Staro 02.11.2019., 08:18   #241
T}{OR
DBS
T}{OR's Avatar
Datum registracije: Nov 2010
Postovi: 1,855
Ovo za G-SYNC i ultra low latency je odlična stvar. Isto tako i Sharpen filter.
Sent from my OP6
Staro 02.11.2019., 10:16   #242
RaneZ
Vršni visioc
RaneZ's Avatar
Postovi: 2,209
Autor T}{OR Pregled postova
Baš probao, COD je ostriji sto je da je.. iako sam smanjio sa 0.5 na 0.4
low latency zakon.
Bez potpisa.
Staro 02.11.2019., 22:41   #243
MadManBD
MadManBD's Avatar
Postovi: 922
Isprobao malo taj sharpen, dobra stvar, prvo stavio na 0.75 al tako je prejako mi se cini, sutra cu probat s 0.5 ili 0.4.
Prva slika bez, druga sa 0.75.
Name:	The Outer Worlds Screenshot 2019.11.02 - 22.19.30.98e.jpg‎
ID:	21627   Click image for larger version
Name:	The Outer Worlds Screenshot 2019.11.02 - 22.21.58.02e.jpg‎
Staro 03.11.2019., 01:31   #244
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,552
Maknuli su Maximum prerendered frames i ubacili low latency mode
Objašnjenje : https://www.howtogeek.com/437761/how...idia-graphics/
Staro 03.11.2019., 07:12   #245
T}{OR
DBS
T}{OR's Avatar
Postovi: 1,855
Autor xulos Pregled postova
To nije novost za ovaj driver. To je dodano još nakon ljeta. Low latency mode i G-Sync support kada radi je novost. Plus Sharpen.
She u svemu, dosta dobar driver.
Sent from my OP6
Staro 03.11.2019., 09:05   #246
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,552
Meni je. Ja sam tek jučer skontao da mi fali Maximum prerendered frames
Staro 03.11.2019., 13:33   #247
Dottore
Dottore's Avatar
Postovi: 7,644
Valja li zadnji driver?
Отправлено через Pixel
HP 845 G8
CPU: AMD Ryzen 7 PRO 5850U
Graphic: AMD Radeon 680M
OS: Windows 11 Pro 24H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
LCD: 14" IPS @ 1920 x 1200
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
OS: Windows 11 Pro 23H2
Staro 03.11.2019., 17:40   #248
Postovi: 16,779
Ja sam ga stavio, PUBG radi bolje nego ikada s tim driverima.
Staro 03.11.2019., 18:10   #249
virty
Ronon Dex
virty's Avatar
Lokacija: DS9
Postovi: 1,623
Meni ok, sve uredno radi.
Poslano sa Sony XZ3
virty je offline   Reply With Quote
Staro 05.11.2019., 08:06   #250
reiben101
reiben101's Avatar
Datum registracije: Oct 2013
Lokacija: EU
Postovi: 62
Izašao GeForce Game Ready 441.12 WHQL driver s optimizacijama za Red Dead Redemption 2 i NFS Heat.
https://www.nvidia.com/en-us/geforce...-ready-driver/
reiben101 je offline   Reply With Quote
Staro 05.11.2019., 08:43   #251
thunder11
thunder11's Avatar
Datum registracije: Dec 2013
Postovi: 1,697
Autor reiben101 Pregled postova
Da se ukratko nadoddam na zadnji driver:
"Nvidia GeForce 441.12 WHQL driver as released by NVIDIA, enables G-SYNC Compatible support on LG’s 2019 B9, C9 and E9 4K OLED TVs"
Sto samo daje šlag na tortu tim TV-ima
Staro 05.11.2019., 09:30   #252
Postovi: 16,779
Dobio sam jučer driver update, nisam skinuo.
Probao, sve radi ok?
Staro 05.11.2019., 09:48   #253
reiben101
reiben101's Avatar
Lokacija: EU
Postovi: 62
Ja sam instalirao sinoć samo zbog RDR2, tako da zasad nisam imao nikakve probleme. Koliko vidim GTAV i dalje ne radi ako ti to išta znači.
Staro 06.01.2020., 18:12   #254
Lynnfield
Zmaj od Bosne
Lynnfield's Avatar
Datum registracije: Dec 2011
Postovi: 218
CES Game Ready Driver ( GeForce Game Ready 441.87 )
Novosti:
Maximum Frame Rate
Variable Rate Super Sampling
Image Sharpening Improvements
Freestyle ‘Splitscreen’ Filter
Windows 10 64bit Standard
RIP Šaban (21.6.2016)
Staro 06.01.2020., 18:33   #255
Mladenxy
Mladenxy's Avatar
Postovi: 4,336
Konačno su se sjetili to staviti u drivere, ograničio na max 75 fpsa.
edit, spustio na 74 fpsa jer sam na 75 hz monitoru imao trganje slike, sad je savršeno a GPU/CPU ne rade uludo.
Zadnje izmijenjeno od: Mladenxy. 06.01.2020. u 18:41.
Staro 06.01.2020., 18:39   #256
sti
Lokacija: Lawl
Postovi: 1,375
Baš me zanima da li ovaj frame limiter unosi dodatni input lag. Trenutno je najbolje koristiti in-game limiter (ako postoji), jer ne unosi dodatni input lag, zatim RTSS (ubacuje 1 frame input laga na 144 Hz, cca 7 ms). Treba pričekati da blurbusters testiraju.
Staro 07.01.2020., 09:18   #257
Full Throttle
Full Throttle's Avatar
Datum registracije: Dec 2009
Lokacija: Zagorje
Postovi: 872
Jako zanimljiva stvar.
Za 2080Ti su maknuli studio drivere za skinuti.
Slučajno ili ne, al meni se počeo komp žestoko blesirati i sve mi se čini da je do njih.
Full Throttle je offline   Reply With Quote
Staro 12.01.2020., 03:03   #258
Blue Spirit
Blue Spirit's Avatar
Datum registracije: Apr 2004
Lokacija: ZG - Dubrava
Postovi: 2,183
Max Frame Rate ( Nvidia FRAME limiter ): Nova opcija unutar novih 441.87 drajvera https://www.nvidia.com/Download/driv...x/156281/en-us
Autor sti Pregled postova
tako je ...
Najmanji Input Delay ima FPS limiter unutar same igre ako postoji, ako ne onda se moramo poslužiti RTSS-om ili novim Nvidia FPS Limiterom.
+ napomena koju nisi spomenuo
Da bi se input lag sveo na minimum, grafička kartica ne smije biti opterečena 99%, tj smije biti maksimalno do 97% . ... prikazano na slici 3
Optimalne postavke za minimalni imput lag ne mogu se genelarizirati već ovise od igre do igre.
Donosi ... tj povećava input lag (pogledaj sliku 2).
Battle(non)sense je testirao i pokazao da je Nvidijin Limiter dovoljno dobar kao i onaj unutar RTSS (RivaTuner Statistics Server - koji dolazi uz MSI afterbuner).
Njegove primjedbe - sugestije Nvidiji za novi Limiter
1) Limiter je ograničen na područje između 40 do 240 FPS-a | sugestija Nvidiji: maknuti ograničenje.
2) Nema ikone tj nekog overlay-a unutar igre koje bi prikazivalo da je Limiter uključen - aktivan | sugestija Nvidiji: Staviti ikonu - HUD / overlay.
3) Ne može se mjenati FPS limit unutar GeForce Experience overlay-a , ako se želi promjeniti tj staviti nova vrijednost Max FPS-a mora se restartat igra.
Battle(non)sense https://www.youtube.com/watch?v=W66pTe8YM2s
slika 2:
in-game Limiter
RTSS = RivaTuner Statistics Server - Framrate limit
NVCPL = Nvidia Control Panel - Max Frame Rate
slika 3:
U Overwatch -u FPS limiter smanjuje imput lag.
On "ne voli" Anti-Lag ( AMD) i Low Latency (Nvidija) koji mu povećavaju imput lag.
Jedino pri GPU loadu od 99% Anti-Lag ( AMD) i Low Latency (Nvidija) donosi smanjenje imput laga u Overwatch -u.
izvor: https://www.youtube.com/watch?v=7CKnJ5ujL_Q
slika 4
PUBG -u također FPS limiter smanjuje tj poboljšava imput lag
... u BF 5 Future Frame Rendering poboljšava imput lag.
U CS GO frame limiter ima suprotan efekt i povećava input lag
izvor: https://www.youtube.com/watch?v=VtSfjBfp1LA
Fortnite je kao i CS GO, nabolje im je ne limitirati FPS za bolji imput lag
... u BF5 i Gears 5 FPS limit + Low Latency (Nvidija) poboljšavaju tj smanjuju input lag
FC 5 ...
Metro Exodus
Division 2
EDIT: napišem post i onda vidim da ste vec pričali o tome ...
doslovno sam prvo napisao post i samo naknadno quotao sti -a, jer je spomenuo najbitnije.
EDIT2: dodana napomena i slike testiranja imput laga.
/connect 185.107.96.125:28990
server rcon: oldschool
Zadnje izmijenjeno od: Blue Spirit. 12.01.2020. u 08:00.
Blue Spirit je online   Reply With Quote
Staro 12.01.2020., 11:09   #259
sti
Lokacija: Lawl
Postovi: 1,375
Točno je da sam zaboravio dodati da grafička ne smije biti zakucana na 99% (GPU bound scenarij), najbolje je držati nekoliko % ispod.
Dakle, NV limiter je jednak RTSS-u po input lagu. In-game limiter je jedini koji ne unosi dodatni input lag. ALI, ono što je meni bitno za Battlefield 5 kojeg igram (a logika bi morala biti ista i za ostale igre) je to što RTSS ima stabilniji frametime, što se više primijeti tijekom igranja nego tih mizernih 1 FPS input laga (7 ms) u odnosu na in-game limiter. To je i Battlenonsense lik rekao u ovom videu kojeg si linkao
Moram još pročitati blurbusters forum, sigurno je i jorimt, autor legendarnog "GSync 101" članka napravio svoja testiranja vezana za novi Nvidia limiter.
Staro 12.01.2020., 11:24   #260
Mladenxy
Mladenxy's Avatar
Postovi: 4,336
Meni je jedino "bitno" da ne radi uludo i nabija fps koji ne vidim na monitoru...ovak gnereira minimum topline/potrošnje. Tu razliku u input lagu ja tak i ne kužim a u multiju i tak igram tolko da igram, i zaboli me za K/D omjer.
Sad kad to imam u driverima forsira za sve igre a detalje prepuštam gforce experienceu koji to po mom mišljenju optimizira i namješta jako dobro. (stavljeno da automaski radi za sve igre).
Staro 12.01.2020., 13:50   #261
Blue Spirit
Postovi: 2,183
Nemojte me quotat još uređujem tekst i dodajem slike i linkove, nadopunit cu post oko 19h !!!!
... ono što je meni bitno za Battlefield 5 kojeg igram (a logika bi morala biti ista i za ostale igre) je to što RTSS ima stabilniji frametime, što se više primijeti tijekom igranja nego tih mizernih 1 FPS input laga (7 ms) u odnosu na in-game limiter. To je i Battlenonsense lik rekao u ovom videu kojeg si linkao
Tako je ...
Your gaming experience isn’t just about the maximum peak frame rate that your PC can achieve.
In the use case where Anti-Lag and the Ultra-Low Latency mode are effective, you do not only face an unstable frame rate,
you also have to deal with inconsistent frame times,which means that the input lag that you are subjected to is constantly changing,
as the frame rate will go up and down depending on what is happening in the game that you are playing.
If you are interested in a smooth gaming experience, where you always have the same amount of input lag, which is important to build up muscle memory in competitive games,
then you must limit your frame rate to a value that your PC can always maintain.
izvor: Battle(non)sense @ 12 min 20 sec https://youtu.be/7CKnJ5ujL_Q
Čak i 60 Hz monitor ima koristi od većeg FPS-a bez obzira na niski refresh rate
Linus: At 60 Hertz monitor with a frame rate well above 200 and the result was much better because the input lag and overall latency is reduced.
Zašto je važan taj muscle memory i stabilan frejm rejt ???
Jer s njime možete kompenzirati niži FPS pri 60 FPS / Hz i pogoditi ono što biste inače mogli jedino sa 144 Hz monitorom.
Primjer upravo iz Linusovog testa sa PRO Gamerima @ 12 min https://youtu.be/OX31kZbAXsA?t=720
Linus: I'm gonna tell you something, you absolutely smoked Shroud and Quarry in that test at 60 Hertz.
Do you think you could train up at 60 Hz and hit as many targets as you did at a higher refresh ?
MrGrimmmz: Yeah definitely yeah !
MrGrimmmz:
When i was going through the test and I was kind of feeling like you know that slight delay it's almost like a pattern right, you you don't want to press it too fast otherwise you're just gonna come up short.
@ 12 min 13 sec https://youtu.be/OX31kZbAXsA?t=733
Ima filing za delay tj tocno zna (muscle memory) kad treba kliknuti mišem, ni pre rano ni pre kasno da bi kompenzirao niži frejm rejt - 60 Hz da bi pogodi protivnika korz sičušni prolaz - koridor na slici ispod.
MrGrimmmz je jedini koji je od njih 3 PRO Gamera (među njim je bio i Shroud koji nije) uspio kroz taj minimalni otvor - prolaz kroz vrata napraviti kil pri 60 Hz.
I would say like it it's more on towards that aspect high refresh rate doesn't make you a better gamer but it makes it easier to be a better gamer I would say.
Nemojte me quotati još uređujem tekst i dodajem slike i linkove, nadopunit cu post oko 19h !!!!
Zadnje izmijenjeno od: Blue Spirit. 12.01.2020. u 16:22.
Staro 12.01.2020., 14:53   #262
Dottore
Dottore's Avatar
Postovi: 7,644
Susjed @Blue Spirit, odličan post!
Lijepo složeno sve u detalje.
Staro 12.01.2020., 15:33   #263
Tajl3r
Dobro je sve.
Tajl3r's Avatar
Datum registracije: Sep 2012
Lokacija: 00001
Postovi: 2,453
@sti bfv konzola i GameTime.Maxvariablefps ///
Staro 12.01.2020., 16:48   #264
sti
Lokacija: Lawl
Postovi: 1,375
Znam, ali kao što je rečeno, RTSS ima stabilniji frametime (jer radi tako što limitira frametime) od in-game limitera u BF5, a dodaje samo 1 frame input laga na 144 Hz, što je 7 milisekundi.
Staro 12.01.2020., 22:34   #265
T}{OR
DBS
T}{OR's Avatar
Postovi: 1,855
edit: video već linkan gore... NVM
Kakvi su dojmovi iz prakse vas koji ste instalirali ove drivere?
Staro 13.01.2020., 19:29   #266
RaneZ
Vršni visioc
RaneZ's Avatar
Postovi: 2,209
Ko i svaki od 98-te. Install, rade
Danas cu cackat sa sharpenom i ostalim điđama.
Bez potpisa.
Staro 18.04.2020., 13:21   #267
Blue Spirit
Postovi: 2,183
NVIDIA RTX Voice: Noise cancellation
Nvidija AI program koji eliminira pozadinski zvuk tipkovnice koji se cuje pri voice chatu ili strimingu (Discord, TS3, OBS , XSplit Broadcaster, Skype, i td. ...)
https://www.nvidia.com/en-us/geforce...e-setup-guide/
https://www.guru3d.com/news-story/nv...bit-of-ai.html
AI Noise Suppression u novim Nevidija drajverima
RTX beta Sound removal:
NVIDIA RTX Voice is a new plugin that leverages NVIDIA RTX GPUs and their AI capabilities to remove distracting background noise from your broadcasts, voice chats, and remote video conferencing meetings.
This allows users to "go live" or join a meeting without having to worry about unwanted sounds like loud keyboard typing or other ambient noise in noisy environments.
RTX Voice also suppresses background noise from players in loud environments, making incoming audio easier to understand. RTX Voice is currently in Beta.
To use RTX Voice, you must be using an NVIDIA Driver 410.18 or newer, and be on Windows 10.
1. Download the App (originalni app - samo za RTX) , pre-modded NVIDIA RTX Voice modani app koji radi i GTX 10 GTX 16 seriji (GTX 1050 60 70 80 GTX 1650 1650 karticama).
2. Install it.
3. Configure RTX Voice:
a. Select the microphone and speaker you want to use.
b. Turn on the background noise removal for the mic and/or the speakers.
We recommend turning on RTX Voice for your microphone, and turn it on for your speakers only if needed. While quality remains almost the same, it is possible to see a small difference in some cases, and the solution takes system resources that you can avoid using if you don’t need it.
4. Configure your voice chat app according to the instructions below.
Discord
1. Go to Settings (cog wheel), and then select Voice and Video.
2. Select Microphone (NVIDIA RTX Voice) and Speaker (NVIDIA RTX Voice) as your devices.
3. For best quality, make sure that you disable any noise cancelling/removal effects in Discord.
OBS
1. Go to Settings > Audio.
2. Select RTX Voice as your devices:
a. In Devices > Mic/Auxiliary Audio, select Microphone (NVIDIA RTX Voice).
b. In Advanced > Monitoring Device, select Speakers (NVIDIA RTX Voice).
XSplit
1. Go to Audio Settings.
a. Under System Sound, select Speakers (NVIDIA RTX Voice).
b. Under Microphone, select Microphone (NVIDIA RTX Voice).
Twitch Studio
1. Go to Settings, and navigate to Audio.
2. Select Microphone (NVIDIA RTX Voice) as your Primary Microphone.
3. For best quality, make sure that you disable the Noise Suppressor and Gate.
Ostala uputstva za:
Chrome , Skype ,Zoom , Slack
pogledajte na https://www.nvidia.com/en-us/geforce...e-setup-guide/
Zadnje izmijenjeno od: Blue Spirit. 25.04.2020. u 10:35.
Staro 22.04.2020., 14:53   #268
Blue Spirit
Postovi: 2,183
nVIDIA RTX Voice works without RTX GPU
nVIDIA RTX Voice - radi i na GTX 1050 1060 1070 1070 Ti 1080 1080 Ti 1650 1660
Imate gotov - unaprijed modan RTX voice ili možete ga sami po donjim uputama prepravit:
pre-modded NVIDIA RTX Voice v0.5.12.6 DL Link 379.6 MB:
The new nVIDIA RTX Voice works just fine without an RTX GPU and on windows 7 too, tested and working on a GTX 1080 and a Titan V, here's how to make it install...
After executing the installer and getting the message that stops it installing the installer files are extracted to C:\temp\NVRTXVoice
Open the file C:\temp\NVRTXVoice\NvAFX\RTXVoice.nvi with a text editor and remove the "constraints" section that looks like this:
HTML:
<constraints>
<property name="Feature.RTXVoice" level="silent" text="${{InstallBlockedMessage}}"/>
</constraints>
with that section deleted save the file and execute the installer here: C:\temp\NVRTXVoice\setup.exe
This software is absolutely unreal! Enjoy.
Edit: You may need to open the file as administrator to modify it.
Another edit: Seems to be working on all 10 and 16 series cards but 900 series results are mixed.
https://forums.guru3d.com/threads/nv...es-how.431781/
Staro 24.04.2020., 21:43   #269
Blue Spirit
Postovi: 2,183
Ovo je pre dobro.
... pogledajte YT video, izmamit ce vam osmijeh na lice i prva misao bit ce vam kako smo do sada bili bez toga.
Must watch za sve koje koji prilikom igranja koriste voice chat ili strimaju.
Program uklanja - eliminira SVE zvukove osim glasa osobe koja govori u mikrofon.
- zvukove tipkovnice
- ventilatora koji zuji
- usisavača
- raznih šumova
- žene / djece (drugih osoba) u pozadini koja se deru/govore
- lupanje dlanovima po stolu
- sirene , mobiteli , alarmi, poruke
Zadnje izmijenjeno od: Blue Spirit. 25.04.2020. u 10:12.
Staro 25.04.2020., 02:28   #270
d0X
Kostolomac
d0X's Avatar
Postovi: 1,482
Oko 5% GPU-a mi troši. Isprobao sa frendom preko Discorda i stvarno radi. Fora
PSN Steam
