Staro 30.01.2019., 18:28   #5281
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,753
Zaista zanimljivo stivo... Izdvojia bi samo jos jedan komentar, IMO, vrijedan paznje:
Before people get triggered at the fact that AMD even has this agreement with Global Foundry, remember that Glo Fo was AMD's manufacturing department that was spuned off because AMD needed cash to stop itself from going bankrupt.
Having said all that. Both AMD and Glo Fo are really lucky that the Zen 2 chips that will probably go gangbuster in 2019-2020 require Glo Fo's 14nm chips for the i/o, and it's entirely possible that Zen 3 chips will just move on to using the 12nm for the i/o.
This gives Glo Fo a lot of business and sales on nodes that they've already perfected in yields, so the folks who bought Glo Fo from AMD can now finally make money and even re-start the 7nm processs that was promising - but cancelled due to being a huge money sink.
Who knows, maybe Glo Fo's 7nm process will show up again as i/o die for the Zen 4/5 CPU's.
I'm happy for both companies. AMD is not known forn abandoning their partners at the drop of a hat like Nvidia or Intel, and I hope their relationship remains good.
Staro 30.01.2019., 18:44   #5282
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,589
Otkud da je ovo kao sad izmjenjeno?
Sjećam se kad sam svojevremeno čitao o tome bila je neka klauzula tipa - ako GloFo ne može AMD-u ponuditi neki ekvivalentan node (kao sada 7nm) AMD ima pravo uzeti od neke druge strane, bez ikakvih penala. Čak sam i to više puta pisao po forumu
Samo me zanima što će sada biti kad Zen2 izađe, a lntelov 14 nm +++++++++ node bude spreman odma u Q2 2020, koju će onda dealbreaker "manu" naći kao pred 2 godine? Vjerojatno priču da AMD kupuje uslugu od Tajvanaca čiji radnici rade u nehumanim uvjetima bez prava na beneficirani radni staž i prekovremene sate.
Random blentavi Youtuber: "lako je Zen2 odlična arhitektura i procesor od 300 USD je u rangu ili bolji od 2.5x skupljeg lntelovog 8c/16t procesora, napomenimo to da za proizvodnju Zen2 procesora ljudi pate."
Tada više ni singltred FTW neće biti glavni forte, nego ljucka prava.
Ok, ne mora biti tako, ali neka nebitna stavka će se naći i hajlajtati gdje se god stigne
Moj guess bi bio sljedeći: zen2 8c16t će biti bolji u velikoj većini stvari od i9 9900K, bit će jeftiniji, gro efikasniji, hladniji, bolji IPC, jedino će u clocku kaskat. Samim time će biti bolji u velikoj većini benchmarka/programa (pogotovo ako se oslanjaju na multithread, odnosno ne oslanjaju gro na clock jedne jezgre, osim ako ih baš ne ubiju u IPC). Jedino bi u 1080p gamingu (sa rtx 2080Ti naravno ) moglo biti "trading blows", ne samo zbog clocka, nego i optimizacija za intel, odnosno prednosti monolitskog, prostog cpu-a... E sad ako ispadne da je i9 9900K, odnosno i7 9700K brži u više od 50% naslova, bit će "still best gaming cpu" iz čega će proizaći da high end beskompromisni "gamer" useri daju karikiram 30,50, 60% više za 4% bolji best gaming cpu. Također masa "influencera" po youtubeu (bilo tech youtuberi, gaymeri i sl.) vjerojatno već imaju i9 9900K ili i7 9700K za gaming, samim time mogu komotno preskočiti zen2 (ako žele, oni ne moraju). Mada ako zen2 bude dobar kao što očekujemo, te se ne dogodi nešto nepredviđeno sa cijenama mislim da će biti prepoznat, hvaljen, preporučivan dominantno i sl.
Zadnje izmijenjeno od: Manuel Calavera. 30.01.2019. u 19:16.
Manuel Calavera je online   Reply With Quote
Staro 30.01.2019., 19:07   #5283
Gigi1
Postovi: 2,138
U sestoj verziji ugovora su placali mali 'penal' glofo za sve sto se radi izvan glofo, u 9.mj. (kad je bilo jasno da nista od 7nm gf)su objavili da pregovaraju sa glofo za sedmu ver. ugovora, cilj u tim pregovorima im je bio da mogu stancati kod ostalih bez ikakvih penala, vjerujem da je u zamjenu za potpunu slobodu dogovoren polaris na gf 12nm + IO die isto na gf
Staro 30.01.2019., 21:57   #5284
Gigi1
Postovi: 2,138
Malo za usporedbu
Apple Q1 Revenue: $84.3B
AMZN Q3 Revenue: $56.6B
Alphabet Q3 Revenue: $33.6B
Intel Q4 Revenue: $19.0B
Facebook Q3 Revenue: $13.7B
QCOM Q4 Revenue: $5.8B
NVIDIA Q4 Revenue: $2.20B
AMD Q4 Revenue: $1.42B
ARM Q3 Revenue: $0.46B
Staro 31.01.2019., 13:08   #5285
stef
stef's Avatar
Lokacija: Zabok
Postovi: 3,417
Ako se još netko sjeća ... ATI je AMD-a koštao $5B, netom prije nego što su izbacili "groundbraking" R600 DX10 flop . Da su se prodali nakon toga, bili bi duplo jeftiniji.
Ovo je najzdravija AMD-ova bilanca u zadnjih bar 10 godina, s vrlo dobrim prognozama za budućnost. S time da je riječ o kompaniji s podijeljenim fokusom što se tiče proizvoda, guraju top tier x86 čipove i GPU.
Srećom pa je fabless priča završila na kraju dosta pozitivno. Zbilja jesu agilniji i mogu kombinirati/žonglirati više opcija. Intel trenutno nemere . I sad ih treba šutnut dobro dok su na podu. Jer neće dugo trajat.
Zadnje izmijenjeno od: stef. 31.01.2019. u 15:04.
Staro 02.02.2019., 12:05   #5286
sakomako
Datum registracije: May 2013
Lokacija: nigdje
Postovi: 599
Ima li se što reći na ovo ili otvoriti novi PDF sa nazivom China nadolazeći socketi i procesori?
https://arstechnica.com/information-...rs/?comments=1
Ako tko zna ima li kavih benchmarka, cijena i sl?
Naravno ovo se moglo okačiti i u Intela, ali ipak im je AMD partner.
No svakako fali i podforum o kineskim CPU. Ne škodi da se ponuda proširuje!
sakomako je offline   Reply With Quote
Staro 02.02.2019., 16:18   #5287
Bubba
E Pluribus UNIX
Bubba's Avatar
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,795
Autor sakomako Pregled postova
Pa stancaju po VIA licenciji nekakve shrotove vec godinama i nitko se nesto spektakularno ne uzbudjuje zbog toga.
Zatvoreno trziste, hrpa ljudi, imas i more "specijalnih" nVidia chipova samo za njihova trzista (cini mi se neki 10x0 sa 5GB RAM-a i takve pizdarije).
I rusi su kombinirali s onim svoji Elbrusom pa se nitko nije posebno obazirao zbog toga.
Programer
Staro 02.02.2019., 20:01   #5288
thunderbird
Premijum AMDebil
thunderbird's Avatar
Lokacija: jastrebarsko
Postovi: 1,150
Kina ko tržište može sve progutati, doslovno sve.
Da netko krene štancati pentium 4 CPU-ove, tamo bi imalo prođu
X
Staro 02.02.2019., 20:17   #5289
sakomako
Lokacija: nigdje
Postovi: 599
Autor Bubba Pregled postova
Ne mislim na shrotove!
Ali mi je ovo zanimljivo:
"A chip almost identical to AMD's EPYC processor has begun to appear in China"
To je iz onog linka!
Staro 02.02.2019., 20:57   #5290
Postovi: 8,496
Baci pogled na pozadinu cijele priče.
AMD and THATIC – Tianjin Haiguang Advanced Technology Investment Co – have formed a joint venture to, in AMD's words, "develop system-on-chips tailored to the Chinese server market that will complement AMD’s own offerings." AMD has basically licensed its microprocessor technologies to THATIC, which will build chips for enterprise, data center and government buyers in China. AMD licensed its Zen processor designs to its friends in China so they can produce complete chips that are, admittedly, virtually identical to its EPYC line.
Staro 03.02.2019., 10:07   #5291
sakomako
Lokacija: nigdje
Postovi: 599
No poznavajući Kineze što možemo očekivati?
Drugo bilo bi lipo vidjeti kakve su karakteristike ovih procesora u odnosu na original?
A još lijepše imati neku naznaku o cijeni za usporedbu?
Također direktna usporedba ovih procesora u benchmarku ne bi štetila!
Staro 03.02.2019., 11:07   #5292
Bubba
E Pluribus UNIX
Bubba's Avatar
Lokacija: M82
Postovi: 6,795
Sto bi trebao ocekivati osim statisticke pogreske benchmarka na doslovno istom procesoru samo otisnutom o necijem tudjem trosku? A i cijena je tebi nebitna kad je China only...
Programer
Staro 03.02.2019., 12:47   #5293
Manuel Calavera
Postovi: 14,589
Sakomako zar ne vidiš da je to za njihovu vladu, institucije i sl. To je samo outsorsan postojeći cpu. Neće se to moći kupiti, niti je to iole relevantno za cpu tržište (ne radi se o nikakvom globalnom "trećem igraču")
Staro 04.02.2019., 09:01   #5294
tiki66
tiki
tiki66's Avatar
Postovi: 2,753
Eventualno će se pojaviti za 15 godina na aliexpressu po 5$ kad neki kinez nađe te kompove u baji i odluči sve rasprodati
Staro 05.02.2019., 20:30   #5295
Postovi: 8,496
Škot s cache nostalgijom
Staro 06.02.2019., 12:58   #5296
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,360
Nikad dosta keša
Slobodno me dodajte na PSN
Staro 12.02.2019., 12:51   #5297
Postovi: 8,496
TSMC to move 7nm EUV process to volume production in March
Taiwan Semiconductor Manufacturing Company (TSMC) is expected to kick off volume production of chips built using an enhanced 7nm with EUV node at the end of March. ASML, which provides extreme ultraviolet (EUV) litho equipment, is looking to ship a total of 30 EUV systems in 2019. Of the units to be shipped, 18 have already been reserved by TSMC. TSMC is also on track to move a newer 5nm node to risk production in the second quarter of 2019.
The foundry will fully incorporate EUV in the 5nm node. TSMC CEO CC Wei disclosed previously the foundry expects to start taping out 5nm chip designs later in the first half of 2019 and move the node to volume production in the first half of 2020. Meanwhile, TSMC continues to expand its 7nm chip client portfolio. Wei noted that the foundry's 7nm chip client portfolio is "growing stronger" as more chip designs for applications such as HPC and automotive demand the process. TSMC started volume producing 7nm chips in April 2018, with AMD, Apple, HiSilicon and Xilinx reportedly being among its major 7nm chip customers.
The foundry will soon roll out its EUV-based 7nm process, which will boost its total 7nm chip sales to account for 25% of total wafer sales this year compared with 9% in 2018.
Izvor: DigiTimes
Staro 12.02.2019., 20:13   #5298
To znači da onda kreće masovka štancanja Ryzena ili?
Sent from Usreo Mobara
Staro 12.02.2019., 21:07   #5299
Postovi: 8,496
Mislim da je već lagano i krenulo, jer Zen 2 bude koristil "običan" TSMC-ov 7nm HKMG proces, dok je ovaj EUV zapravo 7nm+, a to je pak spremno za Zen 3.
AMD Ryzen 3000 Matisse CPUs, X570 motherboards and Radeon Navi GPUs rumored for July 7 launch
New report from RedGamingTech suggests that these new mainstream processors will come to market in July. More specifically, the publication says that its sources have indicated a launch date of July 7th, 2019 (7/7/2019). It should be noted the Radeon VII launched on February 7th. The assumption is that AMD is playing up the 7nm process tech used on these new chips with these “7” dates. The above date is when the processors are expected to be publicly available, which means that AMD will likely announce them well before; perhaps at Computex 2019. Complementing the Ryzen 3000 processors will be motherboards based on AMD's X570 chipset; it's assumed that these boards will also launch on July 7th.
Although the new Ryzen 3000 processors will still work on X470 motherboards (with a firmware update), the X570 platform should bring support for PCIe 4.0 and other performance tweaks. Finally, the same report says that the first 7nm Radeon Navi mainstream GPUs will also land in early July. Navi will represent a big GPU architecture shift for AMD, and it will market the cards towards the gaming sector. Navi is also expected to underpin the graphics pipeline of upcoming consoles from Microsoft and Sony, but those announcements will likely come at a later date.
Izvor: HotHardware i Planet 3DNow!
Zadnje izmijenjeno od: The Exiled. 18.02.2019. u 21:53.
Staro 28.02.2019., 12:12   #5300
Immortalis
Slobodan leni seronja
Immortalis's Avatar
Postovi: 852
https://amp.tomshardware.com/news/as...am4,38707.html
Jos da netko hoce izbaciti i TR4 workstation plocu...
Mada, glupo mi je ovo, nema 4 PCIe slota kao sto intel ploce imaju
Staro 28.02.2019., 12:23   #5301
Lewis
Freelancer
Lewis's Avatar
Lokacija: Bilje (Osijek)
Postovi: 5,328
Svasta, Od kad je Workstation mATX ? Bit ce da su se najeli ludih gljiva pa sad "WS" stavljaju kao naljepnicu GTI na Golfa 1.6D .
Staro 01.03.2019., 17:58   #5302
hooligan.no1
matori
hooligan.no1's Avatar
Datum registracije: Feb 2011
Lokacija: ZADAR
Postovi: 175
7.7. nije daleko.
ASUS x570 high end nadolazeće ploče.
https://twitter.com/VideoCardz/statu...52708722655235
Ispada da će mini-ITX IMPACT imati vertikalni VRM ?!!
hooligan.no1 je offline   Reply With Quote
Staro 03.03.2019., 15:59   #5303
Postovi: 8,496
Singaporean retailer lists purported Ryzen 3000 pricing
Singaporean retailer Bizgram recently published a product catalog featuring some surprising newcomers: the Ryzen 3000 series. These CPUs have not been officially announced yet, although these specific model names have been leaked before. AMD has explicitly said "mid-2019" for the release date of the new CPUs, so to see a retailer already listing them is very curious, though expected when it comes to upcoming CPUs. Firstly, at this stage, it's unlikely prices have been finalized down to the dollar (and the prices are in Singaporean dollars, by the way). More interesting are the CPUs listed, which are identical not only in name but also in the order listed in AdoredTV's leak last year. Everyone would like for this rumor to be true, but given how little AMD has talked about Ryzen 3000, it's hard to make any sort of judgment at this stage.
Izvor: Tom's Hardware
Staro 03.03.2019., 17:56   #5304
Dottore
Dottore's Avatar
Postovi: 7,696
Autor hooligan.no1 Pregled postova
7.7. nije daleko.
Imaju pogrešne izvore. Naziv ploča već postoje u Z170
primjer https://www.asus.com/us/Motherboards...S-VIII-IMPACT/
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 03.03.2019., 18:48   #5305
Manuel Calavera
Postovi: 14,589
Ali nije x570 rog crosshair, nego Z170 maximums, tako da ne mora biti prepreka
Staro 03.03.2019., 19:57   #5306
Autor Dottore Pregled postova
Crosshair je flagship AMD serija ploča. Ne brini
Staro 03.03.2019., 21:33   #5307
stef
stef's Avatar
Lokacija: Zabok
Postovi: 3,417
Autor Lewis Pregled postova
IPMI port, management modul i podrška za ECC memaru. To po definciji je WS/server ploča.
Staro 03.03.2019., 23:29   #5308
silver_tip
silver_tip's Avatar
Lokacija: doma
Postovi: 2,907
Zanimljivo je kako apsolutno nema nikakve racunice kupovati discrete grafiku tko uzima Ryzen 3 3x ili Ryzen 5 3x, ista je ~30$ kada pogleds cjene ostalih procosora u istoj seriji.
Naravno, onome tko se ne igra. Neka zvace 4k uredno i dobar cooler i prst u uvo. Jedan ventilator manje iliti grijace tjelo u kompu....
trebaš seedbox?
Staro 03.03.2019., 23:52   #5309
Dottore
Dottore's Avatar
Postovi: 7,696
Niste shvatili, radi se o rimskim brojevima. To bi moglo zbuniti
Ok je, navikao sam zapamtiti brojčane oznake od Intela (zadnje XI)
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 03.03.2019., 23:59   #5310
Manuel Calavera
Postovi: 14,589
Svejedno ne vidim što je sporno, ne radi se o istim pločama. Crosshair je na x370 bila VI, na X470 je VII, a na X570 će očito biti VIII. Ne može postojati eksluziva na broj
