#3962 |
Postovi: 14,584
Jbga ako ćeš davati preko 1000kn možeš imati i još bolji vrm (6 phase) - ova pod moj komp (u telebitu 1080kn), a do nedavno je bilo i high end x370 crosshair 6 za takve novce po akcijama, no trenutno ih nema (samo po 2400kn). Prednost carbonke je 2 m.2 utora i wifi Dakle od tog što si nabrojao ta najjeftinija je naj deal, no sa tomahawk dobiješ opciju usb updtea biosa... tako da je možda ona najbolje middle of the road rješenje |
#3965 |
Datum registracije: Oct 2018
Lokacija: Kvarner
Postovi: 26
Mislim da cu ici na b450 gaming k4. Neki dan sam gledao kutiju u linksu i pise na kutiji da podrzava r 3xxx. Bila mi je i b450 pro4 u uzem izboru ali moram se uvjeriti da je na kutiji oznaka za 3xxx seriju pa mozda i nju uzmem jer koliko vidim nema velike razlike izmedju to dvije osim cijene.... |
#3966 |
Lokacija: Rijeka / Grobnik
Postovi: 4,241
namjeravam iskoristiti tool i uputstvo odavde za flashat stari bios na primku. al naletio na ovo: https://rog.asus.com/forum/showthrea...oll-back/page5 "So, this method does work, but people should note some of the downfalls with this and any afu type method. If you just flash the UEFI file, you will lose your UUID, primary MAC address, and SN that are stored in the flash. Intel ROMs also seem to store some other info as well specific to the board. This will make your Windows potentially deactivate/reactivate due to the loss of UUID. It may have an effect on warranty (depends if they care about the SN being wiped). If you want to prevent that, you need to make sure you keep those values from a HW info tool or a previously backed-up ROM. You can edit a ROM/CAP file with fd44editor to put those values back into a file before you flash it to make sure you keep them. Even with this tool, there is a second copy of those values in the original flash file that doesn't get restored by the tool -- I have no idea if those are important or not." sta sad to znaci jel mogu ocekivat te probleme? jel neko to ekšli probao? ![]() |
#3967 |
Postovi: 2,138
Zašto bi. Uopce vracao stari bios ako ti sadašnji radi dobro i bez bugova? Edit.koliko sam brzinski preletio forumom, da možeš imati probleme ako ne napraviš flashback kako spada, gubljenje sn, mac id i sl. stvari je automatski gubitak garancije, a i solidna mogucnost da ti odredjeni sklopovi na mbo poput mrežne ili zvucne kartice nece raditi.
#3968 |
Postovi: 4,241
hebe me mema i nikak preko 2800 snjom. sto vise citam to me vise strah tog vracanja starom BIOS-a. mislim da se nebum kockao. solucija 2 kupnja novog RAM-a. solucija 3 kupnja R5-3600 ![]() neznam koliko bi eksli dobio da mogu poletit na 3000 ili vise. jucer sam izvrtio brzinski test u FC i iznenadio se kolika je razlika bila u FPS izmedu 2800 i puno manje postavke. e sad dal to ide na manje kad pricamo o 3000mhz+ nemam pojma. |
#3969 |
Postovi: 2,138
realno - neces dobiti ništa osjetljivo na 3000MHz rama, uvrh glave 1-2% ako igras na 1080p sa nižim detaljima. ako je tebi isplativo za tak mali gain koji neces ni osjetit - uzimati novi ram ili proc to je tvoja odluka, ja osobno ne bih. Ako bas moras imati tih 1-2% radije probaj onda zategnuti timminge na ramu. edit. jesi li probava ryzen dram calculator, isto tako da li je tvoja mema na QVL listi od mbo?
#3971 |
Postovi: 2,138
pa nije ni cudo da nece na 3000MHz sa cl14 jer koliko vidim ta mema je deklarirana na cl16@3000MHz ovo sto ti radi na cl14@2800MHz je super za tvoju memu, neces nista dobiti sa novom memom
#3972 |
trpi, trpi...
Datum registracije: Oct 2019
Lokacija: CRO
Postovi: 110
#3973 |
Postovi: 4,241
nisam je na 14 stavljal za 3000. pratio sam calc od ismusa. i jos sam probao i vece latencije. stagod probas jednostavno nece. najcesce ni ne posta nego moram clear cmos. |
#3974 |
Lokacija: Zgb
Postovi: 123
Jel ima neke bitne razlike između B450-A PRO MAX B450 GAMING PLUS MAX B450 TOMAHAWK MAX Koliko vidim po specifikacijama razlika je u usb-c portu (ne znam po čemu je bolji od običnog usb-a 3.2 Gen2), malo rgb-a na ploči i jednom rgb headeru više. VRM je isti, a heatsink ne izgleda puno veći na tomahawku. To je to ili nešto propuštam? |
#3977 |
aka Mali Mirko
Postovi: 3,108
Postoji upravo zadnja verzija 3.60, i ako je to tako onda bi mogao biti u laganim problemima jer sam Asrock ne preporuča taj bios ako je CPU Pinnacle, Raven, Summit or Bristol Ridge, a ja imam upravo 2600X (Pinnacle Ridge). Vidiću kad sve upalim |
#3979 | |
Nećeš imat nikakvih problema sa Pinnacle Ridge procesorom ![]() |
#3980 |
aka Mali Mirko
Postovi: 3,108
Čak ni ako sam Asrock kaže: *ASRock do NOT recommend updating this BIOS if Pinnacle, Raven, Summit or Bristol Ridge CPU is being used on your system. Ionako nemam drugih opcija nego probati. |
#3981 |
Datum registracije: Dec 2009
Lokacija: Zagorje
Postovi: 872
Dajte mi preporučite AM4 matičnu za novi workstation. Na nju ide 3900X i 2x 2080Ti. Kod slaganja sam stavil x570 Aorus Pro. Sviđa mi se da ima treći PCIex. Dal mi je bolje uzeti kakvu X470 ploču? Ima li razlike osim pciex 4.0? Kakva je sad situacija s podrškom za 2nd gen ryzen? I jel bi moglo biti problema s ovakva dva keksa u dual channelu: https://www.protis.hr/products/detai...rfd4293/143926 Ili mi je sigurnije ići na 4x16 varijatnu? Zadnje izmijenjeno od: Full Throttle. 18.11.2019. u 20:42. |
#3982 |
Lokacija: Unknown
Postovi: 247
U daljnjem researchu za ploču naletio sam na Strix B450-E Gaming za 1000 kn (na nabavi najjeftinija 1300 kn). Čini mi se solidan deal u odnosu na recimo Strix B450-F (1100 kn kod nas), ali i Strix X470 koja je dobro prošla u recenzijama i kod nas se kreće oko 1700 kn, a B450-E ima istu zvučnu i LAN kontroler, istu m.2 podršku i hladnjak, ali ima i wifi + bluetooth modul. VRM je 6-phase. Je li mi nešto promaklo? |
#3984 |
Postovi: 14,584
Ne valja. Pogledaj hardware unboxed recenziju R9 3950X na B450 pločama od neki dan. VRM se grije ko đubre, a nije problem u procesoru. Na B450 asus i gigabyte zasrali motku što se tiče vrm, as rock i msi bolja kupovina. U mbo višeg ranga obrnuta situacija s brandovima (uz iznimku top as rock ploča koje valjaju) |
#3987 |
trpi, trpi...
Lokacija: CRO
Postovi: 110
Kupi tu Strix B450-E Gaming za 1000kn, neces imati problema sa VRM temperaturama niti throttlanjem sa 3900x niti 3950x. |
#3988 |
Lokacija: Zagorje
Postovi: 872
I ja sam razmišljao o 3950X odma nakon najave, al sam shvatil da mi je pametnije uzeti 3900X jer kod svega osim multithreadinga je skoro isti, a tu mi čak nije raw render power toliko bitan pošto budu grafe odrađivale taj posao. A cijena je 4500 vs 7000? A ovo za uzeti mobo sa samo dva pciex utora je isto pametno. Jer nameće se pitanje kolko se uopće može iskoristi treći pciex pošto sam ograničen na 20 lanesa? U svakom slučaju su gore dvije grafe i jedan M2. |
#3989 |
Postovi: 2,138
Za takve sisteme se ne uzima destop am4 ploca/cpu nego HEDT platforma, eno Lewis ti renda sa grafama i udara po intel platformi jer mu daje opciju da može prikjuciti više grafi na mbo od Amd TR platforme. Ne vidim smisao render mašine na desktop platformi sa 2 grafe...
#3990 |
Lokacija: Zagorje
Postovi: 872
Sve je to meni jasno, al sam odustal od HEDT pošto je 1950x kojeg si mogu priuštiti pregažen od strane ryzena. Razmišljam da će mi ovo za jedan duži period biti dovoljno, a onda u budućnosti razmišljati o nadogradnji kad dođe vrijeme za nju. Budimo realni ja sam tek početnik, a Lewis se ovim bavi vjerojatno debelo preko 10 godina. Prilično sam siguran da ni on nije počeo s top platformom. Nek me ispravi ako sam u krivu. |
