#2311 |
MiningMod
Postovi: 8,715
Ma moze se to bolje... 1 * Procesor AMD Ryzen 7 1700X AM4, 3.4Ghz Sifra: AMD-YD170XBCAEWOF - 1.599,00 Kn 1 * Hladnjak MSI GAMING Core Frozr L, Intel/AMD + AM4 Sifra: CORE_FROZR_L - 399,00 Kn 1 * MSI B450 Tomahawk, AM4, DDR4, U3, m.2, ATX Sifra: msi-b450-thawk - 850,00 Kn 1 * Memorija PC-24000, 16 GB, GEIL EVO Spear GSB416GB3000C16ADC, DDR4 3000MHz, kit 2x8GB Sifra: 051.200.225- - 1.150,00 Kn 1 * NZXT H500 crno bez napajanja, ATX Sifra: nzx-h500-black - 769,00 Kn 1 * Fortron napajanje Hydro GE 650W,80+ GOLD modularno Sifra: fsp-hydro-ge-650w - 749,00 Kn 1 * SSD 500.0 GB SAMSUNG 970 Evo NVMe M.2, MZ-V7E500BW Sifra: 051.400.570- - 1.139,00 Kn 1 * Toshiba 3.5 2TB, SATA6Gb, 7200rpm, 64MB Sifra: DT01ACA200 - 489,00 Kn Ukupno: 7.144,00 Kn -2% popust za clanove = 7000 kn |
#2312 | |
Datum registracije: Jan 2013
Lokacija: Planet Zemlja
Postovi: 1,630
1x Procesor AMD Ryzen 7 2700, 3.20GHz, 16MB Cache, s.AM4, YD2700BBAFBOX 1x Arctic Freezer 33 eSports ONE red, Socket: 1150, 1151, 1155, 1156, 2011, 2011-3, 2066, AM4, ACFRE00042A 1x Matična ploča MSI X470 Gaming Plus, s.AM4, 7B79-002R 1x DDR4 16GB (2x8GB) PC4-24000U 3000MHz CL16 G.Skill Aegis, F4-3000C16D-16GISB 1x SSD 500GB Crucial MX500, SATA3, Read: 560MB/s, Write: 510MB/s, CT500MX500SSD1 1x HDD 2TB Seagate BarraCuda, 3.5", 7200RPM, 64MB Cache, SATA3, ST2000DM006 1x Napajanje 650W Corsair RMx Series RM650x 2018, ATX 2.4, CP-9020178-EU 1x Zalman R1 mid tower case. 192(W) x 465(H) x 450(D)mm. MB standard: Standard ATX / Micro ATX. PSU: S Ukupno: 6.998kn 2.) normalno da nije lose na 2k i 4k jer sto je rezolucija veca to je CPU rasterećeniji |
#2313 |
Postovi: 12,613
AMD Ryzen 7 1700X BOX = 1.507,38 kn Cryorig H7 = 255,11 kn XFX 650W PSU easyRail Gold = 681,12 kn ASRock Fatal1ty Gaming B450 K4 = 823,53 kn Team T-Force Vulcan 16GB (2 x 8GB) 3000MHz C16 = 937,02 kn Samsung 860 EVO 500 GB 500GB = 715,86 kn Toshiba 2TB 3.5" 7.2k SATA 6Gb/s = 507,31 kn Ukupno: 5.427,33kn cijena za forumase. Kuciste uzmes gdje ga ima. ![]()
#2315 |
MiningMod
Postovi: 8,715
Realno sve ove tri konfe su bolje od one što si ti napisao. Moja se jedino razlikuje naspram ostalih jer imaš kućište koje i želiš, nasljednik od S340. Te imaš puno bolji i brži SSD (koji ako ne želiš, uzmeš običan Samsung i cijena padne za cca 400kn) . A i mislim da je hladnjak najjači od ovih svih. Kod ibme-a imaš novi i jači proc, ali da se mene pita ja bi išao bolje na NVME SSD neko na 2700 jer ipak kod tebe više utjecaja ima grafika a ne proc. A kod nine imaš dobru cijenu (Samo ja osobno ne volim te asrock ploče za AM4 jer rade probleme sa ramom, al ne znam kako se točno ova kombinacija ponaša....)Zadnje izmijenjeno od: FRipper. 09.12.2018. u 11:03. |
#2316 |
Datum registracije: Feb 2016
Lokacija: Mars
Postovi: 77
Hvala decki. Nova revizija: Proc: AMD Ryzen 7 1700X BOX = 1.507,38 kn Cooler: Cryorig H7 = 255,11 kn Napajanje: Corsair PSU, 650W, CX-M Series = 732kn Maticna: MSI GAMING B450 PRO CARBON AC Memorija: Team T-Force Vulcan 16GB (2 x 8GB) 3000MHz C16 = 937,02 kn SSD: Samsung 970 EVO 500GB M.2 HDD: Toshiba 2TB 3.5" 7.2k SATA 6Gb/s = 507,31 kn Kuciste: NZXT S340 elite Vecina od Nine jedino sto bih dodao nvme ssd i ostao bih pri msi maticnoj te bih isao na vise manje modularno napajanje. |
#2319 |
Lokacija: Mars
Postovi: 77
S340elite mi je vec odavno zapelo za oko po dizajnu ali sam malo istrazio i H500 je također odlično. Nova revizija nadam se finalna. Proc: AMD Ryzen 7 1700X BOX = 1.507,38 kn Cryorig H7 = 255,11 kn Napajanje: Corsair PSU, 550W, TX-M Series = 734.70kn Maticna: MSI GAMING B450 PRO CARBON AC = 1305kn Memorija: Corsair Vengeance LPX 16GB Kit (2 x 8GB) DDR4 3000MHz CL16 = 1193kn SSD: Samsung 970 EVO 500GB M.2 = 1146kn HDD: Toshiba 2TB 3.5" 7.2k SATA 6Gb/s = 523kn Kuciste: NZXT H500, MIDI, MIDI, window, crno, bez napajanja = 784kn Memorija sam stavio ovu posto je predlozena od Nine raprodana. I grafa ce doc poslije vjerovatno Rtx 2070 a mozda i Rtx 2080. Zadnje izmijenjeno od: coconut. 10.12.2018. u 08:44. Razlog: nema potrebe citiranja posta iznad svoga |
#2320 |
Datum registracije: Mar 2011
Postovi: 2,707
Ako mijenjaš dućan u Uzi, ploča je tamo neisplativa za 1300kn, i radije bolji RAM za takvu cijenu: https://www.uzishop.hr/ddr4-memorije...0mhz-cl15.html https://www.uzishop.hr/amd-maticne-p...-x370-atx.html |
#2321 |
Datum registracije: Apr 2009
Lokacija: Bjelovar
Postovi: 244
Ako nije nužna kupovina sada ja bih na Vašem mjestu pričekao 3mj. da nebi tukli glavom o zid....dolazi ryzen 3xxx serija i njihove Navi VGA koje će sudeći po svemu napraviti dar mar kako Intelu tako i sadašnjoj generaciji Ryzena/Rx.... Jasna mi je i ona da se uvijek može tako čekati jer stalno nešto dolazi, no performanse i cijena ovaj put kod AMD-a bi trebala biti drastična a ne kao kod Intela 5% za Cpu i 20% za gpu a skok cijena 50% ![]() Živjeli! |
#2326 |
Postovi: 14,589
Nek vam 2 benčmarka budu da je službeno rečeno da prvo izlazi epyc milan, pa kasnije ryzen. Prema zadnjim info epyc bi trebao do 6 mjeseca... Drugi benčmark je vega, predstavljena je u radnom stanju u 1. mjesecu, a izašla sredinom 8 mjeseca... A veoma je upitno da li će Navi biti predstavljen sada na CES-u u radnom stanju. Glasine za Navi sugeriraju od 6 mjeseca pa sve do kraja godine. Nitko nije ni spomenio mogućnost da bude Q1 2019. Poznavajuć glasine i službene najave nikad ništa nije izašlo ranije, dok je obrnuto čest slučaj. |
#2327 |
laser
Postovi: 2,356
A uostalom to cekanje nove generacije je glupost, kupujes tada kad mislis i imas novaca. Cekanjem mos kupit komp na sv. nikad, jer "svako malo" izlazi nova-"brza"-"bolja" generacija. A to iz prve ruke je valjda od same lise su... |
#2328 |
dakle sto ono ocekujemo od ryzena 2, 9900k za 1800kn, sa jos jacom integriranom grafickom |
#2329 |
Postovi: 14,589
Ja jesam za čekanje, ali pod dva uvjeta - da dolazi u skorije vrijeme (tipa mjesec dana) i/ili da se ima neki upotrebiv pc u međuvremenu tj. ako nov pc nije hitan tj. ne kuburi se pola godine ili više da bi se kupilo 10% bolje za iste novce |
#2330 |
Postovi: 423
Molio bi preporuku za konfiguraciju koja bi se koristila za izradu geodetskih elaborata, izradu profila, rasteri i slično. Znaci AutoCad, Geoplus... Znaci nesto tipa: i7 8700 16gb ddr 4 min 500gb SSD (970 evo) 2TB HDD 1050 ili 1050ti Kućište mATX (fractal ili sl.), neka provjerena matična bez bugova. Ne trebaju nikakve ledice, bitno da je što tiše. LP Sent from my BLA-L29 using Tapatalk |
#2331 |
Postovi: 2,707
Koliko threadova se tipično koristi? Nešto bitnija je jedna jezgra pretpostavljam. 2x Corsair 1X8GB DDR4 3000 C16 LP, COR-CMK8GX4M1D300C16 Intel CPU Desktop Core i7-9700K (3.6GHz, 12MB, LGA1151) box (ima iGPU) SSD ADATA 512GB SX8200 Pro PCIe M.2 2280 Napajanje SilentiumPC Supremo M2 Gold 550W 80+ Gold P/N: SPC140 SEAGATE HDD Desktop Barracuda Guardian (3.5"/2TB/SATA 6Gb/s/7200rpm) Kućište Thermaltake Core V21 GIGABYTE Main Board Desktop Z390 M GAMING Hladnjak za procesor Thermaltake Riing Silent 12 RGB Sync Edition Sveukupno: 8.236,86kn + grafička(polovna GTX 1070 s garancijom?) Zadnje izmijenjeno od: Smartic. 11.12.2018. u 14:12. |
#2333 |
Postovi: 2,707
Ok, onda dodati još 1050 Ti ili 1060 6GB. Uzeti AMD karticu je inače dosta isplativije trenutno, ali ne znam točno kakva je podrška u tim alatima za njihove mogućnosti. RX 580 8GB ima za cca. 1900kn. |
#2334 |
Postovi: 184
Bok ljudi bavim se produkcijom glazbe i naravno treba mi jako računalo jer radim s Kontakt library instrumentima koji gutaju ram ko ludi. Kupio bih i9 proc 9 generacije. Matična ploča mora imati usb type c s thunderbolt supportom jer kupujem zvučnu karticu s tom konekcijom. Da može primiti minimalno 64gb rama i da ima na sebi onboard grafičku :-) Koji ostale komponenete osim procesora preporučate? Limit je 15tis kuna, ako može za manje tim bolje Jedan od mojih uradaka možete poslušati ovdje: https://soundcloud.com/mareproductio...fury-1/s-Fjls1
grrr |
#2335 |
Postovi: 2,707
Procesor Intel Core i9-9900K (16MB Cache, 3.60GHz), LGA1151 V2, boxed without cooler, BX80684I99900KSRELS Matična ploča Gigabyte Z390 Aorus pro, s1151 V2 4x DDR4 16GB (1x16GB) PC4-24000U 3000MHz CL16 G.Skill Aegis, F4-3000C16S-16GISB Phanteks Eclipse P400 Tempered glass Edition white, glass window, PH-EC416PTG_WT Napajanje 550W Fortron Hydro GE, ATX 2.4, PPA5504501 SSD 250GB Samsung 970 EVO, M.2 2280, MZ-V7E250BW HDD 2TB Seagate BarraCuda, 3.5", 7200RPM, 64MB Cache, SATA3, ST2000DM006 MSI Core Frozr L, s. 775/1150/1151/1155/1156/1366/2011/2011-3/AM2/AM2+/AM3/AM3+/FM1/FM2/AM4, 140mm x 155mm x 84mm, 500 - 1800 ±15% RPM Ukupno: ~12.886Kn Možeš povećati storage ako trebaš. Koliko CPU threadova obično koristi taj softver? |
#2336 | |
Postovi: 184
Ne znam točan odgovor na tvoje pitanje. Ovo sam našao na službenoj stranici softvera koji koristim. Ableton je glavni soft a kontakt je podprogram koji s u njega učitava: vst. How many threads are used per Live track? Live uses one thread to process a signal path. A signal path is a single chain of audio flow. In tracks where instrument or effect racks are used, with multiple chains in parallel, Live may use one thread per chain depending on how CPU-intensive each chain may be. If two tracks are "chained" by routings, for instance by a side-chain routing, a track being fed to a return track or any tracks being fed into each-other, they are considered dependent tracks and count as one signal path. Any dependant set of tracks will use one thread each.
grrr |
#2337 |
Lokacija: zadar
Postovi: 129
Pozdrav svima, zanima me sto mislite o ovoj konfiguraciji, sto bi se dalo izmjeniti po vama. pc je prvenstveno za igre. adm mi se cini prilicno ok sa cijenama pa bi pc uzeo kod njih. ne zelim OC, samo da je tih i da se ne grije previse. max 18-19k kuna bez monitora. koja je uopce razlika izmedju 8700 i 9700 procesora i jeli mozda 9900k bolji za igre ili je to overkill u ovom slucaju. hvala na svim prijedlozima. Procesor Intel Core i7-9700K (12MB Cache, 3.60GHz) Matična ploča Gigabyte Z390 Aorus pro, s1151 V2 DDR4 16GB (2x8GB) PC4-25600U 3200MHz CL16 G.Skill Trident Z silver/red Samsung 500GB SSD 970 EVO M.2, MZ-V7E500BW HDD SEAGATE SSHD Desktop FireCuda Guardian (3.5"/2TB/SATA Grafička kartica MSI RTX2080 Duke 8G OC, 8GB GDDR6 Kuciste Fractal Define R6, Blackout, bez napajanja Napajanje ? Nostua NH-D15 Monitor Acer XB271HU 27'' |
#2339 |
Lokacija: zadar
Postovi: 129
#2340 |
The Man
Lokacija: Novi Zagreb
Postovi: 1,252
Ljudovi, molio bih savjet. Trebao bih radnu stanicu koja bi prvenstveno sužila kao poslovna mašina koja bi vrtila neke LCA based optimizacije... znači, pošto se radi o velikim bazama podataka... što brži procesor puno rama i brz pristup hardu... Razmišljam o nekoj kombinaciji i7 8700 ili 9700, nvme pcie hard od 512 gb te 32bg rama? Cifra je oko 10k s monitorom, te pošto je narudžba preko firme da je sastavljeno u jednoj trgovini.
"Everybody's at war with different things...I'm at war with my own heart sometimes" |
