Staro 15.01.2020., 19:37   #2221
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,584
BusMaster šteta što im nisi poslao i ram na testiranje sa tvojim hardverom. Po meni ili ti je ram neispravan ili ne voli s tom pločom (mislim da si rekao da ga nemaš na support listi, a s tim se mbo vendor ograđuje)
Staro 15.01.2020., 21:18   #2222
Amd_Shill
Datum registracije: Dec 2016
Lokacija: Sat
Postovi: 1,119
Autor Disco Pregled postova
Buraz ima x370 prime pro sa r5 1600 i neki g. skill (hynix) 3200 cl16 i nema šanse na 3200, 2933; naravno XMP/DOCP ni u ludilu. Probani razni BIOSi i sve moguće postavke...IMC je očito ograničenje, plus ni RAM nije neki trkaći.
Ubaci sve u ryzen dram calculator i izvuces maksimum.
Vrijedi probati.
Ja sam kilave aegise 2400 koji su radili na 2133 natjerao na 2666 pomocu njega.
Amd_Shill je offline   Reply With Quote
Staro 16.01.2020., 05:51   #2223
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,260
Probao sam calculator sa svojim kompom i niti jedan od tih planova nije prošao, niš, 0.
Slobodno me dodajte na PSN
Disco je online   Reply With Quote
Staro 16.01.2020., 07:11   #2224
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,260
Ekipa sa C6H, ajde probajte ovo:
The EDC limit set to 1 really works for boosting all cores and single core to their MAX! Thanks to the guy that figured this out.
Here is what I did to get it to work
Set your ram timmings to whatever you prefer.
And the fclk to half that of your ram speed.
In extreme Tweaker/core performance boost
set it to – Auto
In extreme Tweaker/precision boost overdrive
precision boost overdrive = auto
max cpu boost clock override = auto
platform throttle limit = auto
Set all 3 options to AUTO
In extreme Tweaker/digi+ power control
cpu load-line calibration set to = LEVEL 3
cpu current capability to 140%
In advanced/amd cbs/nbio common options/xfr enhancement/accepted
and precision boost overdrive = auto
now in
advanced/amd overclocking/amd overclocking/precision boost override
precision boost override set this to -advanced
PBO limits to manual
PPT limit =0
TDC limit =0
EDC limit =1
precision boost overdrive scalar - manual =10x
max cpu boost clock override =200mhz
and the thermal throttle to =200
save and restart.
DO THIS TO AVOID WINDOWS BSOD AND ERRORS.
In advanced/amd cbs/cpu common options
Set everything in there to AUTO
In advanced/amd cbs/nbio common options/smu common options
Set everything to AUTO
MY CPU IS 3900X.
BIOS VERSION 0075 got BSOD, I Tried BIOS 7704 it wouldnt boost then I tried bios 7501 and no BSOD yet seems stable and it boosts same as 0075.
I think this should work on any Bios.
This screenshot is from when cinebench R20 is running in the background all cores boosting to 4149MHz to 4199MHz and single core boosting to 4600MHz.
If you restart and it goes stright back to the BIOS Menu and your mouse or keyborad does not work just press the red button on the motherboard under the Graphics card next to the big start button to load the default again and load your bios again save and exit.
To je frajer sherao na OC.net. Ja sam probao na 7704 i nema nikakvih problema sa BSOD i sličnim.
Kod mene je užas, MC mi skočio sa 3950 na 4050-4075, dok je SC doslovno umro, ni da mrdne preko 2200.
Ne kužim kako sam MC dobio, a SC tako gadno pao, pao ispod defaulta.
OK, ponovio sve ovo i po savjetu ugasio c-state. Sada sve boosta kako treba. SC mrvicu vise 4225.
EDIT: Ups dupli post, sory.
Staro 16.01.2020., 16:00   #2225
Flood
Into my head it goes
Flood's Avatar
Datum registracije: Feb 2004
Lokacija: space de luxe
Postovi: 778
E sad je to druga priča sa ugašenim global c-state. SC 4242
Staro 16.01.2020., 17:02   #2226
Joza_Seraf
Joza_Seraf's Avatar
Datum registracije: Jun 2015
Lokacija: Klc
Postovi: 568
3600 smontiran celsius je gore. Normalno neki idiotizam mora biti. CPU fan eror... znači skoro sam si pucao u glavu kaj je. Brzo na google, google rijesio hahaha. Sad bi bacio neki benchmark, ako može prijedlog da vidimo kolko boosta.
edit: stock voltaža u wind na core 0 mi je 1.42? wtf
Samo čekam dan kada će mi netko pokucati na vrata i zatražiti me bubreg jer sam negdje odscrollao dolje i stavio kvačicu na "Slažem sa svime"!!
Zadnje izmijenjeno od: Joza_Seraf. 16.01.2020. u 17:18.
Joza_Seraf je offline   Reply With Quote
Staro 16.01.2020., 17:22   #2227
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,260
Autor Joza_Seraf Pregled postova
Hmmm....
Staro 16.01.2020., 17:30   #2228
Joza_Seraf
Joza_Seraf's Avatar
Lokacija: Klc
Postovi: 568
Hmmm....
hahahahahahahahahahahahahahahahahahahahah epic
Staro 16.01.2020., 18:09   #2229
BusMaster
BusMaster's Avatar
Datum registracije: Apr 2017
Postovi: 343
Hmmm....
Sorry, je off topic ali moram da "reagujem" ...
Nives Celzius heart atack overclock, boosta na 5+ Ghz. I tata bi sine...)
P.S. Nastavak Asrock STLegendX570 i G-Skill memorije "Saga":
Postavke: Vsoc na 1,15V, Vcore=1,4V, Vmem=1,4V, LLC2.
Rezultat: 1. U slotu A2, B2, ništa preko 2133! Windowsi ne vide više od 8GB!, ali boota win i stabilni su.
2. U slotu A1,A2, stavi mem po defaultu 2133, Bios smrzne u postavkama kad bilo što probam ručno, nema boota..
3. U slotu A1. B1, Bios stavi mem po defaultu 2133, Windowsi nemogu bootat, javlja hardware error.
4. U slotu B1, B2, digne Bios sa 1833Mhz, Windowsi normalno bootaju, prepoznaje 16GB, sve radi ok. nakon toga upišem ručno postavke i timinge za 2133Mhz, opet se par puta restarta i zaglavi pri bootanju.
Naravno svaki puta prije promjene slota, gašenje, baterija van, Cmos reset itd.
Na kraju sam odustao više, neka radi ovako dok ne nabavim novi Ram, eto samo toliko da se neko ne zezne slično sa ovom kobinacijom koju imam, očito me dopao epski primjerak proca ili je baš toliko osjetljiv na ram.
Ram je sigurno B-die Samsung, oba modula, Taiphoon burner ga uredno vidi i iščita postavke.
Staro 16.01.2020., 18:16   #2230
Manuel Calavera
Postovi: 14,584
Kakvo ne prepoznavanje rama na ploči? Pa onda ploča ne valja...
Staro 16.01.2020., 20:24   #2231
Joza_Seraf
Joza_Seraf's Avatar
Lokacija: Klc
Postovi: 568
Jel još kome ide proc do 1.45V u loadu? sve jezgre su na 4.187
Staro 16.01.2020., 21:57   #2232
Amd_Shill
Lokacija: Sat
Postovi: 1,119
Testirao sam blenderom na tri kompa pa evo rezultata
Test blender (BMW):
1. Ryzen 5 2400g (@3.8ghz manual) to odradi za 7:48
2. FX8320E (Stock 3.2ghz) to odradi za 14:14
3. FX8370 (4,7ghz manual) to odradi za 9:43
Staro 17.01.2020., 05:38   #2233
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,260
Baš to, jedno je da RAM ne radi na X mhz i XYZ tajminzima, ali nešto skroz drugo je da ploča vidi samo 1 keks i pobenavi kad su oba keksa ubodena.
@BusMaster:
Trebao bi od nekog posuditi druga dva modula, bilo koja i vidjet što se dešava.
Ako se ponaša isto, onda još probat zamoliti neku dobru dušu da ti posudi neki ryzen pa da probaš i to. E ako ni to ne pomaže, onda je do ploče.
Sad sam tek skužio, digao si napon procu na 1.4V? Ne treba ti to, pusti na auto. Treba ti napon RAM-a i ako ploča ima opciju napona RAMa pri bootanju (c6h to ima). To oboje na 1.4V, ne treba ti više od toga za 3200mhz.
Isto bi ti preporučio da ako uspiješ od nekog posudit druga dva keksa RAM-a, daj njemu svoje kekse neka ih testira.
Zadnje izmijenjeno od: Disco. 17.01.2020. u 05:48.
Staro 17.01.2020., 06:58   #2234
Autor Amd_Shill Pregled postova
Test blender (BMW):
Ako želiš znati kako to odradi R5 3600 koji te zanima, daj link na to što si testirao pa da provučem kroz svoj sistem
Staro 17.01.2020., 08:12   #2235
Flood
Flood's Avatar
Postovi: 778
Brko,ti imaš 3600X...
Staro 17.01.2020., 10:16   #2236
Amd_Shill
Lokacija: Sat
Postovi: 1,119
Na mobu sam...
Ne treba ti link. Ides na stranicu blendera,skines blender i taj file di je slika BMWa.
Ne možeš falit.
Vjerujem da ce 3600 to odvrtit za 5-6 min.
EDIT: kakav je ovaj RAM za R7 2700x?
https://www.hgshop.hr/memorija-g-ski...roizvod/226381
Zadnje izmijenjeno od: Amd_Shill. 17.01.2020. u 11:57.
Staro 17.01.2020., 13:26   #2237
JC Denton
dr. sc. tech. dipl. ing.
JC Denton's Avatar
Lokacija: Rijeka-Opatija
Postovi: 3,164
Test blender (BMW):
Blender verzija 2.81a ?
Staro 17.01.2020., 13:27   #2238
Amd_Shill
Lokacija: Sat
Postovi: 1,119
Autor JC Denton Pregled postova
Da,zadnja.
Staro 17.01.2020., 16:55   #2239
Na mobu sam...
Ne možeš falit.
Eto ga Blender. 3:54, ispod 4 minute
A eto i ponovljeni pokušaj Cinebenča - 3647. Sad smo u 2% Venomgamer fixni i ja varijabilni
Staro 17.01.2020., 16:57   #2240
Amd_Shill
Lokacija: Sat
Postovi: 1,119
3:54
Taj 3600 je zbilja odlican
Staro 17.01.2020., 17:00   #2241
Prije nego kaj opet neko veli "to ne vredi jer je tvoj 3600X", samo da napomenem da je prilikom testa zakucano svih 12 threadova i takt all core je varirao od 4025-4050. 4050 nije prelazio, tako da, najnormalnije ponašanje 3600-tice pri max loadu
Boostovi su ionako samo sa light threaded appove
Amd_shill, ti vidi sad što ti je bolje, 2c/4t više ili 15% više safta po IPC-u
Bilo bi dobro da silver_tipac proba isto sa svojim 1800X koji je isto na automatici. Rezultat njegovog 1800X je bliži 2700X nego 3600, jer su maltene ista uArch i imaju isto threadova. 2700X eventualno malo više boosta no opet kad se zakucaju sve jezgre, nije baš da ide visoko.
Staro 17.01.2020., 17:06   #2242
Amd_Shill
Lokacija: Sat
Postovi: 1,119
Razlika u cijeni je nekih 150kn izmedju R5 3600 i R7 2700x
Staro 17.01.2020., 17:49   #2243
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,260
Pa nek mu izmjeri neko tko ima baš 2700/2700x jer ipak zen+ ima mrvu bolji IPC.
@Brko: baš gledam kako ti je cb skor jako blizu mom kad napravim sve ono što sam napisao koji post ranije (3638 kod mene).
EDIT: Po ovome, 2700x je ipak brži od 3600: https://www.legitreviews.com/12-desk...er-279b_214161
Dok sam našao i neki bzvz YT video iz 2018-e, gdje mu treba 4:34min.
Staro 17.01.2020., 17:53   #2244
Koliko si imao prije tog tjuniranja BIOSa?
Staro 17.01.2020., 17:55   #2245
Manuel Calavera
Postovi: 14,584
Ima u recenzijama 2700X - bmw
270 sekundi
https://www.google.com/amp/s/www.pcw...eview.amp.html
Staro 17.01.2020., 17:56   #2246
Ima u recenzijama
[IMG]file:///storage/6692-1800/Android/data/com.android.chrome/files/Download/2g_ryzen_7_2700x_blender-100755327-large.png[/IMG]
Yebogati, daj link sa weba a ne sa svog mobitela
Staro 17.01.2020., 17:59   #2247
JC Denton
JC Denton's Avatar
Postovi: 3,164
3:54
U usporedbi sa mojim R5 1600 (stock) koji to napravi za 5min:34.2sec. Javim kakav je kad ga OC-am
Staro 17.01.2020., 18:00   #2248
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,260
270 sekundi
Moj gornji link pokazuje koliko se blender ubrzao u verziji 280, 2700x pada na 204 sekunde. 3600 je na 229sekundi.
Ugl za posao i za ono što može iskoristit sve threadove bolji mrvu 2700x, što posao duže traje, veća je prednost.
A ako se hoće i malo gejmat, 3600 all the way.
@brko: moram odvrtit ne sjećam se, ali mislim da je bilo 3580, ovo mi je diglo 100injak mhz MC.
Staro 17.01.2020., 18:14   #2249
Manuel Calavera
Postovi: 14,584
Yup da, razlika je između verzija. To je onda to, 2700X je ipak i nešto jeftiniji, pa kom je multithread krucijalan on je bolji izbor.
A najbolji će biti kad 3700X bude išao za te pare nagodinu
Staro 17.01.2020., 19:09   #2250
Flood
Flood's Avatar
Postovi: 778
Automatika
Blender
Cinebench prije i poslije Disco-vog naputka.
