#61 |
Datum registracije: Aug 2017
Postovi: 1,227
Hakom otvorio natječaj proširenje radiofrekvencijskg (RF) spektara 1965-1980/2110-2170MHz http://www.poslovni.hr/tehnologija/h...il-eura-348637 Prilika za za Tele2 i A1 samo tko će više otvoriti buksu?? |
#63 |
Lokacija: doma
Postovi: 2,886
trebaš seedbox? |
#66 |
Lokacija: doma
Postovi: 2,886
I jel ko fleshao ovaj iz Tele2 B525s-23a sa kakvim drugim fw ?
trebaš seedbox? |
#67 |
Datum registracije: Aug 2013
Postovi: 4,316
#68 |
Lokacija: doma
Postovi: 2,886
trebaš seedbox? |
#69 | ||
Postovi: 111
![]() Citiraj:
1. Extract B525.zip in Desktop for what's in the video to do or easy to follow. 2. Open ADB DRIVERS folder. 3. Right click DriverSetup.exe and run as administrator. 4. Check with the task manager if the DriverSetup.exe process is still in progress, when it is lost means that it is finished mainstall. 5. Go back to the B525 folder, then open the HUAWEI DRIVERS folder. 6. Right click DriverSetup.exe and run as administrator. 7. Check the task manager if the DriverSetup.exe process is still in progress, when it is lost means that it is finished mainstall. Note: If you are a Windows 10 user, open usbfix.reg in the B525 folder to correct the drivers error. 8. Prepare the modem, attach the 1 and 2 soldered in front of the modem. 9. Plug the adapter together when the 1 and 2 are soldered in front of the modem. 10. When the modem does not shine, it means that your glue sticks to 1 and 2 are soldered in front of the modem. You can delete your attachment. 11. When it is sunny, repeat the instruction 8-10. When not shaking, proceed to step number 12. 12. Plug the USB to USB connector into the modem and the computer. 13. Open device manager and icheck on ports when Huawei Mobile Connect appears. 14. Open B525s-65a_Balong_USB_Loader_1.0.1.10.exe and wait 100%. 15. When 100% is and the modem is shine. Check device manager and ports if the ports of the huawei are three. Note: Before you can proceed to the next step, make sure that the 3 ports are set to the device manager. 16. Open the B525s-23a_Update_11.190.65.00.00_AT_04.01.exe. 17. Click the start. 18. When the Ready to download program is out, do not switch the computer or connect the modem to computer to avoid having a flashing problem. 19. When the flash is over, all the leds are flashing. Remove the USB to USB connector. 20. When a wifi signal has been established, the adapter is dropped into the modem. 21. Repeat the 8-15 process. 22. Open the B525s-65a_11.190.61.00.372_Huawei_RELOADED_v2_2019.exe 23. When the flash is over, all the leds are flashing. Remove the USB to USB connector. 24. Reset the modem by holding button on the back of the modem. Na linku je sve potrebno za flash, lozinka je huawei http://tiny.cc/8mt24y Evo i LTE Watch koji funkcionira sa routerom http://tiny.cc/lte_watch Zadnje izmijenjeno od: icanic. 11.04.2019. u 19:51. |
#70 |
Datum registracije: May 2019
Postovi: 14
Vidim da ima ovdje znalaca pa pitanje za nekog od njih ako je probao ili zna. Imam 3G/4G Router D-Link DWR 921. Kad ga smjestim u najvišu točku potkrovlja na A1 kartici iman LTE od 85-93% a na Tele 2 kartici od 23-38% Kad ga stavim van (iznad krova) na A1 imam LTE 100% a Tele 2 LTE od 55-67% Moje pitanje i ideja, s obzirom imam tu mogučnost, mislio sam staviti Router ispod krova a s obzirom da se njegove antene daju skinuti mislio sam kupiti dva SMA kabla po maksimalo 2 metra dužine, skinuti njegove antene (kod DWR-a 921 obje su LTE antene) te ih izvući van na neki nosač kako bih imao bolji signal, tj. stalno u mogućem maksimumu. Pišem u % jer mi Router kad se logiram u postavke pokazuje postotak signala a ne db Bili to funkcioniralo? Zadnje izmijenjeno od: kakav takav. 07.07.2019. u 21:27. Razlog: Zaboravio nešto napisati |
#71 | |
Datum registracije: Sep 2017
Postovi: 1,425
#72 |
Postovi: 14
#73 |
Datum registracije: Feb 2010
Lokacija: Ploče
Postovi: 1,183
Kad se antene izvuku van objekta može se dobiti i preko 20dBm bolji prijem .... ali nije to sve zbog dobitka (dBi) antene nego većinom do otvorenije pozicije prema mobilnoj postaji. Koaks ako je 3mm (RG174) guši oko -2dB po metru a oni od 5mm (RG58) oko -1dB po metru. Ako imaš -3dB znači da gubiš pola signala na prijemu i predaji. Ima koaksijalnih kablova kvalitetnijih (manje gušenje na višim freq.) ako se radi o većim dužinama koje nemožeš izbjeći. |
