#12453 |
Datum registracije: Sep 2011
Postovi: 1,162
#12454 |
Postovi: 311
Bilo bi fora gledati kako piju Nuka-Colu Quantum i onda svijetle u mraku. ![]() |
#12455 |
Datum registracije: Feb 2016
Lokacija: ______
Postovi: 1,457
Watchmen - odustajem nakon 4. epizode. U odnosu na film radnja je pojednostavljeno glupasta, likovi antipatični, svijet u seriji djeluje kao neki žešći trash. Donekle zanimljivo izgleda radnja sa Ozymandiasom ali čini mi se da će i to na kraju ispasti drek. Prva epizoda Mandaloriana je vani, gledao netko, dojmovi? |
#12457 |
Mirko, a ne Harry
Postovi: 5,476
Je li ovo oke redosljed za gledanje Babylon 5:
Hala Madrid! |
#12460 | |
Lokacija: Rijeka / Grobnik
Postovi: 4,303
ovo je kak ja imam zapisano od davnine view order i tak sam nedavno ponovno gledao: "Start off with the pilot ("The Gathering") but dont be put off by it, its not the best but everything has to start somewhere! Then watch all of season 1 and season 2, some people will say "watch In the beginning before season 1" and although the events in that film (the earth/mibari war) are before season 1, it is told from 2278 and has a lot of other stuff in it you just will not appreciate until later, not to mention some of the info on sinclair practically ruins season 1 viewing for you. After season 2, move straight into season 3 and then from season 3 go into season 4... midway through season 4 between the episodes of "Into the Fire" and "Moments of Transition" is the time to watch "Thirdspace" which is set between these 2 episodes and has no spoilers or anything as it is pretty self contained. Then continue with season 4. After season 4 is the time to watch "In The Beginning" in my view as it will show stuff from season 3, before season 1 and also some season 4 things, it will also hint at the near future in season 5 and you will really enjoy this film, i believe personally it is the best of the films. Then watch season 5 upto "Objects at rest" which is the one from last episode, do not watch "sleeping in light" just yet. After objects at rest watch River Of Souls which is set 6 months after Objects at rest (in 2263) not bad film. Then watch Legend of the rangers (if you want to watch it) but i wouldnt bother as its awful and not consistent with rest of B5. This is where it fits in timeline wise as it is set 3 years after objects at rest. After LoTR its time for A Call To Arms, 2nd to in the beginning a good theatrical film introducing the new charaters of the spin off "Crusade". this is set 5 years after season 5. This was kind of pilot for crusade as well as a final movie for b5. If you have the 13 eps of crusade on DVD watch these directly after ACTA, they are good and crusade would have become a great show like B5 if the network would have allowed it to run. After a call to arms and crusade, you are ready to watch Sleeping in Light and cry with the rest of us that there is no more B5 left to watch! sit back and marvel and think yourself enlighted for seeing such a wonderful show as it was meant to be seen. While that will conclude your viewing there are graphic novels which have good plots which fill in some gaps, also there are 3 trilogies; the psi corps trilogy which is fantastic, the centauri prime trilogy which is also top notch and lastly the technomage trilogy which is very dark and exciting. those 3 trilogies are must reads, as are books #7 and #9 which are considered cannon by JMS. " btw ko voli SF i nije ovo pogledao... GREAT MAKER ![]() |
#12463 | |
Postovi: 1,142
Zakon, drago mi je da je atmosfera pogođena. Ja sam jučer pogledao prvih 10 minuta, no bilo je prekasno i bio sam preumoran da nastavim dalje, a opet nisam htio ići spavati dok ne pogledam barem malo uvoda ![]()
Free your mind and open your eyes |
#12467 |
Postovi: 2,065
Thinkpad T430 running |
#12469 |
Postovi: 2,881
#12471 |
Pink Floyd fan
Lokacija: Santa Clara, CA
Postovi: 5,540
Dobro, paprica mu ljutih, sto bi sa 3 (slovima, trecom) epizodom The War of the Worlds ? Istina, nisam jos pogledao ni 2. epizodu al' svejedno ![]()
#12475 |
Torrent freek
Postovi: 3,948
Pogleda ja S1-3, a ne znan šta bi reka, tema je svakako zanimljiva i intrigantna, ali režija i gluma su mi loše iskreno... Sve u svemu dojam nakon 3 sezone je mlak, nije negledljivo, ali nije ni puno više iskreno. Rijetko komentiran ocijene, ali 8,1 koliko ima na IMDB mi je too much.
#12476 |
Suit up!
Postovi: 5,970
Nisam pratija ništa van SW filmova (i igara), ali mi se ovaj Mandorian baš svidija. Puno bolje od novih filmova i na tragu starog SW-a ![]()
