Staro 02.02.2019., 16:12   #10891
JopeCRO
JopeCRO's Avatar
Postovi: 9
Autor ibme74 Pregled postova
1 * AMD CPU Desktop Ryzen 3 4C/4T 1200 (3.1/3.4GHz Boost,10MB,65W,AM4) box, with Wraith Stealth cooler
Sifra: YD1200BBAEBOX - 669,00 Kn
1 * Matična GIGABYTE GA-AB350M-DS3H (S.AM4, 4xDDR4, RAID) mATX
Sifra: GA-AB350M-DS3H - 509,00 Kn
1 * MSI RX 570 Armor 8G OC , 8GB GDDR5, DX12
Sifra: msi-rx570-aroc-8g - 1.484,00 Kn
1 * GIGABYTE SSD 120GB
Sifra: GP-GSTFS31120GNTD - 169,00 Kn
1 * Tvrdi Disk Toshiba P300 1TB 3.5
Sifra: 0140635 - 349,00 Kn
1 * Fortron napajanje Hyper 600W
Sifra: fsp-nap-hyp-600 - 429,00 Kn
1 * Zalman S3, 1x120mm, USB3.0
Sifra: ZAL-S3 - 250,00 Kn
1 * Memorija Transcend 8GB JetRAM DDR4 2666 CL19 1.2V
Sifra: JM2666HLB-8G - 399,00 Kn
1 * System Fan Akyga AW-12A-BK 12cm black
Sifra: AW-12A-BK - 30,00 Kn
Ukupno: 4.288,00 Kn (-2%=4.200kn)
Besplatno slaganje i dostava
Ibme ispravak netocnog navoda... Moze konf do 4.5k
JopeCRO je offline   Reply With Quote
Staro 02.02.2019., 17:50   #10892
ibme74
ibme74's Avatar
Datum registracije: Jan 2013
Lokacija: Planet Zemlja
Postovi: 1,582
Stavi Ryzen 1400 umjesto 1200.
ibme74 je online   Reply With Quote
Staro 02.02.2019., 19:08   #10893
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
1 * HDMI signal to VGA video signal converter
Sifra: TRN-C315-0,2 - 80,00 Kn
1 * AMD CPU Desktop Ryzen 5 4C/8T 1400 (3.2/3.4GHz Boost,10MB,65W,AM4) box, with Wraith Stealth 65W cooler
Sifra: YD1400BBAEBOX - 980,00 Kn
1 * HDD TOSHIBA DT01ACA100 (3.5, 1TB, SATA III-600)
Sifra: DT01ACA100 - 329,00 Kn
1 * SAPPHIRE AMD Radeon NITRO+ RX 580 4GB GDDR5 + 2 Igre (The Division 2, Devil May Cry 5 ili Resident Evil 2)
Sifra: 11265-31-20G - 1.549,00 Kn
1 * Zalman S2, 1x120mm, USB3.0
Sifra: ZAL-S2 - 250,00 Kn
1 * Napajanje SilentiumPC Vero L2 500W, 80+ Bronze
Sifra: 29190422 - 349,00 Kn
Ukupno: 4.614,00 Kn -2% = 4.520,00 Kn
Staro 03.02.2019., 23:23   #10894
NightWalker
NightWalker's Avatar
Datum registracije: Feb 2010
Lokacija: PGŽ
Postovi: 231
Pozdrav, preporuka konfe do 3000 kn za gaming, cs go high/ultra? Graficka s njuskala dolazi u obzir.
NightWalker je offline   Reply With Quote
Staro 04.02.2019., 10:38   #10895
John Creasy
Vocna iglica u mudante
John Creasy's Avatar
Lokacija: Beograd
Postovi: 2,835
Autor NightWalker Pregled postova
ostavi phenoma i uzmi rx470 za cca 700kn s njuške i ko bog si za cs go na svim mogućim detaljima
Staro 04.02.2019., 10:58   #10896
thunderbird
Premijum AMDebil
thunderbird's Avatar
Lokacija: jastrebarsko
Postovi: 1,150
Može i proc nadograditi sa fx83xx, ako ga ploča podržava.
Taj proc + Grafa u rangu rx470 mogu još itekako poslužiti za gaming
X
Staro 04.02.2019., 11:45   #10897
NightWalker
Lokacija: PGŽ
Postovi: 231
Ma radim novi PC za curu, svoj ne diram jer vrti cs go u high bez problema(70/80fps) makar sve staro skoro 8 godina i da maticna podrzava FX83xx
Staro 04.02.2019., 13:36   #10898
Smartic
Smartic's Avatar
Datum registracije: Mar 2011
Postovi: 2,707
AMD CPU Desktop Ryzen 3 4C/4T 2200G (3.7GHz,6MB,65W,AM4) box, RX Vega Graphics, with Wraith Stealth cooler
GIGABYTE SSD 240GB, 2.5, SATA III, 500MBs/420MBs, Retail
Fortron napajanje Hexa Plus 400W, 80+
Memorija 8GB (2x4) 2666MHz G.SKILL Ripjaws V Series CL15
2.671,00KN - 2% ~ 2.618kn
Probao bih s integriranom prvo, da se solidno igrati CS:GO na 1080/medium. Možeš se poigrati i s overclockom RAMa i grafičke.
Puno jača polovna grafička se može naknadno uzeti
Staro 04.02.2019., 13:58   #10899
cdhr
cdhr's Avatar
Datum registracije: Jul 2016
Postovi: 161
I pri kojem fps-u? AKo još očekuješ i neki dobar fps (tipa 60 minimum)- što misliš zašto postoje grafičke skuplje od te cifre za čitav pc?
R5 2600 ~ 1350kn
2x8gb 3000mhz ~ 1000kn
B450 mbo ~ 800kn
RX 580 8gb ~ 1900kn
Odi na yotube ukucaj si ime igre + RX 580 8gb i pogledaj zadovoljovaju li te performanse, jer je to najjača nova gpu koja ti stane
kao amater igrač zadovoljan sam sa 35 - 40 fps da uzivam u igri ali imam OCD na igre kada ih moram igrati na manje od ultra cool vidim optimizacija igara za računalo je na super putu držimo se dalje konzola thx na info nepada mi napamet slagati 5 - 6 k kuna računalo da mi nešto šteka
cdhr je offline   Reply With Quote
Staro 04.02.2019., 14:04   #10900
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,584
Čuj 35-40 fps nije visok kriterij, onda bi te i RX 580 8gb zadovoljila. Ili još bolje polovnu gtx 1070 kao u drugom prijedlogu
Staro 04.02.2019., 14:59   #10901
Postovi: 16,733
Autor cdhr Pregled postova
Da se razumijemo, za 5-6k kn u 2019. godini ne možeš dobiti ni neki jebeni mid-range PC, ovo "da mi ne šteka" i 5-6k kn ne drži vodu. Naravno, ovisno od osobe do osobe, svakome "štekanje" je drugačije definirano.
Ako ti je 35 FPS-a dosta, svaka čast, onda nemaš visoke kriterije.
Ako želiš lockanih 60 ili više, to je drugi par cipela.
Staro 06.02.2019., 15:16   #10902
cdhr
cdhr's Avatar
Postovi: 161
Kupio opet jučer ps4 kao što rekoh nepada mi napamet pljunuti 6k kuna na a možda bude radilo stvar je principa a ne novaca i nekupujemo računalo dok se situacija nestabilizira ili ako treba nećemo više ni imati računalo osim za office programiranje i download ^^
Zadnje izmijenjeno od: coconut. 12.02.2019. u 06:07.
Staro 06.02.2019., 15:28   #10903
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Ja na kompu od cca 5k igram sve nove igre bez problema... tak da ne vidim razloga da je to bacanje novaca.
Imam i ps4 al to me kosta puno vise novaca da bi igrao sve sto pozelim a i nije to to kao kada imas misonju u ruci...
Staro 07.02.2019., 22:33   #10904
Postovi: 16,733
Ma problem je već u 3500kn, prvotno je bio 3000kn. Jedva sam ih nagovorio na 3500kn. Uglavnom, nije da nemaju, nego je "kompjuter je bacanje novaca"...
Složio sam u linksu sljedeće:
1 x Grafička kartica PCI-E ASROCK Radeon RX 560 4G Phantom Gaming, 4GB GDDR5
1 x SSD 240.0 GB CRUCIAL BX500, CT240BX500SSD1, SATA3, 2.5", maks do 540/500 MB/s
1 x Procesor AMD Ryzen 3 2200G BOX, s. AM4, 3.7GHz, 6MB cache, Quad Core, RX Vega, Wraith Stealth cooler
1 x Matična ploča ASROCK A320M-HDV, AMD A320, DDR4, mATX, s. AM4
1 x Memorija PC-17000, 8 GB, G.SKILL Value series, F4-2133C15S-8GNS, DDR4 2133MHz
1 x Napajanje 400W, ANTEC VP400PC EC, ATX v2.3, 120mm vent.
1 x Kućište MS HUNTER, MIDI, ATX, crno
Ispadne 3550kn.
Je li to ok? 1050 mi nikako neće ići u budžet.
Razmišljao sam o varijanti s APU, ali gledam po YT, nije baš to "najigrivije", a bojim se da neće klincu naknadno htjeti kupiti grafu.
U slučaju da ih najebem da mu uzmu rabljenu grafu, zamjenim to napajanje jačim i uzmem 1060 3gb neku s garancijom, je li to bolja opcija?
Da sam sebe citiram.
Ušao u dućan s starim, i najebo ga, uzeli smo klincu:
Ryzen 3 2200G
A350 ASUS matičnu
8 GB ddr4
240GB SSD
Corsair 450W
Neko žblj kučište
i ono najbolje GTX 1050ti.
3850kn sve zajedno, mali prezadovoljan.
Hvala svima.
Staro 11.02.2019., 17:43   #10905
ludiboris
digi-media.org
ludiboris's Avatar
Datum registracije: Aug 2008
Lokacija: ČK
Postovi: 238
Trebao bi preporuku za konfiguraciju do max 4k.
Ukoliko je nesto stvarno isplativo,nategnuo bi za jos max 500 kn preko 4k.
Treba mi sve osim napajanja , hard diska (treba mi samo SSD disk) i optickog pogona.Ali moze sa strane , van konfiguracije 1 ili 2 preporuke za napajanje , koje je malo tise od ovog trenutnog (premda je i ovo koje sad imam u neku ruku dosta tiho).
Ne treba mi primarno za gaming , jer imam ps4.Bitno mi je da konfa dobro pogoni za rad s adobe alatima.
Monitor mi isto ne treba , jer kao i do sad , racunalo imam spojeno na 55" LG 4k LD TV.
Prvenstveno bi nesto sto je u buducnosti lako nadogradivo sa boljim komponentama.Tj. bazirao bi se na maticnu.A i da se grafa i proc dobro nose sa 4k rezom tv-a.Osim rada u programima , uz tu i tamo neku rijetku igru , gledao bi i 4k filmove,te gledao streaming u full hd ili 4k rezi.
Imam trenutno ovo napajanje i HDD koje bi ostavio:
Napajanje : TAGAN 420W , i-Xeye , Super Silent
HDD: https://www.newegg.com/Product/Produ...82E16822136517
Moze i rabljeno i novo , ili kombinacija.
A u obzir dolazi i laptop kojeg bi hdmi-em spajao na tv , ukoliko je isplativ za ovo sto trazim od racunala.
Zadnje izmijenjeno od: ludiboris. 11.02.2019. u 18:00.
ludiboris je offline   Reply With Quote
Staro 11.02.2019., 18:01   #10906
dakky
Uptime freak
dakky's Avatar
Lokacija: Ri, Cro
Postovi: 2,942
Mislim da previše tražiš za te novce... "uz tu i tamo neku rijetku igru" na 4K već si digao ljestvicu za skoro iznos cijele konfe. Da je samo Adobe, dalo bi se ugurati nešto... treba ti masa RAM-a (bar 16 GB), procesor sa što više jezgri.... grafika je nebitna jer i integrirana u Ryzen 5 može glatko 4K gurati. Ali igrati se... druga pjesma... na 4K zaboravi...
Staro 11.02.2019., 18:19   #10907
ludiboris
digi-media.org
ludiboris's Avatar
Lokacija: ČK
Postovi: 238
Mozda sam se i malo krivo izrazio. Ne zelim 4k gaming.
Pod gaming mislim iskljucivo na hearthstone i dotu.. Nista pretjerano.I sad imam grafu radeonku hd 4850 s kojom naravno ne mogu gledati 4k sadrzaje bez stekanja. Ali ima solucija kojom streamam skinuti 4k video sa racunala na tv i u redu ide.
Kao sto si napiso. Treba mi proc, i barem pristojnu kolicinu rama zasad.I dobra maticna.A grafu je kasnije lako staviti, ako bi ju uopce i stavljao.Uz neki solidan ssd.
Staro 11.02.2019., 19:29   #10908
Smartic
Smartic's Avatar
Postovi: 2,707
Neke dvije kombinacije bi bile:
#1
R5 2400G(~1150kn)
G.SKill Aegis 2x8GB DDR4 300MHz(800-850kn)
Asus X370-PRO
WD Black NVMe 250GB ili Crucial MX500 500GB + kućište
#2
R5 2600/1600X
RX 570
Jeftina B450 ploča
Najjeftiniji 240GB SSD
Isti RAM
Staro 12.02.2019., 00:28   #10909
dakky
Uptime freak
dakky's Avatar
Lokacija: Ri, Cro
Postovi: 2,942
Ne bi previše komplicirao, kao što je Smartic napisao... 2400G je sasvim solidan CPU za Adobe i integrirana grafika je dobra za reprodukciju 4K sadrzaja, nije za igranje ali će za te igre posluziti. Išao bi na tu varijantu...
Staro 14.02.2019., 11:46   #10910
Dario99
Datum registracije: Feb 2019
Lokacija: Prijedor
Postovi: 2
Pozdrav ovo je moja licna konfiguracija sta mislite o ovome, treba mi za gejming:
Procesor: Intel Core i7 7700K 4,20Ghz 1151 BOX Kaby Lake
Maticna ploca: GA-Z270-HD3P
RAM: Crucial Balistix Sport 8GB DDR4 3000Mhz
Graficka kartica: AMD RX 580 8GB GDDR5
Napajanje: Raidmax 735W Modularno
Dario99 je offline   Reply With Quote
Staro 14.02.2019., 12:03   #10911
Smartic
Smartic's Avatar
Postovi: 2,707
Kaby Lake nikako uzimati. Pretpostavljam da 7700K još uvijek košta više od 300e?
Uzmi Ryzen 5 2600(+B450 ploču) i RTX 2060 radije. Možda ti stane još 8GB RAMa, a moglo bi se i kvalitetnije napajanje ubaciti.
Staro 15.02.2019., 11:22   #10912
Dario99
Lokacija: Prijedor
Postovi: 2
Da tačno, košta oko 350-400 eura, vidim da dosta ljudi izbjegava Kaby Lake ali ne znam baš najbolje obrazloženje, priznajem nisam ni dovoljno iskusan u ovoj sferi. Ryzen 5 2600 je odličan procesor tu nema dileme ali sa RTX 2060 neću dobiti neki strašniji upgrade od 580 možda nekih max 10FPS u nekim high demanding igrama. Ispravite me ako grijesim ali svakako cu uzeti u razmatranje i ovu konfiguraciju hvala vam na prijedlogu!
Staro 15.02.2019., 11:26   #10913
Postovi: 16,733
Prvo, ovisno o igri, dobivaš između 20-35%, nije 10FSP-a kada pričamo o GTX2060.
Drugo, davati 400EUR za i7 kad za manje od 200EUR možeš dobiti Ryzen 5 2600, a nije takva razlika, čak postoje igre gdje je Ryzen 5 jači CPU.
Duplo više košta a dobivaš 5-10%, je li sada jasnije zašto se ne isplati?
Staro 15.02.2019., 12:21   #10914
Smartic
Smartic's Avatar
Postovi: 2,707
RTX 2060 je više od 50% brža od RX 580, kakvih 10 FPS-a i 20%, nisu uopće u istoj klasi.
Staro 21.02.2019., 16:14   #10915
Jambro
Datum registracije: Mar 2015
Postovi: 63
Dobar dan
Sutra planiram uzeti ryzen 5 2600, Gigabyte B450 Sh3, G. Skill Aeegis DDR 4 3000Mhz Cl 16 pa imam par pitanja..
Da li se isplati za koju stoticu vise uzeti ryzen 5 2600X i Jel istina da na ove procesor e bolje pase memorija G. Skill Ripjaws 3000MHz cl 15 DDR4? Od gore navedene ili je i ovo gore OK?
Hvala
Jambro je offline   Reply With Quote
Staro 21.02.2019., 17:35   #10916
Smartic
Smartic's Avatar
Postovi: 2,707
Ne isplati se 2600X, a Aegis 3000MHz modeli su se pokazali dosta fleksibilnim na Ryzenu tako da je izbor ok. Možda uzeti ploču s 4 RAM slota jedino, ako je to S2H
Staro 21.02.2019., 20:12   #10917
Jambro
Postovi: 63
OK hvala, makar mislim da cu uzet 2600x posto ne planiram klokat proc a ako sam dobro skuzio to je ubiti malo klokani 2600, sve u svemu hvala
Zadnje izmijenjeno od: coconut. 22.02.2019. u 05:40.
Staro 21.02.2019., 20:15   #10918
ibme74
ibme74's Avatar
Postovi: 1,582
To se zove bacanje para, uzmes obicni 2600 a za razlikubu cijeni utrpas kvalitetniju plocu i aftermarket cooler a sto se OC-a tice to ti stvarno nije neki problem sa ryzenom.
Staro 21.02.2019., 20:18   #10919
Jambro
Postovi: 63
Koju plocu npr? Hvala
Staro 21.02.2019., 21:21   #10920
ibme74
ibme74's Avatar
Postovi: 1,582
pa evo npr
1 * Procesor AMD Ryzen 5 2600 (6C/12T, 3.9GHz,19MB,65W,AM4) box, Wraith Stealth
Sifra: YD2600BBAFBOX - 1.399,00 Kn
1 * Asrock B450M Steel Legend, 4xDDR4, AM4
Sifra: ASR-B450M-STEEL - 729,00 Kn
1 * Hladnjak LC-Power LC-CC-120, Intel/AMD + AM4
Sifra: lcp-hlad-lc-cc-120 - 180,00 Kn
Ukupno: 2.308,00 Kn
a toliko te izađe 2600x sa onom jeftinjarom što si sam stavio
