#151 |
Datum registracije: Jul 2017
Lokacija: Ramura
Postovi: 2,793
Nisam s njih. Njih sam do sada koristio samo za kupovanje sitnih kripto iznosa preko kartice. Ali sam povlačio s Krakena, vjerujem da je isto kao i Bitpanda. Nema tu pameti, prodaš kripto za EUR, upišeš IBAN, tražiš withdrawal u EUR i meni je uglavnom sjedalo unutar istog dana na račun (pokrenuo ujutro oko 8, sjelo oko 13-14). Račun ne mora biti devizni. Ako je obični kunski, prilikom primitka pretvorit će ti se u kune po tečaju banke. |
#153 |
Postovi: 900
Za kraken mogu i ja potvrditi ![]() |
#154 |
Lokacija: Cirkus
Postovi: 642
Evo još jedan airdrop, pa tko želi: 1500 TRX (≈ 30.00 USD) and extra 100 TRX (2.00 USD) for each friend you refer Referral link: http://t.me/tronetworkbot?start=46571143 30.08.2019 se završava i šalje na wallet. Sent from my Pixel 2 using Tapatalk |
#155 |
Postovi: 900
Discoin - provjereno od vise izvora, cca 11$ plus daily bonus SCROLL DOWN AND CLICK*"CREATE WALLET" REGISTER (PASSWORD NEEDS 12 CHARACTERS OR MORE) CLICK*"AIRDROP" SCROLL DOWN AND LOOK FOR*"AIRDROP ACHIEVEMENTS" COMPLETE*"PROFILE"*AND*"WALLET" *YOU CAN GET MORE DSCN BY CLAIMING ONCE EVERYDAY CLICK*"DAILY BONUS"*TO CLAIM https://discoinapp.discodery.com/r/vnnyIj |
#156 |
Postovi: 900
LA is an already operative currency for traders. It was created by LATOKEN — a transborder transactions company — to setup a new trading ecosystem, removing middlemen and giving trading access to 1 bln people. This currency is trusted by more than 150K traders all around the world. I was rewarded with plenty of free tokens for signing up and helping to build the largest trading community ever. It’s totally free and all you need to get started is a valid email. You can get your tokens... https://airdrop.latoken.com/invite/dOvesRxBVFbcGDvd |
#157 | |
Postovi: 900
Oba uskoro istjecu ![]() |
#158 |
Propali Amigaš
Lokacija: Nin
Postovi: 7,005
https://www.clearunited.com/pages/r/0d4be2tyw Slično kao initiativeQ, ali iza projekta stoji prava kompanija https://www.clearcenter.com/ https://www.clearos.com/ Zadnje izmijenjeno od: segregator. 13.08.2019. u 16:08. |
#159 |
Postovi: 900
Get a chance to win one of the 20 prizes worth $25 each equivalent in ETH from SpringRole as part of*SpringRole August $500 Giveaway! https://wn.nr/yMBFqG |
#160 | |
Lokacija: Ramura
Postovi: 2,793
BEST airdrop je završio u utorak u 13 sati. Tko se prijavio dobio je 420,4684 BEST (ili cca 30+€) za nekoliko klikova. ![]() Trojici koja su se prijavili preko mog ref linka hvala. Nemam ja ništa od toga, ali čovjeka veseli. Možda jednog dana kada se odlučite trgovati na Bitpandi nam i daju svakome po 10€, ali to budemo vidjeli. Ovi ostali što su brisali ref kod s linka, jebiga, uvijek bude u životu, kako daš tako i primiš. |
#161 | |
Postovi: 2,648
![]() Odavno sam regan na bitpandi, i lajkam. Prava regulirana burza, neće tu biti PnD šema, već polagani kontinuirani rast. Inače odličan airdrop za verified usere i PAN holdere. Ja sam uz airdrop još i kupio BESTa, nek stoji.
#162 |
Postovi: 900
#163 |
Postovi: 900
Hlbit exchange ima drop svojih tokena, dobije se 225coina tj cca 22.5usd. Coin ce biti isporuceni u 10mj... https://t.me/AirdropHLOBbot?start=554790448 |
#164 |
Postovi: 900
TERRA CREDIT LAST AIRDROP*(ALREADY TRADING @ CATEX & BITFOREX) REWARD: 5,101 CREDIT ENDS: AUGUST 31 https://terra-hub.com/register?mref=2878 |
#165 |
Postovi: 900
Hypersonic Network (H2N) is the latest collaborative decentralized Ethereum blockchain based platform that is most efficient Blockchain for the Token economy. Hypersonic Network is giving away 240 (H2N) limited to 100k people worth of 24$ https://t.me/HypersonicN_bot?start=0753188364 |
#166 |
Postovi: 900
#167 |
Postovi: 900
Curate tokens airdrop Tokeni se dijele oko 30.8. https://t.me/CurateCryptoBountyBot?start=0331474a23 |
#168 |
Postovi: 900
Accommodation Coin Airdrop (ACCO) A digital currency based on Ethereum ERC20 token infrastructure, specific for the travel and accommodation industry. The only digital currency that rewards its guests and hosts for good reviews. Sharing your travel data now earns you coins and helps hosts improve their marketing. Dobije se 1000acco cca 25usd. https://t.me/AccommodationCoinbot?start=r0753188364 |
#169 | |
Postovi: 2,648
NASH exchange je napokon otvoren! Jedna od rijetkih ICO-a iz 2018. koji je u odličnom plusu. Po meni bit će to No1 DEX burza, a njihov token NASH ima svijetlu budućnost. trenutno imaju i nagradnjaču za sve koji se regaju preko referrala, pa ako tko želi, evo vam link: nash.io/referrals?code=2F3xXo Na linku su i upute za nagradnjaču, nagrade su izdašne, za prvo mjesto daju 35.000,00 USD u BTC i 15.000,00 NASH (trenutno 1 NASH je = cca 2 USD). Citiraj:
No i bez toga, ovo je po meni jedna od burzi budućnsoti i svakako ću trejdati tamo.
#170 |
Postovi: 900
Pi Network - majnanje putem moba, kao etn. Projekat izgleda jako dobro. App nemora stalno raditi, svaka 24h se dobije obavijest da se klikne mine i to je to. Danas je objavljeno da ce se trejdat uskoro na aacoin exchange po cijeni od 0.16$... minepi.com/killahtm |
#171 |
Postovi: 900
Zen coin Otvoris acc na binance exch. ako nemas i kopiras si adresu od zen coina i svaki dan dobivas do 1zen coin kada se ulogiras na njihov site i claim. Coin trenutno vrijedi 3.39usd ![]() https://getzen.cash/auth/register?ref=79339 |
#173 |
Postovi: 900
Iskreno nzm dokada, ja sam danas saznao za njega. Da coin je od 5mj 2017, ima dobar projekat i jako dobru cijenu s obzirom da je alt ![]() |
#174 |
Datum registracije: Oct 2017
Postovi: 163
Ja sam dvije godine već upoznat sa projektom. Čak sam hostao i secure node sa stakeanih 42 coina neko vrijeme. U svakom slučaju imali su i imaju i dalje perspektivu kad ih usporedim sa more drugih tehnologija. Vrijeme će pokazati gdje će završiti. |
#175 |
Postovi: 900
Trx giveway Samo upises mail adresu pa sta bude ![]() https://bullsvsbears.io?referral=eD88U1i&refSource=copy |
#176 |
Postovi: 163
Nešto dijametralno suprotno ali baš zbog toga stavljam ovdje. ![]() Ovih dana je moguće kupiti dionice od Rimčeve firme Greyp. Imaju tzv. ETO - Equity Token Offering gdje u vlasništvu tokena u blockain tehnologiji praktički kupuješ pravu dionicu. Ovih dana je kupovina sa 10% popusta za one koji su se whitelistali, za 2 tjedna će biti javna ponuda, ako što ostane. Zanimljiv novi koncept. Ja sam dobar dio svog kripta tamo ulio - praktički ga prodao za trenutnu cijenu. Računam kuputi natrag kad još malo padne. ![]() E da, sve to na https://neufund.org |
#177 |
Postovi: 900
#178 |
Postovi: 900
RESHPOOL is a sharing economy based computing resource sharing platform. Users can share the unused idle computing resources for rewards. According to white paper, 1 RSP = 15 Korean Won = ~$0.013. Which gives this airdrop ~$130 initial value. Dijele 10000rsp tokena, lagano za odraditi. https://docs.google.com/forms/d/e/1F...57251519414034 |
#180 |
Postovi: 900
Nema takvo ogranicenje sto se tice ljudi, bar zasada ![]() |
