Staro 26.01.2020., 15:26   #391
Postovi: 23,509
Hm, nisam siguran, probaj
Staro 26.01.2020., 19:55   #392
vik123
Postovi: 30
Malo sam istraživao po netu i izgleda da to ipak nije moguće.
Drugi port na powerline adapteru bliže routeru služi samo za priključiti još jedan uređaj.
vik123 je offline   Reply With Quote
Staro 27.01.2020., 00:06   #393
buljaka
Datum registracije: Aug 2014
Postovi: 2,928
Autor vik123 Pregled postova
Nisi baš dobro istražio . Imaš dva ulaza i dva izlaza. Samo se moram ispraviti , šogor kaže da je morao koristiti onaj razdjelnik koji i ja koristim koji spušta brzinu na 100mbps,8 žica na 2x 4 žice.
Lan coupler i kaže da mu radi internet i Max Tv normalno
Sent from my SM-G950F using Tapatalk
buljaka je online   Reply With Quote
Staro 27.01.2020., 09:21   #394
Postovi: 23,509
Ali mu to "ruši" konekciju na 100 Mb,
neka sa ovim bržim parom (70xx) riješi Lan / Internet.
Staro 27.01.2020., 09:32   #395
vik123
Postovi: 30
Po ovome što sam ja shvatio ustvari ima 1 ulaz i 3 izlaz.
Barem prema slijedećem iskustvu:
"The biggest problem I had was using the 2 ports on the device. I was trying to use 2 Lan ports from my router to the 2 ports on the TP link device. You can't do that. The lights on the router will start flashing and after a while your router will lose connectivity. You can only use 1 router lan port on this product. The other 3 ports can then be used for whatever ethernet device you want to use. The instructions aren't very clear about this. I did some research on line and others were having the same problem. I then realised that I didn't have a defective unit and figured out that you are actually sharing 1 lan port with 3 other ports."
No, ako šogoru radi probat ću onda ipak uzeti TP-Link PA7020P.
Samo mi nije jasno zašto onda treba LAN coupler?
Možeš li skicirati shemu kako je to sve spojeno?
Staro 27.01.2020., 09:45   #396
Postovi: 23,509
Ovo "dijeljenje" Lan kabela na dva ima skicirano u više tema, da sad ne tražim.
Mislim da tebi to nije rješenje.
Rekoh poviše, sa novim parom riješi Lan / Internet,
a ako treba rješavati IpTv (MaxTv) uzmi samo jedan isti od starog para i samo ga pridruži tom starom paru da čine istu mrežu (ne sa novima).
Staro 27.01.2020., 10:08   #397
vik123
Postovi: 30
Jasno mi je kako funkcionira LAN coupler, ali ako bi njega ubacio u priču onda mi ne treba powerline s više portova.
Da ne kompliciram, uzet ću novi kit i na njega provući internet, a stari kit ostaje za IpTV (Iskon).
Staro 29.01.2020., 13:39   #398
vik123
Postovi: 30
Složio sam internet vezu kroz drugi powerline kit i sad mi povremeno pucaju veze iz routera.
Dva puta mi je pukla veza direktno iz routera u STB koji mi je javljao grešku da provjerim jesu li kablovi dobro uštekani i napravim restart routera i STB-a.
Par sati kasnije mi je pukla veza iz routera u kompjuter, a danas je pukao wifi.
Svako pucanje je uspješno riješeno restartom routera, ali trebalo bi mi malo dugoročnije rješenje.
Riječ je o Iskonovom ZyXEL VMG5313-B30A routeru.
Koji bi mogao biti razlog ovom blesiranju routera?
Ima li tu pomoći ili da odustanem od korištenja drugog powerline kita?
U tom slučaju bi složio AP na drugom kraju donjeg stana u nadi da će gornji stan biti pokriven dovoljno jakim wifi signalom.
Staro 29.01.2020., 16:48   #399
Postovi: 23,509
Nije valjda da se sad kolju novi i stari par
Možda stavit onu managment app pa sa njom provjeriti / postaviti da su nezavisni.
Staro 03.02.2020., 09:21   #400
vik123
Postovi: 30
Izgleda da se sve samo od sebe smirilo. Router već par dana ne divlja i sve radi kako treba.
Hvala na savjetima i pomoći.
Staro 06.04.2020., 17:13   #401
Dr. Gogo
aka GOGZ
Dr. Gogo's Avatar
Lokacija: Makarska
Postovi: 174
Poz iman pitanje, ovako konta sam prebacit komp u sobu trenutno je u dnevnoj tu mi je odma i router, sad zanima me posto igram vecinom cod i csgo, ako bi spojio sa nekim powerline adapterom bili mi ping bio visok u igrama? internet mi je trenutno 500 brzina od A1. Trenutno mi je ping cca 15-40 tako se krece... nadan se da san dobro objasnio
Dr. Gogo je offline   Reply With Quote
Staro 06.04.2020., 17:55   #402
Postovi: 23,509
Eh, igrači i ping ...
PowerLine minimalno i ništa "dodaje" na ping - u,
skoro isto kao klasična žica (mreža),
WiFi je po tom pitanju puno gori.
Važno je da je ista faza i da su uredne el. instalacije,
poželjno je module uštekati direktno u zidnu utičnicu a ne preko produžnog,
ako treba uzme se model koji ima "prolaz" (utikač - utičnica).
Staro 06.04.2020., 18:36   #403
Deno
Deno's Avatar
Datum registracije: May 2009
Postovi: 79
Autor Dr. Gogo Pregled postova
Ja trenutno testiram HT mesh na optici za igranje i za sada odlicno radi bez ikakvih gubljenja paketa,ali to ti je najbolje sam probat jer ovisi o puno faktora..
Narucis si i ako ti se ne svida imas pravo vratiti unutar 15 dana
Deno je offline   Reply With Quote
Staro 06.04.2020., 18:50   #404
Dr. Gogo
aka GOGZ
Dr. Gogo's Avatar
Lokacija: Makarska
Postovi: 174
Autor Nikky Pregled postova
Da tako san i mislio direkt odma u uticnicu, znaci sta se tice pinga neb trebalo gubitaka bit, a koji bi model bio dobar? Download mi toliko nije bitan samo da mi je ping ured da nevarira puno.
Staro 06.04.2020., 19:49   #405
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,747
Ping ti nece varirati, bude prakticki isti kao da si pc direktno lan kabelom usteka u router. Kod mene bude ili isti ili za 1ms veci, znaci zanemarivo.
Download/upload ovise o el. instalacijama, duljini samih kablova itd. Meni DL nece nikako preko 200Mbps a UL nije ogranicen tj. ide svih 120Mbps.
Naravno moras zadovoljiti navedene uvjete sto je kolega gore naveo...
Staro 06.04.2020., 20:46   #406
D/G
D/G's Avatar
Datum registracije: Feb 2010
Lokacija: Ploče
Postovi: 1,183
Autor deno1000 Pregled postova
Da bi se isplatilo raditi sa tim moraš imati bar tri ili više wifi dual-band rutera sa softwerom za "mesh" .
Ako imaš jedan ili dva isto će raditi kao obični wifi ruteri.
Staro 06.04.2020., 21:06   #407
Deno
Deno's Avatar
Postovi: 79
pricam o fritz HT-meshu, ali svakako je powerline jaci za gaming.
Ako ima manji stan i ovo je vise nego dobro
https://en.avm.de/products/fritzwlan...repeater-2400/
Zadnje izmijenjeno od: Nikky. 06.04.2020. u 23:28.
Staro 06.04.2020., 23:38   #408
Dr. Gogo
aka GOGZ
Dr. Gogo's Avatar
Lokacija: Makarska
Postovi: 174
oke hvala na odg, stan je cca 60 kvadrata zanimalo me to u vezi pinga jer neda mi se sad vuc utp kabel a sve mi je realativno novo. Lako vratim ako me bude zezalo
Staro 06.04.2020., 23:47   #409
Postovi: 23,509
... a koji bi model bio dobar?
Imaš od TP-Link sa GB mrežom serije 70xx ili noviji serije 80xx,
jeli ima "prolaz" ovisi o modelu / izvedbi,
da se ne zezneš, trebaš "kit" tj. 2 kom,
e sad je štos iskopati gdje ti je najpovoljnije ...
primjer > https://www.nabava.net/powerline/tp-...ijena-86615351
Staro 12.04.2020., 15:36   #410
majesty55
Datum registracije: Aug 2009
Postovi: 6
Pozdrav,
Nisam baš iskusan s ovom problematikom pa da pitam tu. Internet provider isporučuje brzinu od 50 mbps. Kako mi provlačenje utp kabela nije opcija zanimaju me powerline adapteri. Kako imam iptv planirao sam uzeti dva seta powerline adaptera jer koliko sam shvatio s jednim setom ne može funkcionirati iptv i internet. dvoumim se između tp link av600 i tp link av1200. Zanima me za moju brzinu je li mi dovoljan av600? Ne vjerujem da će u nekoj skorijoj budućnosti brzina ići iznad 100 mbps
majesty55 je offline   Reply With Quote
Staro 12.04.2020., 18:15   #411
Postovi: 23,509
AV600 je "dovoljno" ako gledaš samo bandwith prema Internetu i ako je taj tvoj komp "jedini u kući".
Ako imaš više klijenata u kućnoj mreži onda je interesantno / poželjno koristiti noviji (brži) AV1000 / AV1200, kao šta je razlika između 100 Mb i 1 GB mreže.
Šta se tiče rješavanja i IpTv i Lan / Internet preko 2 PowerLine para, to može mada zna katkad zezati.
Treba paziti da svaki par bude samo za sebe tj. da su samo 2 iz svog para "u svojoj mreži" (čitaj povezani).
Ako se nešto poremeti onda na komp stavi njihov managment app sa kojim se mogu podešavati i uparivati.
Za kraj evo jedan PowerLine real DL chart > https://www.smallnetbuilder.com/tool...powerline/view
AV500 daje cca 4x Mbps, treba gledati jeli Lan port 100 Mb ili 1 GB, ...
Staro 12.04.2020., 21:00   #412
majesty55
Postovi: 6
Hvala puno! Komentar je od velike pomoći
Staro 12.04.2020., 21:26   #413
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
Pretrazio sam al nisam nasao. Ima li tko first hand iskustva s AVM stvarima, FRITZ!Powerline?
https://en.avm.de/products/fritzpowerline/
Trabim neko rjesenje za cijelu kucu, a zelio bih sto vise stvari jednog vendora, da ne brkam sve i svasta.
Staro 16.05.2020., 04:33   #414
erda
Lokacija: Sla
Postovi: 180
Kako ovo ispitati, tj. da su "ista faza"?
Ne kužim se u elektriku
erda je offline   Reply With Quote
Staro 16.05.2020., 09:47   #415
Alister
Alister's Avatar
Postovi: 1,487
Imaš trofaznu ili jednofaznu struju u kući?
Alister je online   Reply With Quote
Staro 24.05.2020., 10:27   #416
danex
danex's Avatar
Postovi: 378
Napokon sam uspio posudit powerline da vidim dal bi to funkcioniralo kod mene. I radi. Riječ je o modelu TL-PA6010,model je iz 2014 ak se ne varam. Sad trebam prijedlog novog ili rabljenog kita. Brzina mi nije presudna, jucer smo testirali i bilo je 25mb, ja zadovoljan, možda bi išlo još malo više jel je na jednoj strani bio na produžnom.
Zanima me jel trebam na što pazit kod kupovine ili samo biram fičere poput utićnice, wifi, brzine i više portova?
Jel ovi s utičnicom daju istu brzinu?
Jedno glupo pitanje. Kad powerline ima wifi na sebi jel onda taj uređaj ima full wifi signal ili on samo proširuje wifi od rutera?
Zadnje izmijenjeno od: Nikky. 24.05.2020. u 12:00.
Staro 24.05.2020., 12:44   #417
Postovi: 23,509
A zavisi jeli kupuješ polovno ili novo,
taj TL-PA6010 je nazivno AV600 standard,
70xx serija su AV1000 a 80xx serija AV1200.
U prevodu, sa noijim standardom možda bi dobio i brži transfer, mada si naveo da ti brzina nije toliko bitna.
Verzije sa utikač - utičnica bi bila bolja, direkt u zid i ne gubiš utičnicu.
Kad powerline ima wifi na sebi on radi kao "posebni" AP i nema veze sa WiFi od routera,
a kakav će biti ovisi o dosta faktora. Često je powerline modul (u utičnici) negdje "zbuksan" pa WiFi signal koji daje "nije nešto" ...
Po meni je bolje odvojeni uređaj (AP / Router) kojeg možeš bolje pozicionirati, znaju imati jači signal ...
Ako ti je ostao koji AP / Router (barem većina) se lako prenamjeni u switch + AP funkciju.
Evo primjer 7010, utikač - utičnica, bez WiFi > https://www.uzishop.hr/powerline-ada...pakiranje.html
8010, utikač - utičnica, bez WiFi > https://neutrinomobile.hr/tp-link-pa...ne-av1300.html
Kad pogledaš cijene, pogotovo modele koji imaju WiFi, ispadne da se skoro ne isplate u odnosu na modele koji nemaju WiFi + odvojeni uređaj za WiFi
Staro 24.05.2020., 13:49   #418
danex
danex's Avatar
Postovi: 378
https://www.njuskalo.hr/mrezna-oprem...oglas-31521850 našo sam ovo jeftino rabljeno
Ovaj iz uzija bi bio ok?
Oče što smetat ako bi u toj njegovoj utičnici bio produžni kabel za računalo?Jel što slabije radi ako je spojen na duplu utičnicu?nisam imao vremena isprobat sve opcije jučer.Ako bi htio spojit i tv,jel onda ide powerline-kabel-switch-1.kabel računalo,2.kabel tv?U wifi opciji samo stavim ruter umjesto switcha?
Staro 25.05.2020., 15:23   #419
johnsmith
Lokacija: vž
Postovi: 1,330
Danex: Načelno da (odnosi se na ovaj dio za switch/ruter). Probaj taj powerline prvo isprobati. Te brzine su ko wifi, spojen si 300mbit a max brzina je 50mbit Uglavnom, powerlineu smetaju pwm signali koje proizvode led lampe i elektronika koja koristi pwm. I stanje strujnih instalacija igra ulogu, te duljina "linka" kroz te strujne instalacije. Svakako ako imas led/pwm probaj s upaljenim tim trosilima da vidis kako utjece na brzinu.
Ja sam uzeo neki dlink set (passthrough verzija), pwm je skinuo pola brzine tako da je bilo na rubu upotrebljivosti. Moja topla preporuka svakako probati jer ima previse faktora da bi se moglo reci da ce raditi i da ces imati 100mbit kako god spojis. Mozda ce ti pucati, mozda ces imati 10mbit. Bukvalno.
Staro 26.05.2020., 17:49   #420
danex
danex's Avatar
Postovi: 378
Kupljen https://www.links.hr/hr/powerline-ad...anje-053515076 preko weba pa imam mogučnost povrata ak ne bum bil zadovoljan.Obični produžni bez sklopke ne rade nikakve probleme, kratko testirao. S ciljanom utičnicom nisam imao sreče, daje duplo slabiju brzinu(nije mi se dalo neki dan testirat) al druga opcija dela. Samo da se ne blesira i win umješa prste i bit će to ok
