce na Samsungovom šrot 10nm procesu, 7nm samo za HPC. Napredak u performansama jednak kao prilikom prelaska sa Pascala na Turing.
3080Ti jači 40% od 2080Ti
3080 jači 10% od 2080Ti
3070 slabiji od 2080Ti
Još uvijek nije potvrđeno, ali nema ikakvog financijskog smisla da Nvidia radi velike generacijske skokove i smanjuje svoje ogromne marže (vjerojatno su zato i odjebali TSMC i prešli na Samsungov šrot) kad imaju monopol i odriješene ruke za pljačkanje raje...
Bojim se da je Maxwell - Pascal bio zadnji veliki skok performansi, a nažalost ovo nije CPU univerzum u kojem AMD može razjebati sistem, osim što može najaviti Big Navi za "kraj 2020" (čitaj Q1 2021), koji će možda ponuditi neku alternativu u high endu. Jednostavno previše kaskaju za zelenom bagrom da to zeleni ne bi iskoristili i prebili preko naših novčanika.
sti je online   Reply With Quote
Staro 11.03.2020., 20:13   #52
Mladenxy
Mladenxy's Avatar
Postovi: 4,294
Preko mojeg novčanika se ne budu najeli, to im garantiram Ak bum trošio, trošio bum na PS5. Mogu se predomisliti ak sržu cijene i to opako, za što nema nikakve šanse.
Staro 11.03.2020., 20:17   #53
sti
Lokacija: Lawl
Postovi: 1,370
Isto razmišljam, PC na bubanj ili ga ostaviti sa strane i počastiti se sa PS5 + Oled TV-om... Nove konzole će ionako biti poprilične zvijeri sa cijenom koja će morati biti prilagođena za masovnu prodaju.
Staro 11.03.2020., 20:19   #54
Postovi: 8,130
Autor messiah Pregled postova
Ma je, ali taj keynote je uvijek najzanimljiviji dio, a sad ga više ni ne možemo pratiti, već budu lagano puštali vijest po vijest diljem tech portala.
Autor sti Pregled postova
Ne bi bilo prvi put da Wccftech plasira sve i svašta, pa se možda nekaj i ulovi. Ko će ih znati. Previše njihovih vijesti i glasina podsjeća na NewsBar.
Staro 11.03.2020., 21:06   #55
Ak je tak, nebu onda ni Amperaža turirala u mom kompu.
Ukoliko ima i malo istine u tome, onda je to klinac. Ručna na četvrtom zubu. Novi node, nova uArch, pomak manji nego NA ISTOJ uArch Maxwell -> Pascal.
Ode dionica u qrac ak ovako bude
Bome mudro zboriš. Bude PS5 i Pascal u kompu dok ne krepa.
Staro 11.03.2020., 21:23   #56
Postovi: 8,130
U slučaju da se ovo stvarno odigra, onda im AMD s RDNA 2 itekak diše za vrat ili budu nudili bolje, ali opet se postavlja pitanje na koju foru se nVidia uspjela zajebati.
Staro 12.03.2020., 13:30   #57
RimtuTiTuki
RimtuTiTuki's Avatar
Postovi: 1,629
Mislim da će korona sve pomaknuti za 2-3 mjeseca, tako da se ne bi previše nadao nekim skorim najavama novih grafičkih.
Staro 13.03.2020., 10:16   #58
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,236
Meni je kakogod bolje od trenutne (samo da cijena bude OK), ali da ta usrana pandemija ga je svima metnula.
Nekako mi sve primamljivije izgleda 5700/XT ali me strah drivera...
Slobodno me dodajte na PSN
Staro 13.03.2020., 12:32   #59
messiah
aka Mithrandir
messiah's Avatar
Postovi: 449
Barem je GTC Online free sada
Možete se registrirati online na: https://www.nvidia.com/en-us/gtc/
i pogledati sva predavanja besplatno. Bude ih dobrih iz raznih područja.
Staro 14.03.2020., 12:39   #60
Manuel Calavera
Postovi: 14,578
@sti kakvo spuštanje na zemlju? Kao što sam i spominjao da rtx 3070 bude "ballpark" od rtx 2080Ti (sad malo slabija ili jača otom potom), pa će biti masovnih prelazaka sa pascala na iste. Ljudi su oklijevali prijeći na turing, no recimo vlasnici gtx 1080 će sa rtx 3070 u najgorem slučaju imati 50% performance boost ...
Još ako bi RT bio duplo jači od turinga, recimo nvidia bi napravila dobar marketing kad bi "60" class gpu (rtx 3060) bila u rangu ili jača u RT od rtx 2080Ti, a flagship duplo... Dići će puno love na mainstream gamerima, što recimo turing nije napravio.
