Staro 08.10.2019., 19:10   #361
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,581
Staro 17.10.2019., 12:04   #362
BusMaster
BusMaster's Avatar
Datum registracije: Apr 2017
Postovi: 343
Staro 18.10.2019., 18:29   #363
BusMaster
BusMaster's Avatar
Postovi: 343
AMD Ryzen Threadripper 3990X, 3970X, 3960X CPUs Announcement Planned For November 5th
https://wccftech.com/amd-ryzen-threa...x-launch-leak/
Staro 20.10.2019., 14:52   #364
Manuel Calavera
Postovi: 14,581
Staro 23.10.2019., 08:11   #365
Manuel Calavera
Postovi: 14,581
Staro 01.11.2019., 14:03   #366
BusMaster
BusMaster's Avatar
Postovi: 343
AORUS Teases Their Flagship TRX40 XTREME Motherboard For AMD 3rd Gen Ryzen Threadripper CPUs – 16 Power Phases
https://wccftech.com/aorus-trx40-xtr...er-cpu-teaser/
Staro 06.11.2019., 08:51   #367
Postovi: 8,191
56 core Xeon Platinum 9282 ranges from 8% to 84% better performance (31% higher geomean) than AMD’s 64 core Rome-based system (7742) on leading real-world HPC workloads across manufacturing, life sciences, financial services and earth sciences.
For gaming, 8-cores is the optimal spot for performance scaling in modern PC gaming, and at 8-cores we get the best frequency scaling out of our Coffee Lake products and 14nm process technology today. And clock speed is what feeds the hungry primary threads of game engines today! The first thing I see with this set is that going from 8-cores to 12-cores results in less than 10% scaling in all games, and in that 12-game set, 9 of them improve by 5% or less. What about that 12-core to 16-core jump? Only one game in our results today sees an improvement (Ashes of the Singularity once again) while the other 11 games not only do not scale up in performance, THREE of them actually regress slightly, offering lower performance than a 12-core configuration.
Today something happened that many may not have seen. Intel published a set of benchmarks showing its advantage of a dual Intel Xeon Platinum 9282 system versus the AMD EPYC 7742. Vendors present benchmarks to show that their products are good from time-to-time. There is one difference in this case: we checked Intel’s work and found that they presented a number to intentionally mislead would-be buyers as to the company’s relative performance versus AMD. By Intel using the post-2nd generation Intel Xeon Scalable version of GROMACS but the pre-AMD EPYC 7002 series which had been out for over a month, Intel’s numbers are highly skewed for the Platinum 9282 which only has a 20% lead. One can only conclude that Intel’s “Performance at Intel” blog is not a reputable attempt to present factual information. It is simply a way for Intel to publish misinformation to the market in the hope that people do not do the diligence to see what is backing the claims. Once one does the diligence, things fall apart quickly.
Linux kernel dev Greg Kroah-Hartman reckons Intel Simultaneous Multithreading (SMT) - also known as hyper-threading - should be disabled for security due to MDS (Microarchitectural Data Sampling) bugs. OpenBSD was right, he said. "A year ago they said disable hyper-threading, there's going to be lots of problems here. They chose security over performance at an earlier stage than anyone else. Disable hyper-threading. That's the only way you can solve some of these issues. We are slowing down your workloads. Sorry."
Ryan Shrout i društvo se iz petnih žila trude najbolje što mogu, pa nije čudno da je ovaj materijal ugledal svjetlo dana taman prije sutrašnjeg predstavljanja novih Threadripper 3000 modela.
Staro 06.11.2019., 14:45   #368
BusMaster
BusMaster's Avatar
Postovi: 343
AMD Ryzen Threadripper 3970X 32 Core & 64 Thread CPU Listed Online For Around $1200 US
https://wccftech.com/amd-ryzen-threa...listed-online/
Staro 06.11.2019., 19:57   #369
Momir
Momir's Avatar
Postovi: 1,011
AMD Threadripper gets a new box
Meni malo gadna kutija, ako ce biti takva, ali koda je bitna kutija
Momir je offline   Reply With Quote
Staro 06.11.2019., 20:24   #370
Postovi: 8,191
Sve je bitno, sad kad Ryan Shrout napravi kritički osvrt na potencijalno pakiranje i usporedi to s Intelovim - AMD nakon toga nema kaj tražiti u tom tržišnom segmentu.
Staro 08.11.2019., 09:39   #371
Psycho
Master Of Disaster
Psycho's Avatar
Datum registracije: Nov 2002
Postovi: 1,265
https://www.youtube.com/watch?v=BxqPAPkGe70
TR3960X 1400$
TR3970X 2000$
koliko ce maticna kostati nitko nije spomenuo, mozda 500?
Staro 08.11.2019., 09:51   #372
Postovi: 8,191
Da i cijene novih ploča budu popularne, tak je bilo i s X399 modelima, a ove bi trebale biti i malo skuplje.
Staro 08.11.2019., 12:53   #373
Amd_Shill
Datum registracije: Dec 2016
Lokacija: Sat
Postovi: 1,119
A koja smijesna cifra za te CPU.
Intel bi to naplatio tri puta vise od crvene bande.
Amd_Shill je offline   Reply With Quote
Staro 08.11.2019., 13:17   #374
BusMaster
BusMaster's Avatar
Postovi: 343
Autor Psycho Pregled postova
TR3960X 1400$
TR3970X 2000$
_______________________________________________________________
https://www.tomshardware.com/news/gi...0-motherboards
https://www.tomshardware.com/news/as...-3000-unveiled
https://www.guru3d.com/news-story/as...i-extreme.html
https://www.guru3d.com/news-story/ms...herboards.html
U najavi kažu oko 500-600$ za entry-level TRX40 ploče, Flagshipovi kao ovi gore u linkovima i do 1000$. Sve mobo dolaze sa hrpom PCIex 4.0 lanea, znači ništa jeftino, a i VRM-ovi su redom svi zvjerski... i oprema ploča isto.
Staro 08.11.2019., 13:21   #375
Lewis
Freelancer
Lewis's Avatar
Lokacija: Bilje (Osijek)
Postovi: 5,265
Hmm i dalje nevidim ponatu toliko PCI-E laneova i onda samo 4 (ili 5 u najboljem slucaju) PCI-E slotova na flagship maticnoj od 1000$.
Lewis je online   Reply With Quote
Staro 08.11.2019., 18:24   #376
Psycho
Master Of Disaster
Psycho's Avatar
Postovi: 1,265
Autor BusMaster Pregled postova
800$ - 1000$ za upper i high end ploce. ode bankaaa
Staro 09.11.2019., 18:00   #377
BusMaster
BusMaster's Avatar
Postovi: 343
https://www.tomshardware.com/news/am...ability-retail
Evo i cjena za GB Aorus TRX40 seriju ploča, uglavnom očekivano s obzirom na segment kojem pripadaju... s tim sa će u EU ovo bit vjerojatno u EUR-ima...
Staro 11.11.2019., 17:11   #378
Psycho
Master Of Disaster
Psycho's Avatar
Postovi: 1,265
za mjesec dana u USA..mozda cijelu platformu u kuferu donijeti
Staro 12.11.2019., 16:20   #379
BusMaster
BusMaster's Avatar
Postovi: 343
Enthusiasts Rejoice, AMD’s New Threadripper sTRX4 Socket Is Here To Stay – ‘Long Term’ Longevity Confirmed
https://wccftech.com/enthusiasts-rej...ity-confirmed/
Staro 12.11.2019., 17:11   #380
Manuel Calavera
Postovi: 14,581
Ako je to istina razbili su kompatibilnost...
Ne može nikako biti "long term" jer je ovo predzadnja generacija na ddr4
Staro 16.11.2019., 10:20   #381
Immortalis
Slobodan leni seronja
Immortalis's Avatar
Postovi: 852
Staro 16.11.2019., 13:57   #382
sakomako
Datum registracije: May 2013
Lokacija: nigdje
Postovi: 599
Meni tu nešto ne štima, jer je rečeno da je dobar dio komponenti koje su prije bile na samoj ploči sada ubačen na sam CPU, dakle ploče bi trebale zapravo biti jeftinije radi toga, a ne skuplje?
Barem tako kaže zdrava logika, jer ako s ploče skineš dobar dio komponenti i prebaciš na CPU, onda imaš manje komponenti na samoj ploči pa bi trebala biti zapravo jeftinija.
Ili vrijedi i dalje stara logika deri dok možeš? A koliko je to deri dok možeš najbolje se vidi koliko je Intel bio prisiljen spustiti cijene svojih CPU.
sakomako je offline   Reply With Quote
Staro 16.11.2019., 15:34   #383
Postovi: 8,191
Ove nove ploče podržavaju PCI-E 4.0, a to dodatno poskupljuje ionak skupe ploče, mada je cijeli kontroler integriran u sam CPU, tu je i novi PCI-E 4.0 čispet.
Dodaj k tome novi/bolji VRM sklop, novi(ji) socket, kojekakve I/O kombinacije na temelju PCI-E 4.0 podrške i cijena ide prema gore bez puno muke.
I tak jasno da i proizvođači žele dodatno zaraditi, pa je konačna cijena kombinacija (od) svega (navedenog) pomalo.
Staro 16.11.2019., 18:43   #384
MadBoY
MadModerator
MadBoY's Avatar
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
Autor sakomako Pregled postova
I dalje ploce imaju chipset na sebi, bez obzira sto je dobar dio toga integriran u sam CPU. Chipset je tu za dodatne PCI-E linije, SATA i USB konektore i slicno. Onda jos dodas bolji audio codec, WiFi 6, 10 GbE, bolji VRM s boljim hladjenjem i nabere se troskova.
Staro 16.11.2019., 19:37   #385
Manuel Calavera
Postovi: 14,581
Ali i marža je veća
Staro 25.11.2019., 14:22   #386
BusMaster
BusMaster's Avatar
Postovi: 343
AMD Ryzen Threadripper 3990X 64 Core & 128 Thread Monster CPU Becoming A Reality in 2020
https://wccftech.com/amd-ryzen-threa...nch-confirmed/
BTW, nije li danas trebao biti NDA lift za TR3000 seriju, ne vidim još nigdje recenzije??
Staro 25.11.2019., 15:08   #387
Manuel Calavera
Postovi: 14,581
Pa jel ne čitaš iste te linkove koje postaš
Stay tuned for our AMD Ryzen Threadripper 3970X review which goes live in a few hours. We will be posting our review of the 3970X with ASRock's latest TRX40 Taichi motherboard!
Staro 25.11.2019., 17:15   #388
Postovi: 8,191
The AMD Ryzen Threadripper 3960X and 3970X Review: 24 and 32 Cores on 7nm
I have never used the word ‘bloodbath’ in a review before. It seems messy, violent, and a little bit gruesome. But when we look at the results from the new AMD Threadripper processors, it seems more than appropriate.
Izvor: Ti Mater
Staro 25.11.2019., 17:19   #389
sti
Lokacija: Lawl
Postovi: 1,374
Guru3d:
When you wake up in the morning, pass by that new Threadripper 3970X / TRX40 PC, and softly whisper the words, 'your majesty', then you know that AMD has done something really extraordinary.
https://www.guru3d.com/articles-page...-review,1.html
Staro 25.11.2019., 17:21   #390
Postovi: 8,191
64-core čudovište sad komotno mogu naplatiti kolko god ih volja i odgađati čisto reda-radi.
