#7171 |
Datum registracije: Aug 2014
Postovi: 2,931
1080 30 fps ima elektronsku a ostalo iznad toga nema Poslano sa mog Mi 9 Lite koristeći Tapatalk |
#7172 |
Postovi: 1,542
Zatvorili su svoj dućan u Londonu |
#7173 |
Postovi: 1,542
#7174 |
Creeper
Datum registracije: May 2013
Postovi: 2,215
Mislim da imamo nekakvo štekanje u komunikaciji. EEA Rom je za EU i ima ga na službenim stranicama, ja o njemu pričam. Uglavnom, malo sam istraživao i kako stvari stoje, Xiaomi za zapadna tržišta planira stavljati samo Google dialer jer je to nešto na što su "zapadnjaci" navikli. S tim da bi ove godine i Google dialer trebao dobiti opciju snimanja razgovora.
#7175 | |
Postovi: 1,542
"Starting with (and including) the Mi 9T Pro, all Xiaomi smartphones that launch internationally are shipping with Google's Phone and Messages apps. This change has finally been acknowledged by Xiaomi on its official forums today, and it's definitely been a long time coming. Thus, if you have a Xiaomi handset running a Global or EEA ROM, you no longer have MIUI Dialer and Messaging installed. The Chinese company is giving up on these and using Google's alternatives due to "privacy laws and restrictions around the globe". Xiaomi continues to explain that Google's Phone and Messages use Google Mobile Services, which is obvious and doesn't really get into the nitty gritty." We assume Xiaomi preferred this solution to making sure its own MIUI Dialer and Messaging apps comply with the various privacy regulations across all territories where it's selling its products. This change is not expected to be retrofitted to those models that launched internationally before the Mi 9T Pro. The situation means that if you're stuck with Google's apps you won't be able to record calls, although Xiaomi's team promises that function will return before the end of this year. |
#7176 |
Postovi: 2,931
#7177 |
Postovi: 1,542
A2 počeo primat Android 10 |
#7178 |
woot!!!
Postovi: 2,497
Naletio na redditu, vele ljudi da im se zbrikal A2 tokom updatea na Android 10. https://www.reddit.com/r/Xiaomi/comm...oid_10_update/ Bila je jučer hrpa takvih postova. |
#7179 |
laser
Postovi: 2,348
Xiaomi mobiteli
Sestra javila da je zbrikala a2 lite kad je klikla na upgrade na 10. Sta sad radit, mob je pod garancijom neutrino. Edit: nisan vidia post iznad, provat cu joj tako rijesit Sent from my iPhone using Tapatalk |
#7180 |
Lokacija: Bjelovar
Postovi: 477
Procitaj ovo : https://forum.xda-developers.com/mi-...-lite-t4063937 |
#7181 |
Datum registracije: Mar 2010
Lokacija: Vukovar
Postovi: 3,617
#7182 |
Postovi: 1,542
#7183 |
RESPECT MY AUTHORITAH
Postovi: 7,485
Mi 9 Lite, za gcam 7 mi treba twrp i buffer fix, pa sam probao više verzija gcam 6.2 No slike ispadnu dosta lošije u usproedbi sa stock fotkama. Jedna google ima 8MB a stock app 2MB, oboje HDR uključen. https://imgur.com/a/A0wrkT4 Jedino fotosferu slika ok gcam https://i.imgur.com/jyEmVex.jpg Sada sam guglao, i tek na Gcam_6.2.030_Advanced_BF_V2.2.2beta2.190904.1817.apk i mi9lite.xml nemam ovakav tamniji efekt, to još moram isprobati https://www.celsoazevedo.com/files/a.../changelog693/ https://forum.xda-developers.com/att...5&d=1576073578
#7184 | |
Datum registracije: Sep 2002
Postovi: 2,721
Global MIUI 11.0.4 Sent from my Mi 9T using Tapatalk |
#7185 |
Postovi: 1,542
Da, svi modeli do MI9T imaju .... nakon njega uključujući MI9T PRO nema ... ima googleove app i nema recoreder. Imam ja MI9T sa tom verzijom softa ... neće naknadano ukidat tu opciju na starijm modelima, ostaje sve kako je |
#7186 |
Postovi: 1,674
Za GCAM koristim apk od ovdje https://www.celsoazevedo.com/files/a...nyx05/#apk1269 Imam instaliranu verziju Urnyx's 7.2.010 v2.2 i zadovoljan sam |
#7187 | |
Postovi: 2,931
#7188 |
Master Of Disaster
Datum registracije: Nov 2002
Postovi: 1,268
https://www.gizchina.com/2020/03/17/...-xiaomi-phone/ Evo ako nekome koristi. Btw. Updateao mob na najnoviji software, za razliku od prosle verzije trajnost baterije se vratila u normalu. Imao sam filing da je malo krace trajala. Sve ostalo, bez ikakvih problema za sada. ![]() Sent from my Mi MIX 3 using Tapatalk
#7190 |
Datum registracije: Mar 2020
Lokacija: SMB
Postovi: 45
Xiaomi Mi 9T, SMS je ograničen na 67 znakova umjesto 160, sms ne sadržava čćžšđ niti bilo što slično Neko rješenje? |
#7191 |
Postovi: 2,931
#7192 | |
Postovi: 1,542
Ima Xiaomi poruke i one su ograničene na 67 znakova a google poruke na 145. |
#7193 |
Lokacija: SMB
Postovi: 45
evo nema nikakvih jednostavnih poruka, u sms opcijama niti keyboard opcijama edit: same time post 22:51, ok will try google sms evo radi google sms propisno, a xiaomi messages sam disableao, hvala, nemam sms paket a ipak se nekada koriste, bezveze je bilo 0.29kn za 67 znakova Zadnje izmijenjeno od: maleni. 27.03.2020. u 00:02. |
#7194 |
Postovi: 2,931
#7195 |
Postovi: 1,542
#7196 |
Postovi: 2,931
To ti piše da je u drugoj ostalo 145. U prvoj 5i je stalo 160. Pred kraj odbrojava zadnjih 10. Ako mi ne vjeruješ prebroji😂 Poslano sa mog Mi 9 Lite koristeći Tapatalk |
#7197 |
Postovi: 1,542
To znam. Pa nije da ti ne vjerujem nego velim da mi je prvi put pisalo 67 znakova (kao covjeku gore) i lomilo poruku. A nisam stisnuo dijakriticki znak. |
#7198 | |
Postovi: 2,931
Nego ja pričam da kad stisneš jednostavni način prva poruka je 160 a druga 145. Sve 5 ,👍 Poslano sa mog Mi 9 Lite koristeći Tapatalk |
#7199 |
Lokacija: Vukovar
Postovi: 3,617
#7200 | |
Lokacija: Zagreb, Črnomerec
Postovi: 2,569
Neki ovdje su najavljivali Mi 10 za 550 EUR ![]() |
