#3001 | |
Lokacija: n/a
Postovi: 1,258
ako su Asus, Gigabyte i ASRock izdali nove BIOS-e, izdat ce ih i MSI. |
#3003 | |
Lokacija: n/a
Postovi: 1,258
evo update-a, od istog tipa koji je zapoceo cijelu dramu: https://www.reddit.com/r/Amd/comment...upport_update/ Citiraj:
treba se TPU sad malo posut pepelom ![]() https://www.techpowerup.com/254669/m...s-motherboards Zadnje izmijenjeno od: nathan.fake. 16.04.2019. u 19:59. |
#3004 |
Postovi: 14,584
Kao što rekoh nesporazum/dezinformacija. Jer ništa drugo nema logike. Kog bi oni sa takvom "forom" natjerali na kupovinu nove MSI AM4 ploče? Student iz supporta zajebao i to je to. Kao da netko njemu nešto govori o nadolazećim procesorima i top secret testiranjima... |
#3006 |
Postovi: 14,584
Ma to je smrdilo svatkome tko je iole upućen, no što reče nathan.fake kad preneseš takvu bombastičnu vijest imaš 10-20 puta više klikova i komentara nego inače. Recimo wccftech se uopće nije upecao na to, dok TPU po već koji put ispada veće žutilo. No unatoč tome mislim da je odličan site... |
#3007 |
Zlu ne trebalo, kontaktiro ja Azuz: Dear Asus Valued Customer, * Thank you for contacting Asus, my name is *** and I will try my best to assist you with your current situation. * Regarding the below described case, we kindly invite you to keep updated the BIOS version of your product to the latest BIOS version available at the product's support page at Asus website https://www.asus.com/us/Motherboards...Desk_Download/ Once new processors are tested officially by Asus with your product they shall be listed at the CPU support list available at the product's support page at Asus website https://www.asus.com/us/Motherboards.../HelpDesk_CPU/ Please check Asus website periodically. * In case you are not satisfied by our reply above, please inform us accordingly before filling the satisfaction form. In case you are satisfied by our reply above, we invite you to select 9 or 10 as a positive evaluation. * * Should you have any further questions, please do not hesitate to get back in touch with us. * Kind regards Sent from S7 Presidency Phone |
#3009 | |
Postovi: 8,356
#3010 |
Postovi: 14,584
Kažem, ta priča sa "tjeranjem" na nove ploče im nebi prošla (ako su slučajno i to pokušavali) jer bi ostali izolirani u tom pokušaju. Što bi netko kog je MSI izjebao sa supportom (dok svi drugi vendori nebi) rekao - hej MSI me sjebao - idem kupiti novu AM4 ploču od MSI. How yes no... Da meni naprave takav bezobrazluk prekrižio bi ih za sva vremena kao firmu. Nebi usb od njih kupio... |
#3011 | ||||
Lokacija: n/a
Postovi: 1,258
osim toga, kad neko nadogradi CPU, stari CPU obicno proda/pokloni nekom, taj CPU ponovo treba MBO... znaci dok je CPU-a bit ce i prodaje MBO-a ![]() plus to sto MBO znaju krepat, CPU rijetko, znaci potraznje za MBO uvijek ima. ako AMD vec garantira kompatibilnost, jednostavnije je nadogradit BIOS-e i imat zadovoljne kupce, jer zadovoljan kupac ce preporucit/prodat tvoj brand drugima... Citiraj:
takve stvari se ne mogu promjenit preko noci, roadmap je postojao mjesecima, ali nije bio za javnost... zasto i bi, svi su pod NDA.edit: e da, MSI 300 ploce nece dobit update na "AM4 ComboPI 0.0.7.2", nego ce odmah dobit "AM4 ComboPI 1.0.0.0" ![]() AM4 ComboPI 0.0.7.2 je mikrokod za nadolazece 3000 APU-e (ZEN+) AM4 ComboPI 1.0.0.0 je za nadolazece 3000 CPU-e (Zen 2) Citiraj:
![]() Citiraj:
osim toga, kad neko nadogradi CPU, stari CPU obicno proda/pokloni nekom, taj CPU ponovo treba MBO... znaci dok je CPU-a bit ce i prodaje MBO-a ![]() plus to sto MBO znaju krepat, CPU rijetko, znaci potraznje za MBO uvijek ima. ako AMD vec garantira kompatibilnost, jednostavnije je nadogradit BIOS-e i imat zadovoljne kupce, jer zadovoljan kupac ce preporucit/prodat tvoj brand drugima... Zadnje izmijenjeno od: nathan.fake. 17.04.2019. u 11:37. |
#3012 |
Postovi: 375
Evo, izašao je službeno i BIOS za gigabyte ax370 gaming 5 sa ryzen 3000 podrškom. Problem veličine BIOSa koji se spominjao su riješili na način "Due to BIOS ROM size limited, no Bristol Ridge APU support". |
#3013 |
Postovi: 1,521
Prvo želim svima Sretan Uskrs! Drugo imam sljedeći problem, otkada sam zamjenio staru asrock ab350m hdv sa novom asrock b450m pro4 javlja mi se random freeze računala barem jednom dnevno i to kod nekih nezahtjevnih radnji tipa surfanje po web browseru dok u igrama nikakvih problema nisam imao. Naime čim sam kupio matičnu u slotovima a1 i b1 corsair aegis nije htio raditi u xmp profilu na deklariranih 3000mhz, to sam riješio na način da sam ubacio module u a2 i b2 gdje radi xmp profil na deklariranih 3000mhz pri 1.35 V. Ali mi se konstantno javlja problem da se računalo smrzne, monitor singaliizira "no singal" i jedino restart kompa pomaže. E sad ja već dogovorio da ode ploča na servis ali sam pomislio da nije možda do Aegisa, ima li netko navedenu ploču u kombinaciji s tim ramom i kako radi? Da ne ostajem bzveze bez ploče ako je ram u pitanju, na staroj asrock ab350m hdv koja je slabija radilo sve bez problema pa sam zato odmah i posumnjao u ploču. |
#3015 |
Postovi: 1,521
Baš sam danas i stavio u biosu sve na default da vidim kako će se ponašati. Sad je ram na 2133 pa ću vidjeti, prvi put priželjkujem da se smrzne jer znači da nije do rama, ako je onda sam u banani jer mi za ryzena treba što brži ram ,a ne da radi na 2133mhz. |
#3016 |
Overclocker
Datum registracije: Nov 2016
Postovi: 523
Umjesto čekanja random freeza, testiraj ram nekim od stress programa pa ako je to problem, isprobaj nešto veći napon, možda 2933mhz i/ili opusti pojedine latencije. Nisu 3000 i 2133 jedine opcije. |
#3017 |
Postovi: 1,521
Kontam da nisu, ali uzeo sam ram koji treba raditi na 3000mhz pa zelim da mi radi kako je navedeno da treba a ne se zezati s vecim naponom da bi dobio performanse koje trebaju biti na stocku, sad je na 2133 jer je to default po biosu, ako tu dodje do smrzavanja onda je definitivno maticna u pitanju sto mi je odlicno jer ju saljem na servis i gotovo,ako je ram moram ga mijenjati jer je prije 3 tjedna na lošijoj ploči radio na 3000mhz bez problema tako da nije pokvaren. Fora je sto ga nema na support listi pa me strah da nisu kompatibilni memorija i ploča, ali opet nema ga ni za staru ploču pa je radilo. |
#3018 |
Postovi: 2,138
Mislim da nije ni do rama ni do ploce i da su ti oboje ispravni. Trebas rucno podesiti "advnaced" postavke za ram u biosu. Bilo je ovdje vec linkova, ako ih ne nadjes proguglaj malo za tvoj ram i plocu, podosta samsiguran da ti nova ploca po defaultu stavi neku zategnutiju opciju od stare i zato ti se rusi komp. Memtest+igranje sa postavkama i deri
#3020 |
hvala, i tebi! vec sam se zabrinuo da ovdje nema katolika da su svi metalci. cak i ako smrzne na 2133mhz opet moze biti do rama, jednostavno iskvaren ram, testiraj windows memory diagnostic toolom https://www.techrepublic.com/article...agnostic-tool/ |
#3021 | |||
Postovi: 1,521
Ma sve je po defaultu kako je deklarirano od proizvođača rama, znači 3000mhz na 1.35 v 16-18-18-38, tako je radilo i na staroj matičnoj bez problema. Citiraj:
Jesi li imao problem sa slotovima, meni u A1 i B1 nije htio bootati windows na 3000 mhz, tek kada sam stavio u A2 i B2 i od onda imam ovaj problem sa smrzavanjem. Citiraj:
Daleko sam ja od velikog katolika i vjernika, ali poštujem i red je čestitati ![]() Odvrtio sam testove na defaultu i na 3000 mhz i nije detektiran niti jedan problem za memoriju. Doduše nakon završenog testa na 3000 mhz prilikom restarta se opet računalo smrznulo i morao sam ga manualno restartirati, dok na 2133 se to nije dogodilo. Event Viewer niti u jednom slučaju nije pokazao errore za memoriju, dok je detekrirao Critical error na Kernel power i error na Distributed COM. Sad ne znam ni sam više, iako mi ovo "Kernel power " smrdi na matičnu. |
#3022 |
Postovi: 323
Ništa stari,meni su u Uziju stavili na a2 i b2 odma kod slaganja i radi ko vurica. Negde sam na netu pročital da za dual channel kod B450(ili ryzena?) samo šljakaju drugi ram slotovi kak se spada. True or false,neam pojma,samo znam da nikakvih problema nemam. |
#3023 | |
Drugo pitanje: jesi li testirao RAM sa memtestom sa TechPowerUpa (treba ti USB stick, odličan tool za kreiranje butabilca ima, butaš stick i memtest odradi svoje? Treće pitanje: koliko ti pada napon na tih 1.35V? Stavi na 1.4V. Sent from my SM-G965F using Tapatalk |
#3024 |
Lokacija: TU
Postovi: 27
Sretan Uskrs! @slavonac90 Imam istu ploču samo je ram patriot 2800. Isti problem kao i kod tebe sam riješio tako što sam oćistio cmos ali bez ram-a. |
#3025 |
Postovi: 1,521
Zadnji BIOS je gore, ram testiran samo preko Windows Memory Diganostic toola, što se tiče napona nisam pratio kako se ponaša kod memorije, sada gledam u Cpuid HW monitor i nigdje ni ne vidim da mi pokazuje napon rama, probao sam vaditi bateriju iz matične još kada sam skontao da neće bootati dok je ram u A1 i B1 slotovima,a prebacio u druga dva i sada radi an 3000 mhz kako i treba ali uz smrzavanje računala i crni ekran. Probam još memtest odvriti, nego dal da ga vrtim na bios defaultu od 2133mhz pri 1.2V ili kako je memorija deklarirana za 3000mhz? |
#3027 |
Postovi: 2,138
@slavonac to sto je na defaultu ne znaci nuzno da je to dobar setting za tvoj ram, kazem ti fino guglaj svoj ram za ryzen 2xxx i lupi custom settingse koje ekipa pise po forumima
#3029 |
Kad ljudima kažem da se klone tih Asrockovih Pro4 malokalibarki, ispadam fanboj i dobivam odgovore "nemaju svi para za C6H kenj kenj". Pa dobro onda, i dalje preporučujte te ploče koje su se pokazale kao NAJGORE čak i na ovom forumu, od DOA primjeraka do mušičavosti u radu. Uživajte i sretno u traženju problema. Sent from my SM-G965F using Tapatalk |
#3030 |
Postovi: 1,521
Slažem se s tobom, ja sam gledao naravno da prođem što jeftinije i eto obilo mi se o glavu, na kraju mi ispadne bolja asrock ab350m hdv koja je još jetinija i ne podržava ryzen 1600x na službenoj stranici,što je bio i razlog prelaska na b450m pro4 nego ova. Ubuduće se klonim asrocka i to je to, čak razmišljam da ako utvrde kvar zatražim drugu matičnu uz moju nadoplatu, neku gigabyte ili asus i gotovo. |
