#2341 | ||
MiningMod
Postovi: 8,715
1 * Intel CPU Desktop Core i7-9700K (3.6GHz, 12MB, LGA1151) box Sifra: BX80684I79700KSRELT - 3.500,00 Kn 1 * Hladnjak ARCTIC COOLING Freezer 33 CO Šifra: 050.903.351- - 219,00 Kn 1 * Matična GIGABYTE Z390 UD, S.1151 CL Sifra: Z390_UD - 1.100,00 Kn 1 * Memorija GSkill Aegis 16GB (2x8) DDR4 3000MHz Sifra: F4-3000C16D-16GISB - 1.049,00 Kn 1 * Gainward GF RTX2080Ti Phoenix GS, 11GB GDDR6 Sifra: gai-2080tipgs-11gb - 9.740,00 Kn 1 * SSD 500.0 GB SAMSUNG 970 Evo NVMe M.2, MZ-V7E500BW Sifra: 051.400.570- - 1.139,00 Kn 1 * SEAGATE SSHD Desktop FireCuda Guardian (3.5/2TB/SATA 6Gb/s NCQ) Sifra: ST2000DX002 - 881,00 Kn 1 * SAMA BLACK FISH high-end ATX-III kućište Šifra: 0151339 - 749,00 Kn 1 * Corsair PSU, 750W, TX-M Series Sifra: COR-CP-9020131-EU - 939,00 Kn Ukupno: 19.316,00 Kn -2% za članove foruma = 18.929,00 kn Citiraj:
2 * Memorija GSkill Aegis 16GB (2x8) DDR4 3000MHz Sifra: F4-3000C16D-16GISB - 2.098,00 Kn 1 * SSD 500.0 GB SAMSUNG 970 Evo NVMe M.2, MZ-V7E500BW Sifra: 051.400.570- - 1.139,00 Kn 1 * SAMA ARMOR 550W 80PLUS GOLD Sifra: 0151335 - 449,00 Kn 1 * Kućište Zalman Z1, USB3.0, 2x120mm Sifra: ZAL-ZM-Z1 - 299,00 Kn 1 * Hladnjak MSI GAMING Core Frozr L, Intel/AMD + AM4 Sifra: CORE_FROZR_L - 399,00 Kn 1 * Gigabyte Z370 HD3, Sck. 1151 CL Sifra: Z370_HD3 - 899,00 Kn 1 * Intel CPU Desktop Core i7-9700K (3.6GHz, 12MB, LGA1151) box Sifra: BX80684I79700KSRELT - 3.500,00 Kn 1 * AOC LCD 32 Wide , 16:9, DP, QHD Sifra: AOC-Q3279VWFD8-Es - 1.725,00 Kn Ukupno: 10.508,00 Kn - 2% za članove foruma = 10.300,00 kn Zadnje izmijenjeno od: FRipper. 09.01.2019. u 17:18. |
#2342 |
Postovi: 15
ma hoce ali vjerojatno za koju godinu, mislim da mi u pocetku stvarno nije potrebno jer nema nista toliko zahtjevno da ce zahtjevati OC... puno mi je nekako dati 3000 kuna vise za 2080ti, radije bi obicnu 2080 pa ostatak novaca raspodijeliti na druge komponente. sto kazes na maticne MSI MAG Z390 TOMAHAWK i gigabyte aorus pro/elite? a za napajanje evga supernova g3? |
#2344 |
Datum registracije: Jan 2019
Lokacija: Zaprešić
Postovi: 2
Pozdrav svima, molio bih ako mi netko može složit konfu za 15-16k isključivo za gaming + monitor (nemora bit neki skupi), te me zanima ako bi takva konfa mogla vrtit igre tipa Monster Hunter World i AC Odyssey na high sa 60+ fpsa, i ako ne na kolko bi fpsa moglo. Mogu istegnut još 1000 kuna ako će trebat za nešto. Hvala unaprijed. |
#2345 |
Postovi: 16,829
Za tu lovu mora vrtiti obje igre u isto vrijeme na 60hz ![]() |
#2346 |
Datum registracije: Mar 2011
Postovi: 2,707
Evo ![]() Procesor Intel Core i9-9900K (16MB Cache, 3.60GHz), tray Grafička kartica PNY RTX2080 XLR8 Gaming OC Twin Fan, 8GB GDDR6, 1710/1750MHz, USB-C, VCG20808DFPPB-O Matična ploča Gigabyte Z390 Aorus pro, s1151 V2 DDR4 16GB (2x8GB) Corsair Vengeance LPX White, 3000Hz,CL16, CMK16GX4M2D3000C16W Monitor AOC Q3279VWFD8, 31.5" IPS, 2560x1440, 16:9, 250cd/m², 5ms, 75Hz, 1x VGA, 1x DVI, 1x HDMI 1.4, 1x DisplayPort 1.2 Kućište Fortron CMT330, crno Napajanje Thermaltake ToughPower Grand RGB Gold 750W ATX 2.4, PS-TPG-0750FPCGEU-R HDD 1TB WD Blue, 3.5", 7200RPM, 64MB Cache, SATA3, WD10EZEX MSI Core Frozr L, s. 775/1150/1151/1155/1156/1366/2011/2011-3/AM2/AM2+/AM3/AM3+/FM1/FM2/AM4, 140mm x 155mm x 84mm, 500 - 1800 ±15% RPM SSD 480GB Kingston A400, SATA3, SA400S37/480G Ukupno: 17.091kn Može se i neki 1080p 144Hz monitor. |
#2347 | |
The Man
Lokacija: Novi Zagreb
Postovi: 1,252
![]() Koja firma je u pitanju jer bi tražio ponudu na firmu.
"Everybody's at war with different things...I'm at war with my own heart sometimes" |
#2348 | |
Lurker
Datum registracije: May 2017
Postovi: 52
![]() I vidi si da li ti stane monitor na stol? |
#2349 |
MiningMod
Postovi: 8,715
Sto fali tom kucistu? Mrga od kutije, nema sto ne stane unutra. Monitor svakako pripaziti, pa i da se bude malo udaljen od njega jer ubija oci na blizo. Ja bi tu radje isao na C27G1 za proc svakako 9700K |
#2350 |
Lokacija: Zaprešić
Postovi: 2
Hvala za složenu konfu. Najprihvatljivija ponuda (slao sam onu gore složenu i oni su mi stavili ono što imaju u ponudi) koju sam dobio, a da maknem ovaj monitor i promjenim i9 9900k za i7 9700k bi iznosila oko 15300kn. Komponente su sljedeće: MSI RTX 2080 Ventus 8GB MSI Z390 TOMAHAWK Corsair 1x16GB DDR4 3000 C15 Fortron CMT 330, crno s proz. Thermaltake 750W, 80+Gold RGB Caviar Blue 1TB 7200 HDD MSI CoreFrozr L hladnjak Kingston A400 480GB SSD Stavim Intel i7 9700k, i neki drugi monitor jer imam manji stol pa sam istovremeno dosta blizu kad koristim računalo, a C27G1 mi je malo preskup pa ako može neki drugi prijedlog. Hvala opet |
#2351 |
MiningMod
Postovi: 8,715
Tko ti je to slagao? To je cijena za keš? Jer nekako mi je to skupo... 1 * Palit GF RTX2080 Dual, 8GB GDDR6 1 * MSI MSI Z390 TOMAHAWK 1 * Kućište Rampage Everest PRESTIGE s 4 plava ventilatora 1 * SAMA ARMOR 650W 80PLUS GOLD 1 * WESTERN DIGITAL WD10EZEX 1TB Blue 1 * Hladnjak MSI GAMING Core Frozr L, Intel/AMD + AM4 1 * GIGABYTE SSD 480GB, SATA III, 3D NAND TLC, 550MBs/480MBs 1 * Procesor Intel Core i9-9900K 16MB Cache, 3.60GHz 1 * Memorija GSkill Aegis 16GB (2x8) DDR4 3000MHz Ukupno: 14.802,00 Kn - 2% za članove = 14,500.00kn Ili ja nešto krivo gledam? Sa 9700K - 13,500.00 kn Sa C27G1: 1 * Intel CPU Desktop Core i7-9700K (3.6GHz, 12MB, LGA1151) box+ 1 * Matična GIGABYTE Z390 UD, S.1151 CL 1 * Hladnjak MSI GAMING Core Frozr L, Intel/AMD + AM4 1 * Memorija GSkill Aegis 16GB (2x8) DDR4 3000MHz 1 * GIGABYTE SSD 480GB, SATA III, 3D NAND TLC, 550MBs/480MBs 1 * WESTERN DIGITAL WD10EZEX 1TB Blue 1 * Palit GF RTX2080 Dual, 8GB GDDR6 1 * Kućište Rampage Everest PRESTIGE s 4 plava ventilatora 1 * SAMA ARMOR 650W 80PLUS GOLD 1 * Monitor 27 AOC C27G1, VA, 144Hz, 1ms, Curved, VGA/DP,/2xHDMI, FreeSync, crni Ukupno: 15.400,00 Kn Samo svakako što god odabrao, ovo nikako...pa nemreš mi u 15k konfu staviti 1X ram, 2x pod must Zadnje izmijenjeno od: FRipper. 14.01.2019. u 22:30. |
#2352 |
Lokacija: Varazdin
Postovi: 258
Pozdrav, Trebal bi konfu bez grafe i monitor 144Hz/1ms gaming koja bude mi durala godinama uz upgrade grafe kad će trebat (tak sam sad godinama upgrejdal svoju 2500k konfu samo s grafama i duralo je ![]() Trenutno imam GTX 1070ti koju planiram stavit u donju konfu. Ono kaj mi je must have je 9700k ili 9900k ako upadne u budžet, 1TB HDD mi dosta, 16GB rama mi također dosta, kucite mi treba kvalitetno i decentno, ne trebaju mi ledice i osvjetljeni ventori, bilo bi poželjno da cijela konfa kad se ne igra da je jako tiha. Brža varijanta SSD-a dovoljno 480/500GB. Cooler mi ne smeta ako je ogroman, samo da je tih kad se surfa , ostalo neka prati komentente... Da bude između 10 i 12k kn. Može futura,uzi,links i razni pouzdani webshopovi ali da je sv ena jednom mjestu Zadnje izmijenjeno od: Brc. 18.01.2019. u 22:54. |
#2353 |
Postovi: 2,707
'ello ![]() Situacija ti je dosta komplicirana po pitanju isplativosti... problem je što u kombinaciji s GTX 1070 Ti ne bi baš dobivao puno bolje rezultate s 9900K naspram nečeg poput R5 1600X koji dođe 1/4 cijene. Kužim da bi onda opet mijenjao samo grafičke sljedećih 5 godina, ali meni se čini boljim uzeti 1600X ili 1700X i prebaciti se kompletno na 7nm procesor(Zen2) i grafičku(7nm RTX?) sljedeće godine. Anyway... i9 9900K(~4500kn) Gigabyte Z390 Aorus Elite(~1500kn) Najjeftiniji 2x8GB DDR4 3000 kit(900kn) Corsair RMx 550/650W(750-850kn) Fractal R5(veliko)/Phanteks Eclipse P400(kompaktno)/nešto treće Crucial MX500 500GB(600kn) WD Blue 1TB(300-350kn) Hladnjak MSI Core Frozr L(~370kn) Koje igre igraš i na kojim detaljima? Možeš možda i 240Hz Dell uzeti ako je u pitanju CS:GO i/ili Fortnite. |
#2354 |
Lokacija: Varazdin
Postovi: 258
#2355 |
Postovi: 2,707
#2356 |
Postovi: 1
Pozdrav ljudi, Slazem komp koji ce mi prvenstveno sluzit za programiranje i deep learning, odnosno po naski duboko ucenje neuronskih mreza - za sto je kljucno imat dobru graficku (ili vise njih). Vise se razumijem u software dio, pa bi mi trebao pokoji savjet oko hardwarea. Nakon par sati proucavanja, napravio sam popis komponenti i podijelio ih u par kategorija. Pa krenimo... Komponente za koje sam prilicno siguran da zelim: 2 x Grafička kartica nVidia MSI GeForce RTX 2070 GDDR6 8GB/256bit, 1420MHz/14000MHz, PCI-E 3.0 x16, 3xDP, HDMI, USB Type-C, ARMOR 2X Cooler(Double Slot) RGB Mystic Light, Backplate, Retail 1 x Procesor Intel Core i7-9700K (Octa Core, 3.60 GHz, 12 MB, LGA1151 CL) Komponente koje mi se cine OK: 1 x Memorija Corsair 32 GB (2X16GB) DDR4 3000 C16, CMK32GX4M2D30C16 1 x SSD Kingston A1000 960GB, PCIe NVMe, M.2 80mm, SA1000M8/960G 1 x Hladnjak za CPU, Arctic Cooling Freezer 33 eSports ONE, s. 1155/1156/1150/1151/2011-3/2066/AM4, crveni Komponente za koje nisam siguran odgovaraju li: 1 x Matična ploča Gigabyte Z390 Aorus Pro Komponente koje sigurno jos fale: napajanje kuciste Cijenio bih kad bi netko bacio oko na moj popis i prokomentirao sto misli. Imam i par konkretnih nedoumica: U vezi navedene maticne, je li to OK izbor s obzirom na to da imam dvije graficke koje se obje spajaju na PCIE x16. Odabrana maticna ima jednu izvedbu za x16 i jednu za x8. Treba li mi maticna sa dvije izvedbe na x16? Kolika je ocekivana razlika u performansama? Koja je vasa preporuka za napajanje? Koristio sam stranicu http://www.coolermaster.com/power-supply-calculator/ za racunanje koliko snage trebam, ali izbacilo mi je nesto sto mi nema smisla pa bi trebao vas savjet. Za graficku nisam siguran koliko je bitan vendor i koja je razlika medu njima - MSI, Inno3D, itd. Ako mi jos nesto fali, molim vas napomenite. Hvala! |
#2357 |
MiningMod
Postovi: 8,715
1 * Intel CPU Desktop Core i7-9700K (3.6GHz, 12MB, LGA1151) box Sifra: BX80684I79700KSRELT - 3.699,00 Kn 1 * Hladnjak MSI GAMING Core Frozr L, Intel/AMD + AM4 Sifra: CORE_FROZR_L - 399,00 Kn 1 * Corsair 2X16GB DDR4 3000 C16 Sifra: COR-CMK32GX4M2D30C16 - 1.853,00 Kn 1 * SSD 1TB AD SX8200 PRO PCIe M.2 2280 NVMe Sifra: 0141105 - 1.692,00 Kn 2 * MSI Video Card NVidia GeForce RTX 2070 GAMING 8G GDDR6 8GB/256bit, 1620MHz/1410MHz, PCI-E 3.0 x16, 3xDP, HDMI, 1xUSB Type C, Retail Sifra: RTX_2070_GAMING_8G - 9.874,00 Kn 1 * MSI Main Board Desktop Z390 (S1151, 4xDDR4, 3xPCI-Ex16, 3xPCI-Ex1, USB3.1, USB Type-C, USB2.0, 6xSATA III, 2xM.2, RAID, HDMI, DP, GLAN, RGB) ATX Retail Sifra: MPG_Z390_GAMING_PRO_CARBON - 1.681,00 Kn 1 * Corsair PSU Enthusiast Series RM1000x Power Supply, Fully Modular 80 Plus Gold 1000 Watt, EU Version Sifra: CP-9020094-EU - 1.315,00 Kn 1 * NZXT H700 crno/crveno, bez napajanja, ATX Sifra: nzx-h700-black-red - 1.286,00 Kn Ukupno: 21.799,00 Kn -2% popust za članove foruma = 21.350,00 knb Bespltno slaganje i dostava |
#2361 |
Postovi: 8,281
Grafičke su tu najbitnije, ali Threadripper 1920X je (ovisno o dućanu) jeftiniji od 9700K, a opet zahvalniji ulog za filanje GPU-a, dok 64GB RAM-a ne bi bilo na odmet. Primjera radi:
#2362 |
Postovi: 12,613
![]() 2 x MSI GeForce RTX 2070 VENTUS 8G 8 GB GDDR6 1 x Intel Core i7-9700K box 1 x Thermalright HR-02 Macho Rev. B 1 x G.SKILL Sniper X 32GB (2x16GB) DDR4 3000MHz 1 x Intel SSD 660p Series (1.0TB, M.2 80mm PCIe 3.0 x4, 3D2, QLC) Retail Box Single Pack 1 x ASRock Z390 EXTREME 4, 1151 1 x Seasonic Focus Plus Gold 1000W 1 x be quiet! Silent Base 601 Window Black/Orange Ukupno: 20.616,39 kn
#2363 |
Postovi: 2,707
Threadripper + 2*2080 combo: SSD SAMSUNG 500GB, 970 EVO, MZ-V7E500BW, PCIE X4, M.2, NVME, 512MB, 60MJ MB ASRock X399 TAICHI, TR4, ATX, 8x DDR4, AMD X399, S3 8x, LAN 2x, WL, Bt, 36mj 2x VGA Gigabyte RTX 2080 WINDFORCE 8G, nVidia GeForce RTX 2080, 8GB, do 1830MHz, 36mj (GV-N2080WF3-8GC) Kućište Corsair Carbide SPEC-ALPHA Black Silver, crna, ATX, 24mj (CC-9011084-WW) Cooler Arctic Freezer 33 TR White, 120mm, TR4/AM4, 12mj, bijela, (ACFRE00039A) CPU AMD Ryzen Threadripper 1920X (3.5GHz do 4GHz, 38MB (6MB+32MB), C/T: 12/24, TR4, 180W), 36mj 4x DDR4 8GB (1x8GB), DDR4 3000, CL16, DIMM 288-pin, G.Skill Aegis F4-3000C16S-8GISB JEDINICA NAPAJANJA CORSAIR 1000W RM SERIES RM1000I, ATX, 135MM, 80 PLUS GOLD, MODULARNO Sveukupno: 23.640,73 KN |
#2364 |
MiningMod
Postovi: 8,715
Kako vidim svakako bi trebalo ici na 1920x i 64gb rama. Naravno ako se ima novaca za to... evo kombinacije di kasnije moze staviti jos 2 grafe 1 * AMD Ryzen Threadripper 1920X Sifra: AMD-YD192XA8AEWOF - 2.999,00 Kn 1 * MSI X399 SLI Plus, s2066 Sifra: msi-x399-sli-plus - 2.603,00 Kn 1 * LC-Power LC-CC-240-LICO vodeno hlađ. za procesor Intel/AMD + AM4 Sifra: lcp-hlad-240-lico - 499,00 Kn 2 * Corsair 2X16GB DDR4 3000 C16 Sifra: COR-CMK32GX4M2D30C16 - 3.706,00 Kn 2 * Palit GF RTX2080 Dual, 8GB GDDR6 Sifra: pal-2080-dual-8gb - 11.406,00 Kn 1 * Corsair PSU Enthusiast Series RM1000x Power Supply, Fully Modular 80 Plus Gold 1000 Watt, EU Version Sifra: CP-9020094-EU - 1.315,00 Kn 1 * SSD Crucial P1 500GB 3D NAND NVMe PCIe M.2 2000/1700 Sifra: CT500P1SSD8 - 825,00 Kn 1 * Tvrdi Disk Toshiba P300 2TB 3.5 Sifra: 0140718 - 560,00 Kn 1 * SAMA BLACK FISH high-end ATX-III kućište Sifra: 0151339 - 749,00 Kn Ukupno: 24.662,00 Kn -2% = cc 24.100,00 kn |
#2367 | |
¯\_(ツ)_/¯
Lokacija: Sibenik
Postovi: 1,156
Aorus Pro sam vratio jer je PCB bio gadno savinut u podrucju VRM-a/socketa, kao sta se na slici vidi... A i opcenito je ploca ostavljala jeftin dojam. Zadnje izmijenjeno od: ansha. 11.05.2025. u 09:04. |
#2369 | |
¯\_(ツ)_/¯
Lokacija: Sibenik
Postovi: 1,156
Ono je los QC, mosfeti u sredini jedva dodiruju thermal pad, recept za katastrofu... MSI za sad nikakvih problema, VRM se mora hladit ventom al to sam znao, isto vrijedi za sve x399/x299 ploce ako ces renderat sa clockanim CPU-om. |
#2370 |
Datum registracije: Dec 2012
Lokacija: Rijeka-Zagreb
Postovi: 1,207
Gle tvoje iskustvo.. ne ulazim u to i jebiga.. kroz godinu mi prođe brat bratu 500tinjak ploča i dosad nijedna skrivljena Bolji je odvod topline na GB Stavi obje ploče na bench stol bez ičega i prati... možeš i u svojim identičnim uvjetima te ćeš primjetit blagu razliku u temperaturi.. a sitnice tako male na tome bira se ploča kaj ne ' |
