Staro 06.01.2019., 17:15   #4501
Smartic
Smartic's Avatar
Datum registracije: Mar 2011
Postovi: 2,707
SSD ADATA 240GB SU650, ASU650SS-240GT-R, 2.5", SATA3, 36MJ
CPU AMD Ryzen 5-1600X (3.6GHz do 4GHz, 19MB (3MB+16MB), C/T: 6/12, AM4, 95W), 36mj
DDR4 16GB (2x8GB), DDR4 3000, CL16, DIMM 288-pin, G.Skill F4-3000C16D-16GISB, 36mj
CPU COOLER ENERMAX ETS-N31-02, 1X FAN 92MM, AM4, S1151
MB ASRock B450 Gaming K4, AM4, ATX, 4x DDR4, AMD B450, S3 6x, DP, VGA, HDMI, 24mj (90-MXB8A0-A0UAYZ)
HDD WD 1TB, Blue, (3.5", 64MB, 7200, SATA3), WD10EZEX
Seasonic 520W M12II Bronze Evo SS-520GM2, ATX, 120mm, 80 plus Bronze, PCIe VGA 8p 2x, EPS, SATA 6x, Molex 5x, Modularno, 36mj
VGA Inno3D GTX1070 iChill X3 V2, nVidia GeForce GTX 1070, 8GB, do 1771MHz, DP, DVI-D 2x, HDMI, 24mj (C107C3-3SDN-P5DSX)
Monitor Acer 23.8", Nitro, RG240Ybmiix, 1920x1080, LCD LED, IPS, 1ms, 178/178o, VGA, HDMI 2x, Zvučnici, crna, Freesync, 24mj, (UM.QR0EE.009)
Kućište Sharkoon M25-V, crna, ATX, 12mj (4044951019311)
8.563,99Kn
Staro 06.01.2019., 17:31   #4502
Doc
Postovi: 430
Autor Rataratira Pregled postova
Pozdrav,
Kupuje se komp nećaku za rođendan (12g), namjena gaming (Fortnite, PUBG...) pa molim za par prijedloga.
Budget 8-8,5k, potreban i monitor i da je sve iz jednog dućana.
Hvala!
1 x Procesor AMD Ryzen 5 2600 (6C/12T, 3.9GHz,19MB,65W,AM4)
1 x Maticna GIGABYTE B450M GAMING, 2xDDR4, S.AM4
2 x G.Skill Aegis 8GB DDR4 3000MhZ
1 x Inno3D Video Card GeForce GTX 1070 iChill X4
1 x SSD Adata 120GB SU650 SATA 3D Nand
1 x Toshiba P300 1TB, 64MB, 7200rpm
1 x Fortron napajanje Hexa 85+ 550W, 80+ Bronze
1 x Zalman S2 mid tower case
1 x Monitor Samsung LS24F350FHUX, PLS, FreeSync
Ukupno: 8.754,00 Kn - 2% popusta = 8570kn, slaganje i dostava u cijeni.
Doc je offline   Reply With Quote
Staro 06.01.2019., 19:53   #4503
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
1 * Monitor Samsung LS24F350FHUX, PLS, FreeSync, 4ms
1 * Procesor AMD Ryzen 5 2600 (6C/12T, 3.9GHz,19MB,65W,AM4)
1 * Hladnjak Cooler ARCTIC COOLING Freezer 33
1 * MSI B450 Tomahawk, AM4, DDR4, U3, m.2, ATX
1 * Kingston DDR4 HX Fury, 16GB (2x 8GB), 3200MHz
1 * SSD 256GB TS 110S M.2 2280 NVMe
1 * HDD TOSHIBA DT01ACA100 (3.5, 1TB, SATA III-600)
1 * XFX AMD Radeon RX 580 GTS Black Edition 8GB 256bit GDDR5, bulk + 2 Igre (The Division 2, Devil May Cry 5 ili Resident Evil 2)
1 * Fractal Edison M 650W, 80+ GOLD polu modularno
1 * Kućište Rampage Everest PRESTIGE s 4 plava ventilatora
Ukupno: 8.422,00 Kn - 2% popust za članove = 8.250,00 kn
Staro 07.01.2019., 09:51   #4504
Fishke
Datum registracije: Sep 2015
Postovi: 5
Pozdrav,
Kupujem računalo do 7.000,00kn ako može sve iz istog dućana i da je složeno.
Već sam nešto složio pa me zanima jel se treba što promjeniti. Računalo je za igranje većinom. Kućiste netreba da svjetli previše. ryzen 5 + 1060 6gb bih želio.
* MSI X470 GAMING PRO, D4, U3.1, m2, AM4
* Inno3D GeForce GTX 1060 iChill X3 6GB GDDR5 192-bit HerculeZ X3
* G.Skill Aegis 8GB DDR4 3000MhZ
* GIGABYTE SSD 240GB, 2.5, SATA III, 500MBs/420MBs, Retail
* Zalman Z3 Midi-Tower ATX kućište, bez napajanja, crno
* WESTERN DIGITAL WD10EZEX 1TB Blue
* Fortron napajanje Hexa 85+ 550W, 80+ Bronze, ATX
To je zajedno malo manje od 7k.
Hvala!
Fishke je offline   Reply With Quote
Staro 07.01.2019., 09:58   #4505
Doc
Postovi: 430
Dobro je to složeno.
Staro 07.01.2019., 10:37   #4506
Smartic
Smartic's Avatar
Postovi: 2,707
Može se i bolje, samo 8GB RAMa u konfi od 7k?
CPU AMD RYZEN 5-2600 (3.4GHZ DO 3.9GHZ, 19MB (3MB+16MB), C/T: 6/12, AM4, COOLER, 65W), 36MJ
SEASONIC 520W M12II BRONZE EVO SS-520GM2, ATX, 120MM, 80 PLUS BRONZE, PCIE VGA 8P 2X, EPS, SATA 6X, MOLEX 5X, MODULARNO, 36MJ
KUĆIŠTE SHARKOON M25-V, CRNA, ATX, 12MJ (4044951019311)
HDD WD 1TB, BLUE, (3.5", 64MB, 7200, SATA3), WD10EZEX
VGA INNO3D GTX1070 ICHILL X3 V2, NVIDIA GEFORCE GTX 1070, 8GB, DO 1771MHZ, DP, DVI-D 2X, HDMI, 24MJ (C107C3-3SDN-P5DSX)
MB ASROCK B450M PRO4, AM4, MICRO ATX, 4X DDR4, AMD B450, S3 4X, VGA, DVI-D, HDMI, 24MJ (90-MXB8F0-A0UAYZ)
DDR4 8GB (2X4GB), DDR4 2400, CL15, DIMM 288-PIN, G.SKILL VALUE F4-2400C15D-8GNT, 36MJ
6.998,24KN
Ili se može na RX 590, 16GB RAMa i bolju ploču.
Zadnje izmijenjeno od: Smartic. 07.01.2019. u 10:55.
Staro 07.01.2019., 10:42   #4507
Doc
Postovi: 430
Da, na prvu sam vidio da piše 2 x al to je zvjezdica. Uzmi obavezno još 8GB rama, a ako premašuje budžet smanji ploču na MSI B450 Tomahawk.
Staro 07.01.2019., 10:59   #4508
Smartic
Smartic's Avatar
Postovi: 2,707
Btw. X470 Gaming Pro je bacanje novaca. Loši hladnjaci, loš BIOS za X470 ploču, isti VRM kao B450 ploče, samo s dupliranim komponentama koje gotovo ništa ne donose u smislu efikasnosti.
Staro 07.01.2019., 11:36   #4509
Fishke
Postovi: 5
Hvala na odgovoru.
Možete samo staviti i tu konfiguraciju sa RX 590, 16GB RAMa i boljom pločom.
Staro 07.01.2019., 12:17   #4510
Doc
Postovi: 430
1 x MSI B450 Tomahawk, AM4, DDR4, U3, m.2, ATX
1 x Kingston DDR4 HX Fury, 16GB (2x 8GB), 3200MHz
1 x XFX AMD Radeon RX 580 GTS Black Edition 8GB + 2 igre
1 x SSD 250.0 GB SAMSUNG 970 Evo NVMe M.2, MZ-V7E250BW
1 x SAMA ARMOR 550W 80PLUS GOLD
1 x Chassis INTER-TECH C-3 SAPHIR Gaming Midi Tower
Ukupno: 7.144,00 Kn -2% popusta = 7000kn, slaganje i dostava besplatni.
Staro 08.01.2019., 17:33   #4511
particle
Postovi: 45
Autor FRipper Pregled postova
Da iz istog je.
Samo da javim da je kuma naručila po predloženoj konfiguraciji, i puno se zahvaljuje...
Sent from my MI MAX 3 using Tapatalk
particle je offline   Reply With Quote
Staro 08.01.2019., 17:54   #4512
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Staro 06.02.2019., 16:57   #4513
pezo
Postovi: 22
pozdrav, molim desktop kombinaciju blize 6000kn i preporuku za neki od povoljnijih wide monitora (nije uključen u ovih 6k). ssd imam, makar je samo 120gb ne bih ga htio mjenjat jer mi je sve bitno za posao na njemu ali dolazi u obzir uzet još jedan u slučaju da se moze uklopit u ovu konfu i da nece usporavat rad jer su dva. jedna od namjena računala je vrtit nekoliko instanci emulatora od jednom s čime mi je prošla konfiguracija imala dosta problema i druge slicne multitasking zadaće, ne igram graficki prezahtjevne igre ali je zanimljivo da mi je na proslom kompu koji sam koristio za istu svrhu upravo grafa prva pregorila tak da bi i ona trebala vjerojatno bit donekle zadovoljavajuća. imam svu periferiju osim tipkovnice pa molim i neku relativno dobru tipkovnicu pokušat uklopit, po mogućnosti bezicnu ali u donjem rangu. imam i operativni sustav. hvala vam unaprijed
pezo je offline   Reply With Quote
Staro 06.02.2019., 20:55   #4514
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Što točno misliš pod "wide" monitorom?
Nešto tipa ovoga?
https://www.lg.com/hr/monitori/lg-25...de-ips-monitor
https://www.lg.com/hk_en/monitor/lg-29WK500
Konfa:
1 * AMD CPU Desktop Ryzen 7 8C/16T 1700 (3.7GHz,20MB,65W,AM4) box, with Wraith Spire 95W cooler
Sifra: YD1700BBAEBOX - 1.630,00 Kn
1 * Gigabyte B450M DS3H AMD B450, AM4, 4xDDR4, DVI-D/HDMI, 2xPCIe x16, 1xPCIe x1, 1xM.2, 4xSATA, mATX
Sifra: B450M_DS3H - 599,00 Kn
1 * Memorija GSkill Aegis 16GB (2x8) DDR4 3000MHz
Sifra: F4-3000C16D-16GISB - 1.000,00 Kn
1 * Gainward GF GTX1050Ti, 4GB GDDR5
Sifra: gai-1050ti-4g - 1.299,00 Kn
1 * Fortron napajanje Hexa 85+ 450W, 80+ Bronze, ATX
Sifra: fsp-nap-hexa85-450 - 419,00 Kn
1 * Fortron CMT 110, 1x120mm, USB3.0, crno
Sifra: fsp-cmt-110 - 299,00 Kn
1 * SSD SAMSUNG 860 QVO Basic, 1TB, MZ-76Q1T0BW, SATA 3, 2.5, 550/520 MB/s
Sifra: 051.400.626- - 1.139,00 Kn
Ukupno: 6.385,00 Kn -2% = 6.250,00 Kn
Staro 06.02.2019., 21:24   #4515
Smartic
Smartic's Avatar
Postovi: 2,707
Ovisi koje emulatore koristiš, ali za veliku većinu su bitne single-thread performanse, tako da ne bih baš stavio Ryzen 1700. Prije bih stavio 2600X, a možda i i5 8400.
AMD Ryzen 5 2600X - boxed
Intel SSD 660p Series (1.0TB, M.2 80mm PCIe 3.0 x4, 3D2, QLC) Retail Box Single Pack
Zalman S2 Midi-Tower ATX kućište, bez napajanja, crno
be quiet! System Power 9 400W
Gigabyte GA-AB350M-DS3H V2 (rev. 1.1)
ZOTAC GeForce GTX 1060 3GB AMP! Edition
6.274kn s 3% popusta
25" ultrawide nikako, visina je premala.
Zadnje izmijenjeno od: Smartic. 06.02.2019. u 21:33.
Staro 06.02.2019., 22:36   #4516
Excesse
Datum registracije: Feb 2019
Lokacija: Trogir
Postovi: 10
Pozdrav svima �� Trebao bi confu do 7k moze i minimalna odstupanja. Namjena gaming 1080p . Jedini zahtjev da je kuciste Thermaltake versa h17 s prozorom il nesto slicno ako nema navedene u webshopu. Hvala unaprijed ��
Excesse je offline   Reply With Quote
Staro 06.02.2019., 23:05   #4517
ibme74
ibme74's Avatar
Datum registracije: Jan 2013
Lokacija: Planet Zemlja
Postovi: 1,591
1 * Procesor AMD Ryzen 5 2600 (6C/12T, 3.9GHz,19MB,65W,AM4) box, Wraith Stealth
Sifra: YD2600BBAFBOX - 1.358,00 Kn
1 * Hladnjak LC-Power LC-CC-120, Intel/AMD + AM4
Sifra: lcp-hlad-lc-cc-120 - 180,00 Kn
1 * Matična GIGABYTE GA-AB350M-DS3H (S.AM4, 4xDDR4, RAID) mATX
Sifra: GA-AB350M-DS3H - 509,00 Kn
1 * Palit GF RTX2060 Gaming Pro OC, 6GB
Sifra: pal-2060-gpr-6gb - 3.100,00 Kn
1 * GIGABYTE SSD 240GB, 2.5, SATA III, 500MBs/420MBs, Retail
Sifra: GP-GSTFS31240GNTD - 289,00 Kn
1 * Tvrdi Disk Toshiba P300 1TB 3.5
Sifra: 0140635 - 349,00 Kn
1 * Fortron napajanje Hexa 85+ 550W, 80+ Bronze, ATX
Sifra: fsp-nap-hexa85-550 - 469,00 Kn
1 * Kućište Thermaltake Versa H17 s prozorom
Sifra: 0151463 - 330,00 Kn
Ukupno: 7.584,00 Kn (-2%=7.430kn)
Besplatno slaganje i dostava
ibme74 je offline   Reply With Quote
Staro 06.02.2019., 23:23   #4518
pezo
Postovi: 22
hvala vam obojici. što mislite o opciji da uštedim na ssdu pošto ga već imam (moj prvi post) i uzmem hdd za skladištenje igara pa da pojačamo nešto drugo? ima li to smisla?
@FRipper
da, mislim na tak nešto što se tiče monitora. jesu li to dva koje predlazes?
@smartic
"25" ultrawide nikako, visina je premala."
što točno misliš pod ovim? svakako sam mislio 30+ dijagonalu, dva koja je posto prije tebe mozes birat dijagonalu
koristim nox i momo za android
Zadnje izmijenjeno od: pezo. 06.02.2019. u 23:53.
Staro 07.02.2019., 08:16   #4519
Excesse
Lokacija: Trogir
Postovi: 10
Pc parts izbacuje da nije kompaktibilna mb i cpu. Ako moze blize 7k ��
Staro 07.02.2019., 08:46   #4520
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,584
Kompatibilna je. Za b350 je bio potreban samo bios update, a sad se u pravilu prodaju sa novijim biosima
Čak i da nema novi bios ionako imaš besplatno sastavljanje tj. oni bi ga updejtali
Staro 07.02.2019., 09:18   #4521
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Autor Excesse Pregled postova
Makni hladnjak i stavi 120gb ssd i to je to.
Staro 07.02.2019., 09:40   #4522
Excesse
Lokacija: Trogir
Postovi: 10
Hvala puno ekipa. Moze link odakle je slozena pa da narucim danas sutra.
Staro 07.02.2019., 16:25   #4523
dioxzustar
Lokacija: gornja stubica
Postovi: 8
pozdrav, trebao bih racunalo za igrice...znaci samo kuciste i monitor....do 6000 kuna...odmah mi dajte link s stranicom s koje da narucim ako nije problem...hvala unaprijed.
dioxzustar je offline   Reply With Quote
Staro 07.02.2019., 17:01   #4524
ibme74
ibme74's Avatar
Postovi: 1,591
2 * Ventilator ARCTIC COOLING F12, 120mm, 1350 okr/min
Sifra: 050.908.169- - 90,00 Kn
1 * Patriot Viper4, 3000Mhz, 8GB (2x4GB), CL16
Sifra: pat-pv48g300c6k - 586,00 Kn
1 * SAPPHIRE AMD Radeon PULSE RX 580 4GB GDDR5 + 2 Igre (The Division 2, Devil May Cry 5 ili Resident Evil 2)
Sifra: 11265-09-20G - 1.469,00 Kn
1 * GIGABYTE SSD 120GB
Sifra: GP-GSTFS31120GNTD - 169,00 Kn
1 * Zalman S3, 1x120mm, USB3.0
Sifra: ZAL-S3 - 250,00 Kn
1 * Monitor Samsung LS24F352FHUX PLS AMD FreeSync
Sifra: 0222994- - 899,00 Kn
Ukupno: 6.148,00 Kn (-2%=6.025kn)
U temi se ne smije o trg pa ak te zanima gdje je primjer slozen javi se na PP
Staro 07.02.2019., 19:49   #4525
Smartic
Smartic's Avatar
Postovi: 2,707
Zašto zujalice od 1350rpm i to po 45kn komad
Ovo promijeni:
1 x MS PC COOL 12cm crni ventilator za kućište
1 x Memorija 8GB (2x4) 2666MHz G.SKILL Ripjaws
1 x GIGABYTE SSD 240GB, 2.5, SATA III, 500MBs/420MBs,
1 x Napajanje SilentiumPC Supremo L2 Gold 550W
Ispada samo 10-15kn skuplje.
Staro 07.02.2019., 21:31   #4526
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Kako misliš zujalice?
F12 imaju veći protog zraka a nisu ništa bučniji...
Staro 08.02.2019., 13:19   #4527
ibme74
ibme74's Avatar
Postovi: 1,591
Autor Smartic Pregled postova
Ovo promijeni:
Odakle tebi da su to "zujalice"?
To su beet buy ventovi u tom nizem cijenovnom rangu i daleko od toga da su glasni.
Sto je jos jace napises to i onda stavis 2 najgora MS venta.
BTE zasto sporiji RAM na Ryzena?
Staro 08.02.2019., 13:42   #4528
Smartic
Smartic's Avatar
Postovi: 2,707
Hm, bazirano na nekoliko modela ventova koje sam imao/imam i kako zvuče na 1000rpm, a kako na ~1400rpm. Zujalica je možda pregrubo Ako znaš iz prve ruke za oba venta, u redu.
RAM je sporiji samo na papiru jer gore su malo bolji čipovi, a jeftiniji 70kn.
Staro 08.02.2019., 13:43   #4529
Postovi: 16,813
U svakom slučaju bi preporučio bar 240GB SSD.
Danas igre imaju i po 100GB, a uvijek je nekako kvalitetnije pokretati igre s SSD-a.
Staro 08.02.2019., 18:11   #4530
dioxzustar
Postovi: 8
znaci konfiguracija dobra...? jos umjesto 120 gb ssd stavim 240 i dobro...
znaci zadovoljavajuca konfiguracija??? jer ga danas onda kupujem....
