Staro 26.08.2019., 11:42   #3721
JC Denton
dr. sc. tech. dipl. ing.
JC Denton's Avatar
Lokacija: Rijeka-Opatija
Postovi: 3,164
Autor jazzwa Pregled postova
Može prijedlog za matičnu do 600-650 kn, može li se naći što bolje od ASUS PRIME B450M-A
Možda AsRock B450/450M Pro4? Barem ima hladnjake na VRM-u i malo više USB portova iza (iako je VRM možda malo lošiji, ali msm da to i nije neki faktor u toj cjenovnoj kategoriji. Sve je to manje vise isti drek ).
I mislim da je jedina u tom cjenovnom razredu koja ima 2 M2 slota (iako mislim da jednog dijeli sa SATA portovima i podržava samo SATA diskove...)
Staro 28.08.2019., 05:57   #3722
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,260
Tko želi, može probati modani 7403 ili najnoviji beta 002 bios (riješava davno poznati problem za zaustavljanjem ventilatora i to kako korisnici kažu, za sada 100% uspješno; vau trebalo ima samo par godina da to riješe ).
Izmjenjen je jedino SMU, tj ubačena je verzija iz 7201, to je kod zadužen za boostanje, a 7201 je navodno puno bolje boostao, pa eto.
Morate flashat preko flashbacka:
https://drive.google.com/file/d/1U4F...cKzrvag0s/view
Pričam o c6h.
EDIT: Zanimiljivo, odnosi se na c6h, a primjetio sam ovo i tu na forumu (većina ima puno bolje boost-ove na drugim pločama); sa Asusovih foruma:
Sorry, had a hectic few days.
So tried something interesting. A customer at work brought in a Strix X470-F claiming it was faulty. But we had no Ryzen chips in to test. So I nipped home and took mine in. When I tested it in the customers build lo and behold it worked. So while it was installed I thought I would see what HWinfo was reporting. Long story short it was boosting all cores to 4.2Ghz which never happens on my C6H. That board was running the 1.0.0.3AB bios and out boosted the C6H 1.0.0.2 SMU. Sadly I couldn't test much due to it being work related. But that small test was far superior to my board. So I'm back to square one again lol. Just got to see what future bios updates bring. Or buy a new mobo ^^
Slobodno me dodajte na PSN
Zadnje izmijenjeno od: Disco. 31.08.2019. u 16:02.
Staro 31.08.2019., 16:39   #3723
Omega 3
Datum registracije: Oct 2017
Postovi: 119
Šta je s asus crosshair pločama? Dostupnost im je nikakva što u našim trgovinama što u Njemačkim.
Omega 3 je offline   Reply With Quote
Staro 31.08.2019., 16:51   #3724
VI Hero se prodavale ko vruće kifle pred koji tjedan i sve otišle. 2 i pol godine stara ploča je to.
VII Hero su debelo debelo preskupe za ono što nude i obzirom da ima za manju lovu bolje X570 ploče.
Sent from my SM-G965F using Tapatalk
Staro 31.08.2019., 17:44   #3725
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,584
E, kad su ih prodavali za kiki-riki. Doći će na red za isto i VII Hero
I pritom svaka čast Asusu na popustima, tako se rješavaju stare zalihe. Jedini su pošteno spustili cijene
Staro 31.08.2019., 18:07   #3726
Omega 3
Postovi: 119
Mislim na VIII, u nabavi ih samo AMD ima, mindfactory i jos neke njemacke trgovine uopce nemaju asus modele.
Staro 31.08.2019., 20:06   #3727
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,278
Moja c6h stoji u kutiji, i na znam sta bi s njom.. glavno da sam ju kupio
MojSkuter
Staro 31.08.2019., 20:28   #3728
iggi
Lokacija: qǝɹƃɐz
Postovi: 436
Ja bi je na tvom mjestu sigurno probao.
Barem na stolu...
Što znaš, možda bi procesor ljepše prodisao s njome.
Nemaš što izgubiti osim malo vremena.
iggi je offline   Reply With Quote
Staro 31.08.2019., 22:18   #3729
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,278
Autor iggi Pregled postova
Barem na stolu...
Kad imas ženu dijete posao vrijeme ti je vaznije od love
A komp mi radi brutalno stabilno, brijem da ga necu sad neko vrijeme dirati..
Ma gb koju imam je ipak bolja ploča tako da cu vidjeti, mozda promjenim kuciste od htpca pa ju tu ubacim. Uvjek ju mogu prodati lol
MojSkuter
Staro 31.08.2019., 22:48   #3730
iggi
Lokacija: qǝɹƃɐz
Postovi: 436
Novija i opremljenija, da.
A sad da li je bolja probaj pa vidi...
Ne košta te ništa...
Ja znam da je ne bih prodao, a da je barem ne probam
Staro 01.09.2019., 08:43   #3731
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,260
Mah, probaj da li radi, flashaj zadnji BIOS i prodaj ju.
Po svemu po netu c6h je među pločama koje najslabije boostaju.
Meni se sviđa ostatak opreme plus hladan VRM, a i realno u boostu jer par % razlike, ali opet...
Staro 01.09.2019., 11:18   #3732
Manuel Calavera
Postovi: 14,584
Kažem najbitnije je da mbo ima mesa, dobar kostur (featurei, hardverske komponente - pogotovo vrm). BIOS tj. softverski dio se lako promjeni na bolje. Pogotovo kad se radi o tako važnoj mbo - asusov flagship koji imaju mase (pogotovo "bitnih" ljudi poput recenzenata, pr0 overclockera i sl.)
Staro 01.09.2019., 13:31   #3733
Autor Disco Pregled postova
Koliko to slabije boostaju? Moja boosta na 4.3GHz R5 3600, a deklarirano je 4.2GHz na procesoru.
Može neke konkretne brojke, linkovi, a ne subjektivna tumačenja napisa po nekim forumima. Hvala.
Ne branim ploču nego me zanima dokaz da najslabije boosta i koliki je pad performansi.
Sent from S7 Presidency Phone
Staro 01.09.2019., 13:53   #3734
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,260
Evo 82 stranice trenutno (ima još par tema na asus forumima, ali vjerujem da i sam možeš prošvrljat), BTW moja boosta na 4,115 sa novim procom, a stari je išao na 4,150 (all core na oba 3,85-3,95), dok novi sa ručnim OC-om radi na 4,1 a stari nije mogo preko 4.0:
https://rog.asus.com/forum/showthrea...-Bioses/page82
Tu ima 4000+ stranica, li ne znam koliko zadnjih je za zen2:
https://www.overclock.net/forum/11-a...read-4289.html
Ili to ne smatraš relevantnim podatkom?
Jer sigurno nitko od rivjuera neće sada gledat kako boosta 2 godine stara ploča. A i sam Shamino je napisao da AMD spušta boost clockove, pa se sada ta njegova izjava raširila ko kuga po internetu...
EDIT: Na forumima se vidi i koliko drugih, puno gorih problema ljudi imaju, kojih sam se ja na svu sreću riješio. Boost je najmanji problem, ako i uopće.
Zadnje izmijenjeno od: Disco. 01.09.2019. u 14:06.
Staro 01.09.2019., 14:01   #3735
Druže, tu temu na OCNu pratim od dana kad je otvorena, kad ju je otvorio legendarni elmor.
Samo bih rekao da su u tu temu dovuklo toliko neznalica i noobova da su ubili tu temu, a da pravi znal8ci i testeri jedva dođu do daha da i kažu nešto.
Što se tiče biosa, ja imam taj sporni BIOS sa 1003ABB kodom i R5 3600 pa boosta na 4.3GHz ST i 4GHz MT pod jačim opterećenjem.
Ali dobro, ako Šamino kaže da je tako, onda je valjda tako.
Staro 01.09.2019., 14:19   #3736
BusMaster
BusMaster's Avatar
Datum registracije: Apr 2017
Postovi: 343
ASUS ROG CROSSHAIR VI HERO
Autor Omega 3 Pregled postova
______________________________________________________________
Koliko mi je poznato, dostupna je u DE, u ovoj trgovini i to po dobroj cijeni...
to je preračunato nešto ispod 900Kn, mislim da je jako povoljno za tu klasu MB
Evo ti link:
https://m.notebooksbilliger.de/asus+...ard+sockel+am4
Staro 01.09.2019., 14:29   #3737
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,260
A šta ja znam, kome vjerovat onda? Ja sam na svojo koži iskusio i BSODe i restartove i slabiji boost od reklamiranog.
Da li je ovo u redu? Ne, nije nikako, AMD očekuje od nas da budemo beta testeri, znam i sam sam si kriv jer sam odma kupio proc i ploču. Ali stvarno se nisam nadao da ima gadnih problema sa nestabilnosti.
Sada mi sve radi kako treba i iskreno sam oduševljen jer mi je komp raketa prema starom, u svemu osim u igrama (zbog grafičke) je točno 3 ili više puta jači/brži.
Što se ploče tiče, isto kažem, šteta boosta, ovo me čudi jer je riječ o flagship ploči, al ajd dobro. Što se tiče njenih 14 usba, 8 sata, VRMa koji je pod najgorim silovanjem i opterećenjem max na 40 stupnjeva, mislim da ne moram ni trošit riječi jer tu briljira.
Sve u svemu ja sam sada jako zadvoljan kompom i preporučujem ljudima zen2, ali da ima problema ima, da ljudi i dalje imaju probleme.
A Shamino bi mogao opasno dobit po repu zbog svoje izjave (svi portali su je prenjeli i stvorila se velika medijska pompa jer je to rekao baš on) i bila bi velika šteta da ga Asus najuri zbog tako nečeg jer mislim da je čovjek sposoban i surađuje sa comunityem što je odlično za nas obične smrtnike.
I za kraj, pa ti si me pitao za izvore, i ja sam ti ih dao, tamo to pratim, za druge zasada ne znam, niti mi se prati 25 foruma.
Stavio sam u drugu temu C/P gdje je čovjek koji ima c6h probao svoj proc na strix-f i na njoj se proc boostao više.
Da, ima njubova, ali ima i ljudi koji valjda znaju što rade, ne vjerujem da su baš svi nesposobni...
Jako puno ljudi ima i tih problema sa ventovima općenito na asusovim pločama kolko sam shvatio, ja nemam, ti nemaš, to ne znači da problem ne postoji.
Staro 01.09.2019., 14:53   #3738
Ne znam zašto si ti ovo shvatio kao napad na sebe.
Samo sam htio znati izvor informacija. Ali očito je da problem postoji kod NEKIH a ne generalno SVIH korisnika ove ploče.
Staro 01.09.2019., 16:41   #3739
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,260
Pa ko je rekao svih?
Ugl. dobra ploča koja slabije boosta, tj velike su šanse da slabije boosta.
Postoje i drugi problemi, a to je loto.
Staro 04.09.2019., 12:00   #3740
Ajmo brzo... samo 3 komada na lageru najbrži prst.
Manje od 1100 kn
https://www.uzishop.hr/posebna-ponud...-x370-atx.html
Staro 04.09.2019., 18:57   #3741
Manuel Calavera
Postovi: 14,584
https://youtu.be/xbyWKufthS4
Stevo testirao vrm temp entry x570. Asus Prime x570-p iznenadila
Staro 04.09.2019., 19:16   #3742
sti
Lokacija: Lawl
Postovi: 1,374
Za početak, ako je kriva tema, neka Brko prebaci shodno tome...
Naime, na mojoj Crosshair VI Hero su prestala raditi 2 memorijska (DIMM) utora, treći i četvrti (gledajući od socketa prema "van"). Ako se moduli/keksi postave u bilo koji od ta dva utora, sustav se ne podiže, a na matičnoj ploči gori LED-ica koja indicira da je problem u memoriji (narančasto svjetlo i kod greške 0d). Ako su moduli u prvom i drugom utoru, Windows se normalno podiže ali memorija radi u single channelu (efektivno duplo manja propusnost)
Isprva sam pretpostavio da je problem u procesoru (Ryzen 1600), jer je u njemu memorijski kontroler, tako da sam naručio Ryzen 3600, stavio ga umjesto starog i problem ostaje, tako da je novi Ryzen otišao na refund u Amazon isti dan.
Oba memorijska modula su testirana s programom Memtest86 i prolaze bez greške. Aida stress test i OCCT prolaze 2h bez greške.
Vizualno također ne mogu primijetiti oštećenja na ploči,socketu, DIMM utorima kao ni tragova kratkih spojeva.
Ako netko ima prijedlog uz već isprobana premještanja modula u utorima, flashanje zadnjeg Biosa, clearanje cmosa, vađenje baterije i sve moguće psovke u trenucima očaja, bio bi jako zahvalan
sti je online   Reply With Quote
Staro 04.09.2019., 19:33   #3743
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,278
Uh, Problem je u utorima nema tu sta drugo biti.
Proc i sam kazes ne moze biti. Pregledaj malo CPU socket i CPU pinove da li vidis sta neobicno cisto za svaki slucaj.
Ram radi, a dijagnostika mbo kaze da je neispravna.. znaci utori
E sad, da je jedan utor rekao bih da je kontakt, da probaš malo počistiti.. ali dva? Hm..
Tu su i memorijske trase.. one se cak golim okom na dobrom osvjetljenju naziru između cpu socketa i dimm utora za ram.. nadam se da ih nisi nekako oštetio. Baci oko..
PS
..bas sam na brzinu bacio oko na te dimm utore na c6h, kad mi vec samo stoji u kutiji..
..i razocaralo me kako socijalno izgledaju.. vide se svi kontakti s vanjske strane.
mislim, to su dimm utori, ni ne trebaju biti tako dobro zasticeni kao npr na GB koju imam u kompu, ali svejedno..
uzmi neki kist malo to pocisti, ispusi (ne sa komprimiranim zrakom u spreju jer on vlaži! )
probaj malo pregledat, tesko je reci da li je neki kontakt , ali mozda uz povecalo i dobru lampu bi se mozda moglo i vidjeti nesto vise..
uglavnom ne znam, mozda netko drugi kaze nesto pametnije ..sry
pitanje..
kako si skuzio da ti ne rade ti utori? to se odjednom u sred rada komp ugasio, ili je komp stajao tjedan dana i kada si ga probao upaliti nije htio ili?
MojSkuter
Zadnje izmijenjeno od: Eladio. 04.09.2019. u 19:54.
Staro 04.09.2019., 19:55   #3744
sti
Lokacija: Lawl
Postovi: 1,374
Ne vidim ikakva oštećenja, trase se naziru ispod sloja laka ali nisu u prekidu. RAM sam u dvije godine izvadio jednom, da stavim frendov i vidim radi li.
Jedino šarafanje po matičnoj se radilo prilikom instalacije, u naredne dvije godine nisam ni pastu promijenio.
Ne vidim ni oštećenja na pcb-u, svi elementi golim okom izgledaju netaknuto.
Autor Eladio Pregled postova
pitanje..
Stajao je cca 2 tjedna zbog selidbe i kupovine novog stola. Vratio cooler, stisnuo power button i nije upalio. Matična je imala napajanje ali se ništa nije pokretalo. Keksi su bili u utorima 2 i 4 zbog dual channela. Tek se pomicanjem modula u prva dva utorka sustav dignuo, ali sve daljnje kombinacije s memorijom (utori 1/3 ili 2/4) su rezultirali narančastom ledicom i q-kodom F9 i 0d.
Zadnje izmijenjeno od: sti. 04.09.2019. u 20:13.
Staro 04.09.2019., 20:07   #3745
Događa se. RMA ako imaš garanciju. Nema fleša s kojim ćeš to upogoniti nažalost
Staro 04.09.2019., 21:25   #3746
Manuel Calavera
Postovi: 14,584
Reklamacija
Staro 04.09.2019., 22:20   #3747
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,278
pretpostavljam da si probao samo s jednom pločicom.. a ne isključivo kombinacije s obje?
Autor sti Pregled postova
To sam pitao zbog naravi kvara..
Po ovome zakljucujem da je veća šansa da je "mehanicki" kvar, a ne "električni"..
Ajmo reći, vjerovatno nije ništa izgorilo. Prije bih rekao da je uslijed stajanja se nesto zaprašilo, ili uslijed "seljenja" je nešto "puklo" , neki kontakt ili nešto..
Zanimljivo mi je da su oba dva utora neispravna, taj dio mi se čini ključan, ali nisam nikad radio na projektiranju MBO da bi znao pokazat prstom preciznije šta je zajedničko za oba dva ta utora, jer očito je tu neki kontakt ili neki prekid , nešto što je dodirno za oba utora...
želim reći, da je npr. neki kontakt unutar utora, onda bi mogli sumnjati da ne radi samo taj utor.
ovako je stvar ipak na nekom spoju van samog utora, a taj spoj na neki način ima veze s oba dva..
eto, gledao sam bas star trek pa glumim vulkanca, sumnjam da sam imalo pomogao, ali eto..
kao što su i drugi rekli, reklamacija ako je ikako moguće .. bolje ne prtljati previse ako imas garanciju
MojSkuter
Zadnje izmijenjeno od: Eladio. 04.09.2019. u 22:26.
Staro 04.09.2019., 22:35   #3748
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,278
Imas hrgu od coolera, spominjao si seljenje, pa vidi ovaj komentar:
https://www.techpowerup.com/forums/t...orking.216856/
"With some coolers, attaching them too tightly bends the motherboard and disconnects all or some DIMM pins. Is any of 3 and 4 slot located near CPU socket? I had this problem once. In best cases, you just don't have RAM detected, in worse, the system won't even boot."
PS
..pazi ovo, ovaj je imao problem s metalnim sajbicama: https://rog.asus.com/forum/showthrea...allation-error
..izvadi plocu van, ocisti kuciste, i testiraj van kucista samo plocu i stock cooler ili tako nekako ..
MojSkuter
Zadnje izmijenjeno od: Eladio. 04.09.2019. u 22:43.
Staro 04.09.2019., 22:41   #3749
bilicvitak
bilicvitak's Avatar
Datum registracije: Nov 2014
Lokacija: ¯\_(ツ)_/¯
Postovi: 535
Nije to Rudi Čajavec da bi se moglo pratiti štampu. To su višeslojne ploče i tu se nemre vidjeti kaj se dogodilo između slojeva i gdi može biti prekid..
Veliki hladnjaci pigaju ploče dosta pa možda je zbog toga
Kupujem
bilicvitak je offline   Reply With Quote
Staro 04.09.2019., 22:45   #3750
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,278
..istina.. ako ima garanciju, ja dalje nebi nista dirao
ako nema, e jbg onda
MojSkuter
