Staro 30.01.2019., 19:06   #1
murina
murina's Avatar
Postovi: 490
Arrow Problematična WiFi kartica
Ne znam jesam li na pravoj temi ali imam problem pa ako me ko može uputiti na rješenje bio bih jako zahvalan: komp ne vidi 5Ghz wifi
Ruter je D-link DIR‑842
WiFi adapter je D-Link DWA‑172
Isprobano na dva Win10 kompa, adapter na oba vidi samo 2.4Ghz mrežu. 5Ghz mreža funkcionira uredno, laptopi i mobiteli su spojeni na nju.
Isprobao sam razne kombinacije drivera za adapter (i D-linkove i Microsoftove), sa svima isto radi. Probao sam uštekati u 3.0 i 2.0 USB, ne znam jeli to uopće bitno ali nije pomoglo.
Jedino mjesto gdje je uopće spomenuta 5Ghz mreža je Windows Network Diagnostics, koji je prepoznao problem ali ga nije uspio riješiti. U ovoj kombinaciji mi nije vidio ni jednu WiFi mrežu (obično ih ima bar 15):
Diagnostics Information (Network Adapter)
Details about network adapter diagnosis:
Network adapter WiFi 3 driver information:
Description . . . . . . . . . . : Wireless AC600 Dual Band High-Gain USB Adapter
Manufacturer . . . . . . . . . : D-Link Corporation
Provider . . . . . . . . . . . : D-Link Corporation
Version . . . . . . . . . . . : 1030.11.503.2016
Inf File Name . . . . . . . . . : C:\WINDOWS\INF\oem45.inf
Inf File Date . . . . . . . . . : 15 September 2017 05:29:00
Section Name . . . . . . . . . : RTL8811au.ndi
Hardware ID . . . . . . . . . . : usb\vid_2001&pid_3318
Instance Status Flags . . . . . : 0x180600a
Device Manager Status Code . . : 0
IfType . . . . . . . . . . . . : 71
Physical Media Type . . . . . . : 9
Diagnostics Information (Wireless Connectivity)
Details about wireless connectivity diagnosis:
Information for connection being diagnosed
Interface GUID: f1c487e8-e185-459a-8b04-67240b73734f
Interface name: Wireless AC600 Dual Band High-Gain USB Adapter
Interface type: Native WiFi
Connection incident diagnosed
Auto Configuration ID: 1
List of visible access point(s): 0 item(s) total, 0 item(s) displayed
Connection History
Information for Auto Configuration ID 1
List of visible networks: 0 item(s) total, 0 item(s) displayed
List of preferred networks: 3 item(s)
Profile: podrum studios
SSID: podrum studios
SSID length: 14
Connection mode: Infra
Security: Yes
Set by group policy: No
Connect even if network is not broadcasting: No
Connectable: No
Reason: 0x00028002
Profile: podrum studios 5ghz
SSID: podrum studios 5ghz
SSID length: 19
Security: Yes
Connectable: No
Reason: 0x00028002
Profile: TP-LINK_Extender_DF2C9C
SSID: TP-LINK_Extender_DF2C9C
SSID length: 23
Security: No
Connectable: No
Reason: 0x00028001
Any hint?
Staro 30.01.2019., 19:38   #2
Postovi: 16,654
Device manager -> Network adapters -> nađi svoj wifi adapter -> Properties -> Advanced -> Wireless mode -> izaberi IEEE 802.11a/n/ac
Staro 30.01.2019., 20:45   #3
jp_rv
Datum registracije: May 2014
Lokacija: istra
Postovi: 3,469
ne samo to nego i gledaj kanale. nisu svi kanali podržani u cijelom svijetu.
recimo moja kartica u laptopu vidi samo 36~56 kanal, i ako stavim na routeru 100+ kanal, ne vidim mrežu.
Staro 30.01.2019., 20:55   #4
Postovi: 23,492
Prebačeno u zasebnu temu.
Taj stick je baziran na Realtek RTL8811au chipsetu koji je (ako se ne varam) malo problematičan x
Ovo je zadnji drajver sa supporta > https://media.dlink.eu/ftp/products/...i_20171011.zip
Na stranicama Realteka > https://www.realtek.com/en/component...811au-software
U ovoj dijagnostici se spominje neki extender ?
Probaj doći bliže DIR-842 i na njega se spojiti a ne na extender za početak.
I ovo šta kaže kolega, za 5 Ghz band stavi kanal manji od 40.
Staro 30.01.2019., 21:35   #5
PR3DA70R
PR3DA70R's Avatar
Lokacija: Yautja Prime
Postovi: 1,220
Baš jučer uzeo taj adapter (DWA-172) i spojio na 5GHz. Uredno vidi 2.4 i 5 GHz. Windows 10.
Zadnje izmijenjeno od: Nikky. 30.01.2019. u 22:13.
Staro 31.01.2019., 10:12   #6
murina
murina's Avatar
Postovi: 490
Hvala svima na odgovorima, riješilo se sa kanalom na 36
Da sam bar odmah pitao, a ne izgubio cijeli dan sa čudnim rezultatima i teorijama
edit: Sad me žuljaju ovi noviji opskurni driveri, isplati li se riskirat
Staro 31.01.2019., 11:19   #7
Postovi: 23,492
Kako misliš opskurni?
Na linkovima su od D-Linka (proizv. stick-a) i od Realteka (proizv. chipa).
Ako sad radi ne popravljaj.
Staro 31.01.2019., 12:16   #8
murina
murina's Avatar
Postovi: 490
Ma nisam mislio doslovno opskurni, nego nisu na službenoj od D-Linka
Pardon, sad vidim da si stavio i link na D-Linkovu stranicu. Taj driver mi je trenutno instaliran. Ovaj na Realtekovoj je noviji
Zadnje izmijenjeno od: murina. 31.01.2019. u 12:26.
Staro 03.02.2019., 07:19   #9
skalar
skalar's Avatar
Datum registracije: Apr 2015
Postovi: 1,699
D-Link ti je takva firma da baš ne ažurira drivere,a nisu ni drugi bolji najčešće driveri od chipseta rade dobro,večina wifi stickova imaju 1 ili dva drivera na stranicama proizvođaća i tu je onda karaj njihove brige,a gotovo svaka nadogradnja windowsa zahtjeva modifikaciju drivera ali proizvođaći chipseta izvlaće stvar tu se nemaš kaj brinuti to je normalno.
