Povratak   PC Ekspert Forum > Računala > Software > Web dizajn, programiranje i ostalo
Staro 30.05.2019., 14:30   #1
estugarda
"Samo vodu ne!"
estugarda's Avatar
Lokacija: ZG istok > Legrad
Postovi: 1,744
ALT + code za hrvatsku tipkovnicu
Ima li tko možda kakav link za popis "alt + XXXX" kodova tipkovnice za Hrvatski?
Konkretno recimo "Ø". Na ENG je "alt+0216". Na HRV nije.
It just works. Except when it doesn't.
CPU: AMD Ryzen9 7950X3D @ stock + AC Liquid Freezer II 360
MBO: Asus ProArt X670E-Creator WiFi
RAM: 4x32GB DDR5 G.Skill Trident Z5 Neo 6000
GPU1: NVIDIA GeForce RTX 4090 MSI Suprim Liquid X
GPU2: NVIDIA RTX A4000 custom cooled
SSD1: Samsung 990 PRO 2TB m.2 NVMe
SSD2: Samsung 970 EVO 4TB
PSU: Seasonic Prime GX-1300
CASE: Fractal Design Meshify 2 XL
Display: Asus Proart PA329CRV + 2x Dell 2715h
Audio: Asus Xonar U7 MK2 + Logitech X-530 5.1
Input: Ducky One 3 Classic RGB + Logitech MX Master 3
OS: Windows 11 Pro x64
HP Zbook 17 G6
CPU: i7-9850H @ 2.60GHz
RAM: 4x16GB DDR4 2400
GPU: NVIDIA Quadro RTX 4000
SSD: 512GB NVME SSD
Audio: Fiio Q1 DAC + AudioTechnica M50x
OS: Windows 10 Pro x64
CPU: AMD Ryzen Threadripper 2950X @ stock + Noctua NH-U12S
MBO: Gigabyte X399 Aorus Pro
RAM: 4x16GB DDR4 Corsair Vengance LPX 3200
GPU: NVIDIA GeForce RTX 1080 Ti 11GB
SSD: Samsung Evo Plus 500 m.2 NVMe
HDD: Toshiba 3TB
PSU: Corsair CX650M
CASE: Fractal Design Meshify C
Display: LG IPS231P
Audio: OnBoard + display speakers
Input: Microsoft Natural Keyboard + Logitech G602
CPU: AMD Ryzen 4350G @2.8GHz + AMD stock cooler
MBO: ASrock B550m Phantom Gaming
RAM: GSkill 2x8GB DDR4 3600MHz
GPU: AMD Vega 6
SSD: Samsung Evo Plus M.2 NVME 250GB
PSU: Seasonic 620W
CASE: Fractal Core 2300
Display: 32" LCD TV + BENQ W1070 DLP projector
Sound: Yamaha RX481 + ELAC Cinema 5.1
Input: Logitech vulgaris
CPU: AMD Athlon X2 5050e @0.8-2.6GHz + AC Freezer 64 Pro PWM
MBO: Gigabyte GA-M720-US3
RAM: Kingmax 2x2GB DDR2 800MHz
GPU: Gigabyte GeForce 8600 GTS SP
HDD: Seagate 7200.10 250GB single platter (Speedy Gonzales)
PSU: Chieftec 400W
CASE: Frontier generic
Display: 22" LCD AOC 2230Hf + ACER X1160 DLP projector
Sound: Logitech S-220 2.1
OS: Windows 8.1 PRO x64
2017: FX-8370E, ASRock 990FX Extreme3, nVidia GTX970, Windows 10 x64
2016: FX-8320E, Asus M5A97 PRO, nVidia GTX970, Windows 10 x64
2015: i7 6700k, Asus Z170-A, nVidia 750Ti 4GB, Windows 7 x64
2014: FX-8350, ASRock 990FX Extreme3, nVidia GTX660, Windows 8.1 x64
2012: i7 3610QM, Asus N76VZ, nVidia GT650M, Windows 7 x64
2011: AMD Athlon II X4 640, Gigabyte MA770-UD3, nVidia 9600GS, Windows 7 x64
2010: AMD Phenom II X6 1090T, Thuban, ASrock 880G Extreme3, nVidia GTX260, Windows 7 x64
2010: AMD Phenom II X4 Deneb 945, Gigabyte 790X-DS4, nVidia 8800GTS Ultra 320bit, Windows 7 x64
2009: Intel C2Q Q6600, GIGABYTE EP31, nVidia 8600GS, Windows 7 x64
2008: AMD Athlon X2 Winsdor 5600+ AM2, MSI K9N Neo V3, Gigabyte 790x, nVidia 8600GS, Windows Vista x64
2008: Intel Core2Duo T7200, Toshiba A100-847, nVidia 7600 Go, Windows Vista x64
2007: AMD Athlon X2 4600+ Manchester S939, ASUS A8n32-SLI Deluxe, nVidia 7600GT, Windows Vista x64
2005: AMD Athlon 64 3200+ Venice S939, Asus A8V Deluxe, ATI Radeon X700 PRO, Windows XP x64
2003: AMD Athlon XP 2400+ Thoroughbred, Matsonic MS8137C, Matrox G450, Windows XP
2003: Intel Pentium III Mobile 1000 Tualatin, Compaq Evo N110, ATI RAGE LT Pro, Windows 2000
2002: AMD Duron 1200, Matsonic MS8127C, Matrox G450, Windows XP
2001: AMD Duron 750, Matsonic MS8127C, Matrox G400 DH, SB PCI 128, Windows98,
1998: Intel Pentium II 300 Klamath, Matrox G200, SB AWE64, Windows98
1996: Intel Pentium 120, Matrox Millenium, SB AWE32, Windows95
1993: Intel i386SXSA 40MHz(turbo)
1991: Intel 286 @20Mhz
Zadnje izmijenjeno od: estugarda. 31.05.2019. u 09:12.
estugarda je offline   Reply With Quote
Staro 30.05.2019., 15:23   #2
Postovi: 23,579
Postavio si malo nedorečeno pitanje,
kada ispravno formuliraš onda će ti i Google pomoći,
tražiš odr. code page, primjera radi na "starim winsima" CP 1250,
na novima je ISO/IEC 8859-2.
https://en.wikipedia.org/wiki/Windows-1250
https://en.wikipedia.org/wiki/ISO/IEC_8859-2
Dodatna je "zabava" ako je u igri UTF-8,
kao i pojedini font jer u nekima nemaš naših znakova ...
Staro 30.05.2019., 16:09   #3
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
A probao sam googlati sve što mi je palo na pamet.
Često moram koristiti te neke simbole, pa koristim Characters u Win7. Puno vremena bi si uštedio da mogu veći dio odraditi na tipkovnici. Danas mi problem radi Ø. Ne mogu nigdje naći ni CP 1250 ni ISO/IEC 8859-2, ani UTF-8.
Odnosno znam UTF-8; "U+00D8", ali ne znam to upisati. Font nije bitan.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Zadnje izmijenjeno od: estugarda. 30.05.2019. u 22:32.
Staro 30.05.2019., 16:31   #4
Postovi: 23,579
Tražiš ovaj posebni R ili fi ?
Šta ti daje Alt + 0216 ?
Bitan je font, jer u nekom dobiješ taj posebni Ř a u drugom fi.
Staro 30.05.2019., 17:55   #5
mann
mann's Avatar
Postovi: 2,230
Ja uvijek po ovome radim http://www.asciitable.com Ako ga tu vidis lupi alt i tri broja
Staro 30.05.2019., 22:24   #6
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Autor Nikky Pregled postova
"Posebni Ř" dobijem sa "Alt + 0216" kad mi je input tipkovnica u Win7/10 na HRV. Ako je tipkovnica na ENG; onda dobijem "Ø" ilitiga grčko PHI.
Dakle, na ENG tipkovnici nikakvih problema. Samo na HRV je očito drugi code.
Autor mann Pregled postova
Meni ne pomaže.
ALT+237 bi po ovome trebao biti PHI, ali ispadne mi "Ý".
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Zadnje izmijenjeno od: estugarda. 30.05.2019. u 22:31.
Staro 15.08.2019., 21:46   #7
Did58
Did58's Avatar
Datum registracije: Mar 2017
Postovi: 74
Do kôda se lako može doći u Wordu:
Kopiranjem/upisom nekog znaka/slova u Word pa odmah nakon toga (bez razmaka) Alt+X dobije se kôd tog znaka koji se s ALT+X obratno pretvara u znak, npr:
Ô pa ALT+X je 00D4 i obratno 00D4 pa ALT+X je Ô
ô pa ALT+X je 00F4 i obratno 00F4 pa ALT+X je ô itd.
Za Unicode u polje za pretraživanje (Win 10) upisati: charmap (Character Map/Karta znakova). U Word za primjer upisati: U+0021 pa odmah (bez razmaka) pritiskom tipki ALT+X daje znak ! (uskličnik).
Windows 7 Karta znakova: Start - All Programs - Accessories - System Tools - Character Map
Napomena: "Charmap" neće prikazati sve Alt kôdove, samo neke.
Alt + Codes link: https://www.alt-codes.net/
Zadnje izmijenjeno od: Did58. 15.08.2019. u 22:38. Razlog: EDIT
Did58 je offline   Reply With Quote
