Lokacija: Velika Gorica
Postovi: 59
tromi windozi
12/29/2005 2:52:15 PM pHero Marko ej 12/29/2005 2:52:17 PM pHero Marko si tu? 12/29/2005 2:52:26 PM Marko pHero jesam 12/29/2005 2:52:32 PM pHero Marko e onak 12/29/2005 2:52:55 PM Marko pHero ??? 12/29/2005 2:53:02 PM pHero Marko windozi mi se sporo dižu.... 12/29/2005 2:53:08 PM pHero Marko zašto? ![]() 12/29/2005 2:53:28 PM Marko pHero windowsi ili ti se cijeli komp sporo boota 12/29/2005 2:53:58 PM pHero Marko pa ono kad idu one 3 crtice na boot screenu, meni prolaze kojih 20 puta prije neg se starta 12/29/2005 2:54:33 PM pHero Marko to mi je od početka uvijek tak 12/29/2005 2:54:36 PM pHero Marko al ne bi trebalo bit 12/29/2005 2:54:42 PM pHero Marko a64 3200+ 12/29/2005 2:54:48 PM Marko pHero samo windozi 12/29/2005 2:54:51 PM Marko pHero ili cijeli sistem 12/29/2005 2:54:55 PM Marko pHero od bootscreena 12/29/2005 2:54:57 PM Marko pHero pa nadalje 12/29/2005 2:55:17 PM pHero Marko windozi se brzo dižu 12/29/2005 2:55:24 PM pHero Marko samo na tom boot screnu 12/29/2005 2:55:31 PM Marko pHero ono kada ide loading 12/29/2005 2:55:34 PM pHero Marko da 12/29/2005 2:55:37 PM Marko pHero aha 12/29/2005 2:55:38 PM pHero Marko one 3 crtice 12/29/2005 2:55:38 PM Marko pHero hmm 12/29/2005 2:55:42 PM Marko pHero koji windozi 12/29/2005 2:55:45 PM Marko pHero xp pro 12/29/2005 2:55:48 PM pHero Marko da sp2 12/29/2005 2:55:51 PM Marko pHero obicni ili 64 bit? 12/29/2005 2:56:04 PM pHero Marko obični 12/29/2005 3:00:28 PM Marko pHero nei znao 12/29/2005 3:00:30 PM Marko pHero koliko rama imas 12/29/2005 3:00:34 PM Marko pHero i koliko particija na hardu 12/29/2005 3:00:40 PM Marko pHero i koliko hardova 12/29/2005 3:00:46 PM Marko pHero i koji sata ili ata 12/29/2005 3:00:49 PM pHero Marko 1gb corsair value 12/29/2005 3:00:50 PM pHero Marko sata 12/29/2005 3:00:54 PM pHero Marko wd 250gb 12/29/2005 3:00:56 PM pHero Marko 3 particije 12/29/2005 3:01:05 PM Marko pHero ovako 12/29/2005 3:01:15 PM Marko pHero desni klik na my computer 12/29/2005 3:01:30 PM Marko pHero properties 12/29/2005 3:01:31 PM Marko pHero advanced 12/29/2005 3:01:38 PM Marko pHero virtual memory stettings 12/29/2005 3:01:39 PM Marko pHero settings 12/29/2005 3:01:50 PM Marko pHero advanced 12/29/2005 3:01:54 PM pHero Marko ej ej 12/29/2005 3:02:06 PM Marko pHero kaj kaj 12/29/2005 3:02:10 PM pHero Marko di je virtual memory settings? 12/29/2005 3:02:17 PM Marko pHero aha 12/29/2005 3:02:21 PM Marko pHero to ti je performance setting 12/29/2005 3:02:40 PM Marko pHero pa advanced 12/29/2005 3:02:41 PM pHero Marko ... 12/29/2005 3:02:49 PM Marko pHero pa pod virtual memory 12/29/2005 3:02:51 PM Marko pHero change 12/29/2005 3:02:59 PM Marko pHero makni sa C: 12/29/2005 3:03:12 PM Marko pHero i stavi 1024-1024 na neku drugu particiju 12/29/2005 3:03:15 PM Marko pHero tj, 12/29/2005 3:03:28 PM Marko pHero makni virtualnu memoriju sa particije gdje je windows 12/29/2005 3:03:41 PM pHero Marko aha 12/29/2005 3:03:43 PM pHero Marko ok 12/29/2005 3:03:50 PM Marko pHero to je step 1 12/29/2005 3:03:52 PM pHero Marko kaj da stavim no paging file? 12/29/2005 3:04:32 PM Marko pHero da 12/29/2005 3:04:39 PM Marko pHero i onda set 12/29/2005 3:04:39 PM pHero Marko dalje.. 12/29/2005 3:04:52 PM Marko pHero pa odaberes jednu particiju koja ima najvise gb 12/29/2005 3:04:55 PM Marko pHero i stamo stavis 12/29/2005 3:04:58 PM Marko pHero 1024-1024 12/29/2005 3:05:00 PM Marko pHero custom 12/29/2005 3:05:04 PM Marko pHero pa set 12/29/2005 3:05:08 PM Marko pHero pa restart 12/29/2005 3:05:12 PM Marko pHero to je step 1 12/29/2005 3:05:30 PM pHero Marko ok 12/29/2005 3:05:52 PM pHero Marko ajd idem... 12/29/2005 3:05:57 PM pHero Marko to napravit pHero says: jesam.... pHero says: opet 29 puta prolazi... Marko says: ok Marko says: to nije ni trebalo pomoci pHero says: fino:9 Marko says: jel si instalirao drivere sve Marko says: kak se spada pHero says: valjda Marko says: to valjda znas Marko says: maticna Marko says: jooooooooj Marko says: cek Marko says: znam Marko says: i neznam pHero says: u device menađeru niš ne javlja Marko says: znam da ima veze da se nes treba iskljuciti Marko says: u biosu Marko says: a neznam kaj jer nemam sck 939 pHero says: u biosu imam milju opcija... Marko says: odi na pce ![]() pa sad....
keep it comin' |
Postovi: 12,607
Di si Marrrrrkkkkkooooooooooo?:clap:
Postovi: 59
aj dosta spama.... instaliro sam onaj bootvis i optimiziro i opet ništa, 0% brže.....ništ od toga di vidim, isključujem procese na bootu?
keep it comin' |
M.U.P.
Datum registracije: Sep 2004
Postovi: 2,277
start,raun i upuiši msconfig pogasi sve nepotrebno Isključi fast user switch, izbriši nepotrebne account,skeniraj sa antivirusom,spywareom...
Postovi: 59
ovak... na startupu imam: NVMixer tray NvCpl nwiz NvMcTray SOUNDMAN zlclient NeroCheck jusched DevDetect KHALMNPR MsnMsgr Adobe reader speed launch Logitech Setpoint Microsoft Office kaj tu ni dobro? kaj da smaknem?
keep it comin' |
M.U.P.
Postovi: 2,277
Makni ono kaj ne koristiš ja ti mogu reć da ti netreba NeroCheck MsnMsgr Microsoft Office Adobe reader speed launch Također upiši fiksni IP ako koristiš mrežu da ne traže windowsi sami svaki put Network connections/lan conection/propereties/internet protocol/propereties i upiši 192.168.000.1 Subnet mask 255.255.255.0
Datum registracije: May 2005
Lokacija: Online
Postovi: 2,404
nwiz NvMcTray , imaš ga u mišu... NeroCheck jusched DevDetect ,KHALMNPR - jel ko zna šta je ovo ?? MsnMsgr ![]() Adobe reader speed launch Logitech Setpoint Microsoft Office - ovo dvoje nisam siguran jer neznam način na koji ih ti koristiš |
Postovi: 59
defragmentiro..... ad-awareo, spyboto.... smakno sam nwiz, juscher, adobe..., nerocheck, nvmctray, msnmsgr.... i... nula bodova, ista troma uber spora brzina bootanja...
keep it comin' |
Postovi: 12,607
Pukni na viruse HiJackthis log pa ce Costa ili Atha prozborit sta da maknes i killash
Postovi: 59
šta costa, atha?? reci na hrvatskom
keep it comin' |
#12 | |
Postovi: 12,607
Postovi: 59
sve je ok... ma komp je nov, nema virusa i inih gamadi.... a64 3200+ oc na 2.8ghz 2x512 corsair value WD 250gb 7800gt trebalo bi se brzo bootat.... brijem da tromost nije zbog procesa il takvih stvari....možda u biosu nešto?? bubajte bezveze kaj bi moglo bit, il drajveri - kak da provjerim ak neki driver koči??
keep it comin' |
Pink Floyd fan
Lokacija: Santa Clara, CA
Postovi: 5,532
Pa di si phero ![]() Evo znam ja sto te muci, koliko sam shvatio tebe muci onaj dio kad se win jos ne podignu. Tako je meni isto bilo na jednoj abitici sa prelaskom na winxp. Rjesenje je bilo rucno iskljuciti ATA diskove kojih nema, jer win uporno pri bootanju pokusavaju naci disk a njega nema. To se nalazi u Device Manager-> IDE ATA/ATAPI controllers-> pa tamo ces vec naci parallel controler i samo tamo gdje nema diska stavi no device ili sto vec. Kod mene nvidida ni ne daje tu opciju. Btw koji chipset imas, meni je to radio via chipset.
#15 | |||
Lokacija: Constantinopolis
Postovi: 1,002
#16 |
Lokacija: Online
Postovi: 2,404
Fala lipa , no sad ću bar 5 dana provest na toj stranici sa servisima jer sam vidio brdo zanimljivih savjeta ![]() |
