#2161 | ||
Datum registracije: Dec 2016
Lokacija: Sat
Postovi: 1,119
Bila je u kosarici,ali vas dva ste me nabrzinu uvjerili. Ova je sljedeca na shortlisti ASUS ROG STRIX X570 S njom,plus R7 2700 (1350kn),smarticev RAM ispadne trosak nekih 4600kn Ostatak para mogu usmjerit u subwoofer ![]() |
#2163 |
Postovi: 4,407
#2166 | |
Lokacija: Sat
Postovi: 1,119
![]() Hvala! |
#2169 |
Lokacija: Sat
Postovi: 1,119
#2170 |
Postovi: 14,584
Možda su mbo vendori opet dali prednost Z470 i Z490 pločama. I opet ispušili Shill Ne boj se iqcentra, to je dobar shop. Ako se ne varam maloprodaja od nekog našeg dobavljača. Reklamacije bi trebale biti špica |
#2171 | |
![]() Ako nisu lekcije naučili sa Z270, onda ih ne treba žaliti. |
#2173 |
Lokacija: Sat
Postovi: 1,119
Imam jos jednu ideju,ako vam vec nisam dosadio. ![]() Mogao bi FXa downclockat i prebacit na HTPC duznosti (manji ulog u grafu) Prodat R5 2400g (ili u buducnosti iskoristit za nesto) i iskoristit njegovu plocu i memoriju (Asus B450 Gaming) Ima li smisla? |
#2175 |
#2176 |
Prvoklasni Krkan
Postovi: 5,333
Ekipa sa C6H, ajde probajte ovo: The EDC limit set to 1 really works for boosting all cores and single core to their MAX! Thanks to the guy that figured this out. Here is what I did to get it to work Set your ram timmings to whatever you prefer. And the fclk to half that of your ram speed. In extreme Tweaker/core performance boost set it to – Auto In extreme Tweaker/precision boost overdrive precision boost overdrive = auto max cpu boost clock override = auto platform throttle limit = auto Set all 3 options to AUTO In extreme Tweaker/digi+ power control cpu load-line calibration set to = LEVEL 3 cpu current capability to 140% In advanced/amd cbs/nbio common options/xfr enhancement/accepted precision boost overdrive = auto and precision boost overdrive = auto now in advanced/amd overclocking/amd overclocking/precision boost override precision boost override set this to -advanced PBO limits to manual PPT limit =0 TDC limit =0 EDC limit =1 precision boost overdrive scalar - manual =10x max cpu boost clock override =200mhz and the thermal throttle to =200 save and restart. DO THIS TO AVOID WINDOWS BSOD AND ERRORS. In advanced/amd cbs/cpu common options Set everything in there to AUTO In advanced/amd cbs/nbio common options/smu common options Set everything to AUTO MY CPU IS 3900X. BIOS VERSION 0075 got BSOD, I Tried BIOS 7704 it wouldnt boost then I tried bios 7501 and no BSOD yet seems stable and it boosts same as 0075. I think this should work on any Bios. This screenshot is from when cinebench R20 is running in the background all cores boosting to 4149MHz to 4199MHz and single core boosting to 4600MHz. If you restart and it goes stright back to the BIOS Menu and your mouse or keyborad does not work just press the red button on the motherboard under the Graphics card next to the big start button to load the default again and load your bios again save and exit. To je frajer sherao na OC.net. Ja sam probao na 7704 i nema nikakvih problema sa BSOD i sličnim. Kod mene je užas, MC mi skočio sa 3950 na 4050-4075, dok je SC doslovno umro, ni da mrdne preko 2200. ![]() Ne kužim kako sam MC dobio, a SC tako gadno pao, pao ispod defaulta. Zadnje izmijenjeno od: Disco. 10.01.2020. u 13:16. |
#2178 |
Datum registracije: Sep 2010
Lokacija: Peljesac
Postovi: 293
ja svog fiksiro 4,1 ghz 1.35 v,ram na 3333 1.4 v i ne diram vise nista,ni biose ni nista,vise sam gledo u hw info nego u bilo sto drugo,stabilan 2 cijela dana i nadam se da se nece crashat. ![]() ipak sam ja old scool clocker,peko zanat na wolfdale,nemogu ja sad pustit sve automatici |
#2181 |
Lokacija: Peljesac
Postovi: 293
Ma neda mi se refresat podatke u moj komp, C6h matična,ryzen 5 3600 proc,ostalo isto kao sto pise pod moj komp, Ryzen 1200 radio na 4 ghz 1.3 v,ali ram nikako nije mogo preko 3000,jbg prva gen ryzena,slab mem kontroler,radio je na 1.35 v. Ovo sad,voltaza je 1.35 u biosu,sve opcije u digi postavkama su maxane,load line calibration i sve sto ima.a ima ih bezbroj pola ih ne kuzim Pod opterecenjem voltaza ide na 1.37,u idlu je na 1.33,grije se u primeu do 80 i vise,ali briga me nek se przi,cooler je dark rock 4,mucio sam se sa boostanjem i biosima i brkovim 3600x,ali sad mi je dopizdilo... |
#2184 |
Prvoklasni Krkan
Postovi: 5,333
OK, on je napisao da je ovo za 7501, i javilo se par njih sa 3900x i 3950x da im bostaju ko ludi (4,7 SC); ne mislim se vraćat na taj BIOS zbog par mhz. Ugl. išao danas reda radi malo gnjavit proc sa primeom OCCT-om i realbenchom da vidim temp. Ne zamaram se, nego cisto da provjerim. Dakle prime 95 1h, max 80 stupnjeva (max power and heat), OCCT small+AVX1 max 84(ako sam dobro skužio ovo je kombinacija koja najviše kuri), a realbench 75. Cca 5-10 stupnjeva niže temp nego kada sam zadnji put mjerio. Prime i OCCT dobro zakolju proc i MC je 3850, dok realbench drži na 3950, kao npr kad prekodiravam nešto sa Handbrakeom. To sam išao provjerit kada sam pročitao da ljudi imaju niže temp sa 7704. Ajde bravo, zadovoljan, šteta samo što im toliko treba da sve pokrpaju i ispoliraju. ![]() Zadnje izmijenjeno od: Disco. 12.01.2020. u 11:45. |
#2185 |
Datum registracije: Apr 2017
Postovi: 343
Evo napokon sam sklopio konfu sa R5-3400G proc. i Asrock Steel Legend X570 matičnom. U prilogu validacija: https://valid.x86.fr/pl6xen Ako neko ima iskustva sa navedenim procom na ovoj X570 ili drugoj matičnoj, molim za pomoć, jer sam više izgubio živce sa ovim. Od prvog bootanja, sa originalnim Biosom Ver. 1.70, nije mogla bootati XMP profil sa oba dva mem.modula G-Skill Trident-Z F4-3200C16D-16GTZSW (16Gb kit, Samsung B-die).U manualu piše da podržava max.2667Mhz, za dva single rank modula, što ovi jesu. Probao i to sa konzervativnim timing postavkama (kao na 3200), ali neide nikako, restarta nekoliko puta i onda vrati na 2133. Da bude još gore, nakon instalacije Win10Pro_x64 (1903), kad su oba modula na 2133Mhz, windowsi u system properties uredno jave 16GB rama, ali je dostupno samo 6Gb!, umjesto 14Gb (2Gb ide za int.grafiku). Probao sam sve živo( LLC postavke, Digao napon mem.na 1.40V), i nadogradio bios na zadnji V2.20 (AGESA Combo-AM4 1.0.0.4 Patch B), ali stvar je ista. Svi driveri su najnoviji, Radeon, AMD i ostalo... Također kad su oba modula u ploči, napon na procesoru divlja, Bios nakon gašenja PC-a, gubi postavke o vremenu i slična sr... Poslao sam natrag polču u ADM, zajedno sa procom, testirali je i kažu sve je ok.. Tražio support od Asrocka, još nema odgovora.Kad je unutra jedan modul od 8GB, učita XMP bez problema i veselo radi na 3200Mhz, stabilan je u OCCT-u, temp. ne prelazi 60C (Cooler je AC-34 Esports). Detaljni opis konf. je u validaciji.. Ako netko ima ideju kako ovo riješti, molim za prijedloge... ) Hvala.. |
#2188 |
Prvoklasni Krkan
Postovi: 5,333
Da, odvrti memtest (memtest+), i to sa bootabilnog USB sticka, a ne u win. Pusti neka ga cijelog odvrti. Probaj napravit i Clear CMOS prije ubacivanja oba modula A2 i B2. Ali ih i istestiraj 1 po jedan, a probaj i oba. Vrlo je bitno u kujem su utoru! |
#2189 |
Postovi: 343
Ma nije glupost uopće, Asrock izričito navodi za max. kompatibilnost moraju biti dva modula stavljena u slotove A2 i B2, znači 2 i 4 ako gledaš od proca na gore... Probao sam i sa A1 i B1, znači 1 i 3, pa opet isto... Po njima oni to uopće ne podržavaju, tj. nije preporučeno upoće..!! |
#2190 |
Postovi: 343
Jesu testirani su odvojeno i rade ispravno 100%, svaki od njih u XMP modu ide na 3200 Mhz i boota bez problema... naravno kad je samo jedan uštekan u ploču.. Memtest isto bootan iz UEFI-ja prolazi bez greške... |
