Staro 18.02.2020., 21:23   #7231
Lewis
Freelancer
Lewis's Avatar
Lokacija: Bilje (Osijek)
Postovi: 5,265
Ebo poster, 3D print treba
Ali ja i dalje sam uz Mladena
Print ovoga na nekom SLSL printeru (zbog kolicine materijala) bit te kostao vise nego prava .
Staro 19.02.2020., 22:19   #7232
Postovi: 8,191
US Navy orders AMD + nVidia powered supercomputer with 590TB of RAM
Supercomputer manufacturer Cray is building a machine for the US Navy that will be packed with AMD’s Epyc Rome cores and nVidia’s Volta GPUs. Built on the Shasta platform, it'll boast a performance of 12.8 petaflops, which makes it one of the top 20 most powerful supercomputers in the world today. As you would imagine, the supercomputer will feature some serious hardware, including 290,304 AMD EPYC 7002-series processor cores, 112 nVidia Volta V100 GPUs, and a 200 gigabit per second Cray Slingshot network interconnect. There’ll also be an incredible 590TB of memory, which should be enough for a few Chrome tabs, and 14 petabytes of usable storage, including 1PB of NVMe-based SSDs.
AMD EPYC 7662 and EPYC 7532 launched
The AMD EPYC 7662 is a 64-core and 128-thread processor with 256MB of L3 cache. The chip has a TDP of 225W matching the highest-end mainstream (e.g. non- EPYC 7H12) CPUs. The AMD EPYC 7532 is a 32-core and 64-thread processor with 256MB of L3 cache. The chip has a TDP of 200W. That means that this chip, like the 64-core EPYC 7662, is an eight CCD design. In other words, it has eight chiplets that are attached to the central I/O die. Each has 4 cores and 32MB of L3 cache active per chiplet.
Izvor: TechSpot i ServeTheHome
Staro 19.02.2020., 22:55   #7233
thunderbird
Premijum AMDebil
thunderbird's Avatar
Lokacija: jastrebarsko
Postovi: 1,150
PRC!
X
Staro 23.02.2020., 13:46   #7234
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,581
Nisam ovo vidio, isplivala prva b550
http://www.tomshardware.com/amp/news...board-features
Staro 23.02.2020., 14:23   #7235
Mladenxy
Mladenxy's Avatar
Postovi: 4,326
To je falilo najviše, ak bude cc 550-600 kn + 1400 kn Ryzen 3600 i puna šaka brade. Sve tip top, zadnji krik tehnike za male novce. Dođe mi žao kaj ne kupujem novi komp.
Staro 23.02.2020., 14:31   #7236
Da, samo tko bi onda kupovao X570 ploče? Dobro su to oni proračunali.
Staro 23.02.2020., 14:56   #7237
Manuel Calavera
Postovi: 14,581
I dalje svi koji kupuju pc višeg budžeta/ranga, trebaju nešto ozbiljnije (određeni broj konektora i sl.), overclockeri i sl. - jer mislim da će se nastaviti praksa sa B čipsetima da je 4 phase vrm plafon...
Po meni B550 ne znači ništa, ništa ne mjenja u grand sheme... Čak i ako se potvrdi pci-e 4.0 support, njeni kupci - mainstreameri ga ne trebaju
Zadnje izmijenjeno od: Manuel Calavera. 23.02.2020. u 15:03.
Staro 23.02.2020., 15:09   #7238
Postovi: 8,191
Uglavnom, riječ je o za OEM tržište prepravljenoj B450 ploči.
Staro 07.03.2020., 17:12   #7239
Manuel Calavera
Postovi: 14,581
According to the latest roadmap, AMD will be launching its Zen 3 CPU architecture this year in two key product families, the 4th Generation Ryzen 4000 series desktop processors and the 3rd Generation EPYC Milan server processors.
AMD has listed Zen 3 as 7nm (previously referred to as 7nm+) since it caused confusion as many thought it was AMD referring to TSMC's 7nm EUV node but the company has stated that they've not unveiled the process node officially as of yet and will do so at a later date. Coming to the new roadmap, we see Zen 3 (7nm) listed as a 2020 part with Zen 4 (5nm) replacing in in 2021. Since the Zen 3 parts are shipping in late 2020, it is highly likely that Zen 4 chips would follow suit and could hit the market by end of 2021 or even early 2022.
Čini mi se da je AMD odlučio čvrsto držati se roadmapa (izbaciti zen 3 do kraja godine), a da je ovaj 7nm EUV (ilitiga 7nm+) još uvijek li-la, odnosno nisu sigurni da li će do tada biti dovoljno zreo, te da ako ne bude šibaju ga na običan 7nm, jer će ionako performance gain većinom doći od nove arhitekture (IPC)
https://wccftech.com/amd-zen-3-ryzen...e-2020-launch/
Staro 07.03.2020., 18:09   #7240
Postovi: 8,191
AMD Financial Analyst Day 2020 Round-Up: Laying a path for bigger & better things
AMD’s first Financial Analyst Day since 2017 has just wrapped up. In the last three years AMD has undergone a dramatic change, launching its Zen CPU architecture, and greatly improving the trajectory of a company that was flirting with bankruptcy a few years ago. And now that AMD’s foundation is once again secure, the company has gathered to once again talk to its loyal (and looking at stock prices, now much richer) investors and how it’s planning to use this success to push into bigger and better things. The big takeaway from the financial side of AMD is of course that the company is profitable. After at one point having more debts than cash, careful spending on AMD’s part along with the success of their Zen CPUs and recent GPUs has lifted AMD’s fortunes greatly. The company is now consistently profitable, revenues are growing, and at the same time it’s able to deliver results to shareholders while still using their new success to increase investments in critical R&D.
As a result, the AMD of 2020 is a much different company than the AMD of 2017. Instead of needing to survive, as was the case in 2017, AMD in 2020 gets to thrive. And as a result CEO Dr. Lisa Su is looking to taking AMD on to bigger and better things; to leverage AMD’s strengths to grow the company’s market share and take advantage of new opportunities, all while continuing her successful strategy of focused execution. The big focus here (though far from sole) is on the data center market. Long the breadbasket of Intel and increasingly nVidia as well, it’s a highly profitable market that continues to grow. And it’s a market that slipped away from AMD, and which they’re now clawing back on the strength of their EPYC processors. Over the next 5 years AMD wants to take a much bigger piece of the total data center pie, and in fact the company expects to cross 10% market share of data center CPUs this next quarter. Which, by our reckoning, would be the first time they've hit that kind of market share in a decade (if not more), showing just how much things have changed for AMD.
Izvor: AnadTech
Staro 07.03.2020., 18:13   #7241
Manuel Calavera
Postovi: 14,581
Ovo sam već negdje pročitao i bome iznimno ambiciozna očekivanja. Jer su od 2017 sa prvim epycom, do kraja prošle godine sa manje od 1% došli do nekih 5%, pa sad u kvartal-dva to planiraju poduplati. Nisam siguran koliko je realno, no ako je istinito mora da sklapaju ugovore kao mutavi
EDIT
Bome sam blesav, ako su u cca 2 i pol godine (10 kvartala) povećali marketshare minimalno 400% (prvi Epyc sa 1% na 5%), onda dva? kvartala (ako misle još i na idući Q2) sa 100% porastom (sa 5% na 10%) nije toliko ekstreman porast, malo brže nego prvi epyc (25% brži rast)
Zadnje izmijenjeno od: Manuel Calavera. 07.03.2020. u 18:21.
Staro 07.03.2020., 18:19   #7242
Postovi: 8,191
Da, izgleda da je istina, jer sam Intel više ne zavarava nikoga, pa ni samog sebe oko toga u kojem smjeru je AMD krenul. Mislim da ni AMD nije očekival baš ovakav (pozitivan) obrat u odnosu na samo koju godinu prije Zen arhitekture.
Staro 07.03.2020., 18:24   #7243
Manuel Calavera
Postovi: 14,581
Malo sam bacio matematiku (editirao gore post) i nije to tako nerazumno. Nije prvi epyc uopće loš posao odradio. Čak se ni ne zna koliko ispod 1% su bili, u nekim izvorima su zaokruživali na 1%, a negdje pisali manje od 1%. Znači minimalno je napravio porast od 400% u nepunih 10 kvartala
Staro 07.03.2020., 18:33   #7244
Psycho
Master Of Disaster
Psycho's Avatar
Datum registracije: Nov 2002
Postovi: 1,265
Da su vendori i brandovi bili spremni za potraznju presli bi oni taj postotak vec, ali slaba pripremljenost i sada koronavirus je utjecao na usporen rast ovaj kvartal. problem je mozda jedino sta financijski analiticari ne vide utjecaj AMDa na kompletno trziste te vec valuiraju rast AMDa u tu cijenu koja je trenutno. priblizno 50$ vrijednosti jer je kao u toj vrijednosti uracunat buduci rast AMDa na svim 'platformama' a meni se to uopce ne cini tako.
ipak njihovi postotci u prezentaciji(RDNA2) mi nista ne znaci jer je sve procjenjeno Power(Performance. op. MC) Per Watt, treba vidjeti kad pocnu izlaziti prvi primjerci i real world/sinteticki testovi pa cemo znati puno vise. slijedecih 2 -3 mjeseca lagano strpljen-spasen
Zadnje izmijenjeno od: Psycho. 07.03.2020. u 18:56.
Staro 07.03.2020., 18:40   #7245
Manuel Calavera
Postovi: 14,581
Autor Psycho Pregled postova
ipak njihovi postotci u prezentaciji(RDNA2) mi nista ne znaci jer je sve procjenjeno Power Per Watt, treba vidjeti kad pocnu izlaziti prvi primjerci i real world/sinteticki testovi pa cemo znati puno vise. slijedecih 2 -3 mjeseca lagano strpljen-spasen
Istina. Performance per watt mogu računati samo na određenom stupnju potrošnje (recimo na 100w potrošnje, 200w i sl.), a svi znamo da svaki node/arhitektura imaju svoju krivulju efikasnosti, znači nakon određene točke krene drastično opadati... Primjer tome je ako se sjećate najave polarisa, pa je škot napravio fenomenalan video (mislim da je ovaj) u kojem je dokazao da AMD zapravo nije lagao, no te brojke se dobiju samo sa Polaris 11 (što je u rx 460) na nekih štajaznam 50w potrošnje , a kasnije ne bude tako efikasnot... Dakle cherry pickanje, marketing...
Tako da ne znači da će potencijalni RDNA2 idealno skalirati, odnosno da cca 230w potrošnje biti 50% brži od današnje 5700XT, odnosno da će flagship na 300w biti koliko već brži od 2080Ti jel...
Staro 07.03.2020., 18:57   #7246
Postovi: 8,191
Prema ovome kaj su pokazali neki dan - RDNA 2, tj. kasnije CDNA + CDNA 2 budu temelji za sve veći i veći zamah na serverski, odnosno HPC/ML/AI tržišni segment. Kak god se okrene AMD se (više) ne zajebava i ciljaju na sve i svakoga.
Every $1.00 in Rome chip sales removes somewhere between $1.40 to $3.40 in Intel Xeon SP sales.
GPU sales for servers in 2023 could be equal to CPU sales for servers if accelerated computing takes off for HPC and AI workloads and both are more widely deployed in the cloud and in enterprises.
Staro 07.03.2020., 19:01   #7247
Psycho
Master Of Disaster
Psycho's Avatar
Postovi: 1,265
Zanima me takodjer kako ce se pokazati deal samsunga i amda za mobilni gejming, ali najvise me zanima ovaj aspekt
https://wccftech.com/intel-ai-breakt...idia-v100-gpu/
Iako je bazirano na Intel platformi, zanima me da li ima tu prostora za AMD ili jednostavno zbog instrukcija i softwarea nije pogodan. Iako je to niša DC industrije, ipak ima masu datacentera(supercomputera) upravo s tim setupovima (server + 4 do 8 V100 GPUa) gdje bi AMD mogao profitirati ako je pogodna platforma.
Tocno na ovo sam ciljao kad sam postao prvi link
Staro 07.03.2020., 22:12   #7248
scarzz
scarzz's Avatar
Lokacija: Stuttgart/Rijeka
Postovi: 414
Hoce li za Zen4 trebati novi socket jer imam namjeru da prijedjem sa 4790k na r5 3600 pa me zanima
scarzz je offline   Reply With Quote
Staro 07.03.2020., 22:42   #7249
Max Rockatansky
Lokacija: Zg/Zd
Postovi: 711
Autor scarzz Pregled postova
Misliš na Zen 3 ili baš 4 ?
Krajem godine se očekuje serija 4xxx na Zen 3 arhitekturi koja po dosadašnjim planovima ostaje na AM4 socketu.
(Aktualni 3xxx modeli, osim APUa, su Zen 2).
Staro 07.03.2020., 22:45   #7250
scarzz
scarzz's Avatar
Postovi: 414
Serija 5xxx tj Zen4, znam da ce 4xxx biti na AM4. U DE ovih dana ima MSI akcija ako uzmes npr R5 3600 i MSI X470 Gaming Plus MAX izadje te oko 200E samo na kraju.
Staro 07.03.2020., 22:46   #7251
stef
stef's Avatar
Lokacija: Zabok
Postovi: 3,362
Vjerojatno hoće ... to bi trebao biti DDR5 i moguće PCIe 5.0
Ali bi zato Zen 3 mogao biti kompatibilan. (Sad smo na Zen-u 2).
stef je online   Reply With Quote
Staro 07.03.2020., 23:33   #7252
Max Rockatansky
Lokacija: Zg/Zd
Postovi: 711
Uz tu cijenu se ne isplati brinut o tome ... ako sada uzmeš 3600, još ćeš imati prostora za osjetan upgrade, neki 8-core 4xxxx ili aktualne 12 ili 16-core 3xxxx.
Staro 08.03.2020., 00:03   #7253
Zen4 ilitiga Ryzen 5000 neće ići na sadašnje ploče i čipsete na koje ide trenutni Zen2 i na koje će ići Zen3.
Zen3 je zadnje od procesora što će ići na postojeće AM4 ploče sa DDR4 podrškom.
Mooooooožda neš iskemijaju pa daju podršku za X570 i X670 ploče, ali X470 sigurno ne.
Tako da za tu lovu je to OK, iako je ta ploča tak, dno ponude X470 čipseta ali ako je 200 eura ona skupa sa R5 3600, za te pare bomba. Kupuj samo procesor je skoro 200 eura.
Staro 08.03.2020., 00:08   #7254
scarzz
scarzz's Avatar
Postovi: 414
Mislim da cu ipak uzeti taj kombo posto je cijena dobra samo kakav je r5 3600 u gamingu u odnosu na 8700k i slicno?
Staro 08.03.2020., 00:15   #7255
Jel imaš ili planiraš imati 1080Ti/2080Ti te ganjati brze multiplayer pucačine tipa PUBG na 1080P rezoluciji na Gsync 144/165/240Hz monitoru?
Staro 08.03.2020., 00:19   #7256
scarzz
scarzz's Avatar
Postovi: 414
Pa i ne bas, samo ocekujem osjetno veci skok u performansama, pogotovo u igrama.
Staro 08.03.2020., 00:24   #7257
Ako baš i ne, onda ti je R5 3600 sa pločom za 200 eura logičan izbor.
Što se tiče osjetno većeg skoka u performansama, samo za gaming ne očekuj čuda. Dobiti sigurno nešto hoćeš na minimalnim FPSovila i glatkoći igre. Ali isto ovisi i o samoj igri.
Prelazio sam sa i7 2600K na R5 1600, pa znam što ti pričam. Imao GTX 1070 GPU tada. Ovisi o igri, rezoluciji i slično. Negdje možda 50%, negdje možda 5%.
Govorimo o gamingu.
U svemu ostalome (productivity, nadogradivost, dugovječnost...) R5 3600 rastavlja 4790K na proste faktore.
Staro 08.03.2020., 01:34   #7258
listerstorm
listerstorm's Avatar
Datum registracije: Apr 2011
Postovi: 1,428
Pogledao sam brzinski samo sažetke iz godišnjeg izvješća i financijske tabele i izgleda da 2019. godina sa stajališta prihoda i profitabilnosti nije donijela gotovo nikakva poboljšanja u odnosu na prethodnu godinu.
Npr. kada su izbacili zen (2017.) ostvarili su 22% rast prihoda u odnosu na prijašnju godinu i došli na granicu profitabilnosti.
Nakon toga zen+, ponovno solidan rast prihoda (23%) i veliko poboljšanje profitabilnosti u odnosu na prethodnu godinu.
I sada, u 2019. izlazi 7nm zen 2, amd stigao intel u gamingu i prestigao u cijeni i gotovo svemu ostalom, a prihodi i profitabilnost gotovo isti kao u 2018. (zen+), zapravo je dobit po dionici pala.
Budem malo detaljnije pogledao annual review jer ovo baš i nije logično (pogotovo kad se linkaju mindfactory.de statistike ) , čak i da nije ostvaren napredak u serverima za koji ipak treba vremena.
Staro 08.03.2020., 01:57   #7259
Postovi: 8,191
Mislim da su u tom izvješću bili spomenuli da su se preračunali za Ryzen 3000 Zen 2 potražnju, pa su i nofci bili zgrnuti u manjoj mjeri, jer u prvom mahu jednostavno nisu imali dosta za prodati. EPYC je odličan, ali i dalje su to kapljice u moru u usporedbi s Intelovim brojkama. Mada sve u svemu, AMD je (opet) profitabilan, zarađuje neki dinar i istovremeno otplaćuje dugove nagomilane prijašnjim pizdarijama. Za firmu donedavno pred bankrotom i nije tak loše. Zapravo najlošije im je prošla semi-custom divizija, ali i to polako dolazi na svoje s novim Xbox i PS5 konzolama.
Staro 08.03.2020., 03:36   #7260
listerstorm
Postovi: 1,428
Iskreno, (ja kao okorjeli intel fan mindless grupie (ovako bi me vjerojatno, najblaže rečeno, drug brko nazvao...), ako bih gledao AMD isključivo financijski i troškovno, znači u 12 mjeseci su uspjeli smanjiti dugoročni dug po kreditima za 50%.
Znači otvara se prostor za veliko povećanje R&D budgeta.
Nema te stagnacije prihoda i dobiti koji bi narušili ovaj krasan pokazatelj, pogotovo što se investitora tiče.
Zadnje izmijenjeno od: listerstorm. 08.03.2020. u 04:00.
