Staro 06.01.2006., 16:04   #1
^SuperUnknown^
Prečupavi mod
^SuperUnknown^'s Avatar
Postovi: 9,104
Vasi komentari na Venice konfu za 5300kn :)
Na konfiguraciju, sve uzeto u Bingu:
* CPU AMD Athlon64 3000+ BOX, socket 939, Venice, 1800MHz, 512kb c., HTT 1000MHz 1.272,17 kn
* MBO ASROCK 939Dual-SATA2, ALi 1695, DDR, zvuk, S-ATA, LAN, AGP i PCI-E, s. 939 465,64 kn
* RAM PC-3200, 512MB, DDR, PQI, DDR 400 MHz 308,70 kn
* HDD 80 GB HITACHI, Serial ATA II 3.0, 8 MB cache, 7200, Deskstar GST 7K80 444,59 kn
* DVD?RW NEC ND-4550, 16x, black, Dual layer ? recording, DVD RAM, bulk 379,49 kn
* Floppy drive 3.5'', 1,44MB, crni 48,72 kn
* Monitor 17" Samsung SM795DF sreb. 85 kHz, 0.20mm, DynaFlat 922,09 kn
* VGA PCI-E GAINWARD Ultra/1760 TV/DVI, GeForce PCX 6600, 128MB, DVI, TV 764,29 kn
* Mis Logitech S96, black, opticki 56,99 kn
* Tipkovnica Logitech Deluxe, black 65,25 kn
* Napajanje CHIEFTEC 350W, Delta GPS-350BB-101L, 12cm fan, ATX2 285,77 kn
* Modem Conexant 56k, interni, softverski 44,01 kn
* Kuciste PROTECTOR CS-435, MIDI, crno, bez PS 160,91 kn
* Zvucnici Altec Lansing 121 136,96 kn
Međuzbroj: 5.355,58 kn
Sluzit ce za net, muziku, pokoji film i igru, a ono... sve pomalo, nista zahtjevno, konfa je za lika koji je relativno nov u svemu tome. Najbitnije je da cijena ne odstupa od trenutne, pozeljno bi je bilo i smanjit sto blize 5000... hvala!
Primary macine:
Apple Mac Pro 5,1
64 GB ECC DDR3 800 MHz
Geforce GTX 980 4 GB
Kingston 120GB SSD
30 TB HDDs
Sharkoon QuickPort@USB
Optiarc DVD RW AD-7170A
Mac OS X 10.12.3
Secondary machine:
Apple Mac Pro 2,1
22 GB DDR2 FB-DIMM 667 MHz
Geforce GTX 970 4 GB
Seagate 500GB 7200.10
Hitachi 1000GB 7K1000.B
Seagate 1000GB 7200.11
Hitachi 7K3000 3000GB
Mac OS X 10.10.3
Work rig:
Apple Mac Pro 1,1@2,1
13 GB DDR2 FB-DIMM 667 MHz
Geforce GTX 660 2GB
Seagate 500GB 7200.12
2xWD Black 1000GB
2xSharkoon QuickPort@eSATA
Mac OS X 10.10.3
Sony KDL-26U2000 26"@HDMI
Apple Alu Keyboard
Logitech MX518
LAP:
Apple Macbook Pro 3,1
Intel Core 2 Duo 2.53 GHz
4 GB DDR2
Kingson 180 GB SSD
Seagate 320 GB HDD
* Looking in:
* Listening to:
Technics SA-EX320
iPhone 6S 64GB black
iPad 16GB WiFi 4.3.2
* Connected via:
90/90 Mbps Iskon Trio
* "Powered" by:
UPS APC Smart-UPS1500VA
* Playing:
Tama Arstar II
Yamaha DTXPRESS IV Special
Staro 06.01.2006., 16:23   #2
nino
nino's Avatar
Postovi: 12,600
U globalu cisto ok konfa, nego od mene preporuka za memu uzet 2x256 zbog dual chanella i ukupnih performansi, 20 kn vise ali....
Staro 06.01.2006., 16:25   #3
^SuperUnknown^
Prečupavi mod
Postovi: 9,104
Ja sam mislio neka covjek za pocetak vozi jednu plocicu, a uskoro kad bude nadogradjivao stavi jos 1x512 i dobije opaki upgrade
Primary macine:
Apple Mac Pro 5,1
Kingston 120GB SSD
30 TB HDDs
Mac OS X 10.12.3
Secondary machine:
Apple Mac Pro 2,1
Mac OS X 10.10.3
Work rig:
Geforce GTX 660 2GB
2xWD Black 1000GB
Mac OS X 10.10.3
Apple Alu Keyboard
Logitech MX518
LAP:
4 GB DDR2
Kingson 180 GB SSD
Seagate 320 GB HDD
* Looking in:
* Listening to:
Technics SA-EX320
* Connected via:
* "Powered" by:
* Playing:
Tama Arstar II
Staro 06.01.2006., 16:30   #4
nino
nino's Avatar
Postovi: 12,600
Onda povlacim moj amandman
Staro 06.01.2006., 17:48   #5
E.T.
E.T.'s Avatar
Postovi: 2,458
Samo upozorenje asrokica ima dosta los layout... Naime ide konetori su na dnu ploce pa je potrebno optiku spustiti u najdoljnije utore, no vidim da imas samo jedan drive pa onda nebi smjelo biti problema. Ono sta je ok je smjestaj sata2 konektora koji je na gotovo idealnom mjestu i za koji odmah dobijes i kabel...
Takoder ima samo jedan konektor na ploci za spajanje dodatnog ventilatora i to na samom dnu.... Problem se javlja i ako nisu dobro podeseni uredaji na ide kanalima te postavke u biosu na koje se treba malo naviknuti. Southbridge hladnjak se ne grije previse no malo smeta AGP grafickoj kartici dok je PCI-e dovoljno odmaknuta. Northbridge se poprilicno grije u 3d aplikacijama jer ima samo pasivno hladenje no i to grijanje ne uzrokuje nestabilnost u radu... jedino moze malo podignuti temperaturu cpu-a i gpu-a no sa 12-najskom otraga na kucistu nestaje i taj problem...
www.rabbits-clan.com
E.T. je offline   Reply With Quote
Staro 06.01.2006., 20:08   #6
^SuperUnknown^
Prečupavi mod
Postovi: 9,104
Kao prvo hvala na iscpnim dojmovima A kao drugo, svjestan jesam da ploca nije nesto posebno luda i da ima svojih mana, na kraju krajeva kosta 465 kn Posto proc (i nista) vjerojatno nece bit klokano, dodatni FAN headeri nit nisu nuzni Kaj se tice NB-a, da li bi bilo odmah pametno staviti pasivnog Zalmana + AS5? Gubi li se time garancija, pretpostavljam da ne? U stvari, ono sto me najvise interesira kod te ploce (s obzirom da je low end) da li ploca radi pouzdano i stabilno (sto je na prvom mjestu), odnosno da nema nekakvih "muha" pri radu i podesavanju/instalaciji OS-a? Hvala!
Primary macine:
Apple Mac Pro 5,1
Kingston 120GB SSD
30 TB HDDs
Mac OS X 10.12.3
Secondary machine:
Apple Mac Pro 2,1
Mac OS X 10.10.3
Work rig:
Geforce GTX 660 2GB
2xWD Black 1000GB
Mac OS X 10.10.3
Apple Alu Keyboard
Logitech MX518
LAP:
4 GB DDR2
Kingson 180 GB SSD
Seagate 320 GB HDD
* Looking in:
* Listening to:
Technics SA-EX320
* Connected via:
* "Powered" by:
* Playing:
Tama Arstar II
Staro 06.01.2006., 20:38   #7
E.T.
E.T.'s Avatar
Postovi: 2,458
Pa vidis kod mene je svega tjedan dana i zasad sve ok...kod athe isto u ovaj jedan dan sta je ima...
