Staro 24.07.2019., 05:16   #991
Postovi: 34,003
1m dužine, 2m dužine
Staro 24.07.2019., 10:55   #992
XXX_Man
3X
XXX_Man's Avatar
Datum registracije: Sep 2010
Lokacija: Zagreb, Croatia
Postovi: 216
“The saddest aspect of life right now is that science gathers knowledge faster than society gathers wisdom.” - Isaac Asimov
"With the first link, the chain is forged. The first speech censured...the first thought forbidden...the first freedom denied – chains us all, irrevocably."
XXX_Man je offline   Reply With Quote
Staro 24.07.2019., 14:15   #993
Dottore
Dottore's Avatar
Postovi: 7,671
Taj kabel je malo kratak. Čisto da se zna.
@korejski medo
Jesi li pogledao u Mallu za Anker?
Отправлено через SM-G955F
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 24.07.2019., 17:29   #994
XXX_Man
3X
XXX_Man's Avatar
Postovi: 216
Autor Dottore Pregled postova
Nisam znao, tnx
Staro 24.07.2019., 21:21   #995
panda505
panda505's Avatar
Lokacija: Beertopia
Postovi: 2,013
Autor coconut Pregled postova
Tenkju #1
Tenkju #2
@korejski medo
Šta je najbolje, meni taman treba full kratak jer mi treba samo za powerbank
Ovo za Mall shvatio nisam. Ali sam gledao na Ankerovoj stranici (i na Amazonu) i malo su popaprili cijene tak da mi se za kablove ne da piskat pitajboga koliko dolarčeka.
54' / 74' / 90' / 2014
Staro 24.07.2019., 22:30   #996
Charmander
Ultrapiretik
Charmander's Avatar
Postovi: 903
Ja imam samo ugreen kable. Jedini koji normalno koštaju i znam da 100% imaju propusnost za podatke i punjenje.
Moja trgovanja: 1, 2, 3, 4, 5, 6, 7, 8
Picoin invite: bass999 // minepi.com/bass999
Charmander je offline   Reply With Quote
Staro 25.07.2019., 06:48   #997
Postovi: 34,003
I Baseus kabeli su dobri.
Staro 25.07.2019., 22:26   #998
XXX_Man
3X
XXX_Man's Avatar
Postovi: 216
Da, ja generalno koristim Baseus i zadovoljan sam.
Staro 25.07.2019., 23:03   #999
panda505
panda505's Avatar
Lokacija: Beertopia
Postovi: 2,013
Ja imao nekoliko Baseusovih i Ugreenovih, oboje vrlo solidno (iako mi je USB-C konektor na jednom baseusu bio sjeban).
Jučer sam baš naručio ~10ak kablova za sebe i curu tako da, bit ću neko vrijeme miran
Staro 27.07.2019., 23:47   #1000
hash
Postovi: 1,431
Nakon jedno godinu i pol dana rijetke upotrebe sam napravio kakav takav benchmark mi powerbanka:
https://www.mi.com/global/pb10000/
Dakle, baterija na mobu starom skoro dvije godine od 3080mAh baterije je napunjena:
  • od 8% do 100%
  • od 8% do 100% drugi put
  • na 44% spojen mob na powerbank i vise se mob ne puni
Ne znam jel to puno ili malio, ocekivao sam ipak jos pola punjenja vise.
Powerbank je drzan na 100% cijelo vrijeme (ali ne vidim smisao drzanja powerbanka na 60% radi cuvanja baterije) pa je to neka kao otegotna okolnost.
Baterija na mobu je sigurno degradirala s deklariranih 3080mAh.
Powerbank je stvarno rijetko koristen, ne znam jel 5 puta ispraznjen do kraja. Tesko mi je procijeniti koliko puta je ispraznjen do pola ali rekao bih maksimalno 50 puta, realnija brojka bi bilo 30. Ali to su izmisljeni brojevi koje ne bi trebalo uzimati u obzir.
Vjerojatno bi se u powerbankku dale zamijeniti baterije ali ovakvom upotrebom ce mi sigurno trajati jos koju godinu pa ne vjerujem da ce mi se dati zajebavati.
Nadam se da je korisna informacija, nisam imao pametnijeg posla
Staro 28.07.2019., 03:10   #1001
panda505
panda505's Avatar
Lokacija: Beertopia
Postovi: 2,013
Pa meni to zvuči ko čist oke.
Za 10k mah, ne znam šta bi mogao više očekivati, posebice nakon toliko korištenja...
Poslano sa mog SM-G965F koristeći Tapatalk
Staro 28.07.2019., 11:45   #1002
Postovi: 10,128
Kapacitet powerbanka na papiru 10000mAh * gubitak u konverziji 0,7-0,8 = okvirno koliko mAh mozes napuniti
Neko pravilo je da kod brzih punjenja (QC standardi) naspram vulgaris 5V1A ima vise gubitaka pa mnozis sa nizom cifrom. Ovisi i od proizvodjaca do proizvodjaca, netko koristi bolje, netko losije komponente, dosta faktora je tu.
Po meni je tvoj rezultat dosta dobar.
Staro 28.07.2019., 14:12   #1003
akoj
lijevo smetalo
akoj's Avatar
Datum registracije: Jan 2014
Postovi: 1,120
Punjači, baterije, navigo, memorijske kartice, slušalice i ostala oprema za mobitele
Prije da je iskoristivost 60 - 70 posto. Sama razlika u naponu je vec 74%. I jos npr. Xiaomi navodi da im je efikasnost powerbankova iznad 93%. To je nekih 68%.
U praksi sam iz nekih 15XXX mAh (deklarirano 16000) uspio izvuci 10XXX mAh.
Jedan drugi (no name) powerbank - deklarirano 2500 (stvarno 23XX) dobiveno 14XX.
Naravno ima hrpa parmetra - kabel, temperatura, stanje uredaja koji se puni....
Po meni je sve iznad 60% ok.
Nvisen Y-GX01 // BMAX Y11
akoj je offline   Reply With Quote
Staro 29.07.2019., 13:58   #1004
FerrZG
FerrZG's Avatar
Datum registracije: Oct 2016
Postovi: 171
Meni Samsungov Powerbank (10 000 mAh) napuni S10e (3100 mAh baterija) 2 puta i kod treceg punjenja stane na 15 %. Dakle nekih 0.67 x pri konverziji.
Ovo su podaci za fast charge putem zice.
FerrZG je offline   Reply With Quote
Staro 30.07.2019., 01:36   #1005
hash
Postovi: 1,431
Znaci u nekoj prvoj aproksimaciji, po iskustvima korisnika, 0,65 kad je nov pa padne na 0,55 nakon godinu i pol.
I to pricamo o brand-name powerbankovima.
Ja sam u glavi isto imao neke brojke od 0,7-0,8. Dobro da nisam racunao s tim.
Staro 30.07.2019., 02:13   #1006
panda505
panda505's Avatar
Lokacija: Beertopia
Postovi: 2,013
Ja npr. na svom Ankeru (20k) imam ~5 punjenja bez beda. A koristi ga se ono, žestoko...
Staro 30.07.2019., 10:51   #1007
p3c3k
Datum registracije: Mar 2019
Postovi: 146
Uz S10+ sam uzeo i Samsungov Wireless battery pack. Deklariraju 10000mAh, Jos ga nisam imao priliku koristiti.
Prije sam koristio 10200 mAh Samsung fast charge battery pack i S8 i imam samo rijeci hvale. 4puta ga je napunio bez problema od 20-100%. Iako je sada razlika od 1100mAh, mislim da ce ovaj biti u stanji bezicno napuniti mobitel barem 2 puta
Zadnje izmijenjeno od: p3c3k. 31.07.2019. u 10:37.
p3c3k je offline   Reply With Quote
Staro 01.08.2019., 15:41   #1008
Matta
El Mattador
Matta's Avatar
Lokacija: <->
Postovi: 1,921
On-ear Bluetooth slušalica za razgovor, obavezno USB-C za punjenje, nipošto micro-USB.
Prijedlozi ?
Matta je offline   Reply With Quote
Staro 02.08.2019., 09:06   #1009
Postovi: 10,128
Autor akoj Pregled postova
Imas pravo, malo sam pretjerao pisuci po sjecanju.
Neki dan se igrao s Ankerom Astro 13000mAh (nema fast charge, star 5 godina, koristi se skoro svakodnevno) koji je napunio 2,02 puta moj Note9 sto isto ispada oko 62%.
Staro 15.08.2019., 11:45   #1010
Matta
El Mattador
Matta's Avatar
Lokacija: <->
Postovi: 1,921
Usb-c što kraći (pola metra max) kablovi za punjač Aukey 60W 6-portni ?
OVO ili nešto drugo ?
Hvala !
Staro 15.08.2019., 13:34   #1011
stops
stops's Avatar
Datum registracije: Feb 2013
Postovi: 347
Ugreen all the way!
Na njihovom Aliexpress storeu imas po malo boljoj cijeni, uvijek brza dostava
stops je offline   Reply With Quote
Staro 19.08.2019., 11:31   #1012
renc
Datum registracije: Feb 2019
Postovi: 455
Vi koji imate magnetne držače za auto (s onom metalnom pločicom koja ide na mob ispod maske)...jel vam radi punjenje na wifi punjaču s tom pločicom?
renc je offline   Reply With Quote
Staro 19.08.2019., 11:35   #1013
Postovi: 10,128
Ne. Ali radi ako nastimas plocicu da ne pokriva zavojnicu (ako znas gdje se nalazi). Na S7 nisam uspio, prevelika plocica, ali na N9 stavim plocicu na samo dno pozadine i sve sljaka.
Ako vec koristis maskicu, mozes plocicu zalijepiti na nju i eventualno skidati masku prije punjenja. Nema razloga da ide ispod maske osim estetike
Staro 19.08.2019., 15:05   #1014
Lourdin
Lourdin's Avatar
Postovi: 180
Stižu novi mobiteli, pa bi trebao neke preporuke za maske..
Ja sam za svoj prije 2-3 godine uzeo Ringke sa ringke direct dućana na ebayu.
Nažalost, taj dućan više ne radi.
Znate možda gdje bi mogao uzeti Ringke maske?
Radi se o galaxy s10e i 2 x samsung A40.
Koliko sam uspio vidjeti ringke nema za A40, pa ako znate koju dobru masku za A40 u tom rangu, cijenio bi informaciju.
Također me zanima imate kakvu preporuku za powerbank i neki charge adapter za auto (što ide u upaljač za cigarete)?
Za auto imam blitzwolf usb-c kabel.
Lourdin je offline   Reply With Quote
Staro 19.08.2019., 15:13   #1015
Postovi: 34,003
Pogledaj si Spigen maske. Nisu jeftine, ali su dobre i imaš ih za različite stupnjeve zaštite mobitela.
Staro 19.08.2019., 16:15   #1016
android-split
android-split's Avatar
Datum registracije: Dec 2015
Postovi: 1,044
Poetic i ringke, best buy sigurno
Ja ti trenutno cekam od poetica masku i kaljeno sta su mi poslali za recenziju za s10e
Al mislim da nemaju za a40 nista
android-split je offline   Reply With Quote
Staro 19.08.2019., 16:16   #1017
Postovi: 34,003
Napisao je - s10e i a40 x2
Staro 19.08.2019., 17:08   #1018
android-split
Postovi: 1,044
Pa napisa sam da nemaju za a40 nista. Za s10e imaju.
Staro 19.08.2019., 18:51   #1019
Lourdin
Lourdin's Avatar
Postovi: 180
Spigen i Ringke sam gledao.
Spigen ima za A40, Ringke nema.
Poetic, nikad čuo.. ajd baš ću pogledati malo i njih.
A gdje naručujete spigen, ringke i poetic?
Izravno na njihovom dućanu na netu? Jer vidio sam da Ringke ide iz USA, a Spigen ima u UK za EU, no poštarina je malo poveća koliko sam vidio..
Staro 19.08.2019., 19:10   #1020
android-split
Postovi: 1,044
Sve sta ti dolazi iz sad-a dođe ti jako brzo (manje više). Vjerojatno za puno proizvođaca maski nisi cuo ako nisi za poetic znao. Vrs, uag, tudia, patchworks, spigen, poetic, ringke, caseology, supcase, i-blason, speck, vena,.....
Poetic i ringke ces nac na ebayu i nije ti neka postarina. Naravno sta je uređaj bolji, veci je i izbor. Ne radi svaka firma maske za sve mobitele. Tako da ces za a40 teže nac nego za s10e
Poetic s10e: https://www.poeticcases.com/collecti...alaxy-s10-lite
Zadnje izmijenjeno od: android-split. 19.08.2019. u 19:16.
